[Swift-commit] r3985 - usertools/persistent-coasters
Mon Jan 17 15:48:16 CST 2011
Author: wozniak
Date: 2011-01-17 15:48:16 -0600 (Mon, 17 Jan 2011)
New Revision: 3985
Modified:
   usertools/persistent-coasters/README.txt
   usertools/persistent-coasters/settings.sh
   usertools/persistent-coasters/setup.sh
   usertools/persistent-coasters/start-service.zsh
Log:
Make the user source settings.sh manually.  Add WORKER_MODE
Modified: usertools/persistent-coasters/README.txt
--- usertools/persistent-coasters/README.txt	2011-01-17 21:41:39 UTC (rev 3984)
+++ usertools/persistent-coasters/README.txt	2011-01-17 21:48:16 UTC (rev 3985)
@@ -1,6 +1,7 @@
 Overview of persistent CoasterService process
+0) Source settings.sh or a similar file
 1) Start coaster service
 2) Get URL to which Swift should connect from service output
 3) Run Swift once to send settings to CoasterService,
Modified: usertools/persistent-coasters/settings.sh
--- usertools/persistent-coasters/settings.sh	2011-01-17 21:41:39 UTC (rev 3984)
+++ usertools/persistent-coasters/settings.sh	2011-01-17 21:48:16 UTC (rev 3985)
@@ -5,6 +5,9 @@
 NODES=64
+# How to launch workers- local or ssh
+export WORKER_MODE=local
 export WORKER_LOGGING=INFO
 # WORKER_HOSTS="login1 login2"
Modified: usertools/persistent-coasters/setup.sh
--- usertools/persistent-coasters/setup.sh	2011-01-17 21:41:39 UTC (rev 3984)
+++ usertools/persistent-coasters/setup.sh	2011-01-17 21:48:16 UTC (rev 3985)
@@ -4,7 +4,6 @@
 # Should extend to generate tc as well
 source ${TOOLS}/coasters-setup.sh
-source ./settings.sh
 export WORK
Modified: usertools/persistent-coasters/start-service.zsh
--- usertools/persistent-coasters/start-service.zsh	2011-01-17 21:41:39 UTC (rev 3984)
+++ usertools/persistent-coasters/start-service.zsh	2011-01-17 21:48:16 UTC (rev 3985)
@@ -28,8 +28,12 @@
 local OUT=$1
-source workers-local.zsh
-# source workers-ssh.zsh
+if [[ ${WORKER_MODE} == "local" ]]
+  then
+  source workers-local.zsh
+elif [[ ${WORKER_MODE} == "ssh" ]]
+  source workers-ssh.zsh
+fi
 # Obtain the URL to which Swift should connect
 get_service_coasters()
