[Swift-commit] r4814 - SwiftApps/GOSwift/pykoa/tools
jonmon at ci.uchicago.edu
Mon Jul 11 13:37:06 CDT 2011
Author: jonmon
Date: 2011-07-11 13:37:06 -0500 (Mon, 11 Jul 2011)
New Revision: 4814
Modified:
SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
Log:
goswift now creates and stores the proxy information(I think).
Modified: SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
--- SwiftApps/GOSwift/pykoa/tools/koa_goswift.py 2011-07-11 13:49:07 UTC (rev 4813)
+++ SwiftApps/GOSwift/pykoa/tools/koa_goswift.py 2011-07-11 18:37:06 UTC (rev 4814)
@@ -1,33 +1,29 @@
#!/usr/bin/python
import commands
+import readline
import os
+import re
import sys
-import uuid
+import subprocess
import datetime
-import readline
-import time
-import signal
-from optparse import OptionGroup
from sqlalchemy.sql import text
import pykoa
import pykoa.tools
-from pykoa.constants import GroupStatusCodes as grpc
+from pykoa.process_observer import ProcessObserver
+from pykoa.signal_util import BlockInterrupt, enable_sigint
+from pykoa.tools import url_parse, myproxy
+from pykoa.tools import koa_transfer
+from pykoa.tools.koa_ep_activate import check_explicit_activate
from pykoa.consumers import guc_util
-from pykoa.koaexception import ToolsException, cli_exception_handler
-from pykoa.tools.url_parse import SCPUrl
-from pykoa.tools.koa_ep_activate import check_explicit_activate
-from pykoa.tools import koa_cancel
-from pykoa.tools import koa_transfer
-from pykoa.tools import myproxy
-from pykoa.tools import koa_wait
-from pykoa.data import groups_dao
+from pykoa.constants import get_scheme
+from pykoa.lib.mlsd import MLSDEntry
from pykoa.data import endpoint_dao
from pykoa.data import creds_dao
-from pykoa.data import preflight_dao
+from pykoa.koaexception import ToolsException, cli_exception_handler
def setup_opts(argv):
# Set up help message
help_screen = """ \
@@ -52,6 +48,10 @@
help="Set the time limit for this workflow. " + \
"Default: 30m (30 minutes)")
+ parser.add_option("-g", dest="gsi_activation",
+ default=False, action="store_true",
+ help="Use gsi-ssh delegated credential")
(options, args) = pykoa.tools.parse_args(parser, argv)
return (parser, options, args)
@@ -221,20 +221,121 @@
config_file.close()
script_file.close()
- # Execute the script
- os.chdir( swift_dir+'/'+run_directory )
- ( status, output ) = commands.getstatusoutput( home+'/swift-0.92/bin/swift -sites.file sites.xml -tc.file tc -config cf script.swift' )
- sys.stdout.write( "\nSwift output: " + output + "\n" )
- sys.stdout.write( "Swift exit status: " + str(status) + "\n" )
+ # A logical endpoint (no dots) can be a scp like path, if it has a :
+ if re.match("^[^.]+:", args[0]):
+ url = url_parse.SCPUrl(args[0], allow_empty_path=True)
+ url.update_relative_path()
+ else:
+ url = url_parse.TransferURL(args[0])
+ src_url = None
+ src_cred = None
+ default_myproxy = None
+ ep = None
+ myproxy_host = None
+ if not url.scheme:
+ # See if it's a logical endpoint
+ ep = endpoint_dao.get_logical_by_name(conn, user_id, url.name)
+ if not ep:
+ ep = endpoint_dao.get_public_by_name(conn, url.name)
+ if ep:
+ default_myproxy = ep.myproxy_server
+ # Get first physical ep, if exists
+ phys = endpoint_dao.get_physicals_for_logical(conn, ep.id)
+ if not phys:
+ raise ToolsException("No physical server exists for '%s'" % (
+ url.name))
+ phys = phys[0]
+ scheme = get_scheme(phys.xfer_service_id)
+ src_url = "%s://%s:%d%s" % (scheme, phys.hostname, phys.port, url.path)
+ src_subject = phys.x509_dn
+ # See if LTA endpoint is connected
+ if phys.is_lta and phys.alive == 0:
+ raise ToolsException("The requested Globus Connect endpoint is not currently connected to Globus Online")
+ # Get creds
+ row = creds_dao.get_cred_for_logical(conn, user_id, ep.id)
+ if row and row.exp_time > datetime.datetime.utcnow():
+ src_cred = row.sec_info
+ if not src_url:
+ # Not a logical endpoint
+ if '.' not in url.name:
+ raise ToolsException('EEXIST_ENDPOINT', url.name)
+ url.scheme = "gsiftp"
+ if not url.port:
+ url.port = "2811"
+ src_url = url.full_name + url.path
+ src_subject = ""
+ src_cred = None
+ # Get creds
+ if options.gsi_activation:
+ if ep:
+ check_explicit_activate([ep])
+ cred_file = os.environ["X509_USER_PROXY"]
+ src_cred = open(cred_file).read()
+ elif myproxy_host or ((not src_cred) and default_myproxy):
+ if not myproxy_host:
+ myproxy_host = default_myproxy
+ if ep:
+ check_explicit_activate([ep], myproxy_host)
+ cred_file = myproxy.contact_myproxy_server(myproxy_host,
+ options.myproxy_user, options.myproxy_dn,
+ lifetime=options.myproxy_lifetime)
+ if not cred_file:
+ return 1
+ try:
+ if ep:
+ # Save cred to DB, re-entering passphrases is annoying
+ ep_cache = {'foo': ep.id}
+ koa_transfer.do_activate(conn, cred_file, ep_cache, user_id,
+ quiet=True)
+ finally:
+ os.unlink(cred_file)
+ if not src_cred:
+ raise ToolsException("A credential is needed. Try -g or -m.")
+ ret = execute_swift(user_id, options, src_url, src_cred, src_subject, swift_dir, run_directory, home)
# clean up
# os.remove( swift_dir + "/" + run_directory + "/tc" )
# os.remove( swift_dir + "/" + run_directory + "/sites.xml" )
# os.remove( swift_dir + "/" + run_directory + "/cf" )
# os.remove( swift_dir + "/" + run_directory + "/script.swift" )
- return 0
+ return ret
+def execute_swift(user_id, options, src_url, src_cred, src_subject, swift_dir, run_directory, home):
+ if src_subject:
+ os.environ['GLOBUS_FTP_CLIENT_TEST_SUBJECT'] = src_subject
+ if src_cred:
+ proxyfile = guc_util.sec_text_to_proxy_file(user_id, src_cred)
+ os.environ["X509_USER_CERT"] = proxyfile
+ os.environ["X509_USER_KEY"] = proxyfile
+ # Execute the script
+ os.chdir( swift_dir+'/'+run_directory )
+ ( status, output ) = commands.getstatusoutput( home+'/swift-0.92/bin/swift -sites.file sites.xml -tc.file tc -config cf script.swift' )
+ sys.stdout.write( "\nSwift output: " + output + "\n" )
+ sys.stdout.write( "Swift exit status: " + str(status) + "\n" )
+ if src_cred:
+ os.remove( proxyfile )
+ return status
if __name__ == "__main__":
rc = main()
sys.exit(rc)
More information about the Swift-commit
