[Swift-commit] r4789 - in trunk/src/org/griphyn/vdl: karajan/lib/swiftscript mapping
hategan at ci.uchicago.edu
Wed Jul 6 20:36:12 CDT 2011
Author: hategan
Date: 2011-07-06 20:36:11 -0500 (Wed, 06 Jul 2011)
New Revision: 4789
Modified:
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractInt.java
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FileName.java
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FnArg.java
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java
trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
Log:
fix NPE when provenance logging is requested (i.e. there are cases when data is not initialized properly leading to a state in getMapper() which triggers the NPE), and replace use of RootDataNode.newNode with a RootDataNode constructor
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractInt.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractInt.java 2011-07-07 01:33:24 UTC (rev 4788)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractInt.java 2011-07-07 01:36:11 UTC (rev 4789)
@@ -32,7 +32,7 @@
String str = breader.readLine();
freader.close();
Double i = new Double(str);
- DSHandle result = RootDataNode.newNode(Types.FLOAT, i);
+ DSHandle result = new RootDataNode(Types.FLOAT, i);
int provid = VDLFunction.nextProvenanceID();
VDLFunction.logProvenanceResult(provid, result, "extractint");
VDLFunction.logProvenanceParameter(provid, handle, "filename");
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FileName.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FileName.java 2011-07-07 01:33:24 UTC (rev 4788)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FileName.java 2011-07-07 01:36:11 UTC (rev 4789)
@@ -15,7 +15,7 @@
public Object function(VariableStack stack) throws ExecutionException {
String s = argList(filename(stack), true);
- DSHandle result = RootDataNode.newNode(Types.STRING, s);
+ DSHandle result = new RootDataNode(Types.STRING, s);
//VDLFunction.logProvenanceParameter(provid, (DSHandle) PA_VAR.getValue(stack), "input");
//VDLFunction.logProvenanceResult(provid, result, "filename");
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FnArg.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FnArg.java 2011-07-07 01:33:24 UTC (rev 4788)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FnArg.java 2011-07-07 01:36:11 UTC (rev 4789)
@@ -68,7 +68,7 @@
throw new ExecutionException("Missing command line argument: " + name);
else {
- DSHandle result = RootDataNode.newNode(Types.STRING, value);
+ DSHandle result = new RootDataNode(Types.STRING, value);
int provid=VDLFunction.nextProvenanceID();
VDLFunction.logProvenanceResult(provid, result, "arg");
VDLFunction.logProvenanceParameter(provid, P_NAME.getRawValue(stack), "name");
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java 2011-07-07 01:33:24 UTC (rev 4788)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java 2011-07-07 01:36:11 UTC (rev 4789)
@@ -15,7 +15,6 @@
import org.griphyn.vdl.karajan.lib.VDLFunction;
import org.griphyn.vdl.mapping.AbsFile;
import org.griphyn.vdl.mapping.AbstractDataNode;
-import org.griphyn.vdl.mapping.ArrayDataNode;
import org.griphyn.vdl.mapping.DSHandle;
import org.griphyn.vdl.mapping.InvalidPathException;
import org.griphyn.vdl.mapping.Path;
@@ -108,7 +107,7 @@
DSHandle handle = new RootDataNode(Types.STRING);
handle.setValue(buf.toString());
- handle.closeShallow();
try {
if(VDL2Config.getConfig().getProvenanceLog()) {
DSHandle[] provArgs = SwiftArg.VARGS.asDSHandleArray(stack);
@@ -381,7 +380,7 @@
n.waitFor();
String name = VDLFunction.filename(n)[0];
String result = new AbsFile(name).getDir();
- return RootDataNode.newNode(Types.STRING, result);
+ return new RootDataNode(Types.STRING, result);
@@ -394,7 +393,7 @@
public DSHandle swiftscript_length(VariableStack stack)
Map<?, ?> n = (Map<?, ?>) PA_ARRAY.getValue(stack);
- return RootDataNode.newNode(Types.INT, Integer.valueOf(n.size()));
+ return new RootDataNode(Types.INT, Integer.valueOf(n.size()));
public DSHandle swiftscript_existsfile(VariableStack stack)
Modified: trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java 2011-07-07 01:33:24 UTC (rev 4788)
+++ trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java 2011-07-07 01:36:11 UTC (rev 4789)
@@ -462,6 +462,7 @@
catch (FutureFault fe) {
m = null; // no mapping info if mapper isn't initialised yet
if (m != null) {
// TODO proper type here
// Not sure catching exception here is really the right thing to
Modified: trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java 2011-07-07 01:33:24 UTC (rev 4788)
+++ trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java 2011-07-07 01:36:11 UTC (rev 4789)
@@ -99,8 +99,12 @@
if (initialized) {
return mapper;
- assert(waitingMapperParam != null);
- throw new FutureNotYetAvailable(waitingMapperParam.getFutureWrapper());
+ if (waitingMapperParam == null) {
+ return null;
+ else {
+ throw new FutureNotYetAvailable(waitingMapperParam.getFutureWrapper());
public boolean isArray() {
Modified: trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/RootDataNode.java 2011-07-07 01:33:24 UTC (rev 4788)
+++ trunk/src/org/griphyn/vdl/mapping/RootDataNode.java 2011-07-07 01:36:11 UTC (rev 4789)
@@ -22,20 +22,13 @@
private Map<String, Object> params;
private AbstractDataNode waitingMapperParam;
- public static DSHandle newNode(Type type, Object value) {
- DSHandle handle = new RootDataNode(type);
- handle.setValue(value);
- logger.debug("newNode");
- return handle;
public RootDataNode(Type type) {
super(Field.Factory.createField(null, type));
public RootDataNode(Type type, Object value) {
this(type);
+ initialized();
setValue(value);
@@ -214,8 +207,12 @@
if (initialized) {
return mapper;
- assert (waitingMapperParam != null);
+ return null;
+ else {
@@ -230,5 +227,5 @@
private synchronized void initialized() {
initialized = true;
waitingMapperParam = null;
More information about the Swift-commit
