[Swift-commit] r4106 - SwiftApps/SwiftR/Swift/exec
noreply at svn.ci.uchicago.edu
Tue Feb 15 17:31:55 CST 2011
Author: tga
Date: 2011-02-15 17:31:55 -0600 (Tue, 15 Feb 2011)
New Revision: 4106
Modified:
SwiftApps/SwiftR/Swift/exec/start-swift
Log:
Got SwiftR working on Eureka!!
Modified: SwiftApps/SwiftR/Swift/exec/start-swift
--- SwiftApps/SwiftR/Swift/exec/start-swift 2011-02-15 21:48:43 UTC (rev 4105)
+++ SwiftApps/SwiftR/Swift/exec/start-swift 2011-02-15 23:31:55 UTC (rev 4106)
@@ -162,6 +162,27 @@
END
+make-cobalt-submit-file()
+# Most cobalt options are passed through the command line, we just need to
+# include relevant arguments for worker.pl in here.
+cat > $HOME/batch.sub <<END
+#!/bin/sh
+export WORKER_LOGGING_LEVEL=$workerLogging
+echo '***' COBALT_NODEFILE file: \$COBALT_NODEFILE CONTACT:$CONTACT
+cat \$COBALT_NODEFILE
+echo '***' unique nodes are:
+sort < \$COBALT_NODEFILE|uniq
+for h in \$(sort < \$COBALT_NODEFILE|uniq); do
+ ssh \$h "echo Swift R startup running on host; hostname; cd /; /usr/bin/perl $SWIFTBIN/worker.pl $CONTACT SwiftR-\$h $HOME/.globus/coasters $IDLETIMEOUT" &
+done
+wait
+END
+chmod +x $HOME/batch.sub
# FIXME: for big systems like Ranger, need to use ssh_tree to avoid socket FD exhastion?
make-sge-submit-file()
@@ -254,9 +275,7 @@
IDLETIMEOUT=$((60*60*240)) # 10 days: FIXME: make this a command line arg
# FIXME: set up for capturing batch job id: rm -rf remotepid.* # FIXME: should not be needed if we start in a new dir each time
- if [ "$server" != "cobalt" ]; then
- make-${server}-submit-file
- fi
+ make-${server}-submit-file
#FIXME: doesn't work for SGE on IBI cluster as there is additional text
# returned by qsub
@@ -294,18 +313,14 @@
# so we have multiple workers per node. In future could
# add support for virtual node mode, etc
#CONTACT="http://10.40.9.151:$(echo $CONTACT | sed -e 's,^.*:,,')"
- logdir=`pwd`
+ wkdir=`pwd`
qsub -t "$time" -n $nodes $queueDirective $kernDirective \
- $projDirective -e $logdir/SwiftR-workers.err \
- -o $logdir/SwiftR-workers.out --debuglog $logdir/cobalt.log \
- --cwd / \
- --env WORKER_LOGGING_LEVEL=$workerLogging \
- /usr/bin/perl $SWIFTBIN/worker.pl $CONTACT SwiftR-workers \
- $HOME/.globus/coasters $IDLETIMEOUT >$jobidfile
- #TODO: change current working directory
+ $projDirective -e $wkdir/SwiftR-workers.err \
+ -o $wkdir/SwiftR-workers.out --debuglog $wkdir/cobalt.log \
+ --cwd / $HOME/batch.sub > $jobidfile
succ=$?
else
- qsub batch.sub >$jobidfile
+ qsub batch.sub > $jobidfile
succ=$?
fi
More information about the Swift-commit
