[Swift-commit] r4539 - SwiftApps/Montage/exec
jonmon at ci.uchicago.edu jonmon at ci.uchicago.edu
Wed Jun 1 11:41:33 CDT 2011
Author: jonmon
Date: 2011-06-01 11:41:33 -0500 (Wed, 01 Jun 2011)
New Revision: 4539
Modified:
   SwiftApps/Montage/exec/montage.sh
Log:
o SwiftApps/Montage/exec/montage.sh
  -- The run script now checks to make sure that the SWIFT_MONTAGE environment variable is set
Modified: SwiftApps/Montage/exec/montage.sh
--- SwiftApps/Montage/exec/montage.sh	2011-06-01 16:19:18 UTC (rev 4538)
+++ SwiftApps/Montage/exec/montage.sh	2011-06-01 16:41:33 UTC (rev 4539)
@@ -8,6 +8,12 @@
     exit 1
 fi
+# Fix this. Not sure how to set this variable if it not set or even what the error message should be
+if [ "X$SWIFT_MONTAGE" == "X" ]; then
+    echo "Please set the SWIFT_MONTAGE environment variable to where the Swift_Montage wrappers home directory is."
+    exit 1
+fi
 RUN_DIRECTORY=(`ls | grep run | tail -n 1`)
 NUM=`echo $RUN_DIRECTORY | awk -F . '{print $NF}'`
 WORK_DIRECTORY=(`printf "run.%04d" $((NUM+1))`)
@@ -36,10 +42,20 @@
 echo "#site local.xml work=/gpfs/pads/jonmon/Swift/work/local"            >> sites.properties
 echo "<config>"        >  sites.xml
+echo ""        >> sites.xml
 gensites -L ${SWIFT_MONTAGE}/templates -p sites.properties pads-proj-coasters.xml >> sites.xml
 gensites -L ${SWIFT_MONTAGE}/templates -p sites.properties pads-diff-coasters.xml >> sites.xml
 gensites -L ${SWIFT_MONTAGE}/templates -p sites.properties pads-fit-coasters.xml  >> sites.xml
 gensites -L ${SWIFT_MONTAGE}/templates -p sites.properties local.xml              >> sites.xml
 echo "</config>"        >> sites.xml
 rm -f sites.properties
