[Swift-commit] r4020 - in SwiftApps/SwiftR/Swift: R exec
Thu Jan 20 18:31:06 CST 2011
Author: tga
Date: 2011-01-20 18:31:06 -0600 (Thu, 20 Jan 2011)
New Revision: 4020
Modified:
   SwiftApps/SwiftR/Swift/R/Fifo.R
   SwiftApps/SwiftR/Swift/R/Swift.R
   SwiftApps/SwiftR/Swift/R/Workers.R
   SwiftApps/SwiftR/Swift/exec/fifowrite
   SwiftApps/SwiftR/Swift/exec/killtree
Log:
An assortment of improvements:
* quiet option for swiftapply
* test now automatically starts up workers if none running
* Fifos now have a no timeout option
* Workers can be shut down individually: swiftInit() returns a handle for the
    worker process it starts, up, which can be passed to swiftShutdown()
* Launching workers from within R and running swiftapply works well, at least for local and ssh servers.
Modified: SwiftApps/SwiftR/Swift/R/Fifo.R
--- SwiftApps/SwiftR/Swift/R/Fifo.R	2011-01-20 21:31:55 UTC (rev 4019)
+++ SwiftApps/SwiftR/Swift/R/Fifo.R	2011-01-21 00:31:06 UTC (rev 4020)
@@ -2,12 +2,14 @@
 .checkFifoArgs <- function(fifopath, timeout) {
     # Catch errors proactively
-    tryCatch(
-        timeout <- round(timeout),
-        error = function (e) {
-            stop(paste("Provided timeout value of", timeout, "is not numeric"))
+    if (! is.null(timeout)) {
+        tryCatch(
+            timeout <- round(timeout),
+            error = function (e) {
+                stop(paste("Provided timeout value of", timeout, "is not numeric"))
     if (! file.exists(fifopath) ) {
         stop(paste("fifo specified does not exist or has wrong permissions:",
@@ -16,26 +18,34 @@
-# writes to a fifo with the provided timeout value
+# writes to a fifo with an optional timeout value.
 # if the timeout is exceeded, FALSE is returned
 # otherwise TRUE is returned
-writeFifo <- function (fifopath, message, timeout=3000) {
+writeFifo <- function (fifopath, message, timeout=NULL) {
     .checkFifoArgs(fifopath, timeout)
     bin <- file.path(.find.package("Swift"), "exec/fifowrite")
-    cmdString <- paste(bin, fifopath, "-t", timeout,
-            "-m", paste("'", message, "'", sep=""), "&>/dev/null")
+    if (is.null(timeout)) {
+        cmdString <- bin
+    else {
+        cmdString <- paste(bin, fifopath, "-t", timeout)
+    cmdString <- paste(cmdString, "-m",
+            paste("'", message, "'", sep=""), "&>/dev/null")
     retval <- system(cmdString, wait=TRUE)
     return (retval == 0)
-# reads from a fifo with the provided timeout value
+# reads from a fifo with an optional timeout value
 # if the timeout is exceeded, NA is returned
 # otherwise a vector of the lines of text is
 # read from the fifo
 # timeout is in milliseconds.
-readFifo <- function (fifopath, timeout=3000) {
+readFifo <- function (fifopath, timeout=NULL) {
     # TODO: fork off another process to do reading, to avoid
     # the R process blocking irrecoverably
@@ -43,14 +53,19 @@
     # if the timeout is exceeded, terminates and writes
     # _FIFOTIMEOUT_ to stdout
     bin <- file.path(.find.package("Swift"), "exec/fiforead")
-    cmdString <- paste(bin, fifopath, "-t", timeout)
+        cmdString <- paste(bin, fifopath)
+    else {
     fifodata <- suppressWarnings(system(cmdString, intern=TRUE, ignore.stderr=TRUE))
             # stderr is ignored as we will get all relevant information
             # through stdout
             # want to suppress warning message about exit codea
     toutMsg <- "_FIFOTIMEOUT_"
-    if (length(fifodata) == 1
-        && substr(fifodata[[1]], 1,nchar(toutMsg)) == toutMsg) {
+    if (length(fifodata) == 0
+        || substr(fifodata[[1]], 1,nchar(toutMsg)) == toutMsg) {
         return (NA)
     else {
Modified: SwiftApps/SwiftR/Swift/R/Swift.R
--- SwiftApps/SwiftR/Swift/R/Swift.R	2011-01-20 21:31:55 UTC (rev 4019)
+++ SwiftApps/SwiftR/Swift/R/Swift.R	2011-01-21 00:31:06 UTC (rev 4020)
@@ -1,18 +1,20 @@
 swiftapply <- function( func, arglists,
-                        swiftserver=NULL,
+                        server=NULL,
                         callsperbatch=NULL,
                         runmode=NULL,
                         initialexpr=NULL,
                         workerhosts=NULL,
                         keepwork=NULL,
-                        tmpdir=NULL )
+                        tmpdir=NULL,
+                        timeout=NULL,
+                        quiet=FALSE)
   # Set Swift default options if not passed as keywords or pre-set by user
-  if(is.null(swiftserver))
-    swiftserver <- getOption("swift.server")
-    swiftserver<-"local"
+  if(is.null(server))
+    server <- getOption("swift.server")
+    server<-"local"
   if(is.null(callsperbatch))
     callsperbatch <- getOption("swift.callsperbatch")
@@ -48,15 +50,15 @@
     tmpdir <- Sys.getenv("SWIFTR_TMP");
   if(tmpdir=="")
     tmpdir <- "/tmp";
-  cat("\nSwift properties:\n")
-  cat("  swiftserver =", swiftserver,"\n");
-  cat("  callsperbatch =", callsperbatch,"\n")
-  cat("  runmode =", runmode,"\n")
-  cat("  tmpdir =", tmpdir,"\n")
-  cat("  workerhosts =", workerhosts,"\n")
-  cat("  initialexpr =", initialexpr,"\n\n")
+  if (! quiet) {
+      cat("\nSwift properties:\n")
+      cat("  server =", server,"\n");
+      cat("  callsperbatch =", callsperbatch,"\n")
+      cat("  runmode =", runmode,"\n")
+      cat("  tmpdir =", tmpdir,"\n")
+      cat("  workerhosts =", workerhosts,"\n")
+      cat("  initialexpr =", initialexpr,"\n\n")
   user <- Sys.info()[["user"]]
   # Initialize globals if first call in this workspace
@@ -81,7 +83,9 @@
 #  reqdir <- system(paste("mktemp -d ", basedir, "/SwiftR.run.XXXX",sep=""),intern=TRUE)
   reqdir = sprintf("%s/R%.7d",requestdirbase,requestid)
   dir.create(reqdir,showWarnings=FALSE)
-  cat("Swift request is in",reqdir,"\n")
+  if (! quiet) {
+      cat("Swift request is in",reqdir,"\n")
   narglists <- length(arglists) # number of arglists to process
   batch <- 1   # Next arglist batch number to fill
@@ -109,7 +113,7 @@
   if( runmode == "manual" ) { # Prompt for return (empty line) to continue; assumes user ran a manual R to process the call.
     cat("Manual Swift Run:\n  run dir: ", getwd(), "/", reqdir,"\n\n")
     cat("  swift script: ", RunSwiftScript, "\n")
-    cat("  swiftserver: ", swiftserver,"\n")
+    cat("  server: ", server,"\n")
     cat("  swiftapplyScript: ", swiftapplyScript,"\n")
     cat("  Use RunAllR.sh to process and press return when complete:")
     system(paste("cp ", system.file(package="Swift","exec/RunAllR.sh"), reqdir))
@@ -117,13 +121,13 @@
   else if (runmode == "script") {
     RunSwiftScript <- system.file(package="Swift","exec/RunSwiftScript.sh")
-    system(paste(RunSwiftScript,reqdir,swiftserver,swiftapplyScript,"\"",workerhosts,"\""))
+    system(paste(RunSwiftScript,reqdir,server,swiftapplyScript,"\"",workerhosts,"\""))
   else { # runmode == "service" # FIXME: check and post error if not "service"
     # Send request to service
-    swiftServerDir = paste(tmpdir,"/",user,"/SwiftR/swift.",swiftserver,sep="")
+    swiftServerDir = paste(tmpdir,"/",user,"/SwiftR/swift.",server,sep="")
     requestPipeName=paste(swiftServerDir,"/requestpipe",sep="")
     resultPipeName=paste(swiftServerDir,"/resultpipe",sep="")
@@ -136,21 +140,35 @@
     if (file.exists(requestPipeName)) {
         #TODO: there is a race condition here if the fifo disappears in
         # between checking for existence and opening the fifo
+        writeTimeout <- 2000
+        success <- writeFifo(requestPipeName,paste(reqdir,"\n",sep=""),
+                timeout=writeTimeout)
+        if (! success) {
+            stop(paste("timeout of", writeTimeout,
+                "ms exceeded when attempting to",
+                "rendezvous with swift server: maybe it is not running or",
+                "it has crashed"))
-        requestPipe <- fifo(requestPipeName,open="w",blocking=TRUE)
-        cat(file=requestPipe,paste(reqdir,"\n",sep=""))
-        close(requestPipe)
         # Wait for reply from service
+        res <- readFifo(resultPipeName, timeout=timeout)
+        if ((! length(res) == 0) && is.na(res)) {
+            stop(paste("Timeout of ", timeout, "ms exceeded when waiting",
+                "for response from swift server"))
-        resultPipe <- fifo(resultPipeName,open="r",blocking=TRUE)
-        resultStatus <- readLines(con=resultPipe,n=1,ok=TRUE)
-        close(resultPipe)
+        # Check that the message was correct
+        successMsg <- "done"
+        if (res[[1]] != successMsg)
+            stop(paste("Got unexpected message '",
+                paste(res, collapse="\n"),"' on fifo ",
+                "aborting job", sep=""))
     else {
-        stop(paste("It appears no SwiftR servers of type", swiftserver,
+        stop(paste("Have you run swiftInit?\n",
+                "It appears that no SwiftR servers of type", server,
                 "are running, as no request pipe exists in",
-                swiftServerDir,"exists"))
+                swiftServerDir))
@@ -245,7 +263,6 @@
 basicSwiftTest <- function() { swiftTest_1.1() }
 # .... more tests from below to move here
 swiftTest_4.1 <- function()
   sumivars <- function() { initVar1+initVar2 }
@@ -324,310 +341,318 @@
 runAllSwiftTests <- function()
+    # Launch workerif nothing already running
+    # testPid will be NULL if nothihg launched
+    testPid <- tryCatch(
+            (function() { swiftapply(log, list(list(1)),quiet=TRUE) ;
+                          return(NULL); })(),
+            error=function(x) {swiftInit();})
-### FIXME: Save prior options here: restore them when tests are done.  Recovery if interrrupted?
+    ### FIXME: Save prior options here: restore them when tests are done.
+    ### Recovery if interrrupted?
-failures=0
+    failures=0
-startTime = proc.time()[["elapsed"]]
+    startTime = proc.time()[["elapsed"]]
-cat("\n*** Starting test group 1 - functions on simple data structures ***\n\n")
+    cat("\n*** Starting test group 1 - functions on simple data structures ***\n\n")
-swiftTest_1.1()
+    swiftTest_1.1()
-##### Test 1.2
+    ##### Test 1.2
-# test 10 remote calls
+    # test 10 remote calls
-sumstuff <- function(treedata,cardata) { sum( treedata$Height, cardata$dist ) }
-data(cars)
-data(trees)
+    sumstuff <- function(treedata,cardata) { sum( treedata$Height, cardata$dist ) }
+    data(cars)
+    data(trees)
-args=list(trees,cars)
-arglist <- rep(list(args),10)
+    args=list(trees,cars)
+    arglist <- rep(list(args),10)
-localres = do.call(sumstuff,args)
+    localres = do.call(sumstuff,args)
-cat("\n*** Test 1.2.1: 10 calls to substuff()\n")
-swiftres <- swiftapply(sumstuff,arglist)
-cat("Swift result:\n")
-format(swiftres)
+    cat("\n*** Test 1.2.1: 10 calls to substuff()\n")
+    swiftres <- swiftapply(sumstuff,arglist)
+    cat("Swift result:\n")
+    format(swiftres)
-diffs <- 0
-for(i in 1:length(swiftres) ) {
-  if( !identical(swiftres[[i]],localres) ) {
-    diffs <- diffs + 1
-    if( diffs < 10 ) cat(sprintf("res[%d]=%s\n",i,format( swiftres[[i]] )))
+    diffs <- 0
+    for(i in 1:length(swiftres) ) {
+      if( !identical(swiftres[[i]],localres) ) {
+        diffs <- diffs + 1
+        if( diffs < 10 ) cat(sprintf("res[%d]=%s\n",i,format( swiftres[[i]] )))
-if(diffs == 0) {
-  cat("\n==> test 1.2.1 passed\n")
-} else {
-  cat("\n!!!==> test 1.2.1 failed.\n")
-  cat(sprintf(" %d result elements failed to match.\n",diffs));
-  failures=failures+1
+    if(diffs == 0) {
+      cat("\n==> test 1.2.1 passed\n")
+    } else {
+      cat("\n!!!==> test 1.2.1 failed.\n")
+      cat(sprintf(" %d result elements failed to match.\n",diffs));
+      failures=failures+1
-cat("\n*** Test 1.2.2: 10 calls to substuff() - callsperbatch=10\n")
-swiftres = swiftapply(sumstuff,arglist,callsperbatch=10)
-format(swiftres)
+    cat("\n*** Test 1.2.2: 10 calls to substuff() - callsperbatch=10\n")
+    swiftres = swiftapply(sumstuff,arglist,callsperbatch=10)
+    format(swiftres)
-diffs <- 0
+    diffs <- 0
-if(diffs == 0) {
-  cat("\n==> test 1.2.2 passed\n")
-} else {
-  cat("\n!!!==> test 1.2.2 failed.\n")
+    if(diffs == 0) {
+      cat("\n==> test 1.2.2 passed\n")
+    } else {
+      cat("\n!!!==> test 1.2.2 failed.\n")
-cat("\n*** Test 1.2.3: 10 calls to substuff() - callsperbatch=2\n")
-swiftres = swiftapply(sumstuff,arglist,callsperbatch=2)
-format(swiftres)
+    cat("\n*** Test 1.2.3: 10 calls to substuff() - callsperbatch=2\n")
+    swiftres = swiftapply(sumstuff,arglist,callsperbatch=2)
+    format(swiftres)
-diffs <- 0
-    if( diffs < 10 ) cat(sprintf("res[%d]=%s\n",i, format( swiftres[[i]] )))
+    diffs <- 0
+        if( diffs < 10 ) cat(sprintf("res[%d]=%s\n",i, format( swiftres[[i]] )))
-if(diffs == 0) {
-  cat("\n==> test 1.2.3 passed\n")
-} else {
-  cat("\n!!!==> test 1.2.3 failed.\n")
+    if(diffs == 0) {
+      cat("\n==> test 1.2.3 passed\n")
+    } else {
+      cat("\n!!!==> test 1.2.3 failed.\n")
-cat("\n*** Test 1.2.4: 10 calls to substuff() - callsperbatch=3\n")
-swiftres = swiftapply(sumstuff,arglist,callsperbatch=3)
-format(swiftres)
+    cat("\n*** Test 1.2.4: 10 calls to substuff() - callsperbatch=3\n")
+    swiftres = swiftapply(sumstuff,arglist,callsperbatch=3)
+    format(swiftres)
-diffs <- 0
-    if( diffs < 10 ) cat(sprintf("res[%d]=%d\n",i, format( swiftres[[i]] )))
+    diffs <- 0
+        if( diffs < 10 ) cat(sprintf("res[%d]=%d\n",i, format( swiftres[[i]] )))
-if(diffs == 0) {
-  cat("\n==> test 1.2.4 passed\n")
-} else {
-  cat("\n!!!==> test 1.2.4 failed.\n")
+    if(diffs == 0) {
+      cat("\n==> test 1.2.4 passed\n")
+    } else {
+      cat("\n!!!==> test 1.2.4 failed.\n")
-# swiftres = swiftapply(sumstuff,arglist,callsperbatch=2,site="pbs")
-# test variations on local vs ssh vs pbs; coasters vs non; etc.
+    # swiftres = swiftapply(sumstuff,arglist,callsperbatch=2,site="pbs")
+    # test variations on local vs ssh vs pbs; coasters vs non; etc.
-##### Test Group  2
+    ##### Test Group  2
-cat("\n*** Starting test group 2 - test matrix passing***\n")
+    cat("\n*** Starting test group 2 - test matrix passing***\n")
-matfunc <- function( m1, m2 )
-  (1/m1) %*% m2
+    matfunc <- function( m1, m2 )
+      (1/m1) %*% m2
-n <- 5
-m1 <- array(sin(1:n**2), dim=c(n,n))
-m2 <- t(m1)
+    n <- 5
+    m1 <- array(sin(1:n**2), dim=c(n,n))
+    m2 <- t(m1)
-localres = matfunc(m1,m2)
+    localres = matfunc(m1,m2)
-cat("\n*** Test 2.1: 100 calls to matfunc(dim=5x5) - callsperbatch=9\n")
+    cat("\n*** Test 2.1: 100 calls to matfunc(dim=5x5) - callsperbatch=9\n")
-args=list(m1,m2)
-arglist <- rep(list(args),100)
+    args=list(m1,m2)
+    arglist <- rep(list(args),100)
-swiftres = swiftapply(matfunc,arglist,callsperbatch=9)
+    swiftres = swiftapply(matfunc,arglist,callsperbatch=9)
-diffs <- 0
-#for(i in 1:length(swiftres) ) {
-for(i in c(seq(1,100,10),100)) {
-  if( !all.equal(swiftres[[i]],localres) ) {
-    if( diffs < 10 ) cat(sprintf("res[%d]=%s\n",i,format(swiftres[[i]])))
+    diffs <- 0
+    #for(i in 1:length(swiftres) ) {
+    for(i in c(seq(1,100,10),100)) {
+      if( !all.equal(swiftres[[i]],localres) ) {
+        if( diffs < 10 ) cat(sprintf("res[%d]=%s\n",i,format(swiftres[[i]])))
-if(diffs == 0) {
-  cat("\n==> test 2.1 passed\n")
-} else {
-  cat("\n!!!==> test 2.2 failed.\n")
+    if(diffs == 0) {
+      cat("\n==> test 2.1 passed\n")
+    } else {
+      cat("\n!!!==> test 2.2 failed.\n")
-n <- 237
-n <- 50
-m2 <- t(m1)
+    n <- 237
+    n <- 50
+    m2 <- t(m1)
-cat("\n*** Test 2.2: 123 calls to matfunc(dim=bigger) - callsperbatch=7\n") # FIXME make n easy to adjust and print actual value
+    cat("\n*** Test 2.2: 123 calls to matfunc(dim=bigger) - callsperbatch=7\n") # FIXME make n easy to adjust and print actual value
-args=list(m1,m2)
-arglist <- rep(list(args),123)
+    args=list(m1,m2)
+    arglist <- rep(list(args),123)
-swiftres = swiftapply(matfunc,arglist,callsperbatch=7)
+    swiftres = swiftapply(matfunc,arglist,callsperbatch=7)
-diffs <- 0
-for(i in c(seq(1,length(swiftres),10),length(swiftres))) {
+    diffs <- 0
+    for(i in c(seq(1,length(swiftres),10),length(swiftres))) {
-if(diffs == 0) {
-  cat("\n==> test 2.2 passed\n")
-} else {
+    if(diffs == 0) {
+      cat("\n==> test 2.2 passed\n")
+    } else {
-##### Test Group 3
+    ##### Test Group 3
-cat("\n*** Starting test group 3 - test list element and name passing***\n")
+    cat("\n*** Starting test group 3 - test list element and name passing***\n")
-# Test if list element names are being sent and returned correctly
+    # Test if list element names are being sent and returned correctly
-n <- 5
-m2 <- t(m1)
+    n <- 5
+    m2 <- t(m1)
-inlist = list()
-inlist[[1]]=123
-inlist[[2]]=456
-inlist$name1=789
-inlist$name2=987
-inlist$mat1 =  m1
-inlist[[99]] = m2
+    inlist = list()
+    inlist[[1]]=123
+    inlist[[2]]=456
+    inlist$name1=789
+    inlist$name2=987
+    inlist$mat1 =  m1
+    inlist[[99]] = m2
-listfunc <- function(ilist)
-  olist = ilist
-  olist$sum = ilist[[1]] + ilist[[2]] + ilist$name1 + ilist$name2
-  olist$names = names(ilist)
-  olist$mprod = ilist$mat1 %*% ilist[[99]]
-  return(olist)
-localres = listfunc(inlist)
+    listfunc <- function(ilist)
+      olist = ilist
+      olist$sum = ilist[[1]] + ilist[[2]] + ilist$name1 + ilist$name2
+      olist$names = names(ilist)
+      olist$mprod = ilist$mat1 %*% ilist[[99]]
+      return(olist)
+    localres = listfunc(inlist)
-cat("\n*** Starting test 3.1 - 4 calls in one batch of 5 ***\n")
+    cat("\n*** Starting test 3.1 - 4 calls in one batch of 5 ***\n")
-args=list(inlist)
-arglist <- rep(list(args),4)
+    args=list(inlist)
+    arglist <- rep(list(args),4)
-swiftres = swiftapply(listfunc,arglist,callsperbatch=5)
+    swiftres = swiftapply(listfunc,arglist,callsperbatch=5)
-diffs <- 0
-    if( diffs < 10 ) cat(sprintf("res[%d=%s\n",i,format(swiftres[[i]])))
+    diffs <- 0
+        if( diffs < 10 ) cat(sprintf("res[%d=%s\n",i,format(swiftres[[i]])))
-if(diffs == 0) {
-  cat("\n==> test 3.1 passed\n")
-} else {
-  cat("\n!!!==> test 3.1 failed.\n")
+    if(diffs == 0) {
+      cat("\n==> test 3.1 passed\n")
+    } else {
+      cat("\n!!!==> test 3.1 failed.\n")
-cat("\n*** Starting test 3.2 - 99 calls in batches of 11 ***\n")
+    cat("\n*** Starting test 3.2 - 99 calls in batches of 11 ***\n")
-args=list(inlist)
-arglist <- rep(list(args),99)
+    args=list(inlist)
+    arglist <- rep(list(args),99)
-swiftres = swiftapply(listfunc,arglist,callsperbatch=11)
+    swiftres = swiftapply(listfunc,arglist,callsperbatch=11)
-diffs <- 0
+    diffs <- 0
-if(diffs == 0) {
-  cat("\n==> test 3.2 passed\n")
-} else {
-  cat("\n!!!==> test 3.2 failed.\n")
+    if(diffs == 0) {
+      cat("\n==> test 3.2 passed\n")
+    } else {
+      cat("\n!!!==> test 3.2 failed.\n")
-##### Test Group 4 # test initialexpr string
+    ##### Test Group 4 # test initialexpr string
-cat("\n*** Starting test group 4 - test remote R service initialization string ***\n")
+    cat("\n*** Starting test group 4 - test remote R service initialization string ***\n")
-swiftTest_4.1()
-swiftTest_4.2()
+    swiftTest_4.1()
+    swiftTest_4.2()
-##### Test Group 5 # test error handling
+    ##### Test Group 5 # test error handling
-cat("\n*** Starting test group 5 - test remote R service error ***\n")
+    cat("\n*** Starting test group 5 - test remote R service error ***\n")
-arglist = list(list(1.0),list(2.0),list("3.0"),list(4.0),list(5.0))
+    arglist = list(list(1.0),list(2.0),list("3.0"),list(4.0),list(5.0))
-cat("\nTest of swiftapply(sumivars,arglist)\n")
-swiftres = swiftapply(log,arglist)
-print(swiftres)
+    cat("\nTest of swiftapply(sumivars,arglist)\n")
+    swiftres = swiftapply(log,arglist)
+    print(swiftres)
-goodres = c("numeric","numeric","try-error","numeric","numeric")
+    goodres = c("numeric","numeric","try-error","numeric","numeric")
-diffs <- 0
-  if( class(swiftres[[i]]) != goodres[i] ) {
+    diffs <- 0
+      if( class(swiftres[[i]]) != goodres[i] ) {
-if(diffs == 0) {
-  cat("\n==> test 5.1 passed\n")
-} else {
-  cat("\n!!!==> test 5.1 failed.\n")
+    if(diffs == 0) {
+      cat("\n==> test 5.1 passed\n")
+    } else {
+      cat("\n!!!==> test 5.1 failed.\n")
-endTime <- proc.time()[["elapsed"]]
-runTime <- endTime - startTime
+    endTime <- proc.time()[["elapsed"]]
+    runTime <- endTime - startTime
-cat("\n\n ===> Total elapsed test time = ",runTime," seconds.\n\n")
+    cat("\n\n ===> Total elapsed test time = ",runTime," seconds.\n\n")
+    if (!is.null(testPid))
+        swiftShutdown(pid=testPid)
 } # end function runAllTests
 #options(swift.site="local")
Modified: SwiftApps/SwiftR/Swift/R/Workers.R
--- SwiftApps/SwiftR/Swift/R/Workers.R	2011-01-20 21:31:55 UTC (rev 4019)
+++ SwiftApps/SwiftR/Swift/R/Workers.R	2011-01-21 00:31:06 UTC (rev 4020)
@@ -23,6 +23,8 @@
     #               DEBUG, TRACE
     # Options which are server and site-specific:
     #   project, queue
+    # Swift returns a descriptor for the worker process, which
+    # can be passed to swiftShutdown to stop the worker.
     # In case it was somehow deleted
@@ -86,16 +88,26 @@
     # add hook to ensure child process will be killed when
     # this process exits
     addHook()
+    # Sleep to give start-swift time to set up fifos,etc
+    Sys.sleep(2)
+    return (output)
-swiftShutdown <- function()
+swiftShutdown <- function(pid=NULL)
-    if (is.null(.swift.workers)) {
-        return
+    if (is.null(pid)) {
+        if (is.null(.swift.workers)) {
+            return
+        workers = .swift.workers
+    else {
+        workers=pid
     cat("Shutting down Swift worker processes\n")
     # shut down all worker processes using kill
-    for (pid in .swift.workers) {
+    for (pid in workers) {
         cmdString <- file.path(.find.package("Swift"), "exec/killtree")
         killCmd <- paste(cmdString,pid)
         system(killCmd, wait=FALSE)
Modified: SwiftApps/SwiftR/Swift/exec/fifowrite
--- SwiftApps/SwiftR/Swift/exec/fifowrite	2011-01-20 21:31:55 UTC (rev 4019)
+++ SwiftApps/SwiftR/Swift/exec/fifowrite	2011-01-21 00:31:06 UTC (rev 4020)
@@ -28,8 +28,10 @@
 # fork off a process to read from fifo and write to
 # temp file.
-# Cat reads from stdin and writes to fifo
-echo "$msg" > "$fifo" &
+# echo message to fifo, fork off a process.  The remainder
+# of the code handles the case where there is nothing to
+# read it and echo blocks
+echo -n "$msg" > "$fifo" &
 catpid=$!
 tout_pid=""
 if [ "$timeout" -gt 0 ];
Modified: SwiftApps/SwiftR/Swift/exec/killtree
--- SwiftApps/SwiftR/Swift/exec/killtree	2011-01-20 21:31:55 UTC (rev 4019)
+++ SwiftApps/SwiftR/Swift/exec/killtree	2011-01-21 00:31:06 UTC (rev 4020)
@@ -1,6 +1,5 @@
 #!/bin/sh
 tokill=$1
-echo $tokill
 while [ ! -z $tokill ]
 do
     children=""
