[Swift-commit] r4743 - trunk/src/org/griphyn/vdl/mapping/file
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sat Jul 2 23:12:38 CDT 2011
Author: hategan
Date: 2011-07-02 23:12:37 -0500 (Sat, 02 Jul 2011)
New Revision: 4743
Modified:
   trunk/src/org/griphyn/vdl/mapping/file/SimpleFileMapper.java
Log:
reverted previous change to the simple_mapper; it broke the fmri test and didn't really conform to what the documentation was saying (i.e. it couldn't map arrays of strucs)'
Modified: trunk/src/org/griphyn/vdl/mapping/file/SimpleFileMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/SimpleFileMapper.java	2011-07-03 02:37:10 UTC (rev 4742)
+++ trunk/src/org/griphyn/vdl/mapping/file/SimpleFileMapper.java	2011-07-03 04:12:37 UTC (rev 4743)
@@ -4,72 +4,19 @@
 package org.griphyn.vdl.mapping.file;
 import java.util.Map;
-import java.util.HashMap;
-import org.griphyn.vdl.mapping.Path;
-import org.griphyn.vdl.mapping.PhysicalFormat;
-import org.griphyn.vdl.mapping.AbsFile;
 import org.griphyn.vdl.mapping.MappingParam;
 public class SimpleFileMapper extends AbstractFileMapper {
 	public static final MappingParam PARAM_PADDING = new MappingParam("padding", new Integer(4));
-	private Map filenames = new HashMap();
-	private int count = 0;
-        private String isinput;
 	public SimpleFileMapper() {
 		super();
 	public void setParams(Map params) {
 		super.setParams(params);
 		int precision = PARAM_PADDING.getIntValue(this);
 		setElementMapper(new DefaultFileNameElementMapper(precision));
-		this.isinput = (String)params.get("input");
-    //all input filesnames will be parsed as strings and given numeric index
-	public Path rmap(String name) {
-	    if(this.isinput == null){
-		return super.rmap(name);
-		if (name == null || name.equals("")) {
-			return null;
-		String index = String.valueOf(count);
-		filenames.put(index, name);
-		Path p = Path.EMPTY_PATH;
-		p = p.addFirst(index, true);
-		++count;
-		return p;
-	public PhysicalFormat map(Path path) {
-		return super.map(path);
-		if (path.size()!=1) {
-			return null;
-		if (!path.isArrayIndex(0)) {
-			return null;
-		String location = PARAM_LOCATION.getStringValue(this);
-		String index = path.getFirst();
-		String filename = (String)filenames.get(index);
-		if (filename == null) {
-			return null;
-		if (location != null) {
-			if (!location.endsWith("/")) {
-				filename = location + '/' + filename;
-			} else {
-				filename = location + filename;
-		return new AbsFile(filename);
