[Swift-commit] r3999 - in SwiftApps/SwiftR/Swift: R exec
noreply at svn.ci.uchicago.edu
Wed Jan 19 13:32:48 CST 2011
Author: tga
Date: 2011-01-19 13:32:47 -0600 (Wed, 19 Jan 2011)
New Revision: 3999
Added:
SwiftApps/SwiftR/Swift/R/Workers.R
SwiftApps/SwiftR/Swift/exec/start-swift-daemon
Modified:
SwiftApps/SwiftR/Swift/R/Swift.R
Log:
Checking in work on launching start-swift within R.
All logic to launch and track processes is present, but TERM signal is not
correctly taking down the worker processes at this stage: need to fix.
Modified: SwiftApps/SwiftR/Swift/R/Swift.R
--- SwiftApps/SwiftR/Swift/R/Swift.R 2011-01-18 23:59:39 UTC (rev 3998)
+++ SwiftApps/SwiftR/Swift/R/Swift.R 2011-01-19 19:32:47 UTC (rev 3999)
@@ -193,6 +193,9 @@
options(swift.initialexpr=initcmds) # Set here; used in test group 4
swiftTest_1.1 <- function()
Added: SwiftApps/SwiftR/Swift/R/Workers.R
--- SwiftApps/SwiftR/Swift/R/Workers.R (rev 0)
+++ SwiftApps/SwiftR/Swift/R/Workers.R 2011-01-19 19:32:47 UTC (rev 3999)
@@ -0,0 +1,147 @@
+swiftInit <- function( cores=NULL, server=NULL,
+ hosts=NULL, nodes=NULL, project=NULL,
+ parEnv=NULL, workmode=NULL,
+ throttle=NULL, queue=NULL,
+ rcmd=NULL, time=NULL,
+ workerLogging=NULL )
+ #TODO: document function
+ # server: which server backend to use to acquire workers
+ # for example, local runs tasks on the local machine
+ # pbs, uses the PBS scheduler to obtain nodes on a cluster,
+ # etc
+ # hosts: list of hosts to use (for ssh backend)
+ # nodes: number of hosts to use (for cluster-based backends)
+ # cores: number of cores per host to use #TODO: check
+ # time: (pbs and sge servers only) walltime in hh:mm:ss
+ # Default is 30 minutes on these servers, unlimited
+ # elsewhere
+ # wkloglvl: logging level. Settings are NONE, ERROR, WARn, INFO,
+ # DEBUG, TRACE
+ # Options which are server and site-specific:
+ # project, queue
+ # In case it was somehow deleted
+ if (is.null(.swift.workers)) {
+ .swift.workers <<- list()
+ # Find out where start-swift script lives in this
+ # R installation
+ # Presume UNIX path names - start-swift script
+ cmdString <- file.path(.find.package("Swift"), "exec/start-swift-daemon")
+ if(! is.null(cores) ) {
+ cmdString <- paste(cmdString, "-c", cores)
+ if(! is.null(server) ) {
+ cmdString <- paste(cmdString, "-s", server)
+ if(! is.null(hosts) ) {
+ cmdString <- paste(cmdString, "-h", hosts)
+ if(! is.null(parEnv) ) {
+ cmdString <- paste(cmdString, "-e", parEnv)
+ if(! is.null(workmode) ) {
+ cmdString <- paste(cmdString, "-m", workmode)
+ if(! is.null(nodes) ) {
+ cmdString <- paste(cmdString, "-n", nodes)
+ if(! is.null(throttle) ) {
+ cmdString <- paste(cmdString, "-p", throttle)
+ if(! is.null(queue) ) {
+ cmdString <- paste(cmdString, "-q", queue)
+ if(! is.null(rcmd) ) {
+ cmdString <- paste(cmdString, "-r", rcmd)
+ if(! is.null(time) ) {
+ cmdString <- paste(cmdString, "-t", time)
+ if(! is.null(workerLogging) ) {
+ cmdString <- paste(cmdString, "-w", workerLogging)
+ # launch asynchronously
+ # for now, we will rely on the shell script's output to inform
+ # the user if there was a problem with the workers
+ output <- system(cmdString, intern=TRUE)
+ cat("Started worker manager with pid ", output, "\n")
+ # store pid
+ .swift.workers[[length(.swift.workers) + 1]] <<- output
+ # add hook to ensure child process will be killed when
+ # this process exits
+ addHook()
+swiftShutdown <- function()
+ return
+ cat("Shutting down Swift worker processes\n")
+ # shut down all worker processes using kill
+ for (pid in .swift.workers) {
+ cat("Killing ", pid, "\n")
+ killCmd <- paste("kill","-1", pid, " &> /dev/null")
+ cat(killCmd, "\n")
+ system(killCmd, wait=FALSE)
+.First.lib <- function(libname, packagename) {
+ # When the library is loaded, set up the
+ # list of workers
+.Last.lib <- function(p)
+ # If the library is unloaded we need to do cleanup
+ swiftShutdown()
+# Hook to perform cleanup of workers upon shutting down an R
+# session
+addHook <- function() {
+ # Replace the user's last function with ours
+ # If .UserLast already exists don't worry about it
+ # as we've already added our hook
+ if (!exists(".UserLast")) {
+ if (!exists(".Last")) {
+ # Create a dummy function
+ .UserLast <<- function () {}
+ else {
+ .UserLast <<- .Last
+ .Last <<- function () {
+ swiftShutdown()
+ .UserLast()
+ removeHook()
+removeHook <- function() {
+ if (exists(".UserLast", where=".GlobalEnv")) {
+ .Last <<- .UserLast
+ rm(".UserLast", pos=".GlobalEnv")
Added: SwiftApps/SwiftR/Swift/exec/start-swift-daemon
--- SwiftApps/SwiftR/Swift/exec/start-swift-daemon (rev 0)
+++ SwiftApps/SwiftR/Swift/exec/start-swift-daemon 2011-01-19 19:32:47 UTC (rev 3999)
@@ -0,0 +1,14 @@
+#!/bin/sh
+# This script is intended as a helper script to let
+# R launch start-swift. It works around the limitations
+# of the R system command, which cannot retrieve
+# the process id of the child process.
+# This script forks off a child process, detaches it
+# and then, as the only thing written to stdout, echoes
+# the pid of start-swift
+ssscript=`dirname $0`/start-swift
+# Start as detached daemon, with output going to stdout
+$ssscript "$@" 1>&2 &
+childpid=$!
+echo ${childpid}
+disown $childpid
Property changes on: SwiftApps/SwiftR/Swift/exec/start-swift-daemon
___________________________________________________________________
More information about the Swift-commit
