[Swift-commit] r4059 - in SwiftApps/SwiftR/Swift: . R exec
    noreply at svn.ci.uchicago.edu
    Thu Feb  3 18:28:50 CST 2011
Author: tga
Date: 2011-02-03 18:28:49 -0600 (Thu, 03 Feb 2011)
New Revision: 4059
Modified:
   SwiftApps/SwiftR/Swift/NAMESPACE
   SwiftApps/SwiftR/Swift/R/Apply.R
   SwiftApps/SwiftR/Swift/R/Export.R
   SwiftApps/SwiftR/Swift/exec/SwiftRServer.R
   SwiftApps/SwiftR/Swift/exec/start-swift
Log:
Checking in ongoing work on export mechanism.
It is not quite working yet, but there are only a couple of problems left ot resolve.
Modified: SwiftApps/SwiftR/Swift/NAMESPACE
--- SwiftApps/SwiftR/Swift/NAMESPACE	2011-02-03 22:22:36 UTC (rev 4058)
+++ SwiftApps/SwiftR/Swift/NAMESPACE	2011-02-04 00:28:49 UTC (rev 4059)
@@ -6,6 +6,10 @@
 export(swiftDetach)
 export(swiftDetachAll)
+export(swiftExport)
+export(swiftExportAll)
+export(swiftRemoveAll)
 export(runAllSwiftTests)
 export(basicSwiftTest)
 exportPattern("^swiftTest")
Modified: SwiftApps/SwiftR/Swift/R/Apply.R
--- SwiftApps/SwiftR/Swift/R/Apply.R	2011-02-03 22:22:36 UTC (rev 4058)
+++ SwiftApps/SwiftR/Swift/R/Apply.R	2011-02-04 00:28:49 UTC (rev 4059)
@@ -148,7 +148,9 @@
 writeRequestBatches <- function (func, arglists, initialexpr,
-                        reqdir, callsperbatch) {
+                        reqdir, callsperbatch, exportlist=NULL) {
+  if (is.null(exportlist)) exportlist <- getOption(".swift.exports")
   # Write the function call info out to cbatch.?.RData files in reqdir
   # in batches of size specified by callsperbatch
   # returns the number of batches written
@@ -168,7 +170,9 @@
       arglistbatch[[i]] <- arglists[[arglist]]
       arglist <- arglist +1
-    rcall <- list(initializer=initialexpr,func=func,arglistbatch=arglistbatch)
+    rcall <- list(initializer=initialexpr,
+                    imports=exportlist,
+                    func=func,arglistbatch=arglistbatch)
     save(rcall,
         file=file.path(reqdir,
             paste("cbatch.",as.character(batch),".Rdata",sep="")))
@@ -274,13 +278,13 @@
     # Wait for reply from service
     res <- readFifo(resultPipeName, timeout=timeout)
+    if (length(res) == 0) {
+      stop(paste("Zero length response on named pipe ", resultPipeName))
     if (is.na(res)) {
       stop(paste("Timeout of ", timeout, "ms exceeded when waiting",
             "for response from swift server"))
-    if (length(res) == 0) {
-      stop(paste("Zero length response on named pipe ", resultPipeName))
     return (res)
Modified: SwiftApps/SwiftR/Swift/R/Export.R
--- SwiftApps/SwiftR/Swift/R/Export.R	2011-02-03 22:22:36 UTC (rev 4058)
+++ SwiftApps/SwiftR/Swift/R/Export.R	2011-02-04 00:28:49 UTC (rev 4059)
@@ -47,22 +47,17 @@
 #TODO: not implemented
-swiftExport <- function (..., list=NULL) {
+swiftExport <- function (..., list=NULL, expFile=NULL) {
     # List of object names (as R symbols or as strings)
     # These will be passed directly to save() to be serialized
-        cat("Got here")
-            cat("Got here")
-    #Pseudocode:
+    # TODO: For now,while testing, must manually specify location
     # TODO: choose file location
     # expFile <- ???
     save(..., list=list, file=expFile)
     exportList <- getOption(".swift.exports")
     if (is.null(exportList))
         exportList = list() #TODO: start with removeAll command?
-    exportList[[length(exportList) + 1]] = c("export", expFile)
+    exportList[[length(exportList) + 1]] = c("import", expFile)
     options(.swift.exports=exportList)
Modified: SwiftApps/SwiftR/Swift/exec/SwiftRServer.R
--- SwiftApps/SwiftR/Swift/exec/SwiftRServer.R	2011-02-03 22:22:36 UTC (rev 4058)
+++ SwiftApps/SwiftR/Swift/exec/SwiftRServer.R	2011-02-04 00:28:49 UTC (rev 4059)
@@ -46,6 +46,8 @@
 doInit <- function(initializer) {
+  #print(sprintf("received initializer=%s latestInitializer=%s\n",
+  #                         initializer, latestInitializer));
   if( initializer != latestInitializer) {
     initialExpr <- parse(text=initializer)
     eval(initialExpr)
@@ -54,32 +56,95 @@
+failBatch <- function(rcall, try.error, resultBatchFileName) {
+    # This function is called when an error occurs and
+    # no valid argument values can be produced
+    # It fills a result array with the try.error object
+    # and writes it to resultBatchFileName
+    result <- list()
+    for (c in 1:length(rcall$arglistbatch)) {
+        result[[c]] <- try.error
+    save(result,file=resultBatchFileName)
 runBatch <- function( callBatchFileName, resultBatchFileName )
-  result <- list()
   success <- try(load(callBatchFileName));
-  if (!inherits(success, "try-error")) {
-      success <- try(doInit(rcall$initializer))
+  if (inherits(success, "try-error")) {
+    failBatch(rcall, success, resultBatchFileName)
+    return
+  success <- try(doInit(rcall$initializer))
-    # Load or initialiser failed, return an error for all elements
-    for (c in 1:length(rcall$arglistbatch)) {
-        result[[c]] <- success
-    save(result,file=resultBatchFileName)
+    return
-  else {
-    # print(sprintf("received initializer=%s latestInitializer=%s\n",initializer, latestInitializer));
+  success <- try(loadImports(rcall$imports))
-    for(c in 1:length(rcall$arglistbatch)) {
-     # FIXME: run this under try/catch and save error status in results object (need to make it a list: rval + error status)
-        result[[c]] = try(do.call( rcall$func,
-            as.list(rcall$arglistbatch[[c]] )))
+  result <- list()
+  for(c in 1:length(rcall$arglistbatch)) {
+    # FIXME: run this under try/catch and save error status
+    # in results object (need to make it a list: rval + error status)
+    result[[c]] = try(do.call( rcall$func,
+        as.list(rcall$arglistbatch[[c]] )))
+loadImports <- function (importlist) {
+    # importlist is a list of directives to be carried out in sequence.
+    # There are two distinct directives which appear in the first position:
+    #   - removeAll removes all global R objects
+    #   - import comes with an argument in the second position which is
+    #       the location of an R file to import
+    for (imp in importlist) {
+        directive <- imp[1]
+        if (directive == "import") {
+            # Load the contents of the specified file
+            # into the global environment
+            file <- imp[2]
+            if (!exists(".swift.imported")) {
+                .swift.imported <<- new.env(hash=T, parent=emptyenv())
+                doImport <- TRUE
+            else {
+                # check to see if already imported
+                doImport <- !exists(file, envir=.swift.imported)
+            if (doImport) {
+                #TODO: load can fail with warning
+                load(file, envir=globalenv())
+                # if an error occurs here, assume calling function
+                # will catch it
+                assign(file, TRUE, envir=.swift.imported)
+                cat("Loaded file ", file, "\n")
+            else {
+                cat("Ignored file ", file, "\n")
+        else if (directive == "removeAll") {
+            # delete all visible objects in global environment
+            # TODO: need to record that we did this removeAll
+            cat("Deleting ", ls(envir=globalenv()))
+            #TODO: this fails because it deletes the functions in
+            # this file from the environment
+            rm(list=ls(envir=globalenv()))
+            # reset record of imported items
+            if (exists(".swift.imported", envir=globalenv()))
+                rm(.swift.imported, envir=globalenv())
+            cat("Deleted all")
+        else {
+            stop(paste("Invalid import directive", directive))
 cat("calling server: dir=",fifoDir,"\n")
 setwd(fifoDir)
 SwiftRFifoServer(fifoDir)
Modified: SwiftApps/SwiftR/Swift/exec/start-swift
--- SwiftApps/SwiftR/Swift/exec/start-swift	2011-02-03 22:22:36 UTC (rev 4058)
+++ SwiftApps/SwiftR/Swift/exec/start-swift	2011-02-04 00:28:49 UTC (rev 4059)
@@ -466,11 +466,14 @@
     # Find and terminate R workers: they should register their PiD
     # in a standard location based on the pid of this start-swift
     # script
-    for rwork in `(shopt -s nullglob; echo ../Rworkers/worker.$$/*/)`
-    do
-        kill `cat $rwork/R.pid` &> /dev/null
-        rm -rf $rwork
-    done
+    if [ "$keepdir" = "FALSE" ]
+    then
+        for rwork in `(shopt -s nullglob; echo ../Rworkers/worker.$$/*/)`
+        do
+            kill `cat $rwork/R.pid` &> /dev/null
+            rm -rf $rwork
+        done
+    fi
     stdcleanup_end
     exit 0
More information about the Swift-commit
