[Swift-commit] r4756 - in trunk/src/org/griphyn/vdl/karajan/lib: . swiftscript
hategan at ci.uchicago.edu
Sun Jul 3 19:21:48 CDT 2011
Author: hategan
Date: 2011-07-03 19:21:48 -0500 (Sun, 03 Jul 2011)
New Revision: 4756
Modified:
trunk/src/org/griphyn/vdl/karajan/lib/SwiftArg.java
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
Log:
fixed dirname()
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SwiftArg.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SwiftArg.java 2011-07-03 21:51:26 UTC (rev 4755)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SwiftArg.java 2011-07-04 00:21:48 UTC (rev 4756)
@@ -53,8 +53,12 @@
public Object getValue(VariableStack stack) throws ExecutionException {
Object v = super.getValue(stack);
- if(v == null) return v;
- else return unwrap(stack, super.getValue(stack));
+ if (v == null) {
+ return v;
+ else {
+ return unwrap(stack, super.getValue(stack));
public double getDoubleValue(VariableStack stack) throws ExecutionException {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java 2011-07-03 21:51:26 UTC (rev 4755)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java 2011-07-04 00:21:48 UTC (rev 4756)
@@ -1,6 +1,7 @@
package org.griphyn.vdl.karajan.lib.swiftscript;
import java.io.IOException;
+import java.util.Map;
import java.util.regex.Matcher;
import java.util.regex.Pattern;
@@ -378,11 +379,8 @@
public DSHandle swiftscript_length(VariableStack stack)
- AbstractDataNode n = (AbstractDataNode) PA_ARRAY.getValue(stack);
- n.waitFor();
- ArrayDataNode adn = (ArrayDataNode) n;
- return RootDataNode.newNode(Types.INT, Integer.valueOf(adn.size()));
+ Map<?, ?> n = (Map<?, ?>) PA_ARRAY.getValue(stack);
+ return RootDataNode.newNode(Types.INT, Integer.valueOf(n.size()));
public DSHandle swiftscript_existsfile(VariableStack stack)
More information about the Swift-commit
