[Swift-commit] r4835 - in trunk: libexec resources src/org/griphyn/vdl/engine src/org/griphyn/vdl/karajan src/org/griphyn/vdl/karajan/lib src/org/griphyn/vdl/karajan/lib/swiftscript src/org/griphyn/vdl/mapping src/org/griphyn/vdl/mapping/file src/org/griphyn/vdl/type src/org/griphyn/vdl/type/impl
hategan at ci.uchicago.edu
Sun Jul 24 18:04:12 CDT 2011
Author: hategan
Date: 2011-07-24 18:04:11 -0500 (Sun, 24 Jul 2011)
New Revision: 4835
Added:
trunk/src/org/griphyn/vdl/karajan/lib/AppendArray.java
trunk/src/org/griphyn/vdl/mapping/PathComparator.java
trunk/src/org/griphyn/vdl/mapping/PathElementComparator.java
trunk/src/org/griphyn/vdl/mapping/PathParser.java
trunk/src/org/griphyn/vdl/mapping/PathParsingException.java
Modified:
trunk/libexec/vdl-lib.xml
trunk/resources/Karajan.stg
trunk/resources/swiftscript.g
trunk/resources/swiftscript.stg
trunk/resources/swiftscript.xsd
trunk/src/org/griphyn/vdl/engine/FormalArgumentSignature.java
trunk/src/org/griphyn/vdl/engine/Karajan.java
trunk/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java
trunk/src/org/griphyn/vdl/karajan/lib/CleanDataset.java
trunk/src/org/griphyn/vdl/karajan/lib/CreateArray.java
trunk/src/org/griphyn/vdl/karajan/lib/DoRestartLog.java
trunk/src/org/griphyn/vdl/karajan/lib/ExpandArguments.java
trunk/src/org/griphyn/vdl/karajan/lib/GetArrayIterator.java
trunk/src/org/griphyn/vdl/karajan/lib/GetField.java
trunk/src/org/griphyn/vdl/karajan/lib/GetFieldSubscript.java
trunk/src/org/griphyn/vdl/karajan/lib/IsDone.java
trunk/src/org/griphyn/vdl/karajan/lib/New.java
trunk/src/org/griphyn/vdl/karajan/lib/Operators.java
trunk/src/org/griphyn/vdl/karajan/lib/Range.java
trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java
trunk/src/org/griphyn/vdl/karajan/lib/SliceArray.java
trunk/src/org/griphyn/vdl/karajan/lib/SwiftArg.java
trunk/src/org/griphyn/vdl/karajan/lib/VDLFunction.java
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadData.java
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadStructured.java
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java
trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
trunk/src/org/griphyn/vdl/mapping/ArrayDataNode.java
trunk/src/org/griphyn/vdl/mapping/DSHandle.java
trunk/src/org/griphyn/vdl/mapping/DataNode.java
trunk/src/org/griphyn/vdl/mapping/InvalidPathException.java
trunk/src/org/griphyn/vdl/mapping/Path.java
trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java
trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
trunk/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java
trunk/src/org/griphyn/vdl/mapping/file/AirsnMapper.java
trunk/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.java
trunk/src/org/griphyn/vdl/mapping/file/CSVMapper.java
trunk/src/org/griphyn/vdl/mapping/file/FileSystemArrayMapper.java
trunk/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java
trunk/src/org/griphyn/vdl/mapping/file/ROIMapper.java
trunk/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java
trunk/src/org/griphyn/vdl/type/Field.java
trunk/src/org/griphyn/vdl/type/Type.java
trunk/src/org/griphyn/vdl/type/Types.java
trunk/src/org/griphyn/vdl/type/impl/FieldImpl.java
trunk/src/org/griphyn/vdl/type/impl/TypeImpl.java
trunk/src/org/griphyn/vdl/type/impl/UnresolvedType.java
Log:
array key typing; array types declaration; internal storage of int changed to Integer
Modified: trunk/libexec/vdl-lib.xml
--- trunk/libexec/vdl-lib.xml 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/libexec/vdl-lib.xml 2011-07-24 23:04:11 UTC (rev 4835)
@@ -61,6 +61,7 @@
<export name="getField"><elementDef classname="org.griphyn.vdl.karajan.lib.GetField"/></export>
<export name="getFieldSubscript"><elementDef classname="org.griphyn.vdl.karajan.lib.GetFieldSubscript"/></export>
<export name="setFieldValue"><elementDef classname="org.griphyn.vdl.karajan.lib.SetFieldValue"/></export>
+ <export name="appendArray"><elementDef classname="org.griphyn.vdl.karajan.lib.AppendArray"/></export>
<export name="getFieldValue"><elementDef classname="org.griphyn.vdl.karajan.lib.GetFieldValue"/></export>
<export name="waitFieldValue"><elementDef classname="org.griphyn.vdl.karajan.lib.WaitFieldValue"/></export>
<export name="getArrayIterator"><elementDef classname="org.griphyn.vdl.karajan.lib.GetArrayIterator"/></export>
Modified: trunk/resources/Karajan.stg
--- trunk/resources/Karajan.stg 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/resources/Karajan.stg 2011-07-24 23:04:11 UTC (rev 4835)
@@ -198,7 +198,7 @@
</vdl:infinitecountingwhile>
-foreach(var,in,indexVar,declarations,statements,line,selfClose,cleanups) ::= <<
+foreach(var,in,indexVar,indexVarType,declarations,statements,line,selfClose,cleanups) ::= <<
<vdl:tparallelFor name="\$"$if(selfClose)$ selfClose="$selfClose$"$endif$>
<getarrayiterator>$in$</getarrayiterator>
<set names="\$\$, $var$">
@@ -206,7 +206,7 @@
</set>
$if(indexVar)$
<set name="$indexVar$">
- <vdl:new type="int" value="{\$\$}"/>
+ <vdl:new type="$indexVarType$" value="{\$\$}"/>
</set>
$endif$
<log level="debug" message="FOREACH_IT_START line=$line$ thread={#thread}"/>
@@ -343,15 +343,18 @@
assign(var,value) ::= <<
<vdl:setfieldvalue>
- <argument name="var">
$var$
- </argument>
- <argument name="value">
$value$
- </argument>
</vdl:setfieldvalue>
+append(array, value) ::= <<
+ <vdl:appendArray>
+ $array$
+ $value$
+ </vdl:appendArray>
callexpr(call, datatype, callID, prefix) ::= <<
<sequential>
<set name="swift#callintermediate">
Modified: trunk/resources/swiftscript.g
--- trunk/resources/swiftscript.g 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/resources/swiftscript.g 2011-07-24 23:04:11 UTC (rev 4835)
@@ -166,6 +166,12 @@
code.setAttribute("statements",d);
+// these are non-declaration append-associative array statements
+ | (predictAppendStat) => d=appendStat
+ code.setAttribute("statements",d);
// they all begin with (id name)
| (predictDeclaration) => declaration[code]
@@ -206,10 +212,14 @@
String thisType = (String) t.getAttribute("name");
StringTemplate variable=null;
StringTemplate m = null;
+ StringTemplate sTemp = null;
+ String sType = "";
n=declarator
- (LBRACK RBRACK {thisType = thisType + "[]"; } )*
+ (LBRACK
+ (sTemp=type {sType = (String) sTemp.getAttribute("name") ;} )?
+ RBRACK {thisType = thisType + "[" + sType + "]" ; sType = ""; } )*
thisTypeTemplate=template("type");
thisTypeTemplate.setAttribute("name", thisType);
@@ -465,14 +475,23 @@
-type returns [StringTemplate code=null]
- id:ID
- code=template("type");
- code.setAttribute("name", id.getText());
+type returns [ StringTemplate code = null ]
+ { StringBuilder buf = new StringBuilder(); }
+ id:ID {
+ code = template("type");
+ buf.append(id.getText());
+ (typeSubscript[buf]) * {
+ code.setAttribute("name", buf.toString());
+typeSubscript[StringBuilder buf] :
+ LBRACK { buf.append('['); }
+ (id:ID { buf.append(id.getText()); })?
+ RBRACK { buf.append(']'); }
compoundStat[StringTemplate code]
: LCURLY
@@ -492,6 +511,7 @@
s=ll1statement
| (procedurecallCode) => s=procedurecallCode
| (predictAssignStat) => s=assignStat
+ | (predictAppendStat) => s=appendStat
code.setAttribute("statements",s);
@@ -505,6 +525,7 @@
( code=ll1statement
| (procedurecallCode) => code=procedurecallCode
| (predictAssignStat) => code=assignStat
+ | (predictAppendStat) => code=appendStat
) {statements.setAttribute("statements",code);}
| (procedurecallStatAssignManyReturnParam[statements]) => procedurecallStatAssignManyReturnParam[statements]
@@ -549,7 +570,7 @@
code.setAttribute("var", id.getText());
code.setAttribute("in", ds);
if (indexId != null) {
- code.setAttribute("index", indexId.getText());
+ code.setAttribute("index", indexId.getText());
compoundStat[body] {code.setAttribute("body", body);}
@@ -613,6 +634,10 @@
{StringTemplate x=null;}
: x=identifier ASSIGN ;
+predictAppendStat
+{StringTemplate x=null;}
+ : x=identifier APPEND ;
assignStat returns [StringTemplate code=null]
{StringTemplate id=null;}
@@ -632,6 +657,34 @@
+appendStat returns [ StringTemplate code = null ]
+ { StringTemplate id=null; }
+ id=identifier
+ APPEND
+ (predictProcedurecallAssign) => code=procedurecallCode {
+ StringTemplate o = template("returnParam");
+ o.setAttribute("name",id);
+ code.setAttribute("outputs",o);
+ code=arrayAppend {
+ code.setAttribute("array", id);
+arrayAppend returns [ StringTemplate code = null ]
+ { StringTemplate a = null, e = null, id = null; }
+ e = expression SEMI {
+ code = template("append");
+ code.setAttribute("value", e);
variableAssign returns [StringTemplate code=null]
{StringTemplate a=null, e=null, id=null;}
@@ -750,20 +803,27 @@
-returnParameter returns [StringTemplate code=template("returnParam")]
-{StringTemplate t=null, id=null, d=null;}
- : (t=type{ code.setAttribute("type", t);})?
- id=identifier
- code.setAttribute("name", id);
- (ASSIGN declarator)=>(ASSIGN d=declarator)
- code.setAttribute("bind", d);
+returnParameter returns [ StringTemplate code = template("returnParam") ]
+ { StringTemplate t = null, id = null, d = null; StringBuilder buf = new StringBuilder(); }
+ t = identifier { buf.append(t.getAttribute("name")); }
+ (typeSubscript[buf])*
+ ( id = identifier )?
+ if (id == null) {
+ code.setAttribute("name", t);
+ else {
+ t = template("type");
+ t.setAttribute("name", buf.toString());
+ code.setAttribute("name", id);
+ code.setAttribute("type", t);
+ ((ASSIGN declarator) => (ASSIGN d=declarator) {
+ code.setAttribute("bind", d);
actualParameter returns [StringTemplate code=template("actualParam")]
{StringTemplate d=null, id=null, ai=null;}
@@ -1110,6 +1170,7 @@
LE : "<=" ;
GT : ">" ;
GE : ">=";
+APPEND : "<<";
ASSIGN : '=' ;
AND : "&&";
OR : "||";
Modified: trunk/resources/swiftscript.stg
--- trunk/resources/swiftscript.stg 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/resources/swiftscript.stg 2011-07-24 23:04:11 UTC (rev 4835)
@@ -266,6 +266,13 @@
</assign>
+append(array,value,sourcelocation) ::= <<
+<append src="$sourcelocation$">
+ $array$
+ $value$
+</append>
arraySubscript(array, subscript, sourcelocation) ::= <<
<arraySubscript>
$array$
Modified: trunk/resources/swiftscript.xsd
--- trunk/resources/swiftscript.xsd 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/resources/swiftscript.xsd 2011-07-24 23:04:11 UTC (rev 4835)
@@ -342,6 +342,17 @@
<xs:attribute name="src" type="xs:string" />
</xs:complexType>
+ <xs:complexType name="Append">
+ <xs:annotation>
+ <xs:documentation>appends a value to an array
+ </xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element ref="abstractExpression" minOccurs="2" maxOccurs="2" />
+ </xs:sequence>
+ <xs:attribute name="src" type="xs:string" />
+ </xs:complexType>
<xs:complexType name="Call">
<xs:annotation>
@@ -393,6 +404,8 @@
</xs:element>
<xs:element name="assign" type="Assign"/>
+ <xs:element name="append" type="Append"/>
<xs:element name="call" type="Call"/>
Modified: trunk/src/org/griphyn/vdl/engine/FormalArgumentSignature.java
--- trunk/src/org/griphyn/vdl/engine/FormalArgumentSignature.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/engine/FormalArgumentSignature.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -1,5 +1,7 @@
package org.griphyn.vdl.engine;
+import org.griphyn.vdl.type.Types;
public class FormalArgumentSignature {
private String name;
private String type;
@@ -13,7 +15,7 @@
public FormalArgumentSignature(String type, String name) {
- this.type = type;
+ this.type = Types.normalize(type);
this.name = name;
this.anyType = false;
this.optionalArg = false;
@@ -25,7 +27,7 @@
public FormalArgumentSignature(String type) {
- this.type = type;
Modified: trunk/src/org/griphyn/vdl/engine/Karajan.java
--- trunk/src/org/griphyn/vdl/engine/Karajan.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/engine/Karajan.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -327,8 +327,9 @@
procST.setAttribute("optargs", paramST);
else
procST.setAttribute("arguments", paramST);
- checkIsTypeDefined(param.getType().getLocalPart());
- innerScope.addVariable(param.getName(), param.getType().getLocalPart());
+ String type = normalize(param.getType().getLocalPart());
+ checkIsTypeDefined(type);
+ innerScope.addVariable(param.getName(), type);
for (int i = 0; i < proc.sizeOfInputArray(); i++) {
FormalParameter param = proc.getInputArray(i);
@@ -338,8 +339,9 @@
else
- outerScope.addVariable(param.getName(), param.getType().getLocalPart());
+ outerScope.addVariable(param.getName(), type);
Binding bind;
@@ -359,7 +361,7 @@
StringTemplate paramST = new StringTemplate("parameter");
StringTemplate typeST = new StringTemplate("type");
paramST.setAttribute("name", param.getName());
- typeST.setAttribute("name", param.getType().getLocalPart());
+ typeST.setAttribute("name", normalize(param.getType().getLocalPart()));
typeST.setAttribute("namespace", param.getType().getNamespaceURI());
paramST.setAttribute("type", typeST);
if(!param.isNil())
@@ -463,15 +465,10 @@
scope.bodyTemplate.setAttribute("declarations", variableST);
- void checkIsTypeDefined(String type) throws CompilationException {
- while (type.length() > 2 && type.substring(type.length() - 2).equals("[]"))
- type = type.substring(0, type.length() - 2);
- if (!type.equals("int") && !type.equals("float") && !type.equals("string")
- && !type.equals("boolean") && !type.equals("external")) {
- boolean typeDefined = typesMap.containsKey(type);
- if (!typeDefined)
- throw new CompilationException("Type " + type + " is not defined.");
+ void checkIsTypeDefined(String type) throws CompilationException {
+ if (!org.griphyn.vdl.type.Types.isValidType(type, typesMap.keySet())) {
+ throw new CompilationException("Type " + type + " is not defined.");
public void assign(Assign assign, VariableScope scope) throws CompilationException {
@@ -492,6 +489,31 @@
throw new CompilationException("Compile error in assignment at "+assign.getSrc()+": "+re.getMessage(),re);
+ public void append(Append append, VariableScope scope) throws CompilationException {
+ try {
+ StringTemplate appendST = template("append");
+ StringTemplate array = expressionToKarajan(append.getAbstractExpressionArray(0),scope);
+ StringTemplate value = expressionToKarajan(append.getAbstractExpressionArray(1),scope);
+ String indexType = org.griphyn.vdl.type.Types.getArrayIndexTypeName(datatype(array));
+ if (!"auto".equals(indexType)) {
+ throw new CompilationException("You can only append to an array with " +
+ "'auto' index type. Current index type: " + indexType);
+ if (!datatype(value).equals(org.griphyn.vdl.type.Types.getArrayItemTypeName(datatype(array)))) {
+ throw new CompilationException("You cannot append value of type " + datatype(value) +
+ " to an array of type " + datatype(array));
+ appendST.setAttribute("array", array);
+ appendST.setAttribute("value", value);
+ String rootvar = abstractExpressionToRootVariable(append.getAbstractExpressionArray(0));
+ // an append is always a partial write
+ scope.addWriter(rootvar, new Integer(callID++), true);
+ scope.appendStatement(appendST);
+ } catch(CompilationException re) {
+ throw new CompilationException("Compile error in assignment at "+append.getSrc()+": "+re.getMessage(),re);
public void statementsForSymbols(XmlObject prog, VariableScope scope) throws CompilationException {
XmlCursor cursor = prog.newCursor();
@@ -516,6 +538,7 @@
variableForSymbol((Variable) child, scope);
else if (child instanceof Assign
+ || child instanceof Append
|| child instanceof Call
|| child instanceof Foreach
|| child instanceof Iterate
@@ -539,6 +562,9 @@
else if (child instanceof Assign) {
assign((Assign) child, scope);
+ else if (child instanceof Append) {
+ append((Append) child, scope);
else if (child instanceof Call) {
call((Call) child, scope, false);
@@ -783,13 +809,16 @@
foreachST.setAttribute("in", inST);
String inType = datatype(inST);
- if (inType.length() < 2 || !inType.substring(inType.length() - 2).equals("[]"))
- throw new CompilationException("You can iterate through an array structure only");
- String varType = inType.substring(0, inType.length() - 2);
- innerScope.addVariable(foreach.getVar(), varType);
+ String itemType = org.griphyn.vdl.type.Types.getArrayItemTypeName(inType);
+ String keyType = org.griphyn.vdl.type.Types.getArrayIndexTypeName(inType);
+ if (itemType == null) {
+ throw new CompilationException("You can iterate through an array structure only");
+ innerScope.addVariable(foreach.getVar(), itemType);
foreachST.setAttribute("indexVar", foreach.getIndexVar());
+ foreachST.setAttribute("indexVarType", keyType);
if(foreach.getIndexVar() != null) {
- innerScope.addVariable(foreach.getIndexVar(), "int");
+ innerScope.addVariable(foreach.getIndexVar(), keyType);
innerScope.bodyTemplate = foreachST;
@@ -921,12 +950,19 @@
XmlObject argument = app.getAbstractExpressionArray(i);
StringTemplate argumentST = expressionToKarajan(argument, scope);
String type = datatype(argumentST);
- if(type.equals("string") || type.equals("string[]")
- || type.equals("int") || type.equals("float")
- || type.equals("int[]") || type.equals("float[]")
- || type.equals("boolean") || type.equals("boolean[]")) {
- appST.setAttribute("arguments", argumentST);
- } else {
+ String base = org.griphyn.vdl.type.Types.getArrayItemTypeName(type);
+ String testType;
+ // if array then use the array item type for testing
+ if (base != null) {
+ testType = base;
+ else {
+ testType = type;
+ if (org.griphyn.vdl.type.Types.isPrimitive(testType)) {
+ appST.setAttribute("arguments", argumentST);
+ else {
throw new CompilationException("Cannot pass type '"+type+"' as a parameter to application '"+app.getExecutable()+"'");
@@ -1155,43 +1191,50 @@
StringTemplate arrayST = expressionToKarajan(op.getAbstractExpressionArray(1), scope);
StringTemplate parentST = expressionToKarajan(op.getAbstractExpressionArray(0), scope);
- // handle [*] as identity/no-op
+ String indexType = datatype(arrayST);
+ String declaredIndexType = org.griphyn.vdl.type.Types.getArrayIndexTypeName(datatype(parentST));
+ // the index type must match the declared index type,
+ // unless the declared index type is *
+ // and really, at this point type checking should be delegated to the type system
+ // instead of the ad-hoc string comparisons
if (datatype(arrayST).equals("string")) {
- XmlString var = (XmlString) op.getAbstractExpressionArray(1);
- if (var.getStringValue().equals("*")) {
- return parentST;
- } else {
- throw new CompilationException("Array index must be of type int, or *.");
- } else {
- // the index should be numerical
+ XmlString var = (XmlString) op.getAbstractExpressionArray(1);
+ if (var.getStringValue().equals("*")) {
+ return parentST;
+ if (!indexType.equals(declaredIndexType)
+ && !"".equals(declaredIndexType)
+ && !"any".equals(declaredIndexType)) {
+ throw new CompilationException("Supplied array index type ("
+ + indexType + ") does not match the declared index type (" + declaredIndexType + ")");
+ StringTemplate newst = template("extractarrayelement");
+ newst.setAttribute("arraychild", arrayST);
+ newst.setAttribute("parent", parentST);
+ newst.setAttribute("datatype", org.griphyn.vdl.type.Types.getArrayItemTypeName(datatype(parentST)));
- StringTemplate newst = template("extractarrayelement");
- newst.setAttribute("arraychild", arrayST);
- newst.setAttribute("parent", parentST);
- String arrayType = datatype(parentST);
- if (datatype(arrayST).equals("int")) {
- newst.setAttribute("datatype", arrayType.substring(0, arrayType.length()-2));
- } else {
- return newst;
+ return newst;
} else if (expressionQName.equals(STRUCTURE_MEMBER_EXPR)) {
StructureMember sm = (StructureMember) expression;
StringTemplate parentST = expressionToKarajan(sm.getAbstractExpression(), scope);
String parentType = datatype(parentST);
// if the parent is an array, then check against
// the base type of the array
+ String baseType = org.griphyn.vdl.type.Types.getArrayItemTypeName(parentType);
+ String indexType = org.griphyn.vdl.type.Types.getArrayIndexTypeName(parentType);
+ String arrayType = parentType;
boolean arrayMode = false;
- if(parentType.endsWith("[]")) {
- arrayMode=true;
- parentType = parentType.substring(0, parentType.length() - 2);
+ if (baseType != null) {
+ arrayMode = true;
+ parentType = baseType;
String actualType = null;
@@ -1212,20 +1255,18 @@
if (actualType == null) {
throw new CompilationException("Type " + parentType + " is not defined.");
+ StringTemplate newst;
if(arrayMode) {
- actualType += "[]";
- StringTemplate newst = template("slicearray");
- newst.setAttribute("memberchild", sm.getMemberName());
- newst.setAttribute("datatype", actualType);
- return newst;
- } else {
- StringTemplate newst = template("extractstructelement");
- return newst;
+ actualType = actualType + "[" + indexType + "]";
+ newst = template("slicearray");
+ else {
+ newst = template("extractstructelement");
+ newst.setAttribute("memberchild", sm.getMemberName());
+ newst.setAttribute("datatype", actualType);
+ return newst;
// TODO the template layout for this and ARRAY_SUBSCRIPT are
// both a bit convoluted for historical reasons.
// should be straightforward to tidy up.
@@ -1244,7 +1285,7 @@
if (elemType.equals(""))
logger.warn("WARNING: Empty array constant");
- st.setAttribute("datatype", elemType + "[]");
+ st.setAttribute("datatype", elemType + "[int]");
return st;
} else if (expressionQName.equals(RANGE_EXPR)) {
Range range = (Range)expression;
@@ -1261,16 +1302,20 @@
String fromType = datatype(fromST);
String toType = datatype(toST);
- if (stepST == null && (!fromType.equals("int") || !toType.equals("int")))
+ if (stepST == null && (!fromType.equals("int") || !toType.equals("int"))) {
throw new CompilationException("Step in range specification can be omitted only when from and to types are int");
else if ((fromType.equals("int") && toType.equals("int")) &&
- (stepST == null || datatype(stepST).equals("int")))
- st.setAttribute("datatype", "int[]");
+ (stepST == null || datatype(stepST).equals("int"))) {
+ st.setAttribute("datatype", "int[int]");
else if (fromType.equals("float") && toType.equals("float") &&
- datatype(stepST).equals("float"))
- st.setAttribute("datatype", "float[]");
- else
+ datatype(stepST).equals("float")) {
+ st.setAttribute("datatype", "float[int]");
+ else {
throw new CompilationException("Range can only be specified with numeric types");
return st;
} else if (expressionQName.equals(FUNCTION_EXPR)) {
Function f = (Function) expression;
@@ -1430,15 +1475,17 @@
String escapeQuotes(String in) {
return in.replaceAll("\"", """);
+ public static String normalize(String type) {
+ return org.griphyn.vdl.type.Types.normalize(type);
String datatype(StringTemplate st) {
- String result = null;
try {
- result = st.getAttribute("datatype").toString();
+ return normalize(st.getAttribute("datatype").toString());
catch (Exception e) {
throw new RuntimeException("Not typed properly: " + st);
- return result;
Modified: trunk/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java
--- trunk/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -30,6 +30,7 @@
this.node = node;
this.values = values;
keys = new ArrayList<Object>();
+ keys.addAll(values.keySet());
public Object get(int index) {
Added: trunk/src/org/griphyn/vdl/karajan/lib/AppendArray.java
--- trunk/src/org/griphyn/vdl/karajan/lib/AppendArray.java (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/AppendArray.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -0,0 +1,45 @@
+//This code is developed as part of the Java CoG Kit project
+//The terms of the license can be found at http://www.cogkit.org/license
+//This message may not be removed or altered.
+ * Created on Jul 21, 2011
+package org.griphyn.vdl.karajan.lib;
+import org.globus.cog.karajan.arguments.Arg;
+import org.globus.cog.karajan.stack.VariableStack;
+import org.globus.cog.karajan.util.TypeUtil;
+import org.globus.cog.karajan.workflow.ExecutionException;
+import org.griphyn.vdl.mapping.AbstractDataNode;
+import org.griphyn.vdl.mapping.DSHandle;
+import org.griphyn.vdl.mapping.InvalidPathException;
+import org.griphyn.vdl.mapping.Path;
+public class AppendArray extends SetFieldValue {
+ public static final Arg PA_ID = new Arg.Positional("id");
+ static {
+ setArguments(AppendArray.class, new Arg[] { PA_VAR, PA_VALUE });
+ @Override
+ public Object function(VariableStack stack) throws ExecutionException {
+ DSHandle var = (DSHandle) PA_VAR.getValue(stack);
+ AbstractDataNode value = (AbstractDataNode) PA_VALUE.getValue(stack);
+ // while there isn't a way to avoid conflicts between auto generated indices
+ // and a user manually using the same index, adding a "#" may reduce
+ // the incidence of problems
+ Path path = Path.EMPTY_PATH.addFirst(getThreadPrefix(stack), true);
+ try {
+ deepCopy(var.getField(path), value, stack, 0);
+ catch (InvalidPathException e) {
+ throw new ExecutionException(e);
+ return null;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/CleanDataset.java
--- trunk/src/org/griphyn/vdl/karajan/lib/CleanDataset.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/karajan/lib/CleanDataset.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -32,7 +32,9 @@
else {
AbstractDataNode var = (AbstractDataNode) PA_VAR.getValue(stack);
- logger.info("Cleaning " + var);
+ if (logger.isInfoEnabled()) {
+ logger.info("Cleaning " + var);
var.clean();
return null;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/CreateArray.java
--- trunk/src/org/griphyn/vdl/karajan/lib/CreateArray.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/karajan/lib/CreateArray.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -69,7 +69,7 @@
DSHandle n = (DSHandle) i.next();
// we know this DSHandle cast will work because we checked
// it in the previous scan of the array contents
- Path p = Path.EMPTY_PATH.addLast(String.valueOf(index), true);
+ Path p = Path.EMPTY_PATH.addLast(index, true);
handle.getField(p).set(n);
logger.info("CREATEARRAY MEMBER array="+handle.getIdentifier()+" index="+index+" member="+n.getIdentifier());
Modified: trunk/src/org/griphyn/vdl/karajan/lib/DoRestartLog.java
--- trunk/src/org/griphyn/vdl/karajan/lib/DoRestartLog.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/karajan/lib/DoRestartLog.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -29,7 +29,7 @@
try {
for (Object f : files) {
List pv = TypeUtil.toList(f);
- Path p = Path.parse(TypeUtil.toString(pv.get(0)));
+ Path p = (Path) pv.get(0);
DSHandle handle = (DSHandle) pv.get(1);
LogVar.logVar(stack, handle, p);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/ExpandArguments.java
--- trunk/src/org/griphyn/vdl/karajan/lib/ExpandArguments.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/karajan/lib/ExpandArguments.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -1,19 +1,19 @@
import java.util.ArrayList;
+import java.util.Comparator;
+import java.util.Iterator;
import java.util.Map;
-import java.util.Comparator;
+import java.util.Set;
import java.util.TreeSet;
-import java.util.Set;
-import java.util.Iterator;
import org.apache.log4j.Logger;
import org.griphyn.vdl.mapping.ArrayDataNode;
+import org.griphyn.vdl.mapping.PathElementComparator;
public class ExpandArguments extends VDLFunction {
public static final Logger logger = Logger.getLogger(ExpandArguments.class);
@@ -35,7 +35,7 @@
ArrayDataNode array = (ArrayDataNode) item;
Map m=array.getArrayValue();
Set keySet = m.keySet();
- TreeSet sortedKeySet = new TreeSet(new StringsAsIntegersComparator());
+ TreeSet<Comparable<?>> sortedKeySet = new TreeSet<Comparable<?>>(new PathElementComparator());
sortedKeySet.addAll(keySet);
Iterator it = sortedKeySet.iterator();
while(it.hasNext()) {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/GetArrayIterator.java
--- trunk/src/org/griphyn/vdl/karajan/lib/GetArrayIterator.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/karajan/lib/GetArrayIterator.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -38,9 +38,15 @@
synchronized(var) {
if (var.isClosed()) {
+ if (logger.isDebugEnabled()) {
+ logger.debug("Using closed iterator for " + var);
return new PairIterator(var.getArrayValue());
else {
+ logger.debug("Using future iterator for " + var);
return ((ArrayDataNode) var).getFutureList().futureIterator();
Modified: trunk/src/org/griphyn/vdl/karajan/lib/GetField.java
--- trunk/src/org/griphyn/vdl/karajan/lib/GetField.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/karajan/lib/GetField.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -21,7 +21,6 @@
Object var1 = PA_VAR.getValue(stack);
if(var1 instanceof DSHandle) {
try {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/GetFieldSubscript.java
--- trunk/src/org/griphyn/vdl/karajan/lib/GetFieldSubscript.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/karajan/lib/GetFieldSubscript.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -29,14 +29,11 @@
try {
Path path;
- if (index instanceof String) {
- path = Path.EMPTY_PATH.addFirst((String) index, true);
+ if ("*".equals(index)) {
+ path = Path.CHILDREN;
- else if (index instanceof Double) {
- path = Path.EMPTY_PATH.addFirst(String.valueOf(((Double) index).intValue()), true);
else {
- throw new RuntimeException("Cannot handle array index of Java type " + index.getClass());
+ path = Path.EMPTY_PATH.addFirst((Comparable<?>) index, true);
Collection<DSHandle> fields = var.getFields(path);
if (fields.size() == 1) {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/IsDone.java
--- trunk/src/org/griphyn/vdl/karajan/lib/IsDone.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/karajan/lib/IsDone.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -23,9 +23,9 @@
@Override
protected Object function(VariableStack stack) throws ExecutionException {
List files = TypeUtil.toList(STAGEOUT.getValue(stack));
- for (Object f : files) {
+ for (Object f : files) {
if (!IsLogged.isLogged(stack, handle, p)) {
return Boolean.FALSE;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/New.java
--- trunk/src/org/griphyn/vdl/karajan/lib/New.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/karajan/lib/New.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -103,7 +103,7 @@
// TODO check type consistency of elements with
// the type of the array
Object n = i.next();
if (n instanceof DSHandle) {
handle.getField(p).set((DSHandle) n);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Operators.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Operators.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Operators.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -24,7 +24,12 @@
private DSHandle newNum(Type type, double value) throws ExecutionException {
try {
DSHandle handle = new RootDataNode(type);
- handle.setValue(new Double(value));
+ if (type == Types.INT) {
+ handle.setValue(Integer.valueOf((int) value));
+ else {
+ handle.setValue(new Double(value));
handle.closeShallow();
return handle;
@@ -33,6 +38,18 @@
+ private DSHandle newNum(Type type, int value) throws ExecutionException {
+ try {
+ DSHandle handle = new RootDataNode(type);
+ handle.setValue(new Integer(value));
+ handle.closeShallow();
+ return handle;
+ catch (Exception e) {
+ throw new ExecutionException("Internal error", e);
private DSHandle newString(String value) throws ExecutionException {
try {
DSHandle handle = new RootDataNode(Types.STRING);
@@ -86,12 +103,16 @@
public Object vdlop_sum(VariableStack stack) throws ExecutionException {
Object l = L.getValue(stack);
Object r = R.getValue(stack);
+ Type t = type(stack);
DSHandle ret;
if (l instanceof String || r instanceof String) {
ret = newString(((String) l) + ((String) r));
+ else if (t == Types.INT) {
+ ret = newNum(t, SwiftArg.checkInt(l) + SwiftArg.checkInt(r));
else {
- ret = newNum(type(stack), SwiftArg.checkDouble(l) + SwiftArg.checkDouble(r));
+ ret = newNum(t, SwiftArg.checkDouble(l) + SwiftArg.checkDouble(r));
logBinaryProvenance(stack, "sum", ret);
return ret;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Range.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Range.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Range.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -60,7 +60,7 @@
return Collections.singletonList((DSHandle) this);
else {
- int index = Integer.parseInt(path.getFirst());
+ int index = (Integer) path.getFirst();
DSHandle value = new RootDataNode(type);
value.init(null);
value.setValue(new Double(start + incr * index));
@@ -91,13 +91,18 @@
value.init(null);
- value.setValue(new Double(crt));
+ value.setValue(new Integer((int) crt));
+ else {
+ value.setValue(new Double(crt));
value.closeShallow();
key = index;
public Comparable<?> getKey() {
- return new Double(key);
+ return Integer.valueOf(key);
public DSHandle getValue() {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -68,23 +68,24 @@
if (p.equals("$"))
p = "";
String name = data.getDisplayableName() + p;
- Object v = value.getValue();
- if (! (v instanceof Map))
- logger.info("Set: " + name + "=" + v);
- else
+ if (value.getType().isArray()) {
- unpackHandles((Map<String, DSHandle>) v));
+ unpackHandles(value.getArrayValue()));
+ else {
+ logger.info("Set: " + name + "=" + value.getValue());
- String unpackHandles(Map<String,DSHandle> handles) {
+ String unpackHandles(Map<Comparable<?>, DSHandle> handles) {
StringBuilder sb = new StringBuilder();
sb.append("{");
- Iterator<Map.Entry<String,DSHandle>> it =
+ Iterator<Map.Entry<Comparable<?>, DSHandle>> it =
handles.entrySet().iterator();
while (it.hasNext()) {
- Map.Entry<String,DSHandle> entry = it.next();
+ Map.Entry<Comparable<?>, DSHandle> entry = it.next();
sb.append(entry.getKey());
sb.append('=');
sb.append(entry.getValue().getValue());
@@ -113,21 +114,15 @@
Pair pair = (Pair) it.next();
- Object lhs = pair.get(0);
+ Comparable<?> lhs = (Comparable<?>) pair.get(0);
DSHandle rhs = (DSHandle) pair.get(1);
- Path memberPath;
- if (lhs instanceof Double) {
- memberPath = Path.EMPTY_PATH.addLast(String.valueOf(((Double) lhs).intValue()), true);
- else {
- memberPath = Path.EMPTY_PATH.addLast(String.valueOf(lhs), true);
+ Path memberPath = Path.EMPTY_PATH.addLast(lhs, true);
DSHandle field;
try {
field = dest.getField(memberPath);
catch (InvalidPathException ipe) {
- throw new ExecutionException("Could not get destination field",ipe);
+ throw new ExecutionException("Could not get destination field", ipe);
deepCopy(field, rhs, stack, level + 1);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SliceArray.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SliceArray.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SliceArray.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -60,21 +60,20 @@
RootArrayDataNode destinationArray = new RootArrayDataNode(destinationType);
- Path cutPath = Path.EMPTY_PATH.addLast((String)PA_PATH.getValue(stack), false);
+ Path cutPath = Path.EMPTY_PATH.addLast((String) PA_PATH.getValue(stack), false);
- PairIterator it = new PairIterator(sourceArray.getArrayValue());
+ PairIterator it = new PairIterator(sourceArray.getArrayValue());
Object index = pair.get(0);
DSHandle sourceElement = (DSHandle) pair.get(1);
+ Path p = Path.EMPTY_PATH.addLast((Comparable<?>) index, true);
DSHandle n = sourceElement.getField(cutPath);
- destinationArray.getField(p).set((DSHandle) n);
+ destinationArray.getField(p).set(n);
// all of the inputs should be closed, so
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SwiftArg.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SwiftArg.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SwiftArg.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -66,13 +66,22 @@
public static double checkDouble(Object dbl) throws ExecutionException {
- if (dbl instanceof Double) {
- return ((Double) dbl).doubleValue();
+ if (dbl instanceof Number) {
+ return ((Number) dbl).doubleValue();
else {
throw new ExecutionException("Internal type error. Expected a Double. Got " + classOf(dbl));
+ public static int checkInt(Object i) throws ExecutionException {
+ if (i instanceof Integer) {
+ return ((Integer) i).intValue();
+ else {
+ throw new ExecutionException("Internal type error. Expected a Integer. Got " + classOf(i));
public DSHandle getRawValue(VariableStack stack) throws ExecutionException {
Object v = super.getValue(stack);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/VDLFunction.java
--- trunk/src/org/griphyn/vdl/karajan/lib/VDLFunction.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/karajan/lib/VDLFunction.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -3,7 +3,6 @@
import java.util.Collection;
import java.util.Collections;
import java.util.HashSet;
import java.util.LinkedList;
import java.util.List;
@@ -41,6 +40,7 @@
import org.griphyn.vdl.mapping.Mapper;
+import org.griphyn.vdl.mapping.PathComparator;
import org.griphyn.vdl.mapping.PhysicalFormat;
import org.griphyn.vdl.type.Type;
@@ -154,7 +154,7 @@
return new Double(TypeUtil.toDouble(value));
else if (Types.INT.equals(type)) {
- return new Double(TypeUtil.toInt(value));
+ return new Integer(TypeUtil.toInt(value));
else if (Types.BOOLEAN.equals(type)) {
return new Boolean(TypeUtil.toBoolean(value));
@@ -222,50 +222,6 @@
return l.toArray(EMPTY_STRING_ARRAY);
- private static class PathComparator implements Comparator<Path> {
- public int compare(Path p1, Path p2) {
- for (int i = 0; i < Math.min(p1.size(), p2.size()); i++) {
- int d;
- d = indexOrder(p1.isArrayIndex(i), p2.isArrayIndex(i));
- if (d != 0) {
- return d;
- if (p1.isArrayIndex(i)) {
- d = numericOrder(p1.getElement(i), p2.getElement(i));
- else {
- d = p1.getElement(i).compareTo(p2.getElement(i));
- if (d != 0) {
- return d;
- //the longer one wins
- return p1.size() - p2.size();
- private int indexOrder(boolean i1, boolean i2) {
- //it doesn't matter much what the order between indices and non-indices is,
- //but it needs to be consistent
- if (i1) {
- if (!i2) {
- return -1;
- else {
- if (i2) {
- return 1;
- return 0;
- private int numericOrder(String i1, String i2) {
- //TODO check if we're actually dealing with numeric indices
- return Integer.parseInt(i1) - Integer.parseInt(i2);
private static String leafFileName(DSHandle var) throws ExecutionException {
return leafFileName(var, var.getMapper());
@@ -408,43 +364,12 @@
public static Path parsePath(Object o, VariableStack stack) throws ExecutionException {
- Path q = Path.EMPTY_PATH;
- Path p;
if (o instanceof Path) {
- p = (Path) o;
+ return (Path) o;
else {
- p = Path.parse(TypeUtil.toString(o));
+ return Path.parse(TypeUtil.toString(o));
- for (int i = 0; i < p.size(); i++) {
- if (p.isArrayIndex(i)) {
- if (p.isWildcard(i)) {
- q = q.addLast(p.getElement(i), true);
- else {
- String index = p.getElement(i);
- try {
- // check this is can parse as an integer by trying to parse and getting an exception if not
- Integer.parseInt(index);
- q = q.addLast(index, true);
- catch (NumberFormatException e) {
- Object v = stack.getVar(index);
- if (v instanceof DSHandle) {
- v = ((DSHandle) v).getValue();
- q = q.addLast(TypeUtil.toString(v), true);
- else {
- q = q.addLast(p.getElement(i));
- if (p.hasWildcards() && !q.hasWildcards()) {
- throw new RuntimeException("Error in the wildcard processing routine");
- return q;
private static Set warnset = new HashSet();
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -87,6 +87,22 @@
buf.append(o);
+ else if (h.getType().isArray()) {
+ buf.append('{');
+ boolean first = true;
+ for (Map.Entry<Comparable<?>, DSHandle> e : h.getArrayValue().entrySet()) {
+ if (first) {
+ first = false;
+ else {
+ buf.append(", ");
+ buf.append(e.getKey());
+ buf.append(" = ");
+ prettyPrint(buf, e.getValue());
+ buf.append('}');
else {
buf.append(h);
@@ -105,8 +121,7 @@
buf.append(TypeUtil.toString(args[i]));
- DSHandle handle = new RootDataNode(Types.STRING);
- handle.setValue(buf.toString());
+ DSHandle handle = new RootDataNode(Types.STRING, buf.toString());
try {
if(VDL2Config.getConfig().getProvenanceLog()) {
@@ -134,11 +149,9 @@
String filename = TypeUtil.toString(args[0]);
- DSHandle handle = new RootDataNode(Types.BOOLEAN);
AbsFile file = new AbsFile(filename);
logger.debug("exists: " + file);
- handle.setValue(file.exists());
- handle.closeShallow();
+ DSHandle handle = new RootDataNode(Types.BOOLEAN, file.exists());
try {
@@ -185,9 +198,8 @@
logger.debug("strcut matched '" + group + "'");
- handle.setValue(group);
+ DSHandle handle = new RootDataNode(Types.STRING, group);
VDLFunction.logProvenanceResult(provid, handle, "strcut");
VDLFunction.logProvenanceParameter(provid, PA_INPUT.getRawValue(stack), "input");
VDLFunction.logProvenanceParameter(provid, PA_PATTERN.getRawValue(stack), "pattern");
@@ -203,10 +215,7 @@
"' for pattern '" + pattern + "'");
int result = inputString.indexOf(pattern);
- DSHandle handle = new RootDataNode(Types.INT);
- handle.setValue(new Double(result));
- return handle;
+ return new RootDataNode(Types.INT, result);
public DSHandle swiftscript_strsplit(VariableStack stack)
@@ -219,7 +228,7 @@
DSHandle handle = new RootArrayDataNode(Types.STRING.arrayType());
for (int i = 0; i < split.length; i++) {
- DSHandle el = handle.getField(Path.EMPTY_PATH.addFirst(String.valueOf(i), true));
+ DSHandle el = handle.getField(Path.EMPTY_PATH.addFirst(i, true));
el.setValue(split[i]);
handle.closeDeep();
@@ -279,7 +288,7 @@
try
- handle.setValue(new Double(inputString));
+ handle.setValue(new Integer(inputString));
catch(NumberFormatException e)
@@ -403,12 +412,7 @@
Object[] args = SwiftArg.VARGS.asArray(stack);
String arg = (String) args[0];
AbsFile file = new AbsFile(arg);
- boolean b = file.exists();
- result = new RootDataNode(Types.BOOLEAN);
- result.setValue(b);
- result.closeShallow();
- return result;
+ return new RootDataNode(Types.BOOLEAN, file.exists());
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadData.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadData.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadData.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -119,7 +119,7 @@
String line = br.readLine();
try {
while (line != null) {
- DSHandle child = dest.getField(Path.EMPTY_PATH.addLast(String.valueOf(index), true));
+ DSHandle child = dest.getField(Path.EMPTY_PATH.addLast(index, true));
setValue(child, line);
index++;
@@ -139,8 +139,7 @@
line = line.trim();
if (!line.equals("")) {
- true));
readStruct(child, line, header);
index++;
@@ -211,13 +210,13 @@
try {
if (dest.getType().equals(Types.INT)) {
- dest.setValue(new Double(Integer.parseInt(s.trim())));
+ dest.setValue(Integer.valueOf(s.trim()));
else if (dest.getType().equals(Types.FLOAT)) {
dest.setValue(new Double(s.trim()));
else if (dest.getType().equals(Types.BOOLEAN)) {
- dest.setValue(new Boolean(s.trim()));
+ dest.setValue(Boolean.valueOf(s.trim()));
else if (dest.getType().equals(Types.STRING)) {
dest.setValue(s);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadStructured.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadStructured.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadStructured.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -100,13 +100,13 @@
private void setValue(DSHandle dest, String s) throws ExecutionException {
try {
dest.setValue(s);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -175,8 +175,8 @@
private static void append_i(DSHandle arg, StringBuilder output)
if (arg.getType() == Types.INT) {
- Double d = (Double) arg.getValue();
- output.append(new Integer(d.intValue()));
+ Integer d = (Integer) arg.getValue();
+ output.append(d);
else {
Modified: trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -193,13 +193,16 @@
try {
DSHandle handle = getField(path.getFirst());
if (path.size() > 1) {
return handle.getField(path.butFirst());
- return handle;
+ else {
+ return handle;
catch (NoSuchFieldException e) {
- logger.warn("could not find variable: " + field.getName() +
+ logger.warn("could not find variable: " + field.getId() +
" " + path);
throw new InvalidPathException(path, this);
@@ -216,24 +219,16 @@
fields.add(this);
else {
- Path rest = path.butFirst();
if (path.isWildcard(0)) {
- if (isArray() && !closed) {
- throw new FutureNotYetAvailable(getFutureWrapper());
- for (DSHandle handle : handles.values()) {
- ((AbstractDataNode) handle).getFields(fields, rest);
+ throw new InvalidPathException("getFields([*]) only applies to arrays");
- else {
- try {
- ((AbstractDataNode) getField(path.getFirst())).getFields(
- fields, rest);
- catch (NoSuchFieldException e) {
- throw new InvalidPathException(path, this);
+ try {
+ ((AbstractDataNode) getField(path.getFirst())).getFields(
+ fields, path.butFirst());
+ catch (NoSuchFieldException e) {
+ throw new InvalidPathException(path, this);
@@ -251,70 +246,79 @@
throw new RuntimeException("Can't set root data node!");
- ((AbstractDataNode) getParent()).setField(field.getName(), handle);
+ ((AbstractDataNode) getParent()).setField(field.getId(), handle);
- protected void setField(String name, DSHandle handle) {
+ protected void setField(Comparable<?> id, DSHandle handle) {
synchronized (handles) {
- handles.put(name, handle);
+ handles.put(id, handle);
- protected synchronized DSHandle getField(String name)
- throws NoSuchFieldException {
- DSHandle handle = getHandle(name);
- if (handle == null) {
- if (closed) {
- throw new NoSuchFieldException(name);
+ protected DSHandle getField(Comparable<?> key)
+ throws NoSuchFieldException {
+ synchronized(handles) {
+ DSHandle handle = handles.get(key);
+ if (handle == null) {
+ if (closed) {
+ throw new NoSuchFieldException(key.toString());
+ handle = createField(key);
- handle = createDSHandle(name);
+ return handle;
- return handle;
- protected DSHandle getHandle(String name) {
- synchronized (handles) {
- return handles.get(name);
protected boolean isHandlesEmpty() {
return handles.isEmpty();
- public DSHandle createDSHandle(String fieldName)
+ public DSHandle createField(Comparable<?> key)
if (closed) {
throw new RuntimeException("Cannot write to closed handle: " + this
- + " (" + fieldName + ")");
+ + " (" + key + ")");
- AbstractDataNode child;
- Field childField = getChildField(fieldName);
- if (childField.getType().isArray()) {
- child = new ArrayDataNode(getChildField(fieldName), getRoot(), this);
- else {
- child = new DataNode(getChildField(fieldName), getRoot(), this);
+ return addHandle(key, newNode(getChildField(key)));
+ protected DSHandle addHandle(Comparable<?> id, DSHandle handle) {
- Object o = handles.put(fieldName, child);
+ Object o = handles.put(id, handle);
if (o != null) {
"Trying to create a handle that already exists ("
- + fieldName + ") in " + this);
+ + id + ") in " + this);
- return child;
+ return handle;
+ protected AbstractDataNode newNode(Field f) {
+ if (f.getType().isArray()) {
+ return new ArrayDataNode(f, getRoot(), this);
+ else {
+ return new DataNode(f, getRoot(), this);
- protected Field getChildField(String fieldName) throws NoSuchFieldException {
- return Field.Factory.createField(fieldName, field.getType().getField(
- fieldName).getType());
+ protected Field getChildField(Comparable<?> key) throws NoSuchFieldException {
+ if (getType().isArray()) {
+ return Field.Factory.createField(key, getType().itemType());
+ else {
+ return Field.Factory.createField(key, getType().getField((String) key).getType());
+ protected Field getArrayChildField(Comparable<?> key) {
protected void checkDataException() {
if (value instanceof DependentException) {
@@ -366,43 +370,39 @@
getFringePaths(list, Path.EMPTY_PATH);
return list;
public void getFringePaths(List<Path> list, Path parentPath)
throws HandleOpenException {
checkMappingException();
- if (getField().getType().getBaseType() != null) {
+ if (getType().getBaseType() != null) {
list.add(Path.EMPTY_PATH);
else {
- for (Field field : getField().getType().getFields()) {
- AbstractDataNode mapper;
- String name = field.getName();
+ for (Field field : getType().getFields()) {
+ AbstractDataNode child;
+ String name = (String) field.getId();
try {
- mapper = (AbstractDataNode) this.getField(name);
+ child = (AbstractDataNode) this.getField(name);
("Inconsistency between type declaration and " +
"handle for field '" + name + "'");
- // [m] Hmm. Should there be a difference between field and
- // mapper.getField()?
- // Path fullPath =
- // parentPath.addLast(mapper.getField().getName());
- Path fullPath = parentPath.addLast(field.getName());
- Type type = mapper.field.getType();
+ Path fullPath = parentPath.addLast(name);
+ Type type = child.getType();
if (!type.isPrimitive() &&
- !mapper.isArray() &&
+ !child.isArray() &&
type.getFields().size() == 0) {
list.add(fullPath);
else {
- mapper.getFringePaths(list, fullPath);
+ child.getFringePaths(list, fullPath);
public void closeShallow() {
synchronized(this) {
if (this.closed) {
@@ -560,7 +560,7 @@
Path myPath;
if (parent != null) {
myPath = parent.getPathFromRoot();
- pathFromRoot = myPath.addLast(getField().getName(), parent
+ pathFromRoot = myPath.addLast(getField().getId(), parent
.getField().getType().isArray());
else {
@@ -636,7 +636,7 @@
((AbstractDataNode) h).clean();
- else {
+ else if (!getType().isArray()) {
Mapper mapper = getRoot().getMapper();
if (mapper != null) {
mapper.clean(getPathFromRoot());
Modified: trunk/src/org/griphyn/vdl/mapping/ArrayDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/ArrayDataNode.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/mapping/ArrayDataNode.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -27,7 +27,7 @@
for (Map.Entry<Comparable<?>, DSHandle> e : handles.entrySet()) {
AbstractDataNode mapper = (AbstractDataNode) e.getValue();
- Path fullPath = parentPath.addLast(e.getKey().toString(), getType().isArray());
+ Path fullPath = parentPath.addLast(e.getKey(), getType().isArray());
if (mapper.getType().isComposite()) {
@@ -51,7 +51,6 @@
public boolean isArray() {
return true;
@@ -62,25 +61,32 @@
@Override
- super.setField(name, handle);
- addKey(name);
+ synchronized(getHandles()) {
+ super.setField(id, handle);
+ // Operations on the handles and the wrapper keys need to be synchronized.
+ // When a wrapper is created, it populates its list of keys with the handles
+ // available. If this happens concurrently with a call being exactly at this
+ // point in the code, then it's possible for a key to have both been added
+ // as part of the creation of the wrapper as well as due to the next call,
+ // causing duplicate iterations.
+ addKey(id);
- private void addKey(String name) {
- synchronized(this) {
- if (wrapper != null) {
- ((ArrayIndexFutureList) wrapper).addKey(name);
+ private void addKey(Comparable<?> key) {
+ if (wrapper != null) {
+ ((ArrayIndexFutureList) wrapper).addKey(key);
@Override
- DSHandle h = super.createDSHandle(fieldName);
- addKey(fieldName);
- return h;
+ public DSHandle createField(Comparable<?> key) throws NoSuchFieldException {
+ DSHandle h = super.createField(key);
+ addKey(key);
+ return h;
@Override
@@ -95,4 +101,30 @@
public FutureList getFutureList() {
return (FutureList) getFutureWrapper();
+ protected void getFields(List<DSHandle> fields, Path path) throws InvalidPathException {
+ if (path.isEmpty()) {
+ fields.add(this);
+ else {
+ Path rest = path.butFirst();
+ if (path.isWildcard(0)) {
+ if (!isClosed()) {
+ throw new FutureNotYetAvailable(getFutureWrapper());
+ for (DSHandle handle : getHandles().values()) {
+ ((AbstractDataNode) handle).getFields(fields, rest);
+ else {
+ try {
+ ((AbstractDataNode) getField(path.getKey(0))).getFields(
Modified: trunk/src/org/griphyn/vdl/mapping/DSHandle.java
--- trunk/src/org/griphyn/vdl/mapping/DSHandle.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/mapping/DSHandle.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -30,7 +30,7 @@
public Type getType();
- public void init(Map<String,Object> params);
+ public void init(Map<String, Object> params);
public DSHandle getRoot();
@@ -55,8 +55,8 @@
public void setValue(Object value);
/** create a new logical component */
- public DSHandle createDSHandle(String fieldName) throws NoSuchFieldException;
+ public DSHandle createField(Comparable<?> key) throws NoSuchFieldException;
// special file oriented methods, not sure if these apply to
// all datasets
Modified: trunk/src/org/griphyn/vdl/mapping/DataNode.java
--- trunk/src/org/griphyn/vdl/mapping/DataNode.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/mapping/DataNode.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -12,6 +12,9 @@
protected DataNode(Field field, DSHandle root, DSHandle parent) {
super(field);
+ if (parent != null && field.getId() == null) {
+ throw new IllegalArgumentException("Internal error: field id is null");
this.root = root;
this.parent = parent;
Modified: trunk/src/org/griphyn/vdl/mapping/InvalidPathException.java
--- trunk/src/org/griphyn/vdl/mapping/InvalidPathException.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/mapping/InvalidPathException.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -12,4 +12,8 @@
public InvalidPathException(Path path, DSHandle source) {
this(path.toString(), source);
+ public InvalidPathException(String string) {
+ super(string);
Modified: trunk/src/org/griphyn/vdl/mapping/Path.java
--- trunk/src/org/griphyn/vdl/mapping/Path.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/mapping/Path.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -12,7 +12,7 @@
public class Path {
public static final Path EMPTY_PATH = new EmptyPath();
- public static final Path CHILDREN = Path.parse("*");
+ public static final Path CHILDREN = Path.parse("[*]");
/** A list of Path.Entry that represents the path. */
private List<Path.Entry> entries;
@@ -48,13 +48,13 @@
* The name of this path entry (either the array offset or the type
* member name.
- private String name;
+ private Comparable<?> key;
- public Entry(String name, boolean index) {
- this.name = name;
+ public Entry(Comparable<?> key, boolean index) {
+ this.key = key;
this.index = index;
- if (name == null) {
+ if (key == null) {
"Attempted to create a path entry with a null name");
@@ -72,75 +72,59 @@
public boolean isWildcard() {
- return (name.length() == 1) && (name.charAt(0) == '*');
+ return false;
- public String getName() {
- return name;
+ public Comparable<?> getKey() {
+ return key;
public boolean equals(Object obj) {
if (obj instanceof Entry) {
Entry other = (Entry) obj;
- return name.equals(other.name) && (index == other.index);
+ if (isWildcard()) {
+ return other.isWildcard();
+ return key.equals(other.key);
return false;
public int hashCode() {
- return name.hashCode() + (index ? 0 : 123);
+ return key.hashCode() + (index ? 0 : 123);
public String toString() {
if (index) {
- return '[' + name + ']';
+ return '[' + String.valueOf(key) + ']';
- return name;
+ else {
+ return String.valueOf(key);
+ * equals() and hashCode() cannot be used to
+ * properly test equality between a wildcard and
+ * another entry
+ public static class Wildcard extends Entry {
+ @Override
+ public boolean isIndex() {
+ return true;
+ @Override
+ public boolean isWildcard() {
+ return true;
public static Path parse(String path) {
- if (path == null || path.equals("") || path.equals("$")) {
- return Path.EMPTY_PATH;
- ArrayList<Entry> list = new ArrayList<Entry>();
- StringBuilder sb = new StringBuilder();
- Entry e = new Entry();
- boolean wildcard = false;
- for (int i = 0; i < path.length(); i++) {
- char c = path.charAt(i);
- switch (c) {
- case '[': {
- if (sb.length() == 0) {
- continue; // TODO: what case does this capture?
- // attempt to use multidim arrays?
- //[m] it may simply be incomplete/incorrect
- case '.': {
- e.name = sb.toString();
- list.add(e);
- e = new Entry();
- sb.setLength(0);
- break;
- case ']': {
- e.index = true;
- break;
- case '*': {
- wildcard = true;
- default: {
- sb.append(c);
- break;
- list.add(e);
- list.trimToSize();
- return new Path(list, wildcard);
+ return new PathParser(path).parse();
private Path(List<Entry> entries, boolean wildcard) {
@@ -148,7 +132,7 @@
this.wildcard = wildcard;
- private Path(List<Entry> entries) {
+ protected Path(List<Entry> entries) {
this(entries, false);
for (Entry e : entries) {
if (e.isWildcard()) {
@@ -170,20 +154,24 @@
this.entries = Collections.emptyList();
- public String getElement(int index) {
- return entries.get(index).name;
+ public Comparable<?> getElement(int index) {
+ return entries.get(index).key;
+ public Comparable<?> getKey(int index) {
public int size() {
return entries == null ? 0 : entries.size();
- public String getFirst() {
- return entries.get(0).name;
+ public Comparable<?> getFirst() {
+ return entries.get(0).key;
- public String getLast() {
- return entries.get(entries.size() - 1).name;
+ public Comparable<?> getLast() {
+ return entries.get(entries.size() - 1).key;
public boolean isEmpty() {
@@ -202,7 +190,7 @@
return new Path(entries.subList(fromIndex, toIndex));
- public Path addFirst(String element, boolean index) {
+ public Path addFirst(Comparable<?> element, boolean index) {
Path p = new Path(this);
Entry e;
p.entries.add(0, e = new Entry(element, index));
@@ -216,7 +204,7 @@
return addFirst(element, false);
- public Path addLast(String element, boolean index) {
+ public Path addLast(Comparable<?> element, boolean index) {
Entry e = new Entry(element, index);
p.entries.add(e);
@@ -225,8 +213,15 @@
return p;
+ protected void addLast(Entry e) {
+ if (entries.isEmpty()) {
+ entries = new ArrayList<Entry>();
+ entries.add(e);
- public Path addLast(String element) {
+ public Path addLast(Comparable<?> element) {
return addLast(element, false);
@@ -239,18 +234,59 @@
public String stringForm() {
Iterator<Entry> i = entries.iterator();
while (i.hasNext()) {
- sb.append(i.next().name);
- if (i.hasNext()) {
- sb.append('.');
+ Entry e = i.next();
+ if (e.isWildcard()) {
+ sb.append("[*]");
+ else if (e.isIndex()) {
+ sb.append('[');
+ sb.append(stringForm(e.key));
+ sb.append(']');
+ else {
+ if (!first) {
+ sb.append('.');
+ sb.append(e.key);
+ first = false;
return sb.toString();
+ private String stringForm(Comparable<?> key) {
+ if (key instanceof String) {
+ return "\"" + escape((String) key) + '"';
+ else if (key instanceof Number) {
+ return key.toString();
+ else {
+ throw new IllegalArgumentException("Unsupported key type: " + key);
+ * TODO: match or use the actual language valid escapes
+ private String escape(String key) {
+ StringBuilder sb = new StringBuilder();
+ for (int i = 0; i < key.length(); i++) {
+ char c = key.charAt(i);
+ if (c == '\\' || c == '"') {
+ sb.append('\\');
+ sb.append(c);
+ return sb.toString();
* Returns a human readable string representation of this path. The string
- * returned by this method <strong>will not</strong> correctly be parsed
+ * returned by this method <strong>will not necessarily</strong> correctly be parsed
* into the same path by {@link Path.parse}. In other words no guarantee is
* made that <code>Path.parse(somePath.toString()).equals(somePath)</code>.
* For a consistent such representation of this path use {@link stringForm}.
@@ -261,17 +297,23 @@
StringBuffer sb = new StringBuffer();
- if (e.isIndex()) {
+ sb.append("[*]");
sb.append('[');
- sb.append(e.getName());
+ sb.append(e.getKey());
sb.append(']');
else {
- sb.append('.');
+ if (!first) {
+ sb.append('.');
+ first = false;
return tostrcached = sb.toString();
Added: trunk/src/org/griphyn/vdl/mapping/PathComparator.java
--- trunk/src/org/griphyn/vdl/mapping/PathComparator.java (rev 0)
+++ trunk/src/org/griphyn/vdl/mapping/PathComparator.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -0,0 +1,57 @@
+ * Created on Jul 22, 2011
+package org.griphyn.vdl.mapping;
+public class PathComparator implements Comparator<Path> {
+ @SuppressWarnings("unchecked")
+ public int compare(Path p1, Path p2) {
+ for (int i = 0; i < Math.min(p1.size(), p2.size()); i++) {
+ int d;
+ d = indexOrder(p1.isArrayIndex(i), p2.isArrayIndex(i));
+ if (d != 0) {
+ return d;
+ Comparable<Object> e1 = (Comparable<Object>) p1.getElement(i);
+ Comparable<Object> e2 = (Comparable<Object>) p2.getElement(i);
+ if (p1.isArrayIndex(i)) {
+ if (e1.getClass() != e2.getClass()) {
+ d = e1.getClass().getName().compareTo(e2.getClass().getName());
+ if (d == 0) {
+ d = e1.compareTo(e2);
+ if (d != 0) {
+ return d;
+ //the longer one wins
+ return p1.size() - p2.size();
+ private int indexOrder(boolean i1, boolean i2) {
+ //it doesn't matter much what the order between indices and non-indices is,
+ //but it needs to be consistent
+ if (i1) {
+ if (!i2) {
+ return -1;
+ else {
+ if (i2) {
+ return 1;
+ return 0;
\ No newline at end of file
Added: trunk/src/org/griphyn/vdl/mapping/PathElementComparator.java
--- trunk/src/org/griphyn/vdl/mapping/PathElementComparator.java (rev 0)
+++ trunk/src/org/griphyn/vdl/mapping/PathElementComparator.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -0,0 +1,30 @@
+public class PathElementComparator implements Comparator<Comparable<?>> {
+ @Override
+ public int compare(Comparable<?> p1, Comparable<?> p2) {
+ Comparable<Object> e1 = (Comparable<Object>) p1;
+ Comparable<Object> e2 = (Comparable<Object>) p2;
+ int d = 0;
+ if (d == 0) {
+ return d;
Added: trunk/src/org/griphyn/vdl/mapping/PathParser.java
--- trunk/src/org/griphyn/vdl/mapping/PathParser.java (rev 0)
+++ trunk/src/org/griphyn/vdl/mapping/PathParser.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -0,0 +1,307 @@
+import java.util.ArrayList;
+import java.util.List;
+import org.griphyn.vdl.mapping.Path.Entry;
+public class PathParser {
+ private String str;
+ private int crt = 0;
+ public PathParser(String str) {
+ this.str = str;
+ * path = emptyPath | nonEmptyPath
+ * emptyPath = <nothing> | '$'
+ * nonEmptyPath = element['.' field|indexElement]*
+ * element = field | indexElement
+ * indexElement = '[' index ']'
+ * index = number | '"' string '"' | wildcard
+ * wildcard = '*'
+ * # TODO: this would need to be modified to include complex objects if
+ * # supported as array keys
+ * number = [+|-]('.' digit+)|(digit+['.' digit+])
+ * digit = '0' - '9'
+ * string = (character | escapeSequence)*
+ * escapeSequence = '\' ('\' | '"' | 'n' | 't')
+ * id = idFirstChar [idChar]
+ * idFirstChar = 'a' - 'z' | 'A' - 'Z' | '_'
+ * idChar = idFirstChar | digit
+ public Path parse() {
+ return path();
+ private Path path() {
+ if (str.length() == 0 || str.equals("$")) {
+ return Path.EMPTY_PATH;
+ else {
+ return nonEmptyPath();
+ private Path nonEmptyPath() {
+ List<Path.Entry> l = new ArrayList<Path.Entry>();
+ l.add(element());
+ while (!done()) {
+ if (matchChar('[')) {
+ l.add(arrayElement());
+ else {
+ expect('.');
+ l.add(field());
+ return new Path(l);
+ private Entry element() {
+ return arrayElement();
+ else {
+ return field();
+ private Entry field() {
+ return new Path.Entry(id(), false);
+ private Entry arrayElement() {
+ Path.Entry index = index();
+ expect(']');
+ return index;
+ private Comparable<?> id() {
+ int start = crt;
+ expectIdFirstChar();
+ while (idChar()) {
+ crt++;
+ return str.substring(start, crt);
+ private boolean idChar() {
+ if (crt >= str.length()) {
+ return false;
+ char c = str.charAt(crt);
+ return isLetter(c) || c == '_' || isDigit(c);
+ private void expectIdFirstChar() {
+ checkCrt();
+ if (isLetter(c) || (c == '_')) {
+ crt++;
+ else {
+ throw invalidPath("Unexpected character '" + c + "'");
+ private boolean isLetter(char c) {
+ return (c >= 'a' && c <= 'z') || (c >= 'A' && c <= 'Z');
+ private boolean isDigit(char c) {
+ return (c >= '0' && c <= '9');
+ private Path.Entry index() {
+ if (matchChar('"')) {
+ String s = string();
+ expect('"');
+ return new Path.Entry(s, true);
+ else if (matchChar('*')) {
+ return new Path.Entry.Wildcard();
+ else {
+ return new Path.Entry(number(), true);
+ private String string() {
+ while (!matchChar('"')) {
+ checkCrt();
+ char c = str.charAt(crt++);
+ if (c == '\\') {
+ checkCrt();
+ c = str.charAt(crt++);
+ switch(c) {
+ case '"':
+ c = '"';
+ break;
+ case '\\':
+ c = '\\';
+ break;
+ case 'n':
+ c = '\n';
+ break;
+ case 't':
+ c = '\t';
+ break;
+ default:
+ throw invalidPath("Illegal escape sequence '\\" + c + "'");
+ sb.append(c);
+ crt--;
+ private Comparable<?> number() {
+ checkCrt();
+ int start = crt;
+ skip('-');
+ skip('+');
+ boolean fp = false;
+ if (matchChar('.')) {
+ fp = true;
+ digits();
+ else {
+ digits();
+ fp = true;
+ digits();
+ if (fp) {
+ return Double.parseDouble(str.substring(start, crt));
+ else {
+ return Integer.parseInt(str.substring(start, crt));
+ private void digits() {
+ checkCrt();
+ if (!isDigit(c)) {
+ throw invalidPath("Expected digit but got '" + c + "'");
+ while (crt < str.length() && isDigit(str.charAt(crt))) {
+ crt++;
+ private void expect(char c) {
+ checkCrt();
+ if (!matchChar(c)) {
+ throw invalidPath("Expected '" + c + "'");
+ private boolean matchChar(char c) {
+ if (crt < str.length() && str.charAt(crt) == c) {
+ crt++;
+ return true;
+ else {
+ return false;
+ private void skip(char c) {
+ crt++;
+ private void checkCrt() {
+ throw new PathParsingException("Premature end of path");
+ private boolean done() {
+ return crt >= str.length();
+ private PathParsingException invalidPath(String msg) {
+ return new PathParsingException(msg + " in \"" + str + "\" col " + (crt + 1));
+ private static int failed, total;
+ public static void main(String[] args) {
+ testCorrect("a");
+ testCorrect("a.b");
+ testCorrect("a[0]");
+ testCorrect("a[1.0]");
+ testCorrect("a.b.c");
+ testCorrect("a[\"string\"].c");
+ testCorrect("a[123].b[\"123\"].d");
+ testCorrect("[\"str\\\"rts\"]");
+ testCorrect("x[-.23]");
+ testCorrect("[*]");
+ testInvalid("b.-");
+ testInvalid("a[1");
+ testInvalid("a[\"aa]");
+ testInvalid("[\"invalid\\escape\"]");
+ System.out.println("Total tests: " + total + ", failed tests: " + failed);
+ private static void testInvalid(String p) {
+ total++;
+ try {
+ System.out.print(p + ":");
+ System.out.print(spaces(32 - p.length()));
+ System.out.println("FAILED: " + new PathParser(p).parse().stringForm());
+ failed++;
+ catch (PathParsingException e) {
+ System.out.println("OK: " + e.getMessage());
+ private static void testCorrect(String p) {
+ total++;
+ try {
+ Path pp = new PathParser(p).parse();
+ if (pp.equals(new PathParser(pp.stringForm()).parse())) {
+ System.out.println("OK: " + pp.stringForm());
+ else {
+ System.out.println("FAILED2: " + pp.stringForm());
+ System.out.println("FAILED: " + e.getMessage());
+ failed++;
+ private static String spaces(int count) {
+ for (int i = 0; i < count; i++) {
+ sb.append(' ');
Added: trunk/src/org/griphyn/vdl/mapping/PathParsingException.java
--- trunk/src/org/griphyn/vdl/mapping/PathParsingException.java (rev 0)
+++ trunk/src/org/griphyn/vdl/mapping/PathParsingException.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -0,0 +1,17 @@
+public class PathParsingException extends RuntimeException {
+ public PathParsingException(String msg) {
+ super(msg);
Modified: trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -54,7 +54,7 @@
try {
mapper = MapperFactory.getMapper(desc, params);
- getField().setName(PARAM_PREFIX.getStringValue(mapper));
+ getField().setId(PARAM_PREFIX.getStringValue(mapper));
initialized();
checkInputs();
Modified: trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/RootDataNode.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/mapping/RootDataNode.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -61,7 +61,7 @@
try {
// initialized means that this data has its mapper initialized
// this should be called before checkInputs because the latter
// may trigger calls to things that try to access this data node's
@@ -150,15 +150,6 @@
// any number of indices is ok
try {
for (DSHandle dh : handle.getFields(Path.CHILDREN)) {
- Path path = dh.getPathFromRoot();
- String index = path.getElement(path.size() - 1);
- try {
- catch (NumberFormatException nfe) {
- throw new RuntimeException("Array element has index '" + index
- + "' that does not parse as an integer.");
checkConsistency(dh);
Modified: trunk/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -2,6 +2,8 @@
import java.io.File;
import java.io.FilenameFilter;
+import java.security.MessageDigest;
+import java.security.NoSuchAlgorithmException;
@@ -9,6 +11,7 @@
+import org.globus.cog.util.Base64;
import org.griphyn.vdl.mapping.AbsFile;
import org.griphyn.vdl.mapping.AbstractMapper;
@@ -117,21 +120,37 @@
int level = 0, tokenCount = path.size();
while (pi.hasNext()) {
Path.Entry nextPathElement = (Path.Entry) pi.next();
- String token = nextPathElement.getName();
if (nextPathElement.isIndex()) {
- if(logger.isDebugEnabled())
- logger.debug("Mapping path component index "+token);
- String f = getElementMapper().mapIndex(Integer.parseInt(token));
- logger.debug("field is mapped to: "+f);
- sb.append(f);
+ Comparable<?> key = nextPathElement.getKey();
+ String f, token;
+ if (key instanceof Integer) {
+ token = key.toString();
+ f = getElementMapper().mapIndex(((Integer) key).intValue());
+ else if (key instanceof Double) {
+ token = Double.toHexString(((Double) key).doubleValue());
+ f = getElementMapper().mapField(token);
+ else {
+ MessageDigest md = getDigest();
+ byte[] buf = md.digest(key.toString().getBytes());
+ token = encode(buf);
+ logger.debug("Mapping path component to " + token);
+ sb.append(f);
else {
- logger.debug("Mapping path component field "+token);
+ String token = (String) nextPathElement.getKey();
+ logger.debug("Mapping path component field " + token);
String f = getElementMapper().mapField(token);
+ logger.debug("field is mapped to: " + f);
sb.append(f);
@@ -151,19 +170,39 @@
if (suffix != null) {
sb.append(suffix);
- logger.debug("mapper id="+this.hashCode()+" finished mapping "+path+" to "+sb.toString());
+ logger.debug("mapper id=" + this.hashCode() + " finished mapping "
+ + path + " to " + sb.toString());
return new AbsFile(sb.toString());
- public Collection existing() {
+ private String encode(byte[] buf) {
+ buf = Base64.encode(buf);
+ char[] c = new char[buf.length];
+ for (int i = 0; i < buf.length; i++) {
+ c[i] = (char) buf[i];
+ return String.copyValueOf(c);
+ private MessageDigest getDigest() {
+ try {
+ return MessageDigest.getInstance("SHA-1");
+ catch (NoSuchAlgorithmException e) {
+ throw new Error("JVM error: SHA-1 not available");
+ public Collection<Path> existing() {
logger.debug("list existing paths for mapper id="+this.hashCode());
final String location = PARAM_LOCATION.getStringValue(this);
final String prefix = PARAM_PREFIX.getStringValue(this);
final String suffix = PARAM_SUFFIX.getStringValue(this);
final String pattern = PARAM_PATTERN.getStringValue(this);
- List l = new ArrayList();
+ List<Path> l = new ArrayList<Path>();
final AbsFile f;
if (location == null) {
f = new AbsFile(".");
@@ -286,7 +325,7 @@
protected Path rmapElement(Path path, String e) {
if (Character.isDigit(e.charAt(0))) {
- return path.addLast(String.valueOf(getElementMapper().rmapIndex(e)), true);
+ return path.addLast(getElementMapper().rmapIndex(e), true);
else {
return path.addLast(getElementMapper().rmapField(e));
Modified: trunk/src/org/griphyn/vdl/mapping/file/AirsnMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/AirsnMapper.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/mapping/file/AirsnMapper.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -29,7 +29,7 @@
else {
path = path.addLast("v");
- Integer.valueOf(tok.substring(tok.length() - 4)).toString(), true);
+ Integer.valueOf(tok.substring(tok.length() - 4)), true);
else {
Modified: trunk/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -31,7 +31,7 @@
Set<?> s = m.keySet();
Iterator<?> i = s.iterator();
while(i.hasNext()) {
- String nextKey = i.next().toString();
+ Comparable<?> nextKey = (Comparable<?>) i.next();
l.add(Path.EMPTY_PATH.addLast(nextKey, true));
return l;
Modified: trunk/src/org/griphyn/vdl/mapping/file/CSVMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/CSVMapper.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/mapping/file/CSVMapper.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -158,7 +158,7 @@
int ii = 0;
while (itl.hasNext()) {
Path path = Path.EMPTY_PATH;
- path = path.addFirst(String.valueOf(ii), true);
+ path = path.addFirst(ii, true);
List colContent = (List) itl.next();
Iterator itc = colContent.iterator();
int j = 0;
@@ -184,16 +184,16 @@
readFile();
- Iterator pi = path.iterator();
- Path.Entry pe = (Path.Entry) pi.next();
+ Iterator<Path.Entry> pi = path.iterator();
+ Path.Entry pe = pi.next();
if (!pe.isIndex()) {
return null;
int i = 0;
- try {
- i = Integer.parseInt(pe.getName());
+ if (pe.getKey() instanceof Integer) {
+ i = ((Integer) pe.getKey()).intValue();
+ else {
return null;
if (i > content.size()) {
@@ -208,8 +208,8 @@
return new AbsFile((String) cl.get(0));
- pe = (Path.Entry) pi.next();
- String col = pe.getName();
+ pe = pi.next();
+ String col = String.valueOf(pe.getKey());
if (!colindex.containsKey(col)) {
return null;
Modified: trunk/src/org/griphyn/vdl/mapping/file/FileSystemArrayMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/FileSystemArrayMapper.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/mapping/file/FileSystemArrayMapper.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -8,17 +8,16 @@
public class FileSystemArrayMapper extends AbstractFileMapper {
- private Map filenames = new HashMap();
+ private Map<Object, String> filenames = new HashMap<Object, String>();
private int count = 0;
public Path rmap(String name) {
if (name == null || name.equals("")) {
return null;
- String index = String.valueOf(count);
- filenames.put(index, name);
+ filenames.put(count, name);
Path p = Path.EMPTY_PATH;
- p = p.addFirst(index, true);
+ p = p.addFirst(count, true);
++count;
return p;
@@ -31,8 +30,8 @@
return null;
- String index = path.getFirst();
- String filename = (String)filenames.get(index);
+ Object index = path.getFirst();
+ String filename = filenames.get(index);
if (filename == null) {
return null;
Modified: trunk/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -42,10 +42,10 @@
return (String[]) PARAM_FILES.getValue(this);
for (int i = 0; i < getFiles().length; i++) {
- l.add(Path.EMPTY_PATH.addLast(String.valueOf(i), true));
+ l.add(Path.EMPTY_PATH.addLast(i, true));
return l;
@@ -55,8 +55,14 @@
throw new IllegalArgumentException(path.toString());
else {
- return new AbsFile(getFiles()[index]);
+ Object o = path.getFirst();
+ if (o instanceof Integer) {
+ int index = ((Integer) o).intValue();
+ return new AbsFile(getFiles()[index]);
+ else {
+ throw new IllegalArgumentException("The fixed array mapper can only be used with an int key array");
Modified: trunk/src/org/griphyn/vdl/mapping/file/ROIMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/ROIMapper.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/mapping/file/ROIMapper.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -38,9 +38,10 @@
String tok = st.nextToken();
if (i == 1 && tok.equals("ROI")) {
path = path.addLast("roi");
- if (notseen)
+ if (notseen) {
idx = new Integer(count);
- path = path.addLast(idx.toString(), true);
+ path = path.addLast(idx, true);
if (st.hasMoreElements()) {
i++;
continue;
Modified: trunk/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -44,7 +44,7 @@
Collection output = new ArrayList();
Collection sourceFields;
try {
- sourceFields = sourceHandle.getFields(Path.parse("[*]"));
+ sourceFields = sourceHandle.getFields(Path.CHILDREN);
return Collections.EMPTY_LIST;
Modified: trunk/src/org/griphyn/vdl/type/Field.java
--- trunk/src/org/griphyn/vdl/type/Field.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/type/Field.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -7,13 +7,13 @@
* get the name of the field
* @return
- public String getName();
+ public Comparable<?> getId();
* set the name of the field
- public void setName(String name);
+ public void setId(Comparable<?> id);
* get the type of the field
@@ -38,8 +38,8 @@
return new FieldImpl();
- public static Field createField(String name, Type type) {
- return new FieldImpl(name, type);
+ public static Field createField(Comparable<?> id, Type type) {
+ return new FieldImpl(id, type);
Modified: trunk/src/org/griphyn/vdl/type/Type.java
--- trunk/src/org/griphyn/vdl/type/Type.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/type/Type.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -52,7 +52,7 @@
public URI getNamespaceURI();
boolean isArray();
* Returns true if this type is a composite type (array or struct).
@@ -134,7 +134,7 @@
* This method returns the type of the array consisting of elements of this
- * type.*
+ * type and integer keys.
Type arrayType();
@@ -143,6 +143,11 @@
* If t is a type, t == t.arrayType().itemType();
Type itemType();
+ * For an array, this returns the array key type
+ Type keyType();
* A factory class with static methods for creating instances of Type.
Modified: trunk/src/org/griphyn/vdl/type/Types.java
--- trunk/src/org/griphyn/vdl/type/Types.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/type/Types.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -2,31 +2,97 @@
import java.util.HashMap;
+import org.griphyn.vdl.type.impl.TypeImpl.Array;
public abstract class Types {
//TODO: check namespace references in type definitions
private static Map<String, Type> types =
new HashMap<String, Type>();
+ public synchronized static boolean isValidType(String name, Set<String> validTypes) {
+ if (validTypes.contains(name) || types.containsKey(name)) {
+ return true;
+ else {
+ String[] names = getArrayTypeNames(name);
+ if (names == null) {
+ return false;
+ else {
+ return isValidType(names[0], validTypes) && isValidType(names[1], validTypes);
+ private static String[] getArrayTypeNames(String name) {
+ if(name.endsWith("]")) {
+ int index = name.lastIndexOf('[');
+ if (index == -1) {
+ throw new RuntimeException("Malformed type name: " + name);
+ String keyTypeName = name.substring(index + 1, name.length() - 1);
+ String baseTypeName = name.substring(0, index);
+ if (keyTypeName.equals("")) {
+ keyTypeName = "int";
+ return new String[] {baseTypeName, keyTypeName};
+ else {
+ return null;
+ private static String getArrayComponentTypeName(String name, int index) {
+ return null;
+ else {
+ return names[index];
+ public static String normalize(String t) {
+ String[] names = getArrayTypeNames(t);
+ return t;
+ else {
+ return normalize(names[0]) + "[" + names[1] + "]";
+ public static String getArrayItemTypeName(String name) {
+ return getArrayComponentTypeName(name, 0);
+ public static String getArrayIndexTypeName(String name) {
+ return getArrayComponentTypeName(name, 1);
public synchronized static Type getType(String name) throws NoSuchTypeException {
- Type type = (Type) types.get(name);
+ Type type = types.get(name);
if (type == null) {
- if(name.endsWith("[]")) {
- String base = name.substring(0, name.length() - 2);
- Type baseType = getType(base);
- Type arrayType = baseType.arrayType();
+ if (names != null) {
+ Type baseType = getType(names[0]);
+ Type keyType = getType(names[1]);
+ Type arrayType = new Array(baseType, keyType);
addType(arrayType);
return arrayType;
- } else {
- throw new NoSuchTypeException(name);
+ else {
+ throw new NoSuchTypeException(name);
else {
return type;
public static boolean isPrimitive(String name) {
try {
Type t = getType(name);
@@ -48,7 +114,7 @@
return type;
- public static final Type INT, STRING, FLOAT, BOOLEAN, ANY, EXTERNAL;
+ public static final Type INT, STRING, FLOAT, BOOLEAN, ANY, EXTERNAL, AUTO;
// add built-in primitive types
static {
@@ -58,13 +124,14 @@
BOOLEAN = addPrimitiveType("boolean");
ANY = addPrimitiveType("any");
EXTERNAL = addPrimitiveType("external");
+ AUTO = addPrimitiveType("auto");
public synchronized static void resolveTypes() throws NoSuchTypeException {
Map<String, Type> typesCopy =
new HashMap<String, Type>(types);
for (Map.Entry<String, Type> e : typesCopy.entrySet()) {
- Type type = (Type) e.getValue();
+ Type type = e.getValue();
for (Field field : type.getFields()) {
Type resolved = getType(field.getType().getName());
field.setType(resolved);
Modified: trunk/src/org/griphyn/vdl/type/impl/FieldImpl.java
--- trunk/src/org/griphyn/vdl/type/impl/FieldImpl.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/type/impl/FieldImpl.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -4,31 +4,31 @@
public class FieldImpl implements Field {
- private String name = null;
- private Type type = null;
+ private Comparable<?> id;
+ private Type type;
private boolean array = false;
public FieldImpl() {
- public FieldImpl(String name, Type type, boolean array) {
- this.name = name;
+ public FieldImpl(Comparable<?> id, Type type, boolean array) {
+ this.id = id;
this.type = type;
this.array = array;
- public FieldImpl(String name, Type type) {
- this.name = name;
+ public FieldImpl(Comparable<?> id, Type type) {
+ this.id = id;
this.type = type;
this.array = false;
- return name;
+ public Comparable<?> getId() {
+ return id;
- public void setName(String name) {
- this.name = name;
+ public void setId(Comparable<?> id) {
+ this.id = id;
Modified: trunk/src/org/griphyn/vdl/type/impl/TypeImpl.java
--- trunk/src/org/griphyn/vdl/type/impl/TypeImpl.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/type/impl/TypeImpl.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -9,12 +9,13 @@
import org.griphyn.vdl.type.DuplicateFieldException;
import org.griphyn.vdl.type.Field;
+import org.griphyn.vdl.type.Types;
public class TypeImpl extends UnresolvedType {
private boolean primitive;
- private Map fields;
+ private Map<String, Field> fields;
private Type baseType;
public TypeImpl() {
this((URI) null, null, false);
@@ -31,7 +32,7 @@
private void init(boolean primitive) {
this.primitive = primitive;
- fields = new HashMap();
+ fields = new HashMap<String, Field>();
baseType = null;
@@ -44,9 +45,10 @@
public void addField(Field field) throws DuplicateFieldException {
- if (name == null)
+ if (name == null) {
return;
if (fields.get(name) != null) {
throw new DuplicateFieldException(name);
@@ -65,7 +67,7 @@
throw new NullPointerException();
- Field field = (Field) fields.get(name);
+ Field field = fields.get(name);
if (field != null) {
return field;
@@ -74,8 +76,8 @@
- public List getFieldNames() {
- ArrayList list = new ArrayList();
+ public List<String> getFieldNames() {
+ List<String> list = new ArrayList<String>();
list.addAll(fields.keySet());
return list;
@@ -83,13 +85,13 @@
public List<Field> getFields() {
return new ArrayList<Field>(fields.values());
- public Type getBaseType() {
+ public Type getBaseType() {
return baseType;
public Type arrayType() {
- return new Array(this);
+ return new Array(this, Types.INT);
public Type itemType() {
@@ -113,15 +115,17 @@
return isArray() || !fields.isEmpty();
- private static class Array extends TypeImpl {
+ public static class Array extends TypeImpl {
private Field field;
+ private Type keyType;
/** Constructs an array that will contain elements of the
specified type. */
- public Array(Type type) {
- super(type.getNamespaceURI(), type.getName()+"[]", false);
+ public Array(Type valueType, Type keyType) {
+ super(valueType.getNamespaceURI(), valueType.getName()+"[" + keyType.getName() + "]", false);
field = Field.Factory.newInstance();
- field.setType(type);
+ field.setType(valueType);
+ this.keyType = keyType;
@@ -141,5 +145,9 @@
return field.getType();
+ public Type keyType() {
+ return keyType;
Modified: trunk/src/org/griphyn/vdl/type/impl/UnresolvedType.java
--- trunk/src/org/griphyn/vdl/type/impl/UnresolvedType.java 2011-07-24 04:43:21 UTC (rev 4834)
+++ trunk/src/org/griphyn/vdl/type/impl/UnresolvedType.java 2011-07-24 23:04:11 UTC (rev 4835)
@@ -46,6 +46,10 @@
throw new UnsupportedOperationException();
+ throw new UnsupportedOperationException();
@@ -62,7 +66,7 @@
public List getFields() {
throw new UnsupportedOperationException("addField");
return name;
More information about the Swift-commit
