[Swift-commit] r4774 - in trunk: resources src/org/griphyn/vdl/karajan/lib src/org/griphyn/vdl/mapping
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Tue Jul 5 15:41:06 CDT 2011
Author: hategan
Date: 2011-07-05 15:41:06 -0500 (Tue, 05 Jul 2011)
New Revision: 4774
Modified:
   trunk/resources/Karajan.stg
   trunk/src/org/griphyn/vdl/karajan/lib/InfiniteCountingWhile.java
   trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
Log:
fixed iterate to conform better to what one would expect from it
Modified: trunk/resources/Karajan.stg
--- trunk/resources/Karajan.stg	2011-07-05 20:40:07 UTC (rev 4773)
+++ trunk/resources/Karajan.stg	2011-07-05 20:41:06 UTC (rev 4774)
@@ -186,13 +186,7 @@
 iterate(declarations,statements,cond,var,cleanups) ::= <<
-<vdl:infinitecountingwhile>
-  <set names="\$\$">
-    <each items="{\$}"/>
-  </set>
-  <set name="$var$">
-    <vdl:new type="int" value="{\$\$}" />
-  </set>
+<vdl:infinitecountingwhile var="$var$">
   $sub_comp(declarations=declarations, statements=statements, cleanups=cleanups)$
   <sys:if>
     <vdl:getfieldvalue>$cond$</vdl:getfieldvalue>
Modified: trunk/src/org/griphyn/vdl/karajan/lib/InfiniteCountingWhile.java
--- trunk/src/org/griphyn/vdl/karajan/lib/InfiniteCountingWhile.java	2011-07-05 20:40:07 UTC (rev 4773)
+++ trunk/src/org/griphyn/vdl/karajan/lib/InfiniteCountingWhile.java	2011-07-05 20:41:06 UTC (rev 4774)
@@ -6,33 +6,34 @@
 package org.griphyn.vdl.karajan.lib;
-import java.util.Arrays;
+import java.util.Collections;
 import java.util.List;
+import org.globus.cog.karajan.arguments.Arg;
 import org.globus.cog.karajan.stack.VariableStack;
 import org.globus.cog.karajan.util.ThreadingContext;
-import org.globus.cog.karajan.util.TypeUtil;
-import org.globus.cog.karajan.workflow.Condition;
 import org.globus.cog.karajan.workflow.ExecutionException;
 import org.globus.cog.karajan.workflow.nodes.FlowElement;
 import org.globus.cog.karajan.workflow.nodes.Sequential;
 import org.globus.cog.karajan.workflow.nodes.While;
+import org.griphyn.vdl.mapping.RootDataNode;
+import org.griphyn.vdl.type.Types;
 public class InfiniteCountingWhile extends Sequential {
-	public static final String VAR = "##infinitecountingwhile:var";
+    public static final String COUNTER_NAME = "$";
+    public static final Arg.Positional VAR = new Arg.Positional("var");
 	public InfiniteCountingWhile() {
 		setOptimize(false);
 	public void pre(VariableStack stack) throws ExecutionException {
-		stack.setVar("#condition", new Condition());
 		ThreadingContext tc = (ThreadingContext)stack.getVar("#thread");
 		stack.setVar("#iteratethread", tc);
 		stack.setVar("#thread", tc.split(0));
-		stack.setVar(VAR, "$");
-		String counterName = (String)stack.getVar(VAR);
-		stack.setVar(counterName, Arrays.asList(new Integer[] {new Integer(0)}));
+		stack.setVar(COUNTER_NAME, Collections.singletonList(0));
+		stack.setVar((String) VAR.getStatic(this), new RootDataNode(Types.INT, 0.0));
 		super.pre(stack);
@@ -48,28 +49,23 @@
 		FlowElement fn = null;
-		Condition condition = (Condition) stack.getVar("#condition");
-		if (condition.getValue() != null) {
-			boolean cond = TypeUtil.toBoolean(condition.getValue());
-			if (!cond) {
-				post(stack);
-				return;
+		if (index == elementCount() - 1) {
+		    // the condition is always compiled as the last thing in the loop
+		    // but the increment needs to happen before the condition is
+		    // evaluated
+		    @SuppressWarnings("unchecked")
+		    List<Integer> c = (List<Integer>) stack.getVar(COUNTER_NAME);
+            int i = c.get(0).intValue();
+            i++;
+            ThreadingContext tc = (ThreadingContext)stack.getVar("#iteratethread");
+            stack.setVar("#thread", tc.split(i));
+            stack.setVar(COUNTER_NAME, Collections.singletonList(i));
+            stack.setVar((String) VAR.getStatic(this), new RootDataNode(Types.INT, Double.valueOf(i)));
 		if (index >= elementCount()) {
 			// starting new iteration
 			setIndex(stack, 1);
 			fn = getElement(0);
-			String counterName = (String) stack.getVar(VAR);
-			@SuppressWarnings("unchecked")
-            List<Integer> l = (List<Integer>) stack.getVar(counterName);
-			Integer wrappedi = l.get(0);
-			int i = wrappedi.intValue();
-			i++;
-			ThreadingContext tc = (ThreadingContext)stack.getVar("#iteratethread");
-			stack.setVar("#thread", tc.split(i));
-			stack.setVar(counterName, Arrays.asList(new Integer[] {new Integer(i)}));
 		else {
 			fn = getElement(index++);
Modified: trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/RootDataNode.java	2011-07-05 20:40:07 UTC (rev 4773)
+++ trunk/src/org/griphyn/vdl/mapping/RootDataNode.java	2011-07-05 20:41:06 UTC (rev 4774)
@@ -33,6 +33,11 @@
 	public RootDataNode(Type type) {
 		super(Field.Factory.createField(null, type));
+	public RootDataNode(Type type, Object value) {
+	    this(type);
+	    setValue(value);
 	public void init(Map<String,Object> params) {
 		this.params = params;
