[Swift-commit] r3961 - usertools/persistent-coasters
noreply at svn.ci.uchicago.edu
Wed Jan 12 11:34:43 CST 2011
Author: wozniak
Date: 2011-01-12 11:34:43 -0600 (Wed, 12 Jan 2011)
New Revision: 3961
Added:
usertools/persistent-coasters/coasters-setup.sh
usertools/persistent-coasters/gensites.sh
usertools/persistent-coasters/gentc.sh
usertools/persistent-coasters/helpers.zsh
Modified:
usertools/persistent-coasters/run.zsh
Log:
Additional required scripts from cdm/scripts/tools
Added: usertools/persistent-coasters/coasters-setup.sh
--- usertools/persistent-coasters/coasters-setup.sh (rev 0)
+++ usertools/persistent-coasters/coasters-setup.sh 2011-01-12 17:34:43 UTC (rev 3961)
@@ -0,0 +1,5 @@
+# Source this to setup GLOBUS_HOSTNAME
+ipaddr=$( ifconfig | grep inet | head -1 | cut -d ':' -f 2 | awk '{print $1}' )
+export GLOBUS_HOSTNAME=$ipaddr
Added: usertools/persistent-coasters/gensites.sh
--- usertools/persistent-coasters/gensites.sh (rev 0)
+++ usertools/persistent-coasters/gensites.sh 2011-01-12 17:34:43 UTC (rev 3961)
@@ -0,0 +1,55 @@
+#!/bin/sh
+# Certain sites files may require environment variables,
+# see below.
+# In particular, URL for the coasters persistent service
+# Swift work directory, e.g., ${HOME}/work
+WORK=$1
+# Input sites file, e.g., sites.local.xml
+INPUT=$2
+# Output sites file, e.g., sites.xml
+OUTPUT=$3
+crash()
+ MSG=$1
+ echo ${MSG}
+ exit 1
+[[ ${WORK} == "" ]] && crash "Not specified: WORK"
+[[ ${INPUT} == "" ]] && crash "Not specified: INPUT"
+[[ ${OUTPUT} == "" ]] && crash "Not specified: OUTPUT"
+[[ ${GLOBUS_HOSTNAME} == "" ]] && crash "Not specified: GLOBUS_HOSTNAME"
+# If the sites file requires a PROJECT, QUEUE, N_GRAN, or N_MAX and
+# it is not set in the environment, crash:
+for TOKEN in PROJECT QUEUE N_GRAN N_MAX SLOTS
+ do
+ if grep _${TOKEN}_ ${INPUT} > /dev/null
+ then
+ if ! declare -p ${TOKEN} > /dev/null
+ then
+ printenv
+ crash "Not specified: ${TOKEN}"
+ fi
+ fi
+done
+ echo "s/_NODES_/${NODES}/"
+ echo "s/_HOST_/${GLOBUS_HOSTNAME}/"
+ echo "s at _WORK_@${WORK}@"
+ echo "s/_PROJECT_/${PROJECT}/"
+ echo "s/_QUEUE_/${QUEUE}/"
+ echo "s/_N_GRAN_/${N_GRAN}/"
+ echo "s/_N_MAX_/${N_MAX}/"
+ echo "s/_SLOTS_/${SLOTS}/"
+ echo "s/_MAXTIME_/${MAXTIME}/"
+ echo "s at _SERVICE_COASTERS_@${SERVICE_COASTERS:-NO_URL_GIVEN}@"
+ echo "s at _SERVICE_PORT_@${SERVICE_PORT:-NO_PORT_GIVEN}@"
+} > gensites.sed
+sed -f gensites.sed < ${INPUT} > ${OUTPUT}
Property changes on: usertools/persistent-coasters/gensites.sh
___________________________________________________________________
Added: usertools/persistent-coasters/gentc.sh
--- usertools/persistent-coasters/gentc.sh (rev 0)
+++ usertools/persistent-coasters/gentc.sh 2011-01-12 17:34:43 UTC (rev 3961)
@@ -0,0 +1,26 @@
+#!/bin/sh
+# Substitutes PWD for _DIR_ in tc files
+# example usage: gentc.sh tc.something.data tc.data ${PWD}
+# Input tc file, e.g., tc.local.data
+INPUT=$1
+# Output tc file, e.g., tc.data
+OUTPUT=$2
+DIR=$3
+[[ ${DIR} == "" ]] && echo "No DIR!" && exit 1
+crash()
+ MSG=$1
+ echo ${MSG}
+ exit 1
+ sed "s at _DIR_@${DIR}@"
+} < ${INPUT} > ${OUTPUT}
Property changes on: usertools/persistent-coasters/gentc.sh
Added: usertools/persistent-coasters/helpers.zsh
--- usertools/persistent-coasters/helpers.zsh (rev 0)
+++ usertools/persistent-coasters/helpers.zsh 2011-01-12 17:34:43 UTC (rev 3961)
@@ -0,0 +1,241 @@
+KB=1024
+MB=$(( 1024*KB ))
+GB=$(( 1024*MB ))
+assert() {
+ ERR=$1
+ shift
+ MSG="${*}"
+ check ${ERR} "${MSG}" || exit ${ERR}
+ return 0
+exitcode()
+ ERR=$?
+ MSG="${*}"
+ assert ${ERR} "${MSG}"
+# If CODE is non-zero, print MSG and return CODE
+check()
+ CODE=$1
+ shift
+ MSG=${*}
+ if [[ ${CODE} != 0 ]]
+ then
+ print ${MSG}
+ return ${CODE}
+ fi
+ return 0
+bail()
+ CODE=$1
+ shift
+ MSG="${*}"
+ print "${MSG}"
+ set +x
+crash()
+ CODE=$1
+ shift
+ MSG="${*}"
+ bail ${CODE} ${MSG}
+ exit ${CODE}
+checkvar()
+ local VAR=$1
+ if [[ ${(P)VAR} == "" ]]
+ then
+ crash 1 "Not set: ${VAR}"
+ fi
+ return 0
+checkvars()
+ local VARS
+ VARS=( ${*} )
+ for V in ${VARS}
+ do
+ checkvar ${V}
+ done
+ return 0
+nanos()
+ date +%s.%N
+within()
+ local TIME=$1
+ shift
+ local START STOP DIFF LEFT
+ START=$( nanos )
+ STOP=$( nanos )
+ DIFF=$(( STOP-START ))
+ if (( DIFF < 0 ))
+ then
+ print "TIME exceeded (${DIFF} > ${TIME})!"
+ return 1
+ fi
+ LEFT=$(( TIME-LEFT ))
+ sleep ${LEFT}
+ return 0
+scan()
+# Use shoot to output the contents of a scan
+ [[ $1 == "" ]] && return
+ typeset -g -a $1
+ local i=1
+ local T
+ while read T
+ do
+ eval "${1}[${i}]='${T}'"
+ (( i++ ))
+ done
+shoot()
+# print out an array loaded by scan()
+ local i
+ local N
+ N=$( eval print '${#'$1'}' )
+ # print N $N
+ for (( i=1 ; i <= N ; i++ ))
+ do
+ eval print -- "$"${1}"["${i}"]"
+ done
+scan_kv()
+ [[ $1 == "" ]] && return 1
+ typeset -g -A $1
+ while read T
+ do
+ A=( ${T} )
+ KEY=${A[1]%:} # Strip any tailing :
+ VALUE=${A[2,-1]}
+ eval "${1}[${KEY}]='${VALUE}'"
+ done
+ return 0
+shoot_kv()
+ local VAR=$1
+ eval print -a -C 2 \"'${(kv)'$VAR'[@]}'\"
+ return 0
+tformat()
+# Convert seconds to hh:mm:ss
+ local -Z 2 T=$1
+ local -Z 2 M
+ if (( T <= 60 ))
+ then
+ print "${T}"
+ elif (( T <= 3600 ))
+ then
+ M=$(( T/60 ))
+ print "${M}:$( tformat $(( T%60 )) )"
+ else
+ print "$(( T/3600 )):$( tformat $(( T%3600 )) )"
+ fi
+bformat()
+# Format byte counts
+ local BYTES=$1
+ local LENGTH=${2:-3}
+ local UNIT
+ local UNITS
+ UNITS=( "B" "KB" "MB" "GB" "TB" )
+ local B=${BYTES}
+ for (( UNIT=0 ; UNIT < 4 ; UNIT++ ))
+ do
+ (( B /= 1024 ))
+ (( B == 0 )) && break
+ done
+ local RESULT=${UNITS[UNIT+1]}
+ if [[ ${RESULT} == "B" ]]
+ then
+ print "${BYTES} B"
+ else
+ local -F BF=${BYTES}
+ local MANTISSA=$(( BF / (1024 ** UNIT ) ))
+ MANTISSA=$( significant ${LENGTH} ${MANTISSA} )
+ print "${MANTISSA} ${RESULT}"
+ fi
+ return 0
+significant()
+# Report significant digits from floating point number
+ local DIGITS=$1
+ local NUMBER=$2
+ local -F FLOAT=${NUMBER}
+ local RESULT
+ local DOT=0
+ local LZ=1 # Leading zeros
+ local C
+ local i=1
+ while (( 1 ))
+ do
+ C=${FLOAT[i]}
+ [[ ${C} != "0" ]] && [[ ${C} != "." ]] && break
+ [[ ${C} == "." ]] && DOT=1
+ RESULT+=${C}
+ (( i++ ))
+ done
+ while (( ${DIGITS} > 0 ))
+ do
+ C=${FLOAT[i]}
+ if [[ ${C} == "" ]]
+ then
+ (( ! DOT )) && RESULT+="." && DOT=1
+ C="0"
+ fi
+ RESULT+=${C}
+ [[ ${C} == "." ]] && (( DIGITS++ )) && DOT=1
+ (( i++ ))
+ (( DIGITS-- ))
+ done
+ if (( ! DOT )) # Extra zeros to finish out integer
+ then
+ local -i J=${NUMBER}
+ # J=${J}
+ while (( ${#RESULT} < ${#J} ))
+ do
+ RESULT+="0"
+ done
+ fi
+ print ${RESULT}
+ return 0
Modified: usertools/persistent-coasters/run.zsh
--- usertools/persistent-coasters/run.zsh 2011-01-12 17:31:25 UTC (rev 3960)
+++ usertools/persistent-coasters/run.zsh 2011-01-12 17:34:43 UTC (rev 3961)
@@ -1,5 +1,8 @@
#!/bin/zsh
+# Process management is incomplete here, check for
+# processes with ps
set -x
APP=$( cd $( dirname $0 ) ; /bin/pwd )
More information about the Swift-commit
