[Swift-commit] r4137 - SwiftApps/SwiftR
Tue Feb 22 13:35:00 CST 2011
Author: tga
Date: 2011-02-22 13:35:00 -0600 (Tue, 22 Feb 2011)
New Revision: 4137
Modified:
   SwiftApps/SwiftR/IMMEDIATE-TODO
Log:
TODO update.
Modified: SwiftApps/SwiftR/IMMEDIATE-TODO
--- SwiftApps/SwiftR/IMMEDIATE-TODO	2011-02-22 16:57:24 UTC (rev 4136)
+++ SwiftApps/SwiftR/IMMEDIATE-TODO	2011-02-22 19:35:00 UTC (rev 4137)
@@ -3,17 +3,13 @@
 - ParallelCI and ParallelBoostrap benchmarks
 - smaller focused micro-tests to create plots of speed vs param size and efficiency vs runtime of the evaluated function.
-4) SGE:
-- test in IBI
-- test on Ranger
-- get this to Tim Bates to test on Eddie ()
 VERY HIGH:
 -- Benchmarks
     Timing: dramatic bencmark results for new proposal.
-    - Parallel bootstrap
+    - Parallel bootstrap DONE
     - Parallel CI
     - smaller focused micro-tests looking at param size
     - Sarah Kenny FMRI
@@ -38,9 +34,13 @@
  -- swift fast branch?
  -- swift times?
  -- micro studies on provider staging etc.
 HIGH:
+- test on Ranger
+HIGH:
 Coaster timeout problem:
     He (Mihael) will also look at a better fix to the coaster timeout problem, but for now, you should integrate the timeout change from my trunk/cog/modules/provider-coaster/src/* into your test trunk/
     Otherwise, you'll find that your coaster workers quit after a few minutes of inactivity and then start-swift needs to be killed, workers cleanup up, and start-swift restarted.
