[Swift-commit] r4086 - in SwiftApps/SwiftR: Swift/R mxtests/swift
noreply at svn.ci.uchicago.edu
Fri Feb 11 15:07:52 CST 2011
Author: tga
Date: 2011-02-11 15:07:52 -0600 (Fri, 11 Feb 2011)
New Revision: 4086
Modified:
SwiftApps/SwiftR/Swift/R/Bench.R
SwiftApps/SwiftR/Swift/R/TestFramework.R
SwiftApps/SwiftR/mxtests/swift/BootstrapParallelBigger.R
SwiftApps/SwiftR/mxtests/swift/MakeTests.R
Log:
Continued improvements to performance testing
Modified: SwiftApps/SwiftR/Swift/R/Bench.R
--- SwiftApps/SwiftR/Swift/R/Bench.R 2011-02-11 16:36:08 UTC (rev 4085)
+++ SwiftApps/SwiftR/Swift/R/Bench.R 2011-02-11 21:07:52 UTC (rev 4086)
@@ -34,35 +34,57 @@
-id <- function () { return (1) }
+id <- function () {
+ swiftLapply(rep(list(1), 100),
+ function (x) {x})
mkPerfTest <- function() {
# Have an initial test that will block until
# resources are ready
warmUpGroup <- makeTestGroup(
name="Wait for server to start",
- tests=list(mkTest(id)))
+ tests=rep(list(mkTest(id)), 5))
perfTestGroup1 <- makeParamTestGroup(
name="1 - basic performance test",
f=sleeper,
allargs=list(
- list(1, 10),
- list(1, 20),
- list(1, 50),
- list(1, 100),
- list(2, 10),
- list(2, 20),
- list(2, 50),
- list(2, 100),
- list(3, 10),
- list(3, 20),
- list(3, 50),
- list(3, 100),
- list(4, 10),
- list(4, 20),
- list(4, 50),
- list(4, 100)))
+ list(1, 8),
+ list(1, 16),
+ list(1, 32),
+ list(1, 48),
+ list(1, 64),
+ list(1, 96),
+ list(1, 128),
+ list(2, 8),
+ list(2, 16),
+ list(2, 32),
+ list(2, 48),
+ list(2, 64),
+ list(2, 96),
+ list(2, 128),
+ list(3, 8),
+ list(3, 16),
+ list(3, 32),
+ list(3, 48),
+ list(3, 64),
+ list(3, 96),
+ list(3, 128),
+ list(4, 8),
+ list(4, 16),
+ list(4, 32),
+ list(4, 48),
+ list(4, 64),
+ list(4, 96),
+ list(4, 128),
+ list(5, 8),
+ list(5, 16),
+ list(5, 32),
+ list(5, 48),
+ list(5, 64),
+ list(5, 96),
+ list(5, 128)))
swiftTestSuite <- list(
setup=function () { initSwiftTestOptions();
swiftInit() }, # swiftInit controlled via options
@@ -70,6 +92,7 @@
teardown=function () { swiftShutdown() })
return (swiftTestSuite)
doPerfTest <- function () {
runTestSuite(mkPerfTest())
Modified: SwiftApps/SwiftR/Swift/R/TestFramework.R
--- SwiftApps/SwiftR/Swift/R/TestFramework.R 2011-02-11 16:36:08 UTC (rev 4085)
+++ SwiftApps/SwiftR/Swift/R/TestFramework.R 2011-02-11 21:07:52 UTC (rev 4086)
@@ -45,7 +45,7 @@
return (makeTestGroup(name, tests, setup, teardown))
-analysePerf <- function (testGroupResults, nargs) {
+analysePerf <- function (testGroupResults, nargs=0) {
# Build a list of vectors of performance results for easier analysis
# [[1]] -> first arg
# [[2]] -> second arg
@@ -55,17 +55,32 @@
# $passed
# $time
collated <- list()
- for (i in 1:nargs) {
- collated[[i]] <- unlist(lapply(testGroupResults$tests,
- function(test) {test$args[[i]]}))
+ if (nargs >= 1) {
+ for (i in 1:nargs) {
+ collated[[i]] <- unlist(lapply(testGroupResults$tests,
+ function(test) {test$args[[i]]}))
+ n <- length(testGroupResults$tests)
collated$name <- unlist(lapply(testGroupResults$tests,
function(test) {test$name }))
collated$passed <-unlist(lapply(testGroupResults$tests,
function(test) {test$passed }))
collated$time <- unlist(lapply(testGroupResults$tests,
function(test) {test$time }))
- return (collated)
+ # Store the pnames as vectors
+ if (!is.null(testGroupResults$perfparams)) {
+ pnames <- names(testGroupResults$perfparams)
+ if (!is.na(pnames) && length(pnames) > 0) {
+ for (i in 1:length(pnames)) {
+ collated[[pnames[[i]]]] <- rep(testGroupResults$perfparams[[i]],
+ n)
+ return (data.frame(collated))
@@ -91,13 +106,16 @@
printTestGroup <- function (group) {
cat("\n*** Test group ", group$name, "***\n")
resFmt <- function(res) {
- if (is.null(res)) {
- } else {
- if (inherits(res, "try-error"))
- {paste("ERROR: '", res, "'") }
- else
- {if (res) "PASSED" else "FAILED"}
+ if (is.null(res)) {
+ } else if (inherits(res, "try-error")) {
+ paste("ERROR: '", res, "'")
+ } else if (identical(res, TRUE)) {
+ "PASSED"
+ } else if (identical(res, FALSE)) {
+ "FAILED"
+ } else {
+ "<data>"
timeFmt <- function (time) {
@@ -119,10 +137,12 @@
runTestSuite <- function (suite) {
if (!is.null(suite$setup))
suite$setup()
- resSuite <- lapply(suite$tests, runTestGroup)
+ resSuite <- suite
+ resSuite$tests <- lapply(suite$tests, runTestGroup)
if (!is.null(suite$teardown))
suite$teardown()
- lapply(resSuite, printTestGroup)
+ lapply(resSuite$tests, printTestGroup)
return (resSuite)
Modified: SwiftApps/SwiftR/mxtests/swift/BootstrapParallelBigger.R
--- SwiftApps/SwiftR/mxtests/swift/BootstrapParallelBigger.R 2011-02-11 16:36:08 UTC (rev 4085)
+++ SwiftApps/SwiftR/mxtests/swift/BootstrapParallelBigger.R 2011-02-11 21:07:52 UTC (rev 4086)
@@ -23,20 +23,8 @@
#cat("Running on hosts:", hostnames, "\n")
-main <- function () {
- swiftLibrary(OpenMx)
- swiftSess <- swiftSetup(server="local", cores=4)
- nVar <- 75
- nObs <- 10000
- nReps <- 1024
- perfExperiment(nVar, nObs, nReps)
- swiftShutdown(swiftSess)
bootstrapTest <- function (nVar, nObs, nReps) {
set.seed(10)
topModel <- buildModels(nVar, nObs, nReps)
@@ -58,16 +46,26 @@
# list(75, 10000, 32))
testArgs <- list(
- list(75, 1000, 4),
- list(75, 1000, 8),
- list(75, 1000, 16),
- list(75, 1000, 32))
+ list(75, 100, 4),
+ list(75, 100, 8),
+ list(75, 100, 16),
+ list(75, 100, 32),
+ list(75, 100, 64),
+ list(75, 100, 128),
+ list(75, 100, 256),
+ list(75, 100, 256 + 128),
+ list(75, 100, 512),
+ list(75, 100, 786),
+ list(75, 100, 1024),
+ list(75, 100, 1024 + 512),
+ list(75, 100, 2048 )
-makeBootstrapTestGroup <- function (...) {
+makeBootstrapTestGroup <- function (first=1, last=length(testArgs), ...) {
makePerfTestGroup(
name="BootstrapParallelBigger",
f=bootstrapTest,
- allargs=testArgs,
+ allargs=testArgs[first:last],
@@ -160,8 +158,32 @@
swiftTestSuite <- makeTestSuite(
tests=list(
- makeBootstrapTestGroup(mode="swift", server="local", cores=2),
- makeBootstrapTestGroup(mode="swift", server="local", cores=4),
- makeBootstrapTestGroup(mode="swift", server="ssh", cores=8, hosts="nettle antares deneb"),
- makeBootstrapTestGroup(mode="serial")
+ # 16 cores
+ makeBootstrapTestGroup(mode="swift", server="ssh", cores=2,
+ hosts=c("nettle", "wapato", "dandelion", "cattail",
+ "chicory", "echinacea", "amaranth", "black-cohosh"),
+ first=3, last=5),
+ # 8 cores
+ hosts="nettle wapato dandelion cattail",
+ first=2, last=5),
+ makeBootstrapTestGroup(mode="swift", server="local", cores=4,
+ last=4),
+ makeBootstrapTestGroup(mode="swift", server="local", cores=2,
+ last=4),
+ makeBootstrapTestGroup(mode="swift", server="local", cores=1,
+ last=2),
+ last=2),
+ makeBootstrapTestGroup(mode="serial", last=2)
+padsTestSuite <- makeTestSuite(
+ tests=list(
+ makeBootstrapTestGroup(mode="swift", server="pbs", cores=1, nodes=1),
+ makeBootstrapTestGroup(mode="swift", server="pbs", cores=8, nodes=1),
+ makeBootstrapTestGroup(mode="swift", server="pbs", cores=8, nodes=2),
+ makeBootstrapTestGroup(mode="swift", server="pbs", cores=8, nodes=3),
+ makeBootstrapTestGroup(mode="swift", server="pbs", cores=8, nodes=4),
+ makeBootstrapTestGroup(mode="swift", server="pbs", cores=8, nodes=5)
Modified: SwiftApps/SwiftR/mxtests/swift/MakeTests.R
--- SwiftApps/SwiftR/mxtests/swift/MakeTests.R 2011-02-11 16:36:08 UTC (rev 4085)
+++ SwiftApps/SwiftR/mxtests/swift/MakeTests.R 2011-02-11 21:07:52 UTC (rev 4086)
@@ -4,9 +4,12 @@
swiftSetup <- function (...) {
library(Swift)
swiftSess <- swiftInit(...)
+ # Wait to start
+ Sys.sleep(10)
# Run some small jobs to esnure workers are started and warmed up
- swiftLapply(rep(1, swiftSess$cores * swiftSess$nodes * 2),
- function (x) { x })
+ swiftapply(function (x) { x },
+ rep(1, swiftSess$cores * swiftSess$nodes * 2),
+ callsperbatch=1)
return (swiftSess)
@@ -41,6 +44,7 @@
tg <- makeParamTestGroup(name=paste("swift_",name, " ", paramstr,sep=""),
f=f,
allargs=allargs,
+ perfparams <- params,
setup=function() {swiftSetup(...)},
tearDown <- swiftTearDown)
@@ -48,6 +52,7 @@
tg <- makeParamTestGroup(name=paste("sf_",name, paramstr, sep=""),
f=f,
allargs=allargs,
setup=function() {sfSetup(...)},
tearDown <- sfTearDown)
@@ -57,6 +62,7 @@
tg <- makeParamTestGroup(name=paste("serial_",name, paramstr, sep=""),
f=f,
allargs=allargs,
+ perfparams <- list(),
setup=function()
{try(detach(package:Swift)); try(detach(package:Snowfall))} )
More information about the Swift-commit
