[Swift-commit] r4812 - SwiftApps/GOSwift/pykoa/tools
jonmon at ci.uchicago.edu
Fri Jul 8 20:40:46 CDT 2011
Author: jonmon
Date: 2011-07-08 20:40:46 -0500 (Fri, 08 Jul 2011)
New Revision: 4812
Modified:
SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
Log:
o minor comment edits to the goswift command
o moved the check if the dry run option is set before files and run directory are created.
Modified: SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
--- SwiftApps/GOSwift/pykoa/tools/koa_goswift.py 2011-07-08 15:39:32 UTC (rev 4811)
+++ SwiftApps/GOSwift/pykoa/tools/koa_goswift.py 2011-07-09 01:40:46 UTC (rev 4812)
@@ -146,7 +146,7 @@
return script
-# Do not know what this syntax is but pops up in other pykoa_* files.
+# Do not know what this syntax is but pops up in other pykoa_* files, so I kept it
@cli_exception_handler
def main( argv=sys.argv[1:] ):
(parser, options, args) = setup_opts(argv)
@@ -166,10 +166,11 @@
# get the swift input package
( tc, sites, config, script ) = parse_stdin()
- # write to appropriate files created in /home/jonmon/swift/$run_directory
+ # check to see is the swift directory has been created
if not os.access( '/home/jonmon/swift', os.F_OK ):
os.mkdir( '/home/jonmon/swift' )
+ # default is run.0, if there are other directories then adjust the run directory count
run_directory = 'run.0'
directories = os.listdir( '/home/jonmon/swift' )
@@ -179,15 +180,30 @@
directories.sort()
directories.reverse()
- # if the directories list is not empty
+ # if the directories list is not empty.
if directories:
last_directory = directories[ 0 ]
( run, sep, run_num ) = last_directory.partition( '.' )
run_directory = run + '.' + str( int ( run_num ) + 1 )
+ # get a space seperated String of the sites to execute on
+ execution_sites=" ".join( map ( str, args ) )
+ sys.stdout.write( "\nExecuting Swift on: " + execution_sites + "\n" )
+ sys.stdout.write( "Execution directory: swift/" + run_directory + "\n" )
+ # If I do not execute the script, just print out all important information
+ # useful to verify that the inputs to the Swift command line have been parsed correctly
+ if options.do_not_execute:
+ sys.stdout.write( "\nTC file: \n" + tc + "\n" )
+ sys.stdout.write( "SITES file: \n" + sites + "\n" )
+ sys.stdout.write( "CONFIG file: \n" + config + "\n" )
+ sys.stdout.write( "SWIFTSCRIPT file: \n" + script + "\n" )
+ sys.stdout.write( "swift -sites.file sites.xml -tc.file tc -config cf script.swift\n\n" )
+ return 0
+ # Set up for the acutal execution
os.mkdir( '/home/jonmon/swift/'+run_directory )
- # TODO: check for IOException and return error code for IOErrors
tc_file = open( '/home/jonmon/swift/'+run_directory+'/tc', 'w' )
sites_file = open( '/home/jonmon/swift/'+run_directory+'/sites.xml', 'w' )
config_file = open( '/home/jonmon/swift/'+run_directory+'/cf', 'w' )
@@ -203,21 +219,6 @@
config_file.close()
script_file.close()
- # get a space seperated String of the sites to execute on
- execution_sites=" ".join( map ( str, args ) )
- sys.stdout.write( "\nExecuting Swift on: " + execution_sites + "\n" )
- sys.stdout.write( "Execution directory: swift/" + run_directory + "\n" )
- # If I do not execute the script, just print out all important information
- # useful to verify that the inputs to the Swift command line have been parsed correctly
- if options.do_not_execute:
- sys.stdout.write( "\nTC file: \n" + tc + "\n" )
- sys.stdout.write( "SITES file: \n" + sites + "\n" )
- sys.stdout.write( "CONFIG file: \n" + config + "\n" )
- sys.stdout.write( "SWIFTSCRIPT file: \n" + script + "\n" )
- sys.stdout.write( "swift -sites.file sites.xml -tc.file tc -config cf script.swift\n\n" )
- return 0
# Execute the script
os.chdir( '/home/jonmon/swift/'+run_directory )
( status, output ) = commands.getstatusoutput( '/home/jonmon/swift-0.92/bin/swift -sites.file sites.xml -tc.file tc -config cf script.swift' )
More information about the Swift-commit
