[Swift-commit] r4548 - SwiftApps/SwiftR/Swift/exec
tga at ci.uchicago.edu
Fri Jun 3 11:12:34 CDT 2011
Author: tga
Date: 2011-06-03 11:12:34 -0500 (Fri, 03 Jun 2011)
New Revision: 4548
Modified:
SwiftApps/SwiftR/Swift/exec/configure-server-pbsauto
SwiftApps/SwiftR/Swift/exec/start-swift
Log:
Tweaked time settings for pbsauto so that time parameter is better respected.
Modified: SwiftApps/SwiftR/Swift/exec/configure-server-pbsauto
--- SwiftApps/SwiftR/Swift/exec/configure-server-pbsauto 2011-06-03 15:12:39 UTC (rev 4547)
+++ SwiftApps/SwiftR/Swift/exec/configure-server-pbsauto 2011-06-03 16:12:34 UTC (rev 4548)
@@ -1,7 +1,21 @@
#! /usr/bin/env bash
-#TODO: make configurable
-maxwalltime="00:10:00"
+#TODO: is this best way to do this.
+# we assume that $time_secs specifies the lengths of jobs
+# that should be submitted to pbs.
+#We don't really know the expected duration of R jobs, so we will come up
+# with a sensible value based on $time-secs
+#Swift kills jobs that run for double maxwalltime, so maxwalltime should be
+# > 0.5 $time_secs
+# Ideally we want to run multiple jobs in each batch allocation, so we don't
+# want coasters to mistakenly decide that it can't schedule a job when we
+# have most of the batch allocation left. So we really want
+# maxwalltime to be just over 0.5 $time_secs, once we round both to minutes
+maxwalltime=$(( ($time_secs + 120) / 120 ))
cat >tc <<END
pbscoast bash /bin/bash null null ENV::PATH="$PATH";GLOBUS::maxwalltime="$maxwalltime"
END
@@ -28,8 +42,9 @@
put through the batch system -->
<profile namespace="globus" key="maxNodes">1</profile>
<profile namespace="globus" key="nodeGranularity">1</profile>
+ <profile namespace="globus" key="lowOverallocation">2</profile>
+ <profile namespace="globus" key="highOverallocation">2</profile>
END
if [ "$queue" != NONE ]; then
#TODO: error handling
Modified: SwiftApps/SwiftR/Swift/exec/start-swift
--- SwiftApps/SwiftR/Swift/exec/start-swift 2011-06-03 15:12:39 UTC (rev 4547)
+++ SwiftApps/SwiftR/Swift/exec/start-swift 2011-06-03 16:12:34 UTC (rev 4548)
@@ -427,6 +427,10 @@
verify-is-time()
+ # Three valid formats, following maxWallTime globus param:
+ # minutes (single int)
+ # h:m
+ # h:m:s
argname=$1; shift
#check if positive integer
if [ "$1" -gt 0 ] 2> /dev/null; then
@@ -439,9 +443,14 @@
ms=${1#*:}
m=${ms%%:*}
s=${ms#*:}
- # check than they are integers >= 1
+ # if in h:m format, then #*: won't have deleted anything from m
+ if [ "$ms" = "$s" ]; then
+ s=0
+ fi
+ # check than they are integers >= 0 and at least one is > 0
if [ \( "$h" -ge 0 \) -a \( "$m" -ge 0 \) -a \( "$s" -ge 0 \) \
- -a \( \( "$h" -ge 0 \) -o \( "$m" -ge 0 \) -o \( "$s" -ge 0 \) \) \
+ -a \( \( "$h" -gt 0 \) -o \( "$m" -gt 0 \) -o \( "$s" -gt 0 \) \) \
] 2> /dev/null ; then
time_secs=$(($s + 60 * ($m + $h * 60)))
# echo time_secs: $time_secs
More information about the Swift-commit
