[Swift-commit] r4784 - SwiftApps/GOSwift/pykoa/tools
jonmon at ci.uchicago.edu
Tue Jul 5 22:51:52 CDT 2011
Author: jonmon
Date: 2011-07-05 22:51:52 -0500 (Tue, 05 Jul 2011)
New Revision: 4784
Modified:
SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
Log:
o swift now can be run on the vm through globusonline
Modified: SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
--- SwiftApps/GOSwift/pykoa/tools/koa_goswift.py 2011-07-05 22:26:56 UTC (rev 4783)
+++ SwiftApps/GOSwift/pykoa/tools/koa_goswift.py 2011-07-06 03:51:52 UTC (rev 4784)
@@ -1,4 +1,5 @@
#!/usr/bin/python
+import commands
import os
import sys
import uuid
@@ -172,12 +173,15 @@
# same time will screw everything to #
# fail. #
- # write to appropriate files created in /tmp
- tc_file = open( '/tmp/tc', 'w' )
- sites_file = open( '/tmp/sites.xml', 'w' )
- config_file = open( '/tmp/cf', 'w' )
- script_file = open( '/tmp/script.swift', 'w' )
+ # write to appropriate files created in /home/jonmon/swift
+ if not os.access( '/home/jonmon/swift', os.F_OK ):
+ os.mkdir( '/home/jonmon/swift' )
+ tc_file = open( '/home/jonmon/swift/tc', 'w' )
+ sites_file = open( '/home/jonmon/swift/sites.xml', 'w' )
+ config_file = open( '/home/jonmon/swift/cf', 'w' )
+ script_file = open( '/home/jonmon/swift/script.swift', 'w' )
tc_file.write( tc )
sites_file.write( sites )
config_file.write( config )
@@ -202,13 +206,16 @@
return 0
# Execute the script
+ os.chdir( '/home/jonmon/swift' )
+ ( status, output ) = commands.getstatusoutput( '/home/koa/swift-0.92/bin/swift -sites.file sites.xml -tc.file tc -config cf script.swift' )
+ sys.stdout.write( "Swift output: " + output + "\n" )
+ sys.stdout.write( "Swift exit status: " + str(status) + "\n" )
- # THIS SCRIPT DOES NOT HAVE PRIVALEDGES TO REMOVE FROM /tmp
# clean up
-# os.remove( "/tmp/tc" )
-# os.remove( "/tmp/sites.xml" )
-# os.remove( "/tmp/config" )
-# os.remove( "/tmp/script.swift" )
+ os.remove( "/home/jonmon/swift/tc" )
+ os.remove( "/home/jonmon/swift/sites.xml" )
+ os.remove( "/home/jonmon/swift/cf" )
+ os.remove( "/home/jonmon/swift/script.swift" )
return 0
More information about the Swift-commit
