[Swift-commit] r4866 - SwiftApps/GOSwift/pykoa/tools
jonmon at ci.uchicago.edu
Thu Jul 28 16:47:42 CDT 2011
Author: jonmon
Date: 2011-07-28 16:47:42 -0500 (Thu, 28 Jul 2011)
New Revision: 4866
Added:
SwiftApps/GOSwift/pykoa/tools/koa_goswift_list.py
Modified:
SwiftApps/GOSwift/pykoa/tools/koa_goswift_info.py
Log:
o removed unnecessary imports from koa_goswift_info.py
o added goswift_list command. Lists all created run directories. This can be used to get status or info from a particular run.
Modified: SwiftApps/GOSwift/pykoa/tools/koa_goswift_info.py
--- SwiftApps/GOSwift/pykoa/tools/koa_goswift_info.py 2011-07-28 18:31:33 UTC (rev 4865)
+++ SwiftApps/GOSwift/pykoa/tools/koa_goswift_info.py 2011-07-28 21:47:42 UTC (rev 4866)
@@ -1,26 +1,9 @@
#!/usr/bin/python
-import commands
import os
-import re
import sys
-import subprocess
-import datetime
-from sqlalchemy.sql import text
import pykoa
import pykoa.tools
-from pykoa.process_observer import ProcessObserver
-from pykoa.signal_util import BlockInterrupt, enable_sigint
-from pykoa.tools import url_parse, myproxy
-from pykoa.tools import koa_transfer
-from pykoa.tools.koa_ep_activate import check_explicit_activate
-from pykoa.consumers import guc_util
-from pykoa.constants import get_scheme
-from pykoa.data import endpoint_dao
-from pykoa.data import creds_dao
-from pykoa.koaexception import ToolsException, cli_exception_handler
def setup_opts(argv):
help_screen = """
Added: SwiftApps/GOSwift/pykoa/tools/koa_goswift_list.py
--- SwiftApps/GOSwift/pykoa/tools/koa_goswift_list.py (rev 0)
+++ SwiftApps/GOSwift/pykoa/tools/koa_goswift_list.py 2011-07-28 21:47:42 UTC (rev 4866)
@@ -0,0 +1,44 @@
+import os
+import sys
+import commands
+import pykoa
+import pykoa.tools
+def setup_opts(argv):
+ help_screen = """
+goswift_list
+List all run ids in the users run directory.
+Type 'man goswift_list' for details. \
+ parser = pykoa.tools.get_option_parser(help_screen)
+ (options, args) = pykoa.tools.parse_args(parser, argv)
+ return (parser, options, args)
+def main( argv=sys.argv[1:] ):
+ (parser, options, args) = setup_opts(argv)
+ if len(args) != 0:
+ parser.print_help()
+ return 1
+ run_directory = os.environ["HOME"]+"/Swift";
+ (status, output) = commands.getstatusoutput( "/bin/ls " + run_directory )
+ if status != 0:
+ sys.stderr.write( "FAILED TO LIST DIRECTORY\n" )
+ pykoa.debug("Listing directory failed with error code: "+str(status) + ": /bin/ls " + run_directory)
+ return status
+ sys.stdout.write( output+"\n" )
+ return 0
+if __name__ == "__main__":
+ rc = main()
+ sys.exit(rc)
More information about the Swift-commit
