[Swift-commit] r3977 - usertools/persistent-coasters
noreply at svn.ci.uchicago.edu
Mon Jan 17 14:34:14 CST 2011
Author: wozniak
Date: 2011-01-17 14:34:14 -0600 (Mon, 17 Jan 2011)
New Revision: 3977
Added:
usertools/persistent-coasters/start-service.zsh
Removed:
usertools/persistent-coasters/run.zsh
Log:
Rename main script
Deleted: usertools/persistent-coasters/run.zsh
--- usertools/persistent-coasters/run.zsh 2011-01-17 20:33:30 UTC (rev 3976)
+++ usertools/persistent-coasters/run.zsh 2011-01-17 20:34:14 UTC (rev 3977)
@@ -1,134 +0,0 @@
-#!/bin/zsh
-# If you get "Could not get coasters service" the
-# service may already be running on SERVICE_PORT
-# Process management is incomplete here, check for
-# processes with ps
-set -x
-PC=$( cd $( dirname $0 ) ; /bin/pwd )
-TOOLS=${PC} # In the future this might be ${SWIFT_HOME}/tools
-source ${TOOLS}/helpers.zsh
-[[ $? != 0 ]] && print "Could not load helpers.zsh!" && exit 1
-[[ ${SWIFT} == "" ]] && SWIFT=$( which swift )
-SWIFT_BIN=$( dirname ${SWIFT} )
-COASTER_RESOURCES=${SWIFT_BIN}/../../../../provider-coaster/resources
-WORKER=${COASTER_RESOURCES}/worker.pl
-export SERVICE_PORT=10985
-LOGDIR=logs
-mkdir -p ${LOGDIR}
-exitcode
-SWIFT_OUT=${LOGDIR}/swift.out
-local OUT=$1
-source workers-local.zsh
-# source workers-ssh.zsh
-# Obtain the URL to which Swift should connect
-get_service_coasters()
- local OUT=$1
- LINE=()
- COUNT=0
- for COUNT in {1..3}
- do
- LINE=( $( grep --text "Started coaster service:" ${OUT} ) )
- if [[ ${#LINE} == 0 ]] then
- grep Error ${OUT} >& /dev/null && return 1
- sleep 3
- else
- break
- fi
- done
- [[ ${#LINE} == 0 ]] && return 1
- CONTACT=${LINE[-1]}
- print ${CONTACT}
- return 0
-# Obtain the URL to which the workers should connect
-get_service_local()
- local OUT=$1
- LINE=()
- COUNT=0
- for COUNT in {1..4}
- do
- LINE=( $( grep "Passive queue processor" ${OUT} ) )
- sleep 4
- else
- break
- fi
- if grep "Error" ${OUT} >& /dev/null
- then
- print "coaster-service error!" >&2
- cat ${OUT} >&2
- return 1
- fi
- done
- print ${CONTACT}
- return 0
-SIGNALS="EXIT INT QUIT"
-cleanup_trap()
- print "cleanup_trap()..."
- eval trap - ${SIGNALS}
- [[ ${COASTER_SERVICE_PID} != "" ]] && kill ${COASTER_SERVICE_PID}
- [[ ${STARTWORKERS_PID} != "" ]] && kill ${START_WORKERS_PID}
-# eval trap cleanup_trap ${SIGNALS}
-SERVICE_LOG=${LOGDIR}/coaster-service.log
-coaster-service -nosec -p ${SERVICE_PORT} >& ${SERVICE_LOG} &
-COASTER_SERVICE_PID=${!}
-sleep 1
-SERVICE_COASTERS=$( get_service_coasters ${SERVICE_LOG} )
-exitcode "Could not get coasters service!"
-export SERVICE_COASTERS
-source setup.sh
-exitcode "setup.sh failed!"
-sleep 1
-{ ${SWIFT} -config swift.properties \
- -sites.file sites.passivate.xml \
- -tc.file tc.passivate.data \
- passivate.swift < /dev/null >& ${SWIFT_OUT}
- exitcode "Swift failed!"
- print "Swift finished."
-SWIFT_PID=${!}
-sleep 1
-pwd
-SERVICE_LOCAL=$( get_service_local ${SWIFT_OUT} )
-exitcode "get_service_local failed!"
-export SERVICE_LOCAL
-sleep 1
-print "Starting workers..."
-start_workers ${SERVICE_LOCAL} &
-START_WORKERS_PID=${!}
-sleep 1
-exit 0
Copied: usertools/persistent-coasters/start-service.zsh (from rev 3973, usertools/persistent-coasters/run.zsh)
--- usertools/persistent-coasters/start-service.zsh (rev 0)
+++ usertools/persistent-coasters/start-service.zsh 2011-01-17 20:34:14 UTC (rev 3977)
@@ -0,0 +1,134 @@
+#!/bin/zsh
+# If you get "Could not get coasters service" the
+# service may already be running on SERVICE_PORT
+# Process management is incomplete here, check for
+# processes with ps
+set -x
+PC=$( cd $( dirname $0 ) ; /bin/pwd )
+TOOLS=${PC} # In the future this might be ${SWIFT_HOME}/tools
+source ${TOOLS}/helpers.zsh
+[[ $? != 0 ]] && print "Could not load helpers.zsh!" && exit 1
+[[ ${SWIFT} == "" ]] && SWIFT=$( which swift )
+SWIFT_BIN=$( dirname ${SWIFT} )
+COASTER_RESOURCES=${SWIFT_BIN}/../../../../provider-coaster/resources
+WORKER=${COASTER_RESOURCES}/worker.pl
+export SERVICE_PORT=10985
+LOGDIR=logs
+mkdir -p ${LOGDIR}
+exitcode
+SWIFT_OUT=${LOGDIR}/swift.out
+local OUT=$1
+source workers-local.zsh
+# source workers-ssh.zsh
+# Obtain the URL to which Swift should connect
+get_service_coasters()
+ local OUT=$1
+ LINE=()
+ COUNT=0
+ for COUNT in {1..3}
+ do
+ LINE=( $( grep --text "Started coaster service:" ${OUT} ) )
+ if [[ ${#LINE} == 0 ]] then
+ grep Error ${OUT} >& /dev/null && return 1
+ sleep 3
+ else
+ break
+ fi
+ done
+ [[ ${#LINE} == 0 ]] && return 1
+ CONTACT=${LINE[-1]}
+ print ${CONTACT}
+ return 0
+# Obtain the URL to which the workers should connect
+get_service_local()
+ local OUT=$1
+ LINE=()
+ COUNT=0
+ for COUNT in {1..4}
+ do
+ LINE=( $( grep "Passive queue processor" ${OUT} ) )
+ sleep 4
+ else
+ break
+ fi
+ if grep "Error" ${OUT} >& /dev/null
+ then
+ print "coaster-service error!" >&2
+ cat ${OUT} >&2
+ return 1
+ fi
+ done
+ print ${CONTACT}
+ return 0
+SIGNALS="EXIT INT QUIT"
+cleanup_trap()
+ print "cleanup_trap()..."
+ eval trap - ${SIGNALS}
+ [[ ${COASTER_SERVICE_PID} != "" ]] && kill ${COASTER_SERVICE_PID}
+ [[ ${STARTWORKERS_PID} != "" ]] && kill ${START_WORKERS_PID}
+# eval trap cleanup_trap ${SIGNALS}
+SERVICE_LOG=${LOGDIR}/coaster-service.log
+coaster-service -nosec -p ${SERVICE_PORT} >& ${SERVICE_LOG} &
+COASTER_SERVICE_PID=${!}
+sleep 1
+SERVICE_COASTERS=$( get_service_coasters ${SERVICE_LOG} )
+exitcode "Could not get coasters service!"
+export SERVICE_COASTERS
+source setup.sh
+exitcode "setup.sh failed!"
+sleep 1
+{ ${SWIFT} -config swift.properties \
+ -sites.file sites.passivate.xml \
+ -tc.file tc.passivate.data \
+ passivate.swift < /dev/null >& ${SWIFT_OUT}
+ exitcode "Swift failed!"
+ print "Swift finished."
+SWIFT_PID=${!}
+sleep 1
+pwd
+SERVICE_LOCAL=$( get_service_local ${SWIFT_OUT} )
+exitcode "get_service_local failed!"
+export SERVICE_LOCAL
+sleep 1
+print "Starting workers..."
+start_workers ${SERVICE_LOCAL} &
+START_WORKERS_PID=${!}
+sleep 1
+exit 0
More information about the Swift-commit
