[Swift-commit] r4786 - in trunk: . docs/cookbook
wilde at ci.uchicago.edu wilde at ci.uchicago.edu
Wed Jul 6 17:54:21 CDT 2011
Author: wilde
Date: 2011-07-06 17:54:21 -0500 (Wed, 06 Jul 2011)
New Revision: 4786
Modified:
   trunk/build.xml
   trunk/docs/cookbook/cookbook-asciidoc.txt
Log:
Update build.xml to copy grid/ tools to bin, and initial cookbook page.
Modified: trunk/build.xml
--- trunk/build.xml	2011-07-06 22:41:37 UTC (rev 4785)
+++ trunk/build.xml	2011-07-06 22:54:21 UTC (rev 4786)
@@ -75,8 +75,10 @@
 		<copy todir="${dist.dir}/libexec">
 			<fileset dir="${cog.dir}/modules/${module.name}/libexec"/>
 		</copy>
-		<copy todir="${dist.dir}/bin">
-			<fileset dir="${cog.dir}/modules/${module.name}/bin"/>
+		<copy todir="${dist.dir}/bin" verbose="true" flatten="true">
+			<fileset dir="${cog.dir}/modules/${module.name}/bin">
+				<type type="file" />
+			</fileset>
 		</copy>
 		<copy todir="${dist.dir}/lib/perl">
 			<fileset dir="${cog.dir}/modules/${module.name}/lib/perl"/>
@@ -88,8 +90,39 @@
 		<chmod perm="+x" file="${dist.dir}/bin/swiftrun"/>
                 <chmod perm="+x" file="${dist.dir}/bin/gensites"/>
                 <chmod perm="+x" file="${dist.dir}/bin/chxml"/>
-                <chmod perm="+x" file="${dist.dir}/bin/start-coaster-service"/>
+                <chmod perm="+x" file="${dist.dir}/bin/foreachsite"/>
+                <chmod perm="+x" file="${dist.dir}/bin/gen_gridsites"/>
+                <chmod perm="+x" file="${dist.dir}/bin/get_greensites"/>
+                <chmod perm="+x" file="${dist.dir}/bin/start-swift-service"/>
+                <chmod perm="+x" file="${dist.dir}/bin/start-ranger-service"/>
+                <chmod perm="+x" file="${dist.dir}/bin/mk_osg_sitetest"/>
+                <chmod perm="+x" file="${dist.dir}/bin/nqueued"/>
+                <chmod perm="+x" file="${dist.dir}/bin/osgcat"/>
+                <chmod perm="+x" file="${dist.dir}/bin/mktcfrominst"/>
+                <chmod perm="+x" file="${dist.dir}/bin/start_services"/>
+                <chmod perm="+x" file="${dist.dir}/bin/workers.ranger.sh"/>
+                <chmod perm="+x" file="${dist.dir}/bin/worker.sh"/>
+                <chmod perm="+x" file="${dist.dir}/bin/swift-workers"/>
+                <chmod perm="+x" file="${dist.dir}/bin/run_workers"/>
+                <chmod perm="+x" file="${dist.dir}/bin/maketcfrominst"/>
+                <chmod perm="+x" file="${dist.dir}/bin/mk_catalog.rb"/>
+                <chmod perm="+x" file="${dist.dir}/bin/mk_cats.rb"/>
+                <chmod perm="+x" file="${dist.dir}/bin/ress.rb"/>
+                <chmod perm="+x" file="${dist.dir}/bin/ressfields"/>
+                <chmod perm="+x" file="${dist.dir}/bin/sites"/>
+                <chmod perm="+x" File="${dist.dir}/bin/start-coaster-service"/>
                 <chmod perm="+x" file="${dist.dir}/bin/stop-coaster-service"/>
 		<chmod perm="+x" file="${dist.dir}/libexec/log-processing/active-state-transitions"/>
 		<chmod perm="+x" file="${dist.dir}/libexec/log-processing/add-runid-as-prefix"/>
 		<chmod perm="+x" file="${dist.dir}/libexec/log-processing/affine-transform"/>
Modified: trunk/docs/cookbook/cookbook-asciidoc.txt
--- trunk/docs/cookbook/cookbook-asciidoc.txt	2011-07-06 22:41:37 UTC (rev 4785)
+++ trunk/docs/cookbook/cookbook-asciidoc.txt	2011-07-06 22:54:21 UTC (rev 4786)
@@ -1,5 +1,7 @@
 // To compile use: asciidoc -a toc -n cookbook-asciidoc.txt
+:numbered:
 Swift Cookbook
 Swift team <swift-user at ci.uchicago.edu>
