[Swift-commit] r4054 - SwiftApps/SwiftR/Swift/R
    noreply at svn.ci.uchicago.edu
    Thu Feb  3 12:37:27 CST 2011
Author: tga
Date: 2011-02-03 12:37:26 -0600 (Thu, 03 Feb 2011)
New Revision: 4054
Modified:
   SwiftApps/SwiftR/Swift/R/Swift.R
Log:
Working versions of swiftLibrary and swiftDetach functions which work
analagously to built-in library and detach fucntions (but with fewer options).
These functions are implemented in such a way that the sequence of library
and detach calls is stored in R and added to the initialExpr for all the swift
workers, so new workers can be brought online and have the correct libraries
loaded without intervention from the user.
Modified: SwiftApps/SwiftR/Swift/R/Swift.R
--- SwiftApps/SwiftR/Swift/R/Swift.R	2011-02-03 17:56:19 UTC (rev 4053)
+++ SwiftApps/SwiftR/Swift/R/Swift.R	2011-02-03 18:37:26 UTC (rev 4054)
@@ -61,14 +61,26 @@
   # Build a list of "Library" statements for all of the libraries
   # already specified through swiftLibrary commands.
-  lib <- getOption("swift.libraries")
+  lib <- getOption(".swift.packages")
   if (!is.null(lib)) {
     # library statements
     stmts <- lapply(lib,
-                function (l) {
-                    return (sprintf("library(%s);", l));
+                function (libcmd) {
+                    verb <- libcmd[1];
+                    if (verb == "library") {
+                        return (sprintf("library(%s);", libcmd[2]));
+                    else if (verb == "detach") {
+                        return (sprintf("try(detach(package:%s),silent=T);",
+                                    libcmd[2]));
+                    else {
+                        error(paste("invalid verb ", verb, " in ",
+                                ".swift.packages option"))
     libstr = paste(stmts, collapse=" ")
+    cat("libstr: ", libstr)
   else {
     libstr = ""
@@ -270,31 +282,93 @@
   swiftapply(func, arglists)
-swiftLibrary <- function (newlib, reset=FALSE)
+swiftRemoveAll <- function () {
+    # Cleans up all data in global namespace on workers
+    options(.swift.exports=list(c("removeAll")))
+swiftLibrary <- function (packname) {
     # Add a library to be included on all workers
     # The package can be provided directly or alternatively
     # the package name can be provided.
-    if (reset) {
-        libs = list()
+    # If reset is true, then previously added libraries won't be
+    # reimported on new workers.
+    # Check to see if it is a string, if it is not a string
+    # then we will deparse it to get the expression text
+    if (!is.character(substitute(packname))) {
+        # Maybe library was provided unquoted
+        packname <- deparse(substitute(packname))
+    if (! packname %in% installed.packages()) {
+        # Warn users in case they made a typo
+        warning(paste("Package", packname,
+                "was not a installed package in this instance of R,",
+                "but may be installed on SwiftR workers"))
+    plist <- getOption(".swift.packages")
+    if (is.null(plist)) {
+        plist <- list()
     else {
-        libs <- getOption("swift.libraries")
-        if (is.null(libs))
-            libs <- list()
+        # scan libs for previous detaches and libraries of
+        # this package.  Delete all of them
+        plist = Filter(function(packcmd)
+                        { return (packcmd[2] != packname);},
+                        plist)
-    for (l in newlib) {
-        if (!is.character(l)) {
-            # Maybe library was provided unquoted
-            #FIXME: doesn't work because l is evaluated above
-            l <- deparse(substitute(l))
-        libs[[length(libs) + 1]] <- l
+    # Add the library command to the end of the list of commands to be
+    # executed in slave R instances
+    plist[[length(plist) + 1]] <- c("library", packname)
+    options(.swift.packages=plist)
+swiftDetach <- function (name) {
+    # name is an string or identifier such as "package:OpenMx",
+    #   following the same pattern as the built in R detach() function
+    # Detaches a library from workers and ensures that it will no longer be
+    # imported.  Note that the effect on dependent imports is a little
+    # messy and behaves differently on existing and new workers.
+    # If package A requires package B, and we import A on a worker,
+    # package B will also be imported on the worker.  By detaching package A
+    # we don't also detach B.  This contrasts to a fresh worker, where
+    # package B will not be imported.
+    if (!is.character(substitute(name))) {
+        # Maybe package was provided unquoted
+        name <- deparse(substitute(name))
-    options(swift.libraries=libs)
+    #TODO: remove from options(".swift.packages")
+    # Scan through list and remove any attach or detach of this name
+    # add a detach cmd to the end
+    if (substr(name, 1, 8) != "package:")
+        stop("Can only detach packages.  Package must be specified as package:PackageName")
+    # Get bit after "package:"
+    packname = substr(name, 9, nchar(name))
+    plist = getOption(".swift.packages")
+        plist = list()
+    else {
+        # Previous export/detach commands are now redundant
+                        plist)
+    plist[[length(plist) + 1]] = c("detach", packname)
+swiftExportAll <- function () {
+    return (swiftExport(list=ls(globalenv())))
 #TODO: not implemented
-.swiftExport <- function (...) {
+.swiftExport <- function (..., list=NULL) {
     # List of object names (as R symbols or as strings)
     # These will be passed directly to save() to be serialized
@@ -332,4 +406,16 @@
     #  swiftRemove()
     #   Implementation of this function is somewhat problematic, as it only
     #   partially undoes previous work
+    #Pseudocode:
+    # TODO: choose file location
+    # expFile <- ???
+    save(..., list=list, file=expFile)
+    exportList <- getOption(".swift.exports")
+    if (is.null(exportList))
+        exportList = list() #TODO: start with removeAll command?
+    exportList[[length(exportList) + 1]] = c("export", expFile)
+    options(.swift.exports=exportList)
More information about the Swift-commit
