[Swift-commit] r4556 - in SwiftApps/SwiftR/Swift: R exec
tga at ci.uchicago.edu
Fri Jun 3 13:40:35 CDT 2011
Author: tga
Date: 2011-06-03 13:40:35 -0500 (Fri, 03 Jun 2011)
New Revision: 4556
Modified:
SwiftApps/SwiftR/Swift/R/Apply.R
SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh
SwiftApps/SwiftR/Swift/exec/start-swift
SwiftApps/SwiftR/Swift/exec/start-swift-daemon
Log:
No longer assumes that /tmp/$USER is writable - falls back to a random temporary directory and gives meaningful error messages when misconfigured.
Modified: SwiftApps/SwiftR/Swift/R/Apply.R
--- SwiftApps/SwiftR/Swift/R/Apply.R 2011-06-03 17:32:56 UTC (rev 4555)
+++ SwiftApps/SwiftR/Swift/R/Apply.R 2011-06-03 18:40:35 UTC (rev 4556)
@@ -199,7 +199,16 @@
requestid = getOption(".swift.requestid") + 1;
else {
- requestdirbase = file.path(tmpdir, Sys.info()[["user"]],"SwiftR",
+ topdir <- file.path(tmpdir, Sys.info()[["user"]],"SwiftR")
+ if (!dir.create(topdir,recursive=TRUE,showWarnings=FALSE,
+ mode=kDIR_MODE)) {
+ oldtopdir <- topdir
+ topdir <- tempdir()
+ warning(paste("Could not create working directory", oldtopdir,
+ "instead using", topdir))
+ requestdirbase = file.path(topdir,
sprintf("requests.P%.5d",Sys.getpid()))
dir.create(requestdirbase,recursive=TRUE,showWarnings=FALSE,
mode=kDIR_MODE)
Modified: SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh
--- SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh 2011-06-03 17:32:56 UTC (rev 4555)
+++ SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh 2011-06-03 18:40:35 UTC (rev 4556)
@@ -88,6 +88,19 @@
# Ensure that the dir for this slot exists.
BASEDIR=$tmp/$(id -nu)/SwiftR/Rworkers
+if mkdir -p $BASEDIR; then
+else
+ OLD_BASEDIR=$BASEDIR
+ BASEDIR=$tmp/SwiftR.${SWIFT_WORKER_PID}.Rworkers
+ mkdir -p $BASEDIR
+ basedir_ok=$?
+ if [ $basedir_ok != 0 ]; then
+ echo "Could not create worker directory in either $OLD_BASEDIR or $BASEDIR"
+ exit 1
+ fi
+fi
WORKERDIR=$BASEDIR/worker.$SWIFT_WORKER_PID
SLOTDIR=$WORKERDIR/${SWIFT_JOB_SLOT}
Modified: SwiftApps/SwiftR/Swift/exec/start-swift
--- SwiftApps/SwiftR/Swift/exec/start-swift 2011-06-03 17:32:56 UTC (rev 4555)
+++ SwiftApps/SwiftR/Swift/exec/start-swift 2011-06-03 18:40:35 UTC (rev 4556)
@@ -42,7 +42,7 @@
get-contact
LOGDIR=$(pwd)/swiftworkerlogs # full path. FIXME: Generate this with remote-side paths if not shared dir env?
- LOGDIR=$tmp/$USER/SwiftR/swiftworkerlogs # FIXME: left this in /tmp so it works on any host. Better way?
+ LOGDIR=$topdir/swiftworkerlogs # FIXME: left this in /tmp so it works on any host. Better way?
# mkdir -p $LOGDIR # is done with the ssh command, below
@@ -319,7 +319,7 @@
get-contact
- LOGDIR=/tmp/$USER/SwiftR/swiftworkerlogs # FIXME: left this in /tmp so it works on any host. Better way?
mkdir -p $LOGDIR
@@ -434,7 +434,7 @@
argname=$1; shift
#check if positive integer
if [ "$1" -gt 0 ] 2> /dev/null; then
- time_secs=$time
+ time_secs=$(( $time * 60 ))
# echo time_secs: $time_secs
return 0
fi
@@ -580,26 +580,43 @@
source $SWIFTRBIN/compat-setup
SWIFTBIN=$SWIFTRBIN/../swift/bin # This depends on ~/SwiftR/Swift/swift being a symlink to swift in RLibrary/Swift
-rundir=$tmp/$USER/SwiftR/swift.$server # rundir prefix # FIXME: handle multiple concurent independent swift servers per user
-mkdir -p $(dirname $rundir)
# Setup a working directory
if [ "$workdir" = NONE ]
then
+ topdir=$tmp/$USER/SwiftR
+ if mkdir -p $topdir 2> /dev/null ; then
+ else
+ topdir=$(mktemp -d $tmp/SwiftR.XXXXXX)
+ created_ok=$?
+ if [ "$created_ok" -ne 0 ]; then
+ echo "Could not create temporary directory under $tmp"
+ exit 1
+ fi
+ fi
+ rundir=$topdir/swift.$server # rundir prefix
doack=FALSE
- trundir=$(mktemp -d $rundir.XXXX) # FIXME: check success
- if [ "$?" != "0" ]
+ trundir=$(mktemp -d $rundir.XXXX)
+ created_ok=$?
then
- echo "Could not create temporary directory under $tmp/$USER/SwiftR"
+ echo "Could not create temporary directory under $topdir/SwiftR"
exit 1
fi
else
+ topdir=`dirname "$workdir"`
doack=TRUE # let -daemon script know when we are done
echo Working in $workdir
trundir=$workdir
mkdir -p $workdir
fi
+# link temporary dir with different server name
rm -f $rundir
ln -s $trundir $rundir
Modified: SwiftApps/SwiftR/Swift/exec/start-swift-daemon
--- SwiftApps/SwiftR/Swift/exec/start-swift-daemon 2011-06-03 17:32:56 UTC (rev 4555)
+++ SwiftApps/SwiftR/Swift/exec/start-swift-daemon 2011-06-03 18:40:35 UTC (rev 4556)
@@ -6,20 +6,33 @@
# This script forks off a child process, detaches it
# and then, as the only thing written to stdout, echoes
# the pid of start-swift
+set -x
ssscript=`dirname $0`/start-swift
# Choose a working directory
tmp=${SWIFTR_TMP:-/tmp}
-mkdir -p $tmp/$USER/SwiftR
-workdir=$(mktemp -d $tmp/$USER/SwiftR/swift.XXXX)
+topdir=$tmp/$USER/SwiftR
+if mkdir -p $topdir 2> /dev/null ; then
+else
+ created_ok=$?
+ if [ $created_ok -ne 0 ]; then
+ exit 1
+ fi
+fi
+workdir=$(mktemp -d $topdir/swift.XXXX)
ackfifo=$workdir/ackfifo
mkfifo $ackfifo
if [ "$?" != "0" ]
then
+ echo "Could not create temporary directory under $topdir"
exit 1
fi
More information about the Swift-commit
