[Swift-commit] r4750 - trunk/src/org/griphyn/vdl/engine
hategan at ci.uchicago.edu
Sun Jul 3 16:37:16 CDT 2011
Author: hategan
Date: 2011-07-03 16:37:16 -0500 (Sun, 03 Jul 2011)
New Revision: 4750
Modified:
trunk/src/org/griphyn/vdl/engine/Karajan.java
Log:
complain at compile time about uninitialized but used variables
Modified: trunk/src/org/griphyn/vdl/engine/Karajan.java
--- trunk/src/org/griphyn/vdl/engine/Karajan.java 2011-07-03 17:46:48 UTC (rev 4749)
+++ trunk/src/org/griphyn/vdl/engine/Karajan.java 2011-07-03 21:37:16 UTC (rev 4750)
@@ -7,10 +7,11 @@
import java.io.InputStreamReader;
import java.io.PrintStream;
import java.util.ArrayList;
-import java.util.LinkedList;
import java.util.Collection;
import java.util.HashMap;
import java.util.HashSet;
+import java.util.LinkedList;
+import java.util.List;
import java.util.Map;
import java.util.Set;
import java.util.StringTokenizer;
@@ -30,8 +31,6 @@
import org.apache.xmlbeans.XmlOptions;
import org.apache.xmlbeans.XmlString;
import org.globus.swift.language.*;
-import org.globus.swift.language.Variable.Mapping;
-import org.globus.swift.language.Variable.Mapping.Param;
import org.globus.swift.language.If.Else;
import org.globus.swift.language.If.Then;
import org.globus.swift.language.ImportsDocument.Imports;
@@ -40,8 +39,10 @@
import org.globus.swift.language.Switch.Default;
import org.globus.swift.language.TypesDocument.Types;
import org.globus.swift.language.TypesDocument.Types.Type;
+import org.globus.swift.language.Variable.Mapping;
+import org.globus.swift.language.Variable.Mapping.Param;
+import org.griphyn.vdl.karajan.CompilationException;
import org.griphyn.vdl.karajan.Loader;
-import org.griphyn.vdl.karajan.CompilationException;
import org.griphyn.vdl.toolkit.VDLt2VDLx;
import org.safehaus.uuid.UUIDGenerator;
import org.w3c.dom.Node;
@@ -57,6 +58,9 @@
Map<String,ProcedureSignature> functionsMap =
new HashMap<String,ProcedureSignature>();
Map<String,Type> typesMap = new HashMap<String,Type>();
+ List<StringTemplate> variables = new ArrayList<StringTemplate>();
+ Set<String> usedVariables = new HashSet<String>();
public static final String TEMPLATE_FILE_NAME = "Karajan.stg";
@@ -269,13 +273,35 @@
processProcedures(program, scope);
for (Program program : importList)
statements(program, scope);
+ checkUninitializedVariables();
generateInternedConstants(scope.bodyTemplate);
return scope.bodyTemplate;
- public void procedure(Procedure proc, VariableScope containingScope) throws CompilationException {
+ private void checkUninitializedVariables() throws CompilationException {
+ for (StringTemplate var : variables) {
+ String name = (String) var.getAttribute("name");
+ if (var.getAttribute("waitfor") == null) {
+ if (usedVariables.contains(name)) {
+ if (org.griphyn.vdl.type.Types.isPrimitive((String) var.getAttribute("type"))) {
+ throw new CompilationException("Uninitalized variable: " + name);
+ else {
+ logger.info("Unused variable " + name);
+ private void setVariableUsed(String s) {
+ usedVariables.add(s);
+ public void procedure(Procedure proc, VariableScope containingScope) throws CompilationException {
VariableScope outerScope = new VariableScope(this, containingScope, VariableScope.ENCLOSURE_PROCEDURE);
VariableScope innerScope = new VariableScope(this, outerScope, VariableScope.ENCLOSURE_NONE);
StringTemplate procST = template("procedure");
@@ -340,6 +366,7 @@
variableST.setAttribute("name", var.getName());
variableST.setAttribute("type", var.getType().getLocalPart());
variableST.setAttribute("isGlobal", Boolean.valueOf(var.getIsGlobal()));
+ variables.add(variableST);
if(!var.isNil()) {
@@ -1095,6 +1122,8 @@
if(!scope.isVariableDefined(s)) {
throw new CompilationException("Variable " + s + " is undefined.");
+ setVariableUsed(s);
StringTemplate st = template("id");
st.setAttribute("var", s);
String actualType;
@@ -1272,7 +1301,7 @@
// which shows Compiler Exception and line number of error
- void checkTypesInCondExpr(String op, String left, String right, StringTemplate st)
+ void checkTypesInCondExpr(String op, String left, String right, StringTemplate st)
if (left.equals(right))
st.setAttribute("datatype", "boolean");
More information about the Swift-commit
