[Swift-commit] r4796 - trunk/src/org/griphyn/vdl/mapping
hategan at ci.uchicago.edu
Thu Jul 7 13:25:08 CDT 2011
Author: hategan
Date: 2011-07-07 13:25:08 -0500 (Thu, 07 Jul 2011)
New Revision: 4796
Modified:
trunk/src/org/griphyn/vdl/mapping/AbsFile.java
Log:
implement hasCode and equals so that the garbage collector can properly check equality
Modified: trunk/src/org/griphyn/vdl/mapping/AbsFile.java
--- trunk/src/org/griphyn/vdl/mapping/AbsFile.java 2011-07-07 18:23:43 UTC (rev 4795)
+++ trunk/src/org/griphyn/vdl/mapping/AbsFile.java 2011-07-07 18:25:08 UTC (rev 4796)
@@ -7,8 +7,6 @@
import java.io.FilenameFilter;
import java.io.IOException;
import java.util.ArrayList;
-import java.util.Collection;
-import java.util.Iterator;
import java.util.List;
import org.globus.cog.abstraction.impl.common.task.ServiceContactImpl;
@@ -116,17 +114,14 @@
try {
FileResource fr = getFileResource();
try {
- List l = new ArrayList();
- Collection c = fr.list(path);
- Iterator i = c.iterator();
- while (i.hasNext()) {
- GridFile gf = (GridFile) i.next();
+ List<AbsFile> l = new ArrayList<AbsFile>();
+ for (GridFile gf : fr.list(path)) {
AbsFile f = new AbsFile(protocol, host, gf.getAbsolutePathName());
if (filter == null || filter.accept(new File(f.getDir()), f.getName())) {
l.add(f);
- return (AbsFile[]) l.toArray(FILE_ARRAY);
+ return l.toArray(FILE_ARRAY);
finally {
releaseResource(fr);
@@ -179,4 +174,20 @@
throw new RuntimeException(e);
+ @Override
+ public boolean equals(Object obj) {
+ if (obj instanceof AbsFile) {
+ AbsFile a = (AbsFile) obj;
+ return protocol.equals(a.protocol) && host.equals(a.host) && path.equals(a.path);
+ else {
+ return false;
+ @Override
+ public int hashCode() {
+ return protocol.hashCode() + host.hashCode() + path.hashCode();
More information about the Swift-commit
