[Swift-commit] r4091 - usertools/plotter/src/plotter
Mon Feb 14 17:10:42 CST 2011
Author: wozniak
Date: 2011-02-14 17:10:42 -0600 (Mon, 14 Feb 2011)
New Revision: 4091
Modified:
   usertools/plotter/src/plotter/Lines.java
Log:
Add support for bw, misc cleanups
Modified: usertools/plotter/src/plotter/Lines.java
--- usertools/plotter/src/plotter/Lines.java	2011-02-14 21:58:55 UTC (rev 4090)
+++ usertools/plotter/src/plotter/Lines.java	2011-02-14 23:10:42 UTC (rev 4091)
@@ -1,16 +1,14 @@
 package plotter;
+import gnu.getopt.Getopt;
 import java.awt.Color;
 import java.awt.geom.Rectangle2D;
 import java.io.*;
 import java.util.*;
-import gnu.getopt.Getopt;
 import org.apache.commons.io.IOUtils;
 import org.apache.xmlgraphics.java2d.ps.EPSDocumentGraphics2D;
 import org.jfree.chart.ChartFactory;
 import org.jfree.chart.JFreeChart;
 import org.jfree.chart.axis.NumberAxis;
@@ -30,8 +28,8 @@
   public static boolean bw = false;
-  static int w = 400;
-  static int h = 400;
+  static int width = 400;
+  static int height = 400;
   // null indicates the value was not set by the user
   static Double xmin = null;
@@ -64,11 +62,11 @@
       g2d.setGraphicContext
         (new org.apache.xmlgraphics.java2d.GraphicContext());
-      rectangle = new Rectangle2D.Double(0, 0, w, h);
+      rectangle = new Rectangle2D.Double(0, 0, width, height);
-      g2d.setupDocument(out, w, h);
+      g2d.setupDocument(out, width, height);
     catch (IOException e)
@@ -170,8 +168,8 @@
       switch (c)
-      case 'v':
-        verbose = true;
+        case 'v':
+          verbose = true;
@@ -268,16 +266,17 @@
      width (output image width)
      height (output image height)
      xmin, xmax, ymin, ymax (auto-selected if not given)
+     bw (Black and white, true/false, default false)
   static void scanProperties()
     String tmp;
     tmp = properties.getProperty("width");
     if (tmp != null)
-      w = Integer.parseInt(tmp.trim());
+      width = Integer.parseInt(tmp.trim());
     tmp = properties.getProperty("height");
     if (tmp != null)
-      h = Integer.parseInt(tmp.trim());
+      height = Integer.parseInt(tmp.trim());
     tmp = properties.getProperty("xmin");
     if (tmp != null)
       xmin = Double.parseDouble(tmp);
@@ -290,6 +289,9 @@
     tmp = properties.getProperty("ymax");
     if (tmp != null)
       ymax = Double.parseDouble(tmp);
+    tmp = properties.getProperty("bw");
+    if (tmp != null)
+      bw = Boolean.parseBoolean(tmp);
