[Swift-commit] r4064 - in SwiftApps/SwiftR/Swift: R exec
noreply at svn.ci.uchicago.edu
Mon Feb 7 15:04:05 CST 2011
Author: tga
Date: 2011-02-07 15:04:05 -0600 (Mon, 07 Feb 2011)
New Revision: 4064
Added:
SwiftApps/SwiftR/Swift/R/Init.R
Modified:
SwiftApps/SwiftR/Swift/R/Apply.R
SwiftApps/SwiftR/Swift/R/Export.R
SwiftApps/SwiftR/Swift/R/Tests.R
SwiftApps/SwiftR/Swift/R/Workers.R
SwiftApps/SwiftR/Swift/exec/SwiftRServer.R
Log:
Added automatic selection of directory for exports, cleanup of exported file, tests of export functionality.
Modified: SwiftApps/SwiftR/Swift/R/Apply.R
--- SwiftApps/SwiftR/Swift/R/Apply.R 2011-02-07 17:25:33 UTC (rev 4063)
+++ SwiftApps/SwiftR/Swift/R/Apply.R 2011-02-07 21:04:05 UTC (rev 4064)
@@ -127,21 +127,21 @@
# to lifetime of this R process. If we stored this in a global
# variable, it is possible that, say, directory requests.55555/R0000005
# is created, the user exits the session without saving, and therefore
- # the swift.requestid counter is out of step with the file system
+ # the .swift.requestid counter is out of step with the file system
requestdirbase = getOption("swift.requestdirbase")
if(!is.null(requestdirbase)) {
- requestid = getOption("swift.requestid") + 1;
+ requestid = getOption(".swift.requestid") + 1;
else {
- requestdirbase = sprintf("%s/%s/SwiftR/requests.P%.5d",tmpdir,
- Sys.info()[["user"]],Sys.getpid())
+ requestdirbase = file.path(tmpdir, Sys.info()[["user"]],"SwiftR",
+ sprintf("requests.P%.5d",Sys.getpid()))
dir.create(requestdirbase,recursive=TRUE,showWarnings=FALSE,
mode=kDIR_MODE)
options(swift.requestdirbase=requestdirbase)
requestid = 0;
- options(swift.requestid=requestid)
- reqdir = sprintf("%s/R%.7d",requestdirbase,requestid)
+ options(.swift.requestid=requestid)
+ reqdir = file.path(requestdirbase, sprintf("R%.7d",requestid))
dir.create(reqdir,recursive=TRUE,showWarnings=FALSE,mode=kDIR_MODE)
return (reqdir)
Modified: SwiftApps/SwiftR/Swift/R/Export.R
--- SwiftApps/SwiftR/Swift/R/Export.R 2011-02-07 17:25:33 UTC (rev 4063)
+++ SwiftApps/SwiftR/Swift/R/Export.R 2011-02-07 21:04:05 UTC (rev 4064)
@@ -41,18 +41,42 @@
# partially undoes previous work
-swiftExportAll <- function () {
+swiftExportAll <- function (file=NULL) {
# Exports all functions and data in global environment
- return (swiftExport(list=ls(globalenv())))
+ swiftExport(list=ls(globalenv()), file=file)
-#TODO: not implemented
swiftExport <- function (..., list=NULL, file=NULL) {
# List of object names (as R symbols or as strings)
# These will be passed directly to save() to be serialized
- # TODO: For now,while testing, must manually specify location
- # TODO: choose file location
- # expFile <- ???
+ if (is.null(file)) {
+ dir <- getExportDir()
+ if (is.null(dir)) {
+ error(paste("Could not determine an export directory, try",
+ "setting the",
+ "swift.exportdir option to a directory accessible by this R",
+ "session and the Swift worker processes"))
+ # Separate directory for each new R session to keep files together
+ # and avoid conflicts.
+ cat("Export directory: ", dir, "\n")
+ dir.create(dir, recursive=T, showWarnings=FALSE, mode=kDIR_MODE)
+ # add the file, keeping a counter to use in the file name
+ expid = getOption(".swift.exportid")
+ if (is.null(expid)) expid = 0
+ options(.swift.exportid = expid + 1)
+ file <- file.path(dir, sprintf("E%.7d",expid))
+ cat("Export file: ", file, "\n")
+ # Keep track of files for later cleanup
+ expfiles <- getOption(".swift.exportfiles")
+ if (is.null(expfiles)) expfiles = list()
+ expfiles[[length(expfiles) + 1]] <- file
+ options(.swift.exportfiles=expfiles)
+ #TODO: file mode?
if (is.null(list))
save(..., file=file)
else
@@ -81,3 +105,34 @@
# it is hard to know when they can be safely removed
options(.swift.session=newSession())
+getExportDir <- function () {
+ d <- getOption("swift.exportdir")
+ if (! is.null(d)) d <- file.path(d, ".swiftr", "exports")
+ # Home directory is a candidate
+ d <- Sys.getenv("HOME")[[1]]
+ if (d == "") {
+ return (NULL)
+ else {
+ d <- file.path(d, ".swiftr")
+ return (file.path(d, sprintf("exports.P%.5d",Sys.getpid())))
+# Function called when Swift is unloaded or session ends
+# that is responsible for cleanup
+removeExports <- function () {
+ cat("removing exports\n")
+ for (file in expfiles) {
+ #cat("removing", file, "\n")
+ file.remove(file)
+ options(.swift.exportfiles=NULL)
+ if (!is.null(dir)) {
+ unlink(dir, recursive=T)
Added: SwiftApps/SwiftR/Swift/R/Init.R
--- SwiftApps/SwiftR/Swift/R/Init.R (rev 0)
+++ SwiftApps/SwiftR/Swift/R/Init.R 2011-02-07 21:04:05 UTC (rev 4064)
@@ -0,0 +1,80 @@
+# This file contains functions involved in starting up and shutting down
+# SwiftR
+.onLoad <- function (libname, packagename) {
+ detectSystemInfo()
+.First.lib <- function(libname, packagename) {
+ # When the library is loaded, set up the
+ # list of workers
+ .swift.workers <<- list()
+swiftCleanup <- function () {
+ # Shut down workers
+ swiftShutdown()
+ # Clean up exported files
+ removeExports()
+.Last.lib <- function(p)
+ # If the library is unloaded we need to do cleanup
+ swiftCleanup()
+ removeHook()
+# Hook to perform cleanup of workers upon shutting down an R
+# session
+addHook <- function() {
+ # Replace the user's last function with ours
+ # If .UserLast already exists don't worry about it
+ # as we've already added our hook
+ if (!exists(".UserLast")) {
+ if (!exists(".Last")) {
+ # Create a dummy function
+ .UserLast <<- function () {}
+ else {
+ .UserLast <<- .Last
+ .Last <<- function () {
+ swiftCleanup()
+ .UserLast()
+ removeHook()
+removeHook <- function() {
+ if (exists(".UserLast", where=".GlobalEnv")) {
+ .Last <<- .UserLast
+ rm(".UserLast", pos=".GlobalEnv")
+detectSystemInfo <- function () {
+ # Do initial detection and setting of options to
+ # reflect system info. DOesn't guarantee options will be set
+ os <- tolower(R.version$os)
+ corecount <- 0
+ if (substr(os, 1, 5) == "linux") {
+ corecount <- try(as.numeric(system(
+ "grep -c '^processor' /proc/cpuinfo", intern=T)))
+ #if (substr(os, 1, 5) == "darwin") {
+ #TODO: detect cores on other systems:
+ # * MAC OS X
+ # * BSD?
+ if (!inherits(corecount, "try-error") && corecount >= 1){
+ options(swift.system.cores=corecount)
Modified: SwiftApps/SwiftR/Swift/R/Tests.R
--- SwiftApps/SwiftR/Swift/R/Tests.R 2011-02-07 17:25:33 UTC (rev 4063)
+++ SwiftApps/SwiftR/Swift/R/Tests.R 2011-02-07 21:04:05 UTC (rev 4064)
@@ -42,6 +42,98 @@
+#1.3.* tests export functionality
+swiftTest_1.3.1 <- function()
+ initSwiftTestOptions()
+ cat("\n*** Starting test 1.3.1 ***\n\n")
+ y <- 1
+ inc <- function(x) { x + y }
+ arglist = list(1,2,3,4,5,6,7,8,9)
+ cat("Test of local lapply\n")
+ localres = lapply(arglist, inc)
+ cat("local result=\n")
+ print(localres)
+ # Test swiftExport
+ swiftExport(y)
+ cat("\nTest of swiftLapply\n")
+ swiftres = swiftLapply(arglist, inc)
+ cat("Swift result:\n")
+ print(swiftres)
+ if(identical(localres,swiftres)) {
+ cat("\n==> test 1.3.1 passed\n")
+ } else {
+ cat("\n==> test 1.3.1 FAILED !!!!!\n")
+swiftTest_1.3.2 <- function()
+ # Test swiftExportAll()
+ cat("\n*** Starting test 1.3.2 ***\n\n")
+ y <<- 1
+ print(localres)
+ swiftExportAll()
+ print(swiftres)
+ cat("\n==> test 1.3.2 passed\n")
+ } else {
+ cat("\n==> test 1.3.2 FAILED !!!!!\n")
+swiftTest_1.3.3 <- function()
+ cat("\n*** Starting test 1.3.3 ***\n\n")
+ y <- 1
+ arglist = list(1,2,3,4)
+ swiftExportAll()
+ cat("Swift result before removal:\n")
+ print(swiftres)
+ swiftRemoveAll()
+ cat("Swift result after removal:\n")
+ for (e in swiftres) {
+ if (!inherits(e, "try-error")) {
+ cat("\n==> test 1.3.3 FAILED !!!!!\n")
+ return()
+ cat("\n==> test 1.3.3 passed\n")
basicSwiftTest <- function() { swiftTest_1.1() }
# .... more tests from below to move here
@@ -242,8 +334,10 @@
# swiftres = swiftapply(sumstuff,arglist,callsperbatch=2,site="pbs")
# test variations on local vs ssh vs pbs; coasters vs non; etc.
+ swiftTest_1.3.1()
+ swiftTest_1.3.2()
+ swiftTest_1.3.3()
##### Test Group 2
cat("\n*** Starting test group 2 - test matrix passing***\n")
Modified: SwiftApps/SwiftR/Swift/R/Workers.R
--- SwiftApps/SwiftR/Swift/R/Workers.R 2011-02-07 17:25:33 UTC (rev 4063)
+++ SwiftApps/SwiftR/Swift/R/Workers.R 2011-02-07 21:04:05 UTC (rev 4064)
@@ -225,72 +225,3 @@
return (worker$cores * worker$nodes)
-.onLoad <- function (libname, packagename) {
- detectSystemInfo()
-.First.lib <- function(libname, packagename) {
- # When the library is loaded, set up the
- # list of workers
- .swift.workers <<- list()
-.Last.lib <- function(p)
- # If the library is unloaded we need to do cleanup
- swiftShutdown()
- removeHook()
-# Hook to perform cleanup of workers upon shutting down an R
-# session
-addHook <- function() {
- # Replace the user's last function with ours
- # If .UserLast already exists don't worry about it
- # as we've already added our hook
- if (!exists(".UserLast")) {
- if (!exists(".Last")) {
- # Create a dummy function
- .UserLast <<- function () {}
- else {
- .UserLast <<- .Last
- .Last <<- function () {
- swiftShutdown()
- .UserLast()
- removeHook()
-removeHook <- function() {
- if (exists(".UserLast", where=".GlobalEnv")) {
- .Last <<- .UserLast
- rm(".UserLast", pos=".GlobalEnv")
-detectSystemInfo <- function () {
- # Do initial detection and setting of options to
- # reflect system info. DOesn't guarantee options will be set
- os <- tolower(R.version$os)
- corecount <- 0
- if (substr(os, 1, 5) == "linux") {
- corecount <- try(as.numeric(system(
- "grep -c '^processor' /proc/cpuinfo", intern=T)))
- #if (substr(os, 1, 5) == "darwin") {
- #TODO: detect cores on other systems:
- # * MAC OS X
- # * BSD?
- if (!inherits(corecount, "try-error") && corecount >= 1){
- options(swift.system.cores=corecount)
Modified: SwiftApps/SwiftR/Swift/exec/SwiftRServer.R
--- SwiftApps/SwiftR/Swift/exec/SwiftRServer.R 2011-02-07 17:25:33 UTC (rev 4063)
+++ SwiftApps/SwiftR/Swift/exec/SwiftRServer.R 2011-02-07 21:04:05 UTC (rev 4064)
@@ -70,7 +70,8 @@
success <- try(load(callBatchFileName));
if (inherits(success, "try-error")) {
- failBatch(rcall, success, resultBatchFileName)
+ failBatch(rcall, paste(callBatchFileName, "could not be opened"),
+ resultBatchFileName)
return()
success <- try(loadImports(rcall$imports))
@@ -133,10 +134,10 @@
loadImports <- function (importlist) {
# First check whether the session id has changed
- cat(paste("Import list:", importlist$exports, "\n"), file=stderr())
- cat(paste("New Session:", importlist$session, "\n"), file=stderr())
- cat(paste("Old Session:", try(get(".current.session", envir=globalenv())),
- "\n"), file=stderr())
+ #cat(paste("Import list:", importlist$exports, "\n"), file=stderr())
+ #cat(paste("New Session:", importlist$session, "\n"), file=stderr())
+ #cat(paste("Old Session:", try(get(".current.session", envir=globalenv())),
+ # "\n"), file=stderr())
doSetup <- FALSE
if (!is.null(importlist)) {
if (exists(".current.session", envir=globalenv())) {
@@ -155,7 +156,7 @@
# Load the contents of the specified file
# into the global environment
- cat("File: ", file, "\n")
+ #cat("File: ", file, "\n")
# check to see if already imported
if (!exists(file, envir=.current.imported)) {
#TODO: load can fail with warning
@@ -166,7 +167,7 @@
cat("Loaded file ", file, "\n")
else {
- cat("Ignored file ", file, "\n")
+ #cat("Ignored file ", file, "\n")
More information about the Swift-commit
