[Swift-commit] r4832 - trunk/tests
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Thu Jul 21 10:33:26 CDT 2011
Author: wozniak
Date: 2011-07-21 10:33:26 -0500 (Thu, 21 Jul 2011)
New Revision: 4832
Modified:
   trunk/tests/suite.sh
Log:
Fix COLORIZE test
Modified: trunk/tests/suite.sh
--- trunk/tests/suite.sh	2011-07-19 20:23:41 UTC (rev 4831)
+++ trunk/tests/suite.sh	2011-07-21 15:33:26 UTC (rev 4832)
@@ -97,7 +97,7 @@
   HTML_COMMENTS=1
 fi
-if [ $COLORIZE ]; then
+if (( $COLORIZE )); then
 	LGREEN="\033[1;32m"
 	YELLOW="\033[1;33m"
 	RED="\033[1;31m"
@@ -411,7 +411,7 @@
   echo "| $G"
   echo "|"
   echo -e "\\----------------------------------------------------${GRAY}"
-  echo
+  echo
   if [ $TEXTREPORT == 1 ]; then
   	  stars
 	  printf "$G\n">>$REPORT
@@ -426,7 +426,7 @@
 	  html "$G"
 	  html_~th
 	  html_~tr
 	 html_tr group
 	 html_td
 	 html "#"
@@ -684,7 +684,7 @@
   rm killed_test > /dev/null 2>&1 && sleep 5
   verbose "killing monitor: $MONITOR_PID..."
   kill $MONITOR_PID
   INDIVIDUAL_TEST_TIME=$(( STOP-START ))
   TOTAL_TIME=$(( INDIVIDUAL_TEST_TIME+TOTAL_TIME ))
   echo -e "${YELLOW}TOOK (seconds): $INDIVIDUAL_TEST_TIME${GRAY}"
@@ -725,9 +725,9 @@
 stage_files() {
 	GROUP=$1
 	NAME=$2
 	RESULT="None"
 	if [ -f $GROUP/$NAME.in ]; then
 		echo "Copying input: $NAME.in"
 		cp -v $GROUP/$NAME.in . 2>&1 >> $OUTPUT
@@ -749,18 +749,18 @@
 			RESULT="Passed"
 		fi
 	done
 	output_report test "s" "setup" $RESULT
 	check_bailout
 check_outputs() {
 	GROUP=$1
 	NAME=$2
 	RESULT="None"
 	for EXPECTED in $GROUP/$NAME.*.expected; do
 		BNE=`basename $EXPECTED .expected`
 		echo -n "Checking output: $BNE "
@@ -775,15 +775,15 @@
 			RESULT="Passed"
 		fi
 	done
 	if [ "$RESULT" == "None" ]; then
 		html_td width 25
    		html "  "
    		html_~td
 	fi
 	output_report test "√" "check" $RESULT
 	check_bailout
@@ -791,7 +791,7 @@
 swift_test_case() {
   SWIFTSCRIPT=$1
   NAME=${SWIFTSCRIPT%.swift}
   SETUPSCRIPT=$NAME.setup.sh
   CHECKSCRIPT=$NAME.check.sh
   CLEANSCRIPT=$NAME.clean.sh
@@ -804,12 +804,12 @@
   else
     stage_files $GROUP $NAME
   fi
   ARGS=""
   if [ -f $GROUP/$ARGSFILE ]; then
   	ARGS=`cat $GROUP/$ARGSFILE`
   fi
   CDM=
   [ -r fs.data ] && CDM="-cdm.file fs.data"
@@ -848,9 +848,9 @@
 script_test_case() {
   SHELLSCRIPT=$1
