[Swift-commit] r3968 - SwiftApps/SwiftR/Swift/exec
noreply at svn.ci.uchicago.edu
Sat Jan 15 17:28:25 CST 2011
Author: wilde
Date: 2011-01-15 17:28:25 -0600 (Sat, 15 Jan 2011)
New Revision: 3968
Modified:
SwiftApps/SwiftR/Swift/exec/start-swift
Log:
Interim changes for SGE support, from siraf.
Modified: SwiftApps/SwiftR/Swift/exec/start-swift
--- SwiftApps/SwiftR/Swift/exec/start-swift 2011-01-15 03:08:22 UTC (rev 3967)
+++ SwiftApps/SwiftR/Swift/exec/start-swift 2011-01-15 23:28:25 UTC (rev 3968)
@@ -1,6 +1,6 @@
#! /bin/bash
-set -x
+# set -x
export TRAPEVENTS="EXIT 1 2 3 15" # Signals and conditions to trap
@@ -143,11 +143,10 @@
# FIXME: for big systems like Ranger, need to use ssh_tree to avoid socket FD exhastion?
-echo about to define make-sge
+echo def make-sge-submit-file
make-sge-submit-file()
-echo in $0
if [ $queue != NONE ]; then
queueDirective="#$ -q $queue"
else
@@ -158,14 +157,14 @@
else
projectDirective=""
fi
- if [ $perEnv != NONE ]; then
- parEnvDirective="#$ -pe $parEnv $(($nodes*$cores))
+ if [ $parEnv != NONE ]; then
+ parEnvDirective="#$ -pe $parEnv $(($nodes*$cores))"
else
parEnvDirective=""
fi
# rcmd="qrsh" # FIXME - need to set on system basis; qrsh works for siraf
cat >batch.sub <<END
#!/bin/bash
#$ -S /bin/bash
@@ -173,13 +172,13 @@
#$ -e $HOME
#$ -N SwiftR
#$ -l h_rt=$time
-# #$ -v WORKER_LOGGING_LEVEL=NONE
#$ -V
$parEnvDirective
$queueDirective
$projectDirective
+# $ -v WORKER_LOGGING_LEVEL=NONE
# Ranger Site-specific:
# $ -pe 16way 256
# $ -q development
@@ -229,8 +228,8 @@
usage()
echo >&2 "usage: $0 -c cores -h 'host1 ... hostN' -n nodes -q queue -s server -p parallelJobs -t walltime"
- echo >&2 " valid servers: local, ssh, pbs, pbsf (pbs with firewalled workers)"
- echo >&2 " defaults: cores=2 nodes=1 queue=none server=local parallelJobs=10 walltime=00:30:00 (hh:mm:ss) "
+ echo >&2 " valid servers: local, ssh, pbs, pbsf (for firewalled worker nodes), sge"
+ echo >&2 " defaults: cores=2 nodes=1 queue=none server=local parallelJobs=10 walltime=00:30:00 (hh:mm:ss)"
verify-is-one-of()
@@ -294,7 +293,7 @@
parEnv=NONE
rcmd=ssh # rcmd: ssh (typical) or qrsh (eg for siraf with node login restrictions)
-workmode=slot # slot: start one worker on each slot; node: start on worker for all slots on a node
+workmode=slot # slot: start one worker on each slot; node: start one worker for all slots on a node
while [ $# -gt 0 ]
do
More information about the Swift-commit
