[Swift-commit] r4023 - usertools/plotter/src
noreply at svn.ci.uchicago.edu
Fri Jan 21 11:40:42 CST 2011
Author: wozniak
Date: 2011-01-21 11:40:42 -0600 (Fri, 21 Jan 2011)
New Revision: 4023
Removed:
usertools/plotter/src/Bits.java
usertools/plotter/src/LineReader.java
usertools/plotter/src/Lines.java
usertools/plotter/src/Util.java
Log:
Moving src files
Deleted: usertools/plotter/src/Bits.java
--- usertools/plotter/src/Bits.java 2011-01-21 17:39:55 UTC (rev 4022)
+++ usertools/plotter/src/Bits.java 2011-01-21 17:40:42 UTC (rev 4023)
@@ -1,149 +0,0 @@
-import java.math.BigInteger;
-import java.util.*;
- * Provides random bits, statically.
- * Kills VM exit code 2 on misuse.
-public class Bits
- public static Random rng = null;
- static boolean locked = false;
- static boolean ready = false;
- If not locked, seed the generator with the clock.
- public static void init()
- init(System.currentTimeMillis());
- If not locked, seed the generator with the clock mod 1000.
- Useful for debugging.
- @param print If true, print the seed.
- public static long init(boolean print)
- long seed = System.currentTimeMillis() % 1000;
- init(seed);
- if (print)
- System.out.println("Bits.seed: " + seed);
- return seed;
- @param seed The seed.
- public static void init(long seed)
- assert (!locked) : "Bits locked!";
- // System.out.println("Seeding RNG...");
- rng = new Random(seed);
- ready = true;
- Lock the generator to prevent seeding
- public static void lock()
- locked = true;
- Unlock the generator
- public static void unlock()
- locked = false;
- public static double nextDouble()
- if (! ready)
- System.err.println("Bits not ready!");
- System.exit(2);
- return rng.nextDouble();
- public static double nextDouble(double d)
- return rng.nextDouble() * d;
- public static int nextInt()
- if (! ready)
- System.exit(2);
- return rng.nextInt();
- Return a integer in [0..t).
- public static int nextInt(int t)
- double d = nextDouble();
- int i = (new Double(d * t)).intValue();
- return i;
- public static boolean nextBoolean()
- if (! ready)
- System.exit(2);
- return rng.nextBoolean();
- public static long nextLong()
- if (! ready)
- System.exit(2);
- return rng.nextLong();
- public static long nextLong(long t)
- long i = (new Double(d * t)).longValue();
- return i;
- public static BigInteger nextBigInteger(BigInteger i)
- if (i.equals(BigInteger.ZERO))
- return BigInteger.ZERO;
- int b = i.bitLength()+1;
- BigInteger result;
- do
- result = BigInteger.valueOf(b);
- } while (result.compareTo(i) >= 0);
- return result;
- public static void nextBytes(byte[] bytes)
- rng.nextBytes(bytes);
Deleted: usertools/plotter/src/LineReader.java
--- usertools/plotter/src/LineReader.java 2011-01-21 17:39:55 UTC (rev 4022)
+++ usertools/plotter/src/LineReader.java 2011-01-21 17:40:42 UTC (rev 4023)
@@ -1,156 +0,0 @@
- * Utility to read a file into a List of String lines.
- * Omits comments with #
- * Wraps lines that end on backslash
-public class LineReader
- LineReader()
- public static List<String> read(java.io.File file)
- throws java.io.FileNotFoundException
- java.io.BufferedReader reader =
- new java.io.BufferedReader(new java.io.FileReader(file));
- return read(reader);
- public static List<String> read(String s)
- new java.io.BufferedReader(new java.io.StringReader(s));
- public static List<String> read(java.io.BufferedReader reader)
- List<String> result = new ArrayList<String>();
- try
- String prevline = "";
- String line = "";
- while ((line = reader.readLine()) != null)
- int hash = line.indexOf("#");
- if (hash >= 0)
- line = line.substring(0,hash);
- line = spaces(line);
- line = (prevline + " " + line).trim();
- if (line.endsWith("\\"))
- line = line.substring(0, line.length()-2);
- prevline = line;
- continue;
- else
- prevline = "";
- line = line.trim();
- if (line.length() > 0)
- result.add(line);
- reader.close();
- catch (java.io.IOException e)
- System.out.println("LineReader: I/O problem.");
- return null;
- return result;
- public static List<String[]> tokens(List<String> lines)
- List<String[]> result = new ArrayList<String[]>(lines.size());
- for (String line : lines)
- String[] tokens = tokenize(line);
- result.add(tokens);
- return result;
- public static int maxTokens(List<String[]> tokens)
- int result = 0;
- for (String[] t : tokens)
- if (t.length > result)
- result = t.length;
- return result;
- Take line-oriented data and produce an array of doubles.
- public static double[][] array(List<String> lines)
- List<String[]> tokens = tokens(lines);
- int columns = maxTokens(tokens);
- int rows = lines.size();
- double[][] result = new double[rows][columns];
- for (int i = 0; i < rows; i++)
- for (int j = 0; j < columns; j++)
- try
- String v = tokens.get(i)[j];
- double d = Double.parseDouble(v);
- result[i][j] = d;
- catch (NumberFormatException e)
- throw new RuntimeException("Problem in row: " + i);
- return result;
- public static String spaces(String line)
- String result = "";
- for (int i = 0; i < line.length(); i++)
- if (line.charAt(i) == '=' &&
- line.charAt(i+1) != '=' &&
- line.charAt(i-1) != '=')
- result += " = ";
- else
- result += line.substring(i,i+1);
- return result;
- public static String[] tokenize(String line)
- if (line == null)
- return null;
- List<String> words = new ArrayList<String>();
- String[] ws = line.split("\\s");
- for (int i = 0; i < ws.length; i++)
- if (ws[i].length() > 0)
- words.add(ws[i]);
- String[] result = new String[words.size()];
- for (int i = 0; i < words.size(); i++)
- result[i] = words.get(i);
- return result;
- public static List<String> list(String line)
- for (int i = 0; i < tokens.length; i++)
- result.add(tokens[i]);
- return result;
Deleted: usertools/plotter/src/Lines.java
--- usertools/plotter/src/Lines.java 2011-01-21 17:39:55 UTC (rev 4022)
+++ usertools/plotter/src/Lines.java 2011-01-21 17:40:42 UTC (rev 4023)
@@ -1,344 +0,0 @@
-import java.awt.Color;
-import java.awt.geom.Rectangle2D;
-import java.io.*;
-import gnu.getopt.Getopt;
-import org.apache.commons.io.IOUtils;
-import org.apache.xmlgraphics.java2d.ps.EPSDocumentGraphics2D;
-import org.jfree.chart.ChartFactory;
-import org.jfree.chart.JFreeChart;
-import org.jfree.chart.axis.NumberAxis;
-import org.jfree.chart.plot.PlotOrientation;
-import org.jfree.chart.plot.XYPlot;
-import org.jfree.chart.renderer.xy.XYLineAndShapeRenderer;
-import org.jfree.data.Range;
-import org.jfree.data.general.Series;
-import org.jfree.data.xy.XYSeriesCollection;
- * See main() for command-line arguments
-public class Lines
- static Properties properties;
- public static boolean bw = false;
- static int w = 400;
- static int h = 400;
- // null indicates the value was not set by the user
- static Double xmin = null;
- static Double xmax = null;
- static Double ymin = null;
- static Double ymax = null;
- Generate simple plot.
- @param collection The x,y data.
- @param title Plot title.
- @param xlabel X label text.
- @param ylabel Y label text.
- @param output EPS filename.
- public static boolean plot(XYSeriesCollection collection,
- String title, String xlabel,
- String ylabel, String output)
- EPSDocumentGraphics2D g2d = null;
- Rectangle2D.Double rectangle = null;
- OutputStream out = null;
- try
- out = new FileOutputStream(output);
- out = new BufferedOutputStream(out);
- g2d = new EPSDocumentGraphics2D(false);
- g2d.setGraphicContext
- (new org.apache.xmlgraphics.java2d.GraphicContext());
- rectangle = new Rectangle2D.Double(0, 0, w, h);
- g2d.setupDocument(out, w, h);
- catch (IOException e)
- System.out.println("Problem with file: " + output);
- return false;
- final boolean withLegend = true;
- JFreeChart chart =
- ChartFactory.createXYLineChart
- (title, xlabel, ylabel, collection,
- PlotOrientation.VERTICAL, withLegend, false, false);
- setupPlot(chart, collection);
- chart.draw(g2d, rectangle);
- try
- g2d.finish();
- catch (Exception e)
- System.out.println("Err!");
- IOUtils.closeQuietly(out);
- System.out.println("PLOTTED: " + output);
- return true;
- private static void setupPlot(JFreeChart chart,
- XYSeriesCollection collection)
- XYPlot plot = chart.getXYPlot();
- XYLineAndShapeRenderer renderer = new XYLineAndShapeRenderer();
- if (bw)
- for (int i = 0; i < plot.getSeriesCount(); i++)
- renderer.setSeriesPaint(i, Color.BLACK);
- Series series = collection.getSeries(i);
- if (! showShape(series.getDescription()))
- // System.out.println("invis");
- renderer.setSeriesShapesVisible(i, false);
- setAxes(plot);
- plot.setRenderer(renderer);
- plot.setBackgroundPaint(Color.WHITE);
- static void setAxes(XYPlot plot)
- // Actual values: modify if necessary
- double axmin, axmax, aymin, aymax;
- if (xmin != null || xmax != null)
- NumberAxis axis = (NumberAxis) plot.getDomainAxis();
- Range range = axis.getRange();
- axmin = range.getLowerBound();
- axmax = range.getUpperBound();
- if (xmin != null) axmin = xmin;
- if (xmax != null) axmax = xmax;
- axis.setRange(axmin, axmax);
- if (ymin != null || ymax != null)
- NumberAxis axis = (NumberAxis) plot.getRangeAxis();
- aymin = range.getLowerBound();
- aymax = range.getUpperBound();
- if (ymin != null) aymin = ymin;
- if (ymax != null) aymax = ymax;
- axis.setRange(aymin, aymax);
- Args: Lines <properties> <output file> <data file>*
- Reads settings from properties: see scanProperties()
- Produces EPS output file
- Data files are two-columns of numbers each -
- see LineReader.read() and LineReader.array()
- public static void main(String[] args)
- // Settings:
- boolean verbose = false;
- Getopt g = new Getopt("testprog", args, "v");
- int c = -1;
- while ((c = g.getopt()) != -1)
- switch (c)
- case 'v':
- verbose = true;
- if (args.length < 3)
- ("usage: [<options>] <properties> <output> <data>*");
- System.exit(2);
- Bits.init();
- Util.verbose(verbose);
- String propFile = args[0];
- String output = args[1];
- List<String> names = new ArrayList<String>();
- for (int i = 2; i < args.length; i++)
- names.add(args[i]);
- String title = null;
- String xlabel = null;
- String ylabel = null;
- List<double[][]> data = new ArrayList<double[][]>();
- List<String> labels = new ArrayList<String>();
- properties = new Properties();
- load(propFile);
- title = properties.getProperty("title");
- xlabel = properties.getProperty("xlabel");
- ylabel = properties.getProperty("ylabel");
- scanProperties();
- for (String name : names)
- File file = new File(name);
- Util.verbose("open: " + file);
- List<String> lines = null;
- try
- lines = LineReader.read(file);
- catch (FileNotFoundException e)
- System.out.println("not found: " + file);
- System.exit(1);
- double[][] array = LineReader.array(lines);
- data.add(array);
- addLabel(name, labels);
- Util.verbose("array:\n" + toString(array));
- XYSeriesCollection collection = Util.collection(data, labels,
- names);
- plot(collection, title, xlabel, ylabel, output);
- static void load(String propFile)
- try
- if (propFile.equals("-"))
- properties.load(System.in);
- else
- properties.load(new FileInputStream(propFile));
- System.out.println(e);
- System.exit(1);
- e.printStackTrace();
- System.exit(1);
- Various plot properties. All are currently optional
- Example.
- Assume you want to plot a two-column table in file.data.
- The first column is the x values and the second column
- is the y values. See LineReader for details.
- Your properties may include:
- title = Plot
- xlabel = size
- ylabel = speed
- label.file.data = legend text
- width (output image width)
- height (output image height)
- xmin, xmax, ymin, ymax (auto-selected if not given)
- static void scanProperties()
- String tmp;
- tmp = properties.getProperty("width");
- if (tmp != null)
- w = Integer.parseInt(tmp.trim());
- tmp = properties.getProperty("height");
- if (tmp != null)
- h = Integer.parseInt(tmp.trim());
- tmp = properties.getProperty("xmin");
- if (tmp != null)
- xmin = Double.parseDouble(tmp);
- tmp = properties.getProperty("xmax");
- if (tmp != null)
- xmax = Double.parseDouble(tmp);
- tmp = properties.getProperty("ymin");
- if (tmp != null)
- ymin = Double.parseDouble(tmp);
- tmp = properties.getProperty("ymax");
- if (tmp != null)
- ymax = Double.parseDouble(tmp);
- Arrays.copyOfRange is a Java 1.6 feature.
- This has the same signature.
- static String[] select(String[] s, int p, int q)
- String[] result = new String[q-p];
- int j = 0;
- for (int i = p; i < q; i++)
- result[j++] = s[i];
- return result;
- static void addLabel(String name,
- List<String> labels)
- String label = properties.getProperty("label."+name);
- if (label == null)
- label = "";
- labels.add(label);
- static boolean showShape(String name)
- // System.out.println(name);
- String mode = properties.getProperty("shape."+name);
- // System.out.println(mode);
- if ("none".equals(mode))
- return false;
- return true;
- static String toString(double[][] array)
- StringBuilder sb = new StringBuilder();
- for (int i = 0; i < array.length; i++)
- double[] row = array[i];
- for (int j = 0; j < row.length; j++)
- sb.append(array[i][j]);
- if (j < row.length-1)
- sb.append(" ");
- sb.append("\n");
- return sb.toString();
Deleted: usertools/plotter/src/Util.java
--- usertools/plotter/src/Util.java 2011-01-21 17:39:55 UTC (rev 4022)
+++ usertools/plotter/src/Util.java 2011-01-21 17:40:42 UTC (rev 4023)
@@ -1,57 +0,0 @@
- * Plot data helpers.
-import java.util.List;
-import org.jfree.data.xy.XYSeries;
-public class Util
- static boolean v = false;
- Stores the label as the Series key.
- Stores the filename as the Series description.
- static XYSeriesCollection collection(List<double[][]> data,
- List<String> labels,
- List<String> names)
- final XYSeriesCollection collection = new XYSeriesCollection();
- int count = 0;
- for (double[][] d : data)
- String label = "data: " + count;
- try
- label = labels.get(count);
- catch (IndexOutOfBoundsException e)
- XYSeries series = new XYSeries(label);
- for (int i = 0; i < d.length; i++)
- series.add(d[i][0], d[i][1]);
- series.setDescription(names.get(count));
- collection.addSeries(series);
- count++;
- return collection;
- public static void verbose(String s)
- if (v)
- System.out.println(s);
- public static void verbose(boolean status)
- v = status;
More information about the Swift-commit
