[Swift-commit] r4142 - in SwiftApps/SwiftR/Swift: . exec tests
noreply at svn.ci.uchicago.edu
Thu Feb 24 17:25:51 CST 2011
Author: tga
Date: 2011-02-24 17:25:50 -0600 (Thu, 24 Feb 2011)
New Revision: 4142
Added:
SwiftApps/SwiftR/Swift/tests/
SwiftApps/SwiftR/Swift/tests/runtests.R
Removed:
Modified:
SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh
SwiftApps/SwiftR/Swift/exec/rserver.swift
Log:
Oops I shouldn't have deleted that.
Modified: SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh
--- SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh 2011-02-24 23:00:09 UTC (rev 4141)
+++ SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh 2011-02-24 23:25:50 UTC (rev 4142)
@@ -83,6 +83,31 @@
RPIDS=
+TIMEOUT=5
+function start_timeout {
+ ppid=$$
+ trap "timeout_handler" SIGHUP
+ sleep $TIMEOUT
+ kill -1 $ppid &> /dev/null #SIGHUP
+function stop_timeout {
+ trap "" SIGHUP
+function timeout_handler {
+ echo 'Timed out waiting to contact R process'
+ echo 'R log follows:'
+ echo '====================='
+ cat $SLOTDIR/R.log
+ exit 1
# Try to make slotdir.
# If the mkdir succeeds, this is the first request to the slot,
# so we create a new R server and send the current request to it;
@@ -99,18 +124,18 @@
#which Rscript >> $SLOTDIR/R.log
echo $PATH
$RServerScript $SLOTDIR >> $SLOTDIR/R.log 2>&1 & # launch R server
+ start_timeout
# idletimer $SLOTDIR </dev/null >/dev/null 2>&1 & # R saves pid in R.pid for idletimer to kill it
echo "$0: INFO: Launched $RServerScript $SLOTDIR Rscript"
else
# wait to make sure fifo exists
# fromR fifo is created last, so wait for that one
- if [ ! -p $SLOTDIR/fromR.fifo ]; then
- sleep 5 # FIXME: try a few times, or wait longer?
- echo "$0: ERROR: FIFO $SLOTDIR/fromR.fifo did not appear within 5 seconds.\n"
- exit 1
+ start_timeout
+ while 1; do
+ if [ -p $SLOTDIR/fromR.fifo ]; then
+ break
fi
- fi
+ done
fi
# Ready to talk to the server: send request and read response
@@ -130,7 +155,7 @@
touch $SLOTDIR/lastwrite
echo DB: Sent request
+ stop_timeout # started up ok
echo dummy stderr response 1>&2 # FIXME - testing if this is the provider staging problem (not xfering zero len stderr)
res=$(cat < $SLOTDIR/fromR.fifo)
Modified: SwiftApps/SwiftR/Swift/exec/rserver.swift
--- SwiftApps/SwiftR/Swift/exec/rserver.swift 2011-02-24 23:00:09 UTC (rev 4141)
+++ SwiftApps/SwiftR/Swift/exec/rserver.swift 2011-02-24 23:25:50 UTC (rev 4142)
@@ -10,7 +10,7 @@
app (external e, RData result, file stout, file sterr) runR (file shellscript, file RServerScript, RData rcall)
- bash "--noprofile" @shellscript @RServerScript @rcall @result stdout=@stout stderr=@sterr;
+ bash @shellscript @RServerScript @rcall @result stdout=@stout stderr=@sterr;
app ack (external e[])
Copied: SwiftApps/SwiftR/Swift/tests (from rev 4140, SwiftApps/SwiftR/Swift/tests)
Deleted: SwiftApps/SwiftR/Swift/tests/runtests.R
--- SwiftApps/SwiftR/Swift/tests/runtests.R 2011-02-24 22:49:20 UTC (rev 4140)
+++ SwiftApps/SwiftR/Swift/tests/runtests.R 2011-02-24 23:25:50 UTC (rev 4142)
@@ -1,5 +0,0 @@
-#!/usr/bin/env Rscript
-library(Swift)
-#TODO: take command line options to setup options
-runAllSwiftTests()
Copied: SwiftApps/SwiftR/Swift/tests/runtests.R (from rev 4140, SwiftApps/SwiftR/Swift/tests/runtests.R)
--- SwiftApps/SwiftR/Swift/tests/runtests.R (rev 0)
@@ -0,0 +1,5 @@
+#!/usr/bin/env Rscript
+library(Swift)
+#TODO: take command line options to setup options
+runAllSwiftTests()
More information about the Swift-commit
