[Swift-commit] r3955 - provenancedb
noreply at svn.ci.uchicago.edu
Wed Jan 12 10:52:57 CST 2011
Author: lgadelha
Date: 2011-01-12 10:52:57 -0600 (Wed, 12 Jan 2011)
New Revision: 3955
Modified:
provenancedb/pql_functions.sql
provenancedb/prov-init.sql
Log:
Added support for lineage queries using SQL recursion.
Modified: provenancedb/pql_functions.sql
--- provenancedb/pql_functions.sql 2011-01-12 16:24:09 UTC (rev 3954)
+++ provenancedb/pql_functions.sql 2011-01-12 16:52:57 UTC (rev 3955)
@@ -149,3 +149,18 @@
ds_usage.param_name='prot' OR ds_usage.param_name='prepTarFile' OR ds_usage.param_name='nSim') AND
annot_wf_txt.name='oops_run_id' AND annot_wf_txt.value=$1;
$$ LANGUAGE SQL;
+-- recursive query to find ancestor entities in a provenance graph
+create or replace function ancestors(varchar) returns setof varchar as $$
+ with recursive anc(ancestor,descendant) as
+ select parent as ancestor, child as descendant from parent_of where child=$1
+ union all
+ select parent_of.parent as ancestor, anc.descendant as descendant
+ from anc,parent_of
+ where anc.ancestor=parent_of.child
+ select ancestor from anc
+$$ language sql;
Modified: provenancedb/prov-init.sql
--- provenancedb/prov-init.sql 2011-01-12 16:24:09 UTC (rev 3954)
+++ provenancedb/prov-init.sql 2011-01-12 16:52:57 UTC (rev 3955)
@@ -198,6 +198,13 @@
primary key (id, name)
+create view parent_of as
+ select process_id as parent,dataset_id as child from ds_usage where direction='O'
+ union
+ select dataset_id as parent,process_id as child from ds_usage where direction='I'
+ union
+ select out_id as parent,in_id as child from ds_containment;
-- extrainfo stores lines generated by the SWIFT_EXTRA_INFO feature
-- extrainfo will be processes into annotation tables
-- CREATE TABLE extrainfo
More information about the Swift-commit
