[Swift-commit] r4043 - in SwiftApps/SwiftR/Swift: . R exec man
Fri Jan 28 15:12:17 CST 2011
Author: tga
Date: 2011-01-28 15:12:17 -0600 (Fri, 28 Jan 2011)
New Revision: 4043
Modified:
   SwiftApps/SwiftR/Swift/DESCRIPTION
   SwiftApps/SwiftR/Swift/R/Swift.R
   SwiftApps/SwiftR/Swift/R/Workers.R
   SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh
   SwiftApps/SwiftR/Swift/exec/start-swift
   SwiftApps/SwiftR/Swift/man/Swift-package.Rd
Log:
* Moved tests to separate file
* Now cleans up swift server directory by default when done.
Modified: SwiftApps/SwiftR/Swift/DESCRIPTION
--- SwiftApps/SwiftR/Swift/DESCRIPTION	2011-01-27 23:29:10 UTC (rev 4042)
+++ SwiftApps/SwiftR/Swift/DESCRIPTION	2011-01-28 21:12:17 UTC (rev 4043)
@@ -1,8 +1,8 @@
 Package: Swift
 Type: Package
 Title: R interface to Swift parallel scripting languaage
-Version: 0.1.1
-Date: 2010-02-25
+Version: 0.1.2
+Date: 2010-02-28
 Author: Michael Wilde
 Maintainer: Michael Wilde <wilde at mcs.anl.gov>
 Description: Routines to invoke R functions on remote resources through Swift.
Modified: SwiftApps/SwiftR/Swift/R/Swift.R
--- SwiftApps/SwiftR/Swift/R/Swift.R	2011-01-27 23:29:10 UTC (rev 4042)
+++ SwiftApps/SwiftR/Swift/R/Swift.R	2011-01-28 21:12:17 UTC (rev 4043)
@@ -230,6 +230,7 @@
   names(rlist) = names(arglists)
   if( ! keepwork ) {
+    cat("Removing ", reqdir, "\n")
     unlink(reqdir,recursive=TRUE)
   return(rlist)
@@ -246,462 +247,3 @@
   names(arglists) = names(tlist)
   swiftapply(func, arglists)
-#* checking R code for possible problems ... NOTE
-#swiftapply: no visible binding for '<<-' assignment to 'swiftprops'
-#swiftapply: no visible binding for global variable 'swiftprops'
-#swiftapply: no visible binding for global variable 'result'
-#------------------ Tests moved here from test dir:
-initSwiftTestOptions <- function()
-  options(swift.site="service")
-  options(swift.keepwork=TRUE)
-  initcmds <- "initVar1 <<- 19; initVar2 <<- sqrt(400)+3"
-  options(swift.initialexpr=initcmds) # Set here; used in test group 4
-swiftTest_1.1 <- function()
-  initSwiftTestOptions()
-  cat("\n*** Starting  test 1.1 ***\n\n")
-  sumstuff <- function(treedata,cardata) { sum( treedata$Height, cardata$dist ) }
-  data(cars)
-  data(trees)
-  args=list(trees,cars)
-  arglist = rep(list(args),1)
-  cat("Test of local do.call(sumstuff)\n")
-  localres = do.call(sumstuff,args)
-  cat("local result=\n")
-  print(localres)
-  cat("\nTest of swiftapply(sumstuff,arglist)\n")
-  swiftres = swiftapply(sumstuff,arglist)
-  cat("Swift result:\n")
-  print(swiftres)
-  if(identical(localres,swiftres[[1]])) {
-    cat("\n==> test 1.1 passed\n")
-  } else {
-    cat("\n==> test 1.1 FAILED !!!!!\n")
-basicSwiftTest <- function() { swiftTest_1.1() }
-# .... more tests from below to move here
-swiftTest_4.1 <- function()
-  sumivars <- function() { initVar1+initVar2 }
-  args=list()
-  localres = 42
-  cat("\nTest of swiftapply(sumivars,arglist)\n")
-  swiftres = swiftapply(sumivars,arglist)
-  print(swiftres)
-    cat("\n==> test 4.1 passed\n")
-  } else {
-    cat("\n==> test 4.1 FAILED !!!!!\n")
-swiftTest_4.2 <- function()
-  options(swift.initialexpr="initVar3 <<- 123; initVar4 <<- 100");
-  mulivars <- function() { initVar3*initVar4 }
-  args=list()
-  localres = 12300;
-  cat("\nTest of swiftapply(mulivars,arglist)\n")
-  swiftres = swiftapply(mulivars,arglist)
-  print(swiftres)
-    cat("\n==> test 4.2 passed\n")
-  } else {
-    cat("\n==> test 4.2 FAILED !!!!!\n")
-# Performance tests
-swiftTest_6.1 <- function(delay,ncalls)
-  timed <- function(delay) { Sys.sleep(delay); delay }
-  args=list(delay)
-  arglist = rep(list(args),ncalls)
-  cat("\nTest of swiftapply(delay,arglist)\n")
-  startTime = proc.time()[["elapsed"]]
-  swiftres = swiftapply(timed,arglist)
-  endTime = proc.time()[["elapsed"]]
-  runTime <- endTime - startTime
-  cat("\n\n ===> Total elapsed unit test time = ",runTime," seconds.\n\n")
-  print(swiftres[[1]])
-  if(identical(delay,swiftres[[1]])) {
-    cat("\n==> test 6.1 passed\n")
-  } else {
-    cat("\n==> test 6.1 FAILED !!!!!\n")
-runAllSwiftTests <- function()
-    # Launch workerif nothing already running
-    # testPid will be NULL if nothihg launched
-    testPid <- tryCatch(
-            (function() { swiftapply(log, list(list(1)),quiet=TRUE) ;
-                          return(NULL); })(),
-            error=function(x) {swiftInit();})
-    ### FIXME: Save prior options here: restore them when tests are done.
-    ### Recovery if interrrupted?
-    failures=0
-    cat("\n*** Starting test group 1 - functions on simple data structures ***\n\n")
-    swiftTest_1.1()
-    ##### Test 1.2
-    # test 10 remote calls
-    data(cars)
-    data(trees)
-    arglist <- rep(list(args),10)
-    cat("\n*** Test 1.2.1: 10 calls to substuff()\n")
-    swiftres <- swiftapply(sumstuff,arglist)
-    format(swiftres)
-    diffs <- 0
-    for(i in 1:length(swiftres) ) {
-      if( !identical(swiftres[[i]],localres) ) {
-        diffs <- diffs + 1
-        if( diffs < 10 ) cat(sprintf("res[%d]=%s\n",i,format( swiftres[[i]] )))
-    if(diffs == 0) {
-      cat("\n==> test 1.2.1 passed\n")
-    } else {
-      cat("\n!!!==> test 1.2.1 failed.\n")
-      cat(sprintf(" %d result elements failed to match.\n",diffs));
-      failures=failures+1
-    cat("\n*** Test 1.2.2: 10 calls to substuff() - callsperbatch=10\n")
-    swiftres = swiftapply(sumstuff,arglist,callsperbatch=10)
-    format(swiftres)
-    diffs <- 0
-    if(diffs == 0) {
-      cat("\n==> test 1.2.2 passed\n")
-    } else {
-      cat("\n!!!==> test 1.2.2 failed.\n")
-    cat("\n*** Test 1.2.3: 10 calls to substuff() - callsperbatch=2\n")
-    swiftres = swiftapply(sumstuff,arglist,callsperbatch=2)
-    format(swiftres)
-    diffs <- 0
-        if( diffs < 10 ) cat(sprintf("res[%d]=%s\n",i, format( swiftres[[i]] )))
-    if(diffs == 0) {
-      cat("\n==> test 1.2.3 passed\n")
-    } else {
-      cat("\n!!!==> test 1.2.3 failed.\n")
-    cat("\n*** Test 1.2.4: 10 calls to substuff() - callsperbatch=3\n")
-    swiftres = swiftapply(sumstuff,arglist,callsperbatch=3)
-    format(swiftres)
-    diffs <- 0
-        if( diffs < 10 ) cat(sprintf("res[%d]=%d\n",i, format( swiftres[[i]] )))
-    if(diffs == 0) {
-      cat("\n==> test 1.2.4 passed\n")
-    } else {
-      cat("\n!!!==> test 1.2.4 failed.\n")
-    # swiftres = swiftapply(sumstuff,arglist,callsperbatch=2,site="pbs")
-    # test variations on local vs ssh vs pbs; coasters vs non; etc.
-    ##### Test Group  2
-    cat("\n*** Starting test group 2 - test matrix passing***\n")
-    matfunc <- function( m1, m2 )
-      (1/m1) %*% m2
-    n <- 5
-    m1 <- array(sin(1:n**2), dim=c(n,n))
-    m2 <- t(m1)
-    localres = matfunc(m1,m2)
-    cat("\n*** Test 2.1: 100 calls to matfunc(dim=5x5) - callsperbatch=9\n")
-    args=list(m1,m2)
-    arglist <- rep(list(args),100)
-    swiftres = swiftapply(matfunc,arglist,callsperbatch=9)
-    diffs <- 0
-    #for(i in 1:length(swiftres) ) {
-    for(i in c(seq(1,100,10),100)) {
-      if( !all.equal(swiftres[[i]],localres) ) {
-        if( diffs < 10 ) cat(sprintf("res[%d]=%s\n",i,format(swiftres[[i]])))
-    if(diffs == 0) {
-      cat("\n==> test 2.1 passed\n")
-    } else {
-      cat("\n!!!==> test 2.2 failed.\n")
-    n <- 237
-    n <- 50
-    m2 <- t(m1)
-    cat("\n*** Test 2.2: 123 calls to matfunc(dim=bigger) - callsperbatch=7\n") # FIXME make n easy to adjust and print actual value
-    args=list(m1,m2)
-    arglist <- rep(list(args),123)
-    swiftres = swiftapply(matfunc,arglist,callsperbatch=7)
-    diffs <- 0
-    for(i in c(seq(1,length(swiftres),10),length(swiftres))) {
-    if(diffs == 0) {
-      cat("\n==> test 2.2 passed\n")
-    } else {
-    ##### Test Group 3
-    cat("\n*** Starting test group 3 - test list element and name passing***\n")
-    # Test if list element names are being sent and returned correctly
-    n <- 5
-    m2 <- t(m1)
-    inlist = list()
-    inlist[[1]]=123
-    inlist[[2]]=456
-    inlist$name1=789
-    inlist$name2=987
-    inlist$mat1 =  m1
-    inlist[[99]] = m2
-    listfunc <- function(ilist)
-      olist = ilist
-      olist$sum = ilist[[1]] + ilist[[2]] + ilist$name1 + ilist$name2
-      olist$names = names(ilist)
-      olist$mprod = ilist$mat1 %*% ilist[[99]]
-      return(olist)
-    localres = listfunc(inlist)
-    cat("\n*** Starting test 3.1 - 4 calls in one batch of 5 ***\n")
-    args=list(inlist)
-    arglist <- rep(list(args),4)
-    swiftres = swiftapply(listfunc,arglist,callsperbatch=5)
-    diffs <- 0
-        if( diffs < 10 ) cat(sprintf("res[%d=%s\n",i,format(swiftres[[i]])))
-    if(diffs == 0) {
-      cat("\n==> test 3.1 passed\n")
-    } else {
-      cat("\n!!!==> test 3.1 failed.\n")
-    cat("\n*** Starting test 3.2 - 99 calls in batches of 11 ***\n")
-    args=list(inlist)
-    arglist <- rep(list(args),99)
-    swiftres = swiftapply(listfunc,arglist,callsperbatch=11)
-    diffs <- 0
-    if(diffs == 0) {
-      cat("\n==> test 3.2 passed\n")
-    } else {
-      cat("\n!!!==> test 3.2 failed.\n")
-    ##### Test Group 4 # test initialexpr string
-    cat("\n*** Starting test group 4 - test remote R service initialization string ***\n")
-    swiftTest_4.1()
-    swiftTest_4.2()
-    ##### Test Group 5 # test error handling
-    cat("\n*** Starting test group 5 - test remote R service error ***\n")
-    arglist = list(list(1.0),list(2.0),list("3.0"),list(4.0),list(5.0))
-    swiftres = swiftapply(log,arglist)
-    print(swiftres)
-    goodres = c("numeric","numeric","try-error","numeric","numeric")
-    diffs <- 0
-      if( class(swiftres[[i]]) != goodres[i] ) {
-    if(diffs == 0) {
-      cat("\n==> test 5.1 passed\n")
-    } else {
-      cat("\n!!!==> test 5.1 failed.\n")
-    endTime <- proc.time()[["elapsed"]]
-    cat("\n\n ===> Total elapsed test time = ",runTime," seconds.\n\n")
-    if (!is.null(testPid))
-        swiftShutdown(testPid)
-} # end function runAllTests
-#options(swift.site="local")
-#runAllTests()
-testloop <- function(npass)
-  for(i in 1:npass) {
-    cat("\n\n\n ***** Starting test pass ", i, " ***** \n\n\n");
-    runAllSwiftTests()
-    cat("\n\n\n ***** Completed test pass ", i, " ***** \n\n\n");
-    system("sleep 3")
Modified: SwiftApps/SwiftR/Swift/R/Workers.R
--- SwiftApps/SwiftR/Swift/R/Workers.R	2011-01-27 23:29:10 UTC (rev 4042)
+++ SwiftApps/SwiftR/Swift/R/Workers.R	2011-01-28 21:12:17 UTC (rev 4043)
@@ -6,7 +6,7 @@
                     parEnv=NULL, workmode=NULL,
                     throttle=NULL, queue=NULL,
                     rcmd=NULL, time=NULL,
-                    workerLogging=NULL )
+                    workerLogging=NULL,keepworkdir=NULL)
     # server: which server backend to use to acquire workers
     #           for example, local runs tasks on the local machine
@@ -121,6 +121,10 @@
         cmdString <- paste(cmdString, "-w", shQuote(workerLogging))
+    if(is.null(keepworkdir))
+        keepworkdir <- getOption("swift.keepworkdir")
+    if(!is.null(keepworkdir) && keepworkdir)
+        cmdString <- paste(cmdString, "-k")
     # launch asynchronously
Modified: SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh
--- SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh	2011-01-27 23:29:10 UTC (rev 4042)
+++ SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh	2011-01-28 21:12:17 UTC (rev 4043)
@@ -128,4 +128,4 @@
 echo DB: Freed $SLOTDIR/mutex
-# Fixme: how to get exceptions and stdout/stderr text from R server ???
\ No newline at end of file
+# Fixme: how to get exceptions and stdout/stderr text from R server ???
Modified: SwiftApps/SwiftR/Swift/exec/start-swift
--- SwiftApps/SwiftR/Swift/exec/start-swift	2011-01-27 23:29:10 UTC (rev 4042)
+++ SwiftApps/SwiftR/Swift/exec/start-swift	2011-01-28 21:12:17 UTC (rev 4043)
@@ -5,13 +5,6 @@
 export TRAPEVENTS="EXIT 1 2 3 15"  # Signals and conditions to trap
-# Standard clenuup actions
-function stdcleanup {
-    # don't accept any more requests: unlink fifo from filesystem
-    if [ -p requestpipe ]; then
-        rm requestpipe
-    fi
 # Define internal functions
@@ -280,7 +273,8 @@
     echo Started workers from batch job $(cat $jobidfile)
   else
     echo Batch queue submission failed, exiting.
-    stdcleanup
+    stdcleanup_start
+    stdcleanup_end
     exit 1
   fi
@@ -346,6 +340,7 @@
    -s server   local       local, pbs, sge, ssh, pbsf (for firewalled worker nodes)
    -t time     00:30:00    hh:mm:ss, for PBS and SGE only
    -w wkloglvl NONE        NONE, ERROR, WARN, INFO, DEBUG, TRACE
+   -k keepdir              No argument, if flag is set, will keep working directory
     Examples:
@@ -380,6 +375,7 @@
 project=NONE
 parEnv=NONE
 workerLogging=ERROR
+keepdir=FALSE
 rcmd=ssh      # rcmd: ssh (typical) or qrsh (eg for siraf with node login restrictions)
 workmode=slot # slot: start one worker on each slot; node: start one worker for all slots on a node
@@ -399,6 +395,7 @@
     -s) server=$2; verify-is-one-of server $server local ssh pbs pbsf sge; shift ;;
     -t) time=$2; verify-not-null time $time; shift ;;
     -w) workerLogging=$2; verify-is-one-of workerLoggingLevel $workerLogging NONE ERROR WARN INFO DEBUG TRACE; shift ;;
+    -k) keepdir=TRUE ;;
     *)  usage; exit 1 ;;
   esac
   shift
@@ -410,10 +407,28 @@
 rundir=$tmp/$USER/SwiftR/swift.$server  # rundir prefix # FIXME: handle multiple concurent independent swift servers per user
 mkdir -p $(dirname $rundir)
 trundir=$(mktemp -d $rundir.XXXX) # FIXME: check success
-rm -rf $rundir
+rm -f $rundir
 ln -s $trundir $rundir
-cd $rundir
+cd $trundir
+# Standard clenuup actions
+function stdcleanup_start {
+    # don't accept any more requests: unlink fifo from filesystem
+    if [ -p requestpipe ]; then
+        rm requestpipe
+    fi
+function stdcleanup_end {
+    # Check to see if we should leave
+    # logs, etc around
+    if [ "$keepdir" = "FALSE" ]; then
+        cd /
+        rm -rf "$trundir"
+    fi
 echo Running in $trundir "(linked to $rundir)"
 script=$SWIFTRBIN/rserver.swift
@@ -443,7 +458,7 @@
   source $SWIFTRBIN/configure-server-local $cores
   function onexit {
-    stdcleanup
+    stdcleanup_start
     # Find and terminate R workers: they should register their PiD
     # in a standard location based on the pid of this start-swift
     # script
@@ -452,6 +467,7 @@
         kill `cat $rwork/R.pid` &> /dev/null
         rm -rf $rwork
     done
+    stdcleanup_end
     exit 0
@@ -473,7 +489,7 @@
   function onexit {
-    stdcleanup
+    stdcleanup_start
     coasterservicepid="" # null: saved in case we go back to using coaster servers
     trap - $TRAPEVENTS
     sshpids=$(cat $sshpidfile)
@@ -488,6 +504,7 @@
     if [ "_$sshpids$starterpid$coasterservicepid" != _ ]; then
       echo kill $sshpids $starterpid $coasterservicepid >& /dev/null
     fi
+    stdcleanup_end
     # exit cleanly
     exit 0
@@ -511,7 +528,7 @@
   function onexit {
-    stdcleanup
+    stdcleanup_start
     trap - $TRAPEVENTS
@@ -524,6 +541,7 @@
       qdel "$jobid"
     fi
     # eit cleanly
+    stdcleanup_end
     exit 0
Modified: SwiftApps/SwiftR/Swift/man/Swift-package.Rd
--- SwiftApps/SwiftR/Swift/man/Swift-package.Rd	2011-01-27 23:29:10 UTC (rev 4042)
+++ SwiftApps/SwiftR/Swift/man/Swift-package.Rd	2011-01-28 21:12:17 UTC (rev 4043)
@@ -27,8 +27,8 @@
 \tabular{ll}{
 Package: \tab Swift\cr
 Type: \tab Package\cr
-Version: \tab 0.1.1\cr
-Date: \tab 2011-01-26\cr
+Version: \tab 0.1.2\cr
+Date: \tab 2011-01-28\cr
 License: \tab Globus Toolkit Public License v3 (based on Apache License 2.0):
 http://www.globus.org/toolkit/legal/4.0/license-v3.html \cr
 LazyLoad: \tab yes\cr
