[Swift-commit] r3907 - in text/parco10submission: . code
Sat Jan 8 16:42:43 CST 2011
Author: wilde
Date: 2011-01-08 16:42:43 -0600 (Sat, 08 Jan 2011)
New Revision: 3907
Added:
   text/parco10submission/code/
   text/parco10submission/code/glass.swift
   text/parco10submission/code/glassRunCavities.swift.ORIG
   text/parco10submission/code/modis.swift
Modified:
   text/parco10submission/paper.tex
Log:
Moved example scripts to a code/ dir and include them from \InputVerbatim directives.
Added: text/parco10submission/code/glass.swift
--- text/parco10submission/code/glass.swift	                        (rev 0)
+++ text/parco10submission/code/glass.swift	2011-01-08 22:42:43 UTC (rev 3907)
@@ -0,0 +1,82 @@
+type Arc;
+type Restart;
+type Log;
+type GlassIn{
+  Restart startfile;
+type GlassOut{
+  Arc arcfile;
+  Restart restartfile;
+  Restart final;
+  Log logfile;
+app (GlassOut o) glassCavityRun(
+  GlassIn i, string rad, string temp, string steps,
+  string volume, string fraca, string energyfunction,
+  string centerstring, string arctimestring)
+  glassRun "-a" @filename(o.final) "--lf" @filename(i.startfile)
+    "--temp" temp "--stepsperparticle" steps "--volume" volume
+    "--fraca" fraca "--energy_function" energyfunction
+    "--cradius" rad "--ccoord" centerstring arctimestring
+    stdout=@filename(o.logfile);
+CreateGlassSystem()
+  string temp=@arg("temp","2.0");
+  string steps=@arg("steps","10");
+  string esteps=@arg("esteps","100");
+  string ceqsteps=@arg("ceqsteps","100");
+  string natoms=@arg("natoms","200");
+  string volume=@arg("volume","200");
+  string rlist=@arg("rlist","rlist");
+  string clist=@arg("clist","clist");
+  string fraca=@arg("fraca","0.5");
+  string radii[] = readData(rlist);
+  string centers[] = readData(clist);
+  int nmodels=@toint( @arg("n","1") );
+  int nsub=@toint( @arg("nsub","1") );
+  string savearc=@arg("savearc","FALSE");
+  string arctimestring;
+  if(savearc=="FALSE") {
+    arctimestring="--arc_time=10000000";
+  else{
+    arctimestring="";
+  string energyfunction=@arg("energyfunction","softsphereratiosmooth");
+  GlassIn modelIn[][][] <ext;exec="GlassCavityOutArray.map",
+    rlist=rlist, clist=clist, steps=ceqsteps, n=nmodels,
+    esteps=esteps, temp=temp, volume=volume,
+    e=energyfunction, natoms=natoms, i="true">;
+  GlassOut modelOut[][][][] <ext; exec="GlassCavityContinueOutArray.map",
+    n=nmodels, nsub=nsub, rlist=rlist, clist=clist,
+    ceqsteps=ceqsteps, esteps=esteps, steps=steps, temp=temp, volume=volume,
+    e=energyfunction, natoms=natoms>;
+  foreach rad,rindex in radii {
+    foreach centerstring,cindex in centers {
+      foreach model in [0:nmodels-1] {
+        foreach job in [0:nsub-1] {
+          string fname =
+            @filename(modelOut[rindex][cindex][model][job].final)
+          if (fname != "NULL") {
+            modelOut[rindex][cindex][model][job] =
+              glassCavityRun( modelIn[rindex][cindex][model],
+                rad, temp, steps, volume, fraca, energyfunction,
+                centerstring, arctimestring);
+CreateGlassSystem();
Added: text/parco10submission/code/glassRunCavities.swift.ORIG
--- text/parco10submission/code/glassRunCavities.swift.ORIG	                        (rev 0)
+++ text/parco10submission/code/glassRunCavities.swift.ORIG	2011-01-08 22:42:43 UTC (rev 3907)
@@ -0,0 +1,120 @@
+type file;
+type Text;
+type Arc;
+type Restart;
+type Log;
+type GlassOut{
+    Arc arcfile;
+    Restart final;
+    Log logfile;
+type GlassIn{
+// Lib functions (to be moved to imported file
+app (file o) echoi (int i)     { echo i stdout=@o;}
+app (file o) echof (float f)   { echo f stdout=@o;}
+app (file o) echob (boolean b) { echo b stdout=@o;}
+app (file o) echos (string s)  { echo s stdout=@o;}
+(string s) itostr (int i)
+  file f;
+  f = echoi(i);
+  s = readData(f);
+(string s) ftostr (float n)
+  file f;
+  f = echof(n);
+  s = readData(f);
+(int n) strtoi (string s)
+  file f;
+  f = echos(s);
+  n = readData(f);
+(float n) strtof (string s)
+  file f;
+  f = echos(s);
+  n = readData(f);
+app (file o) sprintfsApp (string fmt, string e[])
+  sprintfs fmt e stdout=@o;
+(string s) sprintfs (string fmt, string e[])
+  file f;
+  f = sprintfsApp(fmt,e);
+  s = readData(f);
+//glassSim app declarations
+//app (int result) multiply(int a,int b)
+//    file f;
+//    multiply a b stdout=@filename(f);
+//    result=readData(f);
+app (GlassOut o) glassCavityRun(GlassIn i,string rad,string temp,string steps,string volume,string fraca,string energyfunction,string centerstring,string arctimestring)
+    glassRun "-a" @filename(o.final) "--lf" @filename(i.startfile) "--temp" temp "--stepsperparticle" steps "--volume" volume "--fraca" fraca "--energy_function" energyfunction "--cradius" rad "--ccoord" centerstring arctimestring stdout=@filename(o.logfile);
+    int nmodels=strtoi( @arg("n","1") );
+    int nsub=strtoi( @arg("nsub","1") );
+//    int njobs=nsub*nmodels;
+    else{
+        arctimestring="";
+    GlassIn modelIn[][][] <ext;exec="GlassCavityOutArray.map",rlist=rlist,clist=clist,steps=ceqsteps,n=nmodels,esteps=esteps,temp=temp,volume=volume,e=energyfunction,natoms=natoms,i="true">;
+    GlassOut modelOut[][][][] <ext;exec="GlassCavityContinueOutArray.map",n=nmodels,nsub=nsub,rlist=rlist,clist=clist,ceqsteps=ceqsteps,esteps=esteps,steps=steps,temp=temp,volume=volume,e=energyfunction,natoms=natoms>;
+                    if( !(@filename(modelOut[rindex][cindex][model][job].final)=="NULL") ){
+                        modelOut[rindex][cindex][model][job]=glassCavityRun(modelIn[rindex][cindex][model],rad,temp,steps,volume,fraca,energyfunction,centerstring,arctimestring);
Added: text/parco10submission/code/modis.swift
--- text/parco10submission/code/modis.swift	                        (rev 0)
+++ text/parco10submission/code/modis.swift	2011-01-08 22:42:43 UTC (rev 3907)
@@ -0,0 +1,84 @@
+type file;
+type MODIS; type image;
+type landuse;
+# Define application program interfaces
+app (landuse output) getLandUse (imagefile input, int sortfield)
+  getlanduse @input sortfield stdout=@output ;
+app (file output, file tilelist) analyzeLandUse
+    (MODIS input[], string usetype, int maxnum)
+  analyzelanduse @output @tilelist usetype maxnum @filenames(input);
+app (image output) colorMODIS (MODIS input)
+  colormodis @input @output;
+app (image output) assemble
+    (file selected, image img[], string webdir)
+  assemble @output @selected @filename(img[0]) webdir;
+app (image grid) markMap (file tilelist)
+  markmap @tilelist @grid;
+# Constants and command line arguments
+int nFiles =      @toint(@arg("nfiles","1000"));
+int nSelect =     @toint(@arg("nselect","12"));
+string landType = @arg("landtype","urban");
+string runID =    @arg("runid","modis-run");
+string MODISdir=  @arg("modisdir","/home/wilde/bigdata/data/modis/2002");
+string webDir =   @arg("webdir","/home/wilde/public_html/geo/");
+# Input Dataset
+image geos[] <ext; exec="modis.mapper",
+  location=MODISdir, suffix=".tif", n=nFiles >;
+# Compute the land use summary of each MODIS tile
+landuse land[] <structured_regexp_mapper; source=geos, match="(h..v..)",
+  transform=@strcat(runID,"/\\1.landuse.byfreq")>;
+foreach g,i in geos {
+    land[i] = getLandUse(g,1);
+# Find the top N tiles (by total area of selected landuse types)
+file topSelected<"topselected.txt">;
+file selectedTiles<"selectedtiles.txt">;
+(topSelected, selectedTiles) = analyzeLandUse(land, landType, nSelect);
+# Mark the top N tiles on a sinusoidal gridded map
+image gridMap<"markedGrid.gif">;
+gridMap = markMap(topSelected);
+# Create multi-color images for all tiles
+image colorImage[] <structured_regexp_mapper;
+          source=geos, match="(h..v..)",
+          transform="landuse/\\1.color.png">;
+foreach g, i in geos {
+  colorImage[i] = colorMODIS(g);
+# Assemble a montage of the top selected areas
+image montage <single_file_mapper; file=@strcat(runID,"/","map.png") >; # @arg
+montage = assemble(selectedTiles,colorImage,webDir);
Modified: text/parco10submission/paper.tex
--- text/parco10submission/paper.tex	2011-01-08 22:10:00 UTC (rev 3906)
+++ text/parco10submission/paper.tex	2011-01-08 22:42:43 UTC (rev 3907)
@@ -1286,92 +1286,9 @@
 \pagebreak
 {\bf \small Swift example 1: MODIS satellite image processing script}
-\begin{Verbatim}[fontsize=\scriptsize,frame=single,framesep=2mm,gobble=7, numbers=left]
-     1	type file;
-     2	type MODIS; type image;
-     3	type landuse;
-     4
-     5	# Define application program interfaces
-     6
-     7	app (landuse output) getLandUse (imagefile input, int sortfield)
-     8	{
-     9	  getlanduse @input sortfield stdout=@output ;
-    10	}
-    11
-    12	app (file output, file tilelist) analyzeLandUse
-    13	    (MODIS input[], string usetype, int maxnum)
-    14	{
-    15	  analyzelanduse @output @tilelist usetype maxnum @filenames(input);
-    16	}
-    17
-    18	app (image output) colorMODIS (MODIS input)
-    19	{
-    20	  colormodis @input @output;
-    21	}
-    22
-    23	app (image output) assemble
-    24	    (file selected, image img[], string webdir)
-    25	{
-    26	  assemble @output @selected @filename(img[0]) webdir;
-    27	}
-    28
-    29	app (image grid) markMap (file tilelist)
-    30	{
-    31	  markmap @tilelist @grid;
-    32	}
-    33
-    34	# Constants and command line arguments
-    35
-    36	int nFiles =      @toint(@arg("nfiles","1000"));
-    37	int nSelect =     @toint(@arg("nselect","12"));
-    38	string landType = @arg("landtype","urban");
-    39	string runID =    @arg("runid","modis-run");
-    40	string MODISdir=  @arg("modisdir","/home/wilde/bigdata/data/modis/2002");
-    41	string webDir =   @arg("webdir","/home/wilde/public_html/geo/");
-    42
-    43
-    44
-    45	# Input Dataset
-    46
-    47	image geos[] <ext; exec="modis.mapper",
-    48	  location=MODISdir, suffix=".tif", n=nFiles >;
-    49
-    50	# Compute the land use summary of each MODIS tile
-    51
-    52	landuse land[] <structured_regexp_mapper; source=geos, match="(h..v..)",
-    53	  transform=@strcat(runID,"/\\1.landuse.byfreq")>;
-    54
-    55	foreach g,i in geos {
-    56	    land[i] = getLandUse(g,1);
-    57	}
-    58
-    59	# Find the top N tiles (by total area of selected landuse types)
-    60
-    61	file topSelected<"topselected.txt">;
-    62	file selectedTiles<"selectedtiles.txt">;
-    63	(topSelected, selectedTiles) = analyzeLandUse(land, landType, nSelect);
-    64
-    65	# Mark the top N tiles on a sinusoidal gridded map
-    66
-    67	image gridMap<"markedGrid.gif">;
-    68	gridMap = markMap(topSelected);
-    69
-    70	# Create multi-color images for all tiles
-    71
-    72	image colorImage[] <structured_regexp_mapper;
-    73	          source=geos, match="(h..v..)",
-    74	          transform="landuse/\\1.color.png">;
-    75
-    76	foreach g, i in geos {
-    77	  colorImage[i] = colorMODIS(g);
-    78	}
-    79
-    80	# Assemble a montage of the top selected areas
-    81
-    82	image montage <single_file_mapper; file=@strcat(runID,"/","map.png") >; # @arg
-    83	montage = assemble(selectedTiles,colorImage,webDir);
-\end{Verbatim}
+\VerbatimInput[fontsize=\scriptsize,frame=single,framesep=2mm, numbers=left] {code/modis.swift}
+%\VerbatimInput [fontsize=\scriptsize,frame=single,framesep=2mm,gobble=7, numbers=left]{modis.swift}
+%\end{Verbatim}
 %\end{verbatim}
 \subsection{Simulation of glass cavity dynamics and thermodynamics.}
@@ -1410,90 +1327,9 @@
 {\bf \small Swift example 2: Monte-Carlo simulation of glass cavity dynamics.}
 %\begin{verbatim}
-     1	type Arc;
-     2	type Restart;
-     3	type Log;
-     4
-     5	type GlassIn{
-     6	  Restart startfile;
-     7	}
-     8
-     9	type GlassOut{
-    10	  Arc arcfile;
-    11	  Restart restartfile;
-    12	  Restart startfile;
-    13	  Restart final;
-    14	  Log logfile;
-    15	}
-    16
-    17	app (GlassOut o) glassCavityRun(
-    18	  GlassIn i, string rad, string temp, string steps,
-    19	  string volume, string fraca, string energyfunction,
-    20	  string centerstring, string arctimestring)
-    21	{
-    22	  glassRun "-a" @filename(o.final) "--lf" @filename(i.startfile)
-    23	    "--temp" temp "--stepsperparticle" steps "--volume" volume
-    24	    "--fraca" fraca "--energy_function" energyfunction
-    25	    "--cradius" rad "--ccoord" centerstring arctimestring
-    26	    stdout=@filename(o.logfile);
-    27	}
-    28
-    29	CreateGlassSystem()
-    30	{
-    31	  string temp=@arg("temp","2.0");
-    32	  string steps=@arg("steps","10");
-    33	  string esteps=@arg("esteps","100");
-    34	  string ceqsteps=@arg("ceqsteps","100");
-    35	  string natoms=@arg("natoms","200");
-    36	  string volume=@arg("volume","200");
-    37	  string rlist=@arg("rlist","rlist");
-    38	  string clist=@arg("clist","clist");
-    39	  string fraca=@arg("fraca","0.5");
-    40	  string radii[] = readData(rlist);
-    41	  string centers[] = readData(clist);
-    42	  int nmodels=@toint( @arg("n","1") );
-    43	  int nsub=@toint( @arg("nsub","1") );
-    44	  string savearc=@arg("savearc","FALSE");
-    45	  string arctimestring;
-    46	  if(savearc=="FALSE") {
-    47	    arctimestring="--arc_time=10000000";
-    48	  }
-    49	  else{
-    50	    arctimestring="";
-    51	  }
-    52	  string energyfunction=@arg("energyfunction","softsphereratiosmooth");
-    53
-    54	  GlassIn modelIn[][][] <ext;exec="GlassCavityOutArray.map",
-    55	    rlist=rlist, clist=clist, steps=ceqsteps, n=nmodels,
-    56	    esteps=esteps, temp=temp, volume=volume,
-    57	    e=energyfunction, natoms=natoms, i="true">;
-    58	  GlassOut modelOut[][][][] <ext; exec="GlassCavityContinueOutArray.map",
-    59	    n=nmodels, nsub=nsub, rlist=rlist, clist=clist,
-    60	    ceqsteps=ceqsteps, esteps=esteps, steps=steps, temp=temp, volume=volume,
-    61	    e=energyfunction, natoms=natoms>;
-    62
-    63	  foreach rad,rindex in radii {
-    64	    foreach centerstring,cindex in centers {
-    65	      foreach model in [0:nmodels-1] {
-    66	        foreach job in [0:nsub-1] {
-    67	          string fname =
-    68	            @filename(modelOut[rindex][cindex][model][job].final)
-    69	          if (fname != "NULL") {
-    70	            modelOut[rindex][cindex][model][job] =
-    71	              glassCavityRun( modelIn[rindex][cindex][model],
-    72	                rad, temp, steps, volume, fraca, energyfunction,
-    73	                centerstring, arctimestring);
-    74	          }
-    75	        }
-    76	      }
-    77	    }
-    78	  }
-    79	}
-    80
-    81
-    82	CreateGlassSystem();
-\end{Verbatim}
+%\begin{Verbatim}[fontsize=\scriptsize,frame=single,framesep=2mm,gobble=7, numbers=left]
+\VerbatimInput[fontsize=\scriptsize,frame=single,framesep=2mm, numbers=left] {code/glass.swift}
+%\end{Verbatim}
 %\end{verbatim}
 \section{Performance Characteristics}
