[Swift-commit] r4134 - SwiftApps/SwiftR
noreply at svn.ci.uchicago.edu
Mon Feb 21 20:12:12 CST 2011
Author: tga
Date: 2011-02-21 20:12:12 -0600 (Mon, 21 Feb 2011)
New Revision: 4134
Modified:
SwiftApps/SwiftR/IMMEDIATE-TODO
Log:
One more note
Modified: SwiftApps/SwiftR/IMMEDIATE-TODO
--- SwiftApps/SwiftR/IMMEDIATE-TODO 2011-02-22 02:07:06 UTC (rev 4133)
+++ SwiftApps/SwiftR/IMMEDIATE-TODO 2011-02-22 02:12:12 UTC (rev 4134)
@@ -45,8 +45,9 @@
He (Mihael) will also look at a better fix to the coaster timeout problem, but for now, you should integrate the timeout change from my trunk/cog/modules/provider-coaster/src/* into your test trunk/
Otherwise, you'll find that your coaster workers quit after a few minutes of inactivity and then start-swift needs to be killed, workers cleanup up, and start-swift restarted.
+HIGH:
+See email about pbs breaking on UVa cluster
MID:
- saner approach to channels: channel per request to avoid the issue
of what happens if a "done" is never read
More information about the Swift-commit
