[Swift-commit] r4110 - in branches/release-0.92: . bin
noreply at svn.ci.uchicago.edu
Wed Feb 16 14:23:28 CST 2011
Author: davidk
Date: 2011-02-16 14:23:28 -0600 (Wed, 16 Feb 2011)
New Revision: 4110
Added:
branches/release-0.92/bin/gensites
Modified:
branches/release-0.92/build.xml
Log:
Initial commit of gensites script
Added: branches/release-0.92/bin/gensites
--- branches/release-0.92/bin/gensites (rev 0)
+++ branches/release-0.92/bin/gensites 2011-02-16 20:23:28 UTC (rev 4110)
@@ -0,0 +1,193 @@
+#!/bin/sh
+# crash: Report a problem and exit
+crash()
+ MSG=$1
+ echo ${MSG}
+ exit 1
+# get_value: Return the right hand side of an equals
+# statment in swift.properties format: gensites.foo=bar
+# will return bar
+get_value()
+ echo $1 |cut -d "=" -f2
+# Verify an argument is not null
+verify_not_null()
+ argname=$1; shift
+ if [ _$1 != _ ]; then
+ return 0;
+ else
+ echo $0: value for $argname can not be null
+ exit 1
+ fi
+# Print usage information and exit
+usage()
+ cat << END
+ usage: gensites template [-p properties.file] [-L template_directory] [-h]
+ template Name of template to use
+ -p properties.file Specify a swift.properties to use
+ -L template_directory Specify a non-standard template directory
+ -T List all templates available
+ -h Help / usage information
+ Examples:
+ Create a site configuration file for sites.xml using default properties.file in current directory
+ $ gensites pads > sites.xml
+ Use a specific properties file for a site
+ $ gensites -p sites.properties pads > sites.xml
+ Specify a non-standard directory where templates are located
+ $ gensites -L template.dir pads > sites.xml
+END
+exit 0;
+# Parse command line arguments
+while [ $# -gt 0 ]
+do
+ case "$1" in
+ -p) PROPERTIES_FILE=$2; verify_not_null properties_file $PROPERTIES_FILE; shift ;;
+ -L) TEMPLATE_DIRECTORY=$2; verify_not_null template_directory $TEMPLATE_DIRECTORY; shift ;;
+ -T) LIST_TEMPLATES=1 ;;
+ -h|-help) usage ;;
+ *) TEMPLATE=$1 ;;
+ esac
+ shift
+done
+# Determine SWIFT_HOME
+if [ -z "$SWIFT_HOME" ]; then
+ SWIFT_BIN_DIR=`which swift`
+ # From SVN
+ SWIFT_HOME=`dirname $SWIFT_BIN_DIR`"/../../../etc/sites"
+ # From a distribution
+ if [ ! -d "$SWIFT_HOME" ]; then
+ SWIFT_HOME=`dirname $SWIFT_BIN_DIR`"../../etc/sites"
+ fi
+ # Can't find swift path, give up
+ crash "Unable to determine SWIFT_HOME. Please set manually."
+ fi
+fi
+# List templates
+if [ ! -z "$LIST_TEMPLATES" ]; then
+ ls -1 $SWIFT_HOME/* | xargs -n1 basename
+ ls -1 $HOME/.swift/sites/* | xargs -n1 basename
+ exit 0
+fi
+# Require template name to be specified by user
+if [ -z "$TEMPLATE" ]; then
+ crash "Not specified: TEMPLATE"
+fi
+# Use custom template directory if asked
+if [ -d "$TEMPLATE_DIRECTORY" ]; then
+ TEMPLATE_PATH="$TEMPLATE_DIRECTORY/$TEMPLATE"
+fi
+# Locate template
+if [ ! -f "$TEMPLATE_PATH" ]; then
+ if [ -f "$TEMPLATE" ]; then
+ $TEMPLATE_PATH = $TEMPLATE
+ elif [ -f "$SWIFT_HOME/$TEMPLATE" ]; then
+ TEMPLATE_PATH=$SWIFT_HOME/$TEMPLATE
+ elif [ -f "$HOME/.swift/sites/$TEMPLATE" ]; then
+ TEMPLATE_PATH=$HOME/.swift/sites/$TEMPLATE
+ fi
+ if [ ! -f "$TEMPLATE_PATH" ]; then
+ crash "Cannot find template for $TEMPLATE"
+ fi
+fi
+# Ensure a properties file exists
+if [ ! -f "$PROPERTIES_FILE" ]; then
+ PROPERTIES_FILE="swift.properties"
+ if [ ! -f "$PROPERTIES_FILE" ]; then
+ crash "Unable to find a valid properties file! Please specify a valid file with the -p option"
+ fi
+fi
+# Parse values into variables for later sed processing
+WORK=`pwd`"/work"
+while read line
+do
+ case "$line" in
+ $TEMPLATE".work="*)
+ WORK=`get_value $line`
+ $TEMPLATE".globus_hostname="*)
+ GLOBUS_HOSTNAME=`get_value $line`
+ $TEMPLATE".nodes="*)
+ NODES=`get_value $line`
+ $TEMPLATE".project="*)
+ PROJECT=`get_value $line`
+ $TEMPLATE".queue="*)
+ QUEUE=`get_value $line`
+ $TEMPLATE".n_gran="*)
+ N_GRAN=`get_value $line`
+ $TEMPLATE".n_max="*)
+ MAXTIME=`get_value $line`
+ esac
+done < $PROPERTIES_FILE
+# Test for mandatory variables
+[[ ${WORK} == "" ]] && crash "Not specified: WORK"
+# Verify that the variables by the template are defined
+for TOKEN in PROJECT QUEUE N_GRAN N_MAX SLOTS
+ do
+ if grep _${TOKEN}_ ${TEMPLATE_PATH} > /dev/null
+ then
+ if ! declare -p ${TOKEN} > /dev/null
+ then
+ printenv
+ crash "Not specified: ${TOKEN}"
+ fi
+ fi
+done
+# Replace values
+SEDFILE=`mktemp`
+ echo "s/_NODES_/${NODES}/"
+ echo "s/_HOST_/${GLOBUS_HOSTNAME}/"
+ echo "s at _WORK_@${WORK}@"
+ echo "s/_PROJECT_/${PROJECT}/"
+ echo "s/_QUEUE_/${QUEUE}/"
+ echo "s/_N_GRAN_/${N_GRAN}/"
+ echo "s/_N_MAX_/${N_MAX}/"
+ echo "s/_SLOTS_/${SLOTS}/"
+ echo "s/_MAXTIME_/${MAXTIME}/"
+ echo "s at _SERVICE_COASTERS_@${SERVICE_COASTERS:-NO_URL_GIVEN}@"
+ echo "s at _SERVICE_PORT_@${SERVICE_PORT:-NO_PORT_GIVEN}@"
+} > $SEDFILE
+sed -f $SEDFILE < ${TEMPLATE_PATH}
+rm $SEDFILE
Property changes on: branches/release-0.92/bin/gensites
___________________________________________________________________
Modified: branches/release-0.92/build.xml
--- branches/release-0.92/build.xml 2011-02-16 18:50:01 UTC (rev 4109)
+++ branches/release-0.92/build.xml 2011-02-16 20:23:28 UTC (rev 4110)
@@ -86,6 +86,7 @@
<chmod perm="+x" file="${dist.dir}/bin/swift-plot-log"/>
<chmod perm="+x" file="${dist.dir}/bin/swiftconfig"/>
<chmod perm="+x" file="${dist.dir}/bin/swiftrun"/>
+ <chmod perm="+x" file="${dist.dir}/bin/gensites"/>
<chmod perm="+x" file="${dist.dir}/libexec/log-processing/active-state-transitions"/>
<chmod perm="+x" file="${dist.dir}/libexec/log-processing/add-runid-as-prefix"/>
<chmod perm="+x" file="${dist.dir}/libexec/log-processing/affine-transform"/>
More information about the Swift-commit
