[Swift-commit] r3982 - usertools/persistent-coasters
Mon Jan 17 15:39:34 CST 2011
Author: wozniak
Date: 2011-01-17 15:39:33 -0600 (Mon, 17 Jan 2011)
New Revision: 3982
Added:
   usertools/persistent-coasters/run-job.zsh
   usertools/persistent-coasters/system-info.sh
   usertools/persistent-coasters/system-info.swift
Log:
Add a user job to test the service once started
Added: usertools/persistent-coasters/run-job.zsh
--- usertools/persistent-coasters/run-job.zsh	                        (rev 0)
+++ usertools/persistent-coasters/run-job.zsh	2011-01-17 21:39:33 UTC (rev 3982)
@@ -0,0 +1,16 @@
+#!/bin/zsh
+# Launch a user job
+# Use after running start-service.zsh
+APP=$( cd $( dirname $0 ) ; /bin/pwd )
+TOOLS=${APP} # In the future this might be ${SWIFT_HOME}/tools
+source ${TOOLS}/helpers.zsh
+[[ $? != 0 ]] && print "Could not load helpers.zsh!" && exit 1
+SWIFT_OUT=logs/swift-user.out
+swift -config swift.properties \
+           -sites.file sites.xml \
+           -tc.file tc.data \
+           system-info.swift < /dev/null # >& ${SWIFT_OUT}
+exitcode "Swift user job failed!"
Property changes on: usertools/persistent-coasters/run-job.zsh
___________________________________________________________________
Added: usertools/persistent-coasters/system-info.sh
--- usertools/persistent-coasters/system-info.sh	                        (rev 0)
+++ usertools/persistent-coasters/system-info.sh	2011-01-17 21:39:33 UTC (rev 3982)
@@ -0,0 +1,10 @@
+#!/bin/bash
+# User script to be submitted by Swift using persistent Coasters
+# Simply report some system info to stdout for diagnostics
+hostname
+echo
+uname -a
+exit 0
Property changes on: usertools/persistent-coasters/system-info.sh
Added: usertools/persistent-coasters/system-info.swift
--- usertools/persistent-coasters/system-info.swift	                        (rev 0)
+++ usertools/persistent-coasters/system-info.swift	2011-01-17 21:39:33 UTC (rev 3982)
@@ -0,0 +1,20 @@
+ * Simple script that does nothing of consequence to
+ * the CoasterService.  Settings are passed along
+ * which configure the CoasterService.
+ * We can do some diagnostic stuff here.
+type file;
+app (file output) passivate (file script)
+  sh @script stdout=@output;
+file s<"system-info.sh">;
+file o<"system-info.out">;
+o = passivate(s);
