[Swift-commit] r3872 - text/parco10submission
noreply at svn.ci.uchicago.edu
Thu Jan 6 15:26:49 CST 2011
Author: dsk
Date: 2011-01-06 15:26:48 -0600 (Thu, 06 Jan 2011)
New Revision: 3872
Modified:
text/parco10submission/paper.tex
Log:
updates in related work
Modified: text/parco10submission/paper.tex
--- text/parco10submission/paper.tex 2011-01-06 19:42:30 UTC (rev 3871)
+++ text/parco10submission/paper.tex 2011-01-06 21:26:48 UTC (rev 3872)
@@ -1662,34 +1662,26 @@
programming tool for the specification and execution of large parallel
computations on large quantities of data, and facilitating the
utilization of large distributed resources. However, the two also
-differ in many aspects:
+differ in many aspects. The
+MapReduce programming model supports key-value pairs as
+input or output datasets and two types of computation functions,
+map and reduce; Swift provides a type system and allows the
+definition of complex data structures and arbitrary computational
+procedures.
+In MapReduce, input and output data can be of
+several different formats, and it is also possible to define new
+data sources; Swift provides a more flexible mapping mechanism to
+map between logical data structures and various physical
+representations.
+Swift does not automatically partition input
+datasets as MapReduce does; Swift datasets can be organized in structures, and
+individual items in a dataset can be transferred accordingly along
+with computations.
+MapReduce schedules computations within a
+cluster with shared Google File System; Swift schedules across
+distributed Grid sites that may span multiple administrative
+domains, and deals with security and resource usage policy issues.
-\begin{itemize}
-\item Programming model: MapReduce only supports key-value pairs as
- input or output datasets and two types of computation functions,
- map and reduce; Swift provides a type system and allows the
- definition of complex data structures and arbitrary computational
- procedures.
-\item Data format: in MapReduce, input and output data can be of
- several different formats, and it is also possible to define new
- data sources. Swift provides a more flexible mapping mechanism to
- map between logical data structures and various physical
- representations.
-\item Dataset partition: Swift does not automatically partition input
- datasets. Instead, datasets can be organized in structures, and
- individual items in a dataset can be transferred accordingly along
- with computations.
-\item Execution environment: MapReduce schedules computations within a
- cluster with shared Google File System, where Swift schedules across
- distributed Grid sites that may span multiple administrative
- domains, and deals with security and resource usage policy issues.
-\end{itemize}
BPEL~\cite{BPEL_2006} is a Web Service-based standard that specifies
how a set of Web services interact to form a larger, composite Web
Service. BPEL is starting to be tested in scientific contexts. While
@@ -1699,7 +1691,7 @@
application with repetitive patterns on a collection of datasets could
result in large, repetitive BPEL documents~\cite{Sedna_2007}, and BPEL
is cumbersome if not impossible to write for computational
-scientists. Although BPEL can use \katznote{an? the?} XML Schema to describe data types,
+scientists. Although BPEL can use an XML Schema to describe data types,
it does not provide support for mapping between a logical XML view and
arbitrary physical representations.
More information about the Swift-commit
