[Swift-commit] r4793 - SwiftApps/GOSwift/pykoa/tools
jonmon at ci.uchicago.edu
Thu Jul 7 11:47:45 CDT 2011
Author: jonmon
Date: 2011-07-07 11:47:45 -0500 (Thu, 07 Jul 2011)
New Revision: 4793
Modified:
SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
Log:
o whitespace changes
Modified: SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
--- SwiftApps/GOSwift/pykoa/tools/koa_goswift.py 2011-07-07 16:45:50 UTC (rev 4792)
+++ SwiftApps/GOSwift/pykoa/tools/koa_goswift.py 2011-07-07 16:47:45 UTC (rev 4793)
@@ -79,7 +79,7 @@
tc = ""
for line in lines:
if line == "# begin tc":
begin_tc = True
@@ -89,7 +89,7 @@
elif begin_tc:
tc += line + "\n"
return tc
def extract_sites( lines ):
@@ -97,7 +97,7 @@
sites = ""
for line in lines:
if line == "# begin sites":
begin_sites = True
@@ -107,7 +107,7 @@
elif begin_sites:
sites += line + "\n"
return sites
def extract_config( lines ):
@@ -115,7 +115,7 @@
config = ""
for line in lines:
if line == "# begin config":
begin_config = True
@@ -125,7 +125,7 @@
elif begin_config:
config += line + "\n"
return config
def extract_script( lines ):
@@ -133,7 +133,7 @@
script = ""
for line in lines:
if line == "# begin script":
begin_script = True
@@ -143,7 +143,7 @@
elif begin_script:
script += line + "\n"
return script
# Do not know what this syntax is but pops up in other pykoa_* files.
@@ -186,7 +186,7 @@
run_directory = run + '.' + str( int ( run_num ) + 1 )
os.mkdir( '/home/jonmon/swift/'+run_directory )
# TODO: check for IOException and return error code for IOErrors
tc_file = open( '/home/jonmon/swift/'+run_directory+'/tc', 'w' )
sites_file = open( '/home/jonmon/swift/'+run_directory+'/sites.xml', 'w' )
More information about the Swift-commit
