[Swift-commit] r4559 - trunk/src/org/griphyn/vdl/karajan/lib/swiftscript
wozniak at ci.uchicago.edu
Fri Jun 3 14:10:23 CDT 2011
Author: wozniak
Date: 2011-06-03 14:10:23 -0500 (Fri, 03 Jun 2011)
New Revision: 4559
Modified:
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java
Log:
Update tracef(), sprintf() functionality
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java 2011-06-03 18:54:44 UTC (rev 4558)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java 2011-06-03 19:10:23 UTC (rev 4559)
@@ -55,13 +55,14 @@
return result;
- private String format(DSHandle[] args)
+ public static String format(DSHandle[] args)
throws ExecutionException {
if (! (args[0].getType() == Types.STRING))
throw new ExecutionException
("First argument to sprintf() must be a string!");
- String spec = args[0].toString();
+ String spec = (String) args[0].getValue();
+ logger.debug("spec: " + spec);
DSHandle[] vars = copyArray(args, 1, args.length-1);
StringBuilder output = new StringBuilder();
@@ -71,7 +72,7 @@
public static DSHandle[] copyArray(DSHandle[] src,
- int offset, int length)
+ int offset, int length)
DSHandle[] result = new DSHandle[length];
@@ -99,7 +100,7 @@
else if (c == '\\') {
char d = spec.charAt(++i);
- escape(d, output);
+ escape(i, spec, d, output);
else {
output.append(c);
@@ -107,7 +108,7 @@
i++;
private static int append(char c, int arg, DSHandle[] vars,
StringBuilder output)
@@ -147,7 +148,7 @@
return arg+1;
- private static void append_M(DSHandle arg, StringBuilder output)
+ private static void append_M(DSHandle arg, StringBuilder output)
try {
synchronized (arg.getRoot()) {
@@ -167,7 +168,7 @@
private static void append_f(DSHandle arg, StringBuilder output)
if (arg.getType() == Types.FLOAT) {
- output.append(arg).toString();
+ output.append(arg.getValue());
else {
@@ -178,7 +179,8 @@
private static void append_i(DSHandle arg, StringBuilder output)
if (arg.getType() == Types.INT) {
+ Double d = (Double) arg.getValue();
+ output.append(new Integer(d.intValue()));
else {
@@ -197,7 +199,7 @@
String entry = ""+i;
DSHandle handle =
node.getField(Path.parse(entry));
- output.append(handle);
+ output.append(handle.getValue());
if (i < size-1)
output.append(",");
@@ -218,7 +220,7 @@
private static void append_s(DSHandle arg, StringBuilder output)
if (arg.getType() == Types.STRING) {
else {
@@ -226,7 +228,12 @@
- private static void escape(char c, StringBuilder output)
+ * @param i Only used for error messages
+ * @param spec Only used for error messages
+ private static void escape(int i, String spec,
+ char c, StringBuilder output)
if (c == '\\') {
output.append('\\');
@@ -239,7 +246,9 @@
else {
- ("tracef(): unknown backslash escape sequence!");
+ ("tracef(): unknown backslash escape sequence! " +
+ "(\\" + c + ")\n" +
+ "\t in " + spec + " character: " + i);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java 2011-06-03 18:54:44 UTC (rev 4558)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java 2011-06-03 19:10:23 UTC (rev 4559)
@@ -37,12 +37,7 @@
VDLFunction.waitFor(stack, handle);
- DSHandle[] vars = Sprintf.copyArray(args, 1, args.length-1);
- StringBuilder output = new StringBuilder();
- Sprintf.format(spec, vars, output);
- String msg = output.toString();
+ String msg = Sprintf.format(args);
logger.info(msg);
System.out.print(msg);
return null;
More information about the Swift-commit
