[Swift-commit] r4771 - SwiftApps/GOSwift/pykoa/tools
jonmon at ci.uchicago.edu
Tue Jul 5 15:23:23 CDT 2011
Author: jonmon
Date: 2011-07-05 15:23:23 -0500 (Tue, 05 Jul 2011)
New Revision: 4771
Modified:
SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
Log:
o write the parsed information from stdin to individual to be used for execution. These files are written to /tmp
-- These files will not have unique names. Need to make the file names unique
-- I cannot remove them from /tmp in the python script. Need to think of an alternative place for them so /tmp will not fill up.
Modified: SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
--- SwiftApps/GOSwift/pykoa/tools/koa_goswift.py 2011-07-05 18:25:03 UTC (rev 4770)
+++ SwiftApps/GOSwift/pykoa/tools/koa_goswift.py 2011-07-05 20:23:23 UTC (rev 4771)
@@ -162,16 +162,40 @@
parser.print_help()
return 1
- ( tc, sites_file, config, script ) = parse_stdin()
+ # get the swift input package
+ ( tc, sites, config, script ) = parse_stdin()
+ # FIX: Must create a unique file. Multiple #
+ # runs using this will clober files. #
+ # Multiple calls to goswift at the #
+ # same time will screw everything to #
+ # fail. #
+ # write to appropriate files created in /tmp
+ tc_file = open( '/tmp/tc', 'w' )
+ sites_file = open( '/tmp/sites.xml', 'w' )
+ config_file = open( '/tmp/cf', 'w' )
+ script_file = open( '/tmp/script.swift', 'w' )
+ tc_file.write( tc )
+ sites_file.write( sites )
+ config_file.write( config )
+ script_file.write( script )
+ tc_file.close()
+ sites_file.close()
+ config_file.close()
+ script_file.close()
# get a space seperated list of the sites to execute on
- sites=" ".join( map ( str, args ) )
- sys.stdout.write( "\nExecuting Swift on: " + sites + "\n" )
+ execution_sites=" ".join( map ( str, args ) )
+ sys.stdout.write( "\nExecuting Swift on: " + execution_sites + "\n" )
# If I do not execute the script, just print out all pertatent information
if options.do_not_execute:
sys.stdout.write( "\nTC file: \n" + tc + "\n" )
- sys.stdout.write( "SITES file: \n" + sites_file + "\n" )
+ sys.stdout.write( "SITES file: \n" + sites + "\n" )
sys.stdout.write( "CONFIG file: \n" + config + "\n" )
sys.stdout.write( "SWIFTSCRIPT file: \n" + script + "\n" )
sys.stdout.write( "swift -sites.file sites.xml -tc.file tc -config cf script.swift\n\n" )
@@ -179,6 +203,13 @@
# Execute the script
+ # THIS SCRIPT DOES NOT HAVE PRIVALEDGES TO REMOVE FROM /tmp
+ # clean up
+# os.remove( "/tmp/tc" )
+# os.remove( "/tmp/sites.xml" )
+# os.remove( "/tmp/config" )
+# os.remove( "/tmp/script.swift" )
return 0
if __name__ == "__main__":
More information about the Swift-commit
