[Swift-commit] r5425 - in usertools: swift-ec2-boot swift-gp-boot swift-vm-boot swift-vm-boot/ec2 swift-vm-boot/futuregrid swift-vm-boot/futuregrid/bin swift-vm-boot/futuregrid/plan swift-vm-boot/gp
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Fri Dec 16 12:39:53 CST 2011
Author: davidk
Date: 2011-12-16 12:38:06 -0600 (Fri, 16 Dec 2011)
New Revision: 5425
Added:
   usertools/swift-vm-boot/ec2/
   usertools/swift-vm-boot/ec2/THIRDPARTYLICENSE.TXT
   usertools/swift-vm-boot/ec2/bin/
   usertools/swift-vm-boot/ec2/lib/
   usertools/swift-vm-boot/ec2/license.txt
   usertools/swift-vm-boot/ec2/notice.txt
   usertools/swift-vm-boot/futuregrid/
   usertools/swift-vm-boot/futuregrid/bin/
   usertools/swift-vm-boot/futuregrid/bin/bootit.sh
   usertools/swift-vm-boot/futuregrid/bin/handleoutput.py
   usertools/swift-vm-boot/futuregrid/bin/nimbus-register-key.py
   usertools/swift-vm-boot/futuregrid/bin/register_key.py
   usertools/swift-vm-boot/futuregrid/bin/virtualenv.py
   usertools/swift-vm-boot/futuregrid/env.sh
   usertools/swift-vm-boot/futuregrid/hosts.txt
   usertools/swift-vm-boot/futuregrid/install.sh
   usertools/swift-vm-boot/futuregrid/plan/
   usertools/swift-vm-boot/futuregrid/plan/test-level1.conf
   usertools/swift-vm-boot/futuregrid/plan/top.conf
   usertools/swift-vm-boot/gp/
   usertools/swift-vm-boot/gp/ec2.template.conf
   usertools/swift-vm-boot/gp/globus-provision-0.3.2.tar.gz
   usertools/swift-vm-boot/gp/install.sh
Removed:
   usertools/swift-ec2-boot/THIRDPARTYLICENSE.TXT
   usertools/swift-ec2-boot/bin/
   usertools/swift-ec2-boot/lib/
   usertools/swift-ec2-boot/license.txt
   usertools/swift-ec2-boot/notice.txt
   usertools/swift-gp-boot/ec2.template.conf
   usertools/swift-gp-boot/globus-provision-0.3.2.tar.gz
   usertools/swift-gp-boot/install.sh
   usertools/swift-vm-boot/bin/
   usertools/swift-vm-boot/env.sh
   usertools/swift-vm-boot/hosts.txt
   usertools/swift-vm-boot/install.sh
   usertools/swift-vm-boot/plan/
Log:
Move the various vm tools into one directory
Deleted: usertools/swift-ec2-boot/THIRDPARTYLICENSE.TXT
--- usertools/swift-ec2-boot/THIRDPARTYLICENSE.TXT	2011-12-16 18:28:15 UTC (rev 5424)
+++ usertools/swift-ec2-boot/THIRDPARTYLICENSE.TXT	2011-12-16 18:38:06 UTC (rev 5425)
@@ -1,974 +0,0 @@
-%% The following software may be included in this product:
-  xalan-j2-2.7.0.jar
-Use of any of this software is governed by the terms of the license below:
-   ==  NOTICE file corresponding to section 4(d) of the Apache License,   ==
-   ==  Version 2.0, in this case for the Apache Xalan serializer          ==
-   ==  distribution.                                                      ==
-   This product includes software developed by IBM Corporation (http://www.ibm.com)
-   and The Apache Software Foundation (http://www.apache.org/).
-   Portions of this software was originally based on the following:
-     - software copyright (c) 1999-2002, Lotus Development Corporation.,
-       http://www.lotus.com.
-     - software copyright (c) 2001-2002, Sun Microsystems.,
-       http://www.sun.com.
-     - software copyright (c) 2003, IBM Corporation., http://www.ibm.com.
-  commons-cli-1.1.jar
-  commons-codec-1.3.jar
-  commons-discovery-0.2.jar
-  commons-httpclient-3.0.jar
-  commons-logging-1.0.4.jar
-  jets3t-0.8.0.jar
-  log4j.jar
-  stax-api-1.0.1.jar
-  wss4j-1.5.1.jar
-  wstx-asl-3.2.0.jar
-  xalan-j2-serializer.jar
-  xmlsec-1.3.0.jar
-  java-xmlbuilder-0.4-SNAPSHOT.jar
-                                 Apache License
-                           Version 2.0, January 2004
-                        http://www.apache.org/licenses/
-   TERMS AND CONDITIONS FOR USE, REPRODUCTION, AND DISTRIBUTION
-   1. Definitions.
-      "License" shall mean the terms and conditions for use, reproduction,
-      and distribution as defined by Sections 1 through 9 of this document.
-      "Licensor" shall mean the copyright owner or entity authorized by
-      the copyright owner that is granting the License.
-      "Legal Entity" shall mean the union of the acting entity and all
-      other entities that control, are controlled by, or are under common
-      control with that entity. For the purposes of this definition,
-      "control" means (i) the power, direct or indirect, to cause the
-      direction or management of such entity, whether by contract or
-      otherwise, or (ii) ownership of fifty percent (50%) or more of the
-      outstanding shares, or (iii) beneficial ownership of such entity.
-      "You" (or "Your") shall mean an individual or Legal Entity
-      exercising permissions granted by this License.
-      "Source" form shall mean the preferred form for making modifications,
-      including but not limited to software source code, documentation
-      source, and configuration files.
-      "Object" form shall mean any form resulting from mechanical
-      transformation or translation of a Source form, including but
-      not limited to compiled object code, generated documentation,
-      and conversions to other media types.
-      "Work" shall mean the work of authorship, whether in Source or
-      Object form, made available under the License, as indicated by a
-      copyright notice that is included in or attached to the work
-      (an example is provided in the Appendix below).
-      "Derivative Works" shall mean any work, whether in Source or Object
-      form, that is based on (or derived from) the Work and for which the
-      editorial revisions, annotations, elaborations, or other modifications
-      represent, as a whole, an original work of authorship. For the purposes
-      of this License, Derivative Works shall not include works that remain
-      separable from, or merely link (or bind by name) to the interfaces of,
-      the Work and Derivative Works thereof.
-      "Contribution" shall mean any work of authorship, including
-      the original version of the Work and any modifications or additions
-      to that Work or Derivative Works thereof, that is intentionally
-      submitted to Licensor for inclusion in the Work by the copyright owner
-      or by an individual or Legal Entity authorized to submit on behalf of
-      the copyright owner. For the purposes of this definition, "submitted"
-      means any form of electronic, verbal, or written communication sent
-      to the Licensor or its representatives, including but not limited to
-      communication on electronic mailing lists, source code control systems,
-      and issue tracking systems that are managed by, or on behalf of, the
-      Licensor for the purpose of discussing and improving the Work, but
-      excluding communication that is conspicuously marked or otherwise
-      designated in writing by the copyright owner as "Not a Contribution."
-      "Contributor" shall mean Licensor and any individual or Legal Entity
-      on behalf of whom a Contribution has been received by Licensor and
-      subsequently incorporated within the Work.
-   2. Grant of Copyright License. Subject to the terms and conditions of
-      this License, each Contributor hereby grants to You a perpetual,
-      worldwide, non-exclusive, no-charge, royalty-free, irrevocable
-      copyright license to reproduce, prepare Derivative Works of,
-      publicly display, publicly perform, sublicense, and distribute the
-      Work and such Derivative Works in Source or Object form.
-   3. Grant of Patent License. Subject to the terms and conditions of
-      (except as stated in this section) patent license to make, have made,
-      use, offer to sell, sell, import, and otherwise transfer the Work,
-      where such license applies only to those patent claims licensable
-      by such Contributor that are necessarily infringed by their
-      Contribution(s) alone or by combination of their Contribution(s)
-      with the Work to which such Contribution(s) was submitted. If You
-      institute patent litigation against any entity (including a
-      cross-claim or counterclaim in a lawsuit) alleging that the Work
-      or a Contribution incorporated within the Work constitutes direct
-      or contributory patent infringement, then any patent licenses
-      granted to You under this License for that Work shall terminate
-      as of the date such litigation is filed.
-   4. Redistribution. You may reproduce and distribute copies of the
-      Work or Derivative Works thereof in any medium, with or without
-      modifications, and in Source or Object form, provided that You
-      meet the following conditions:
-      (a) You must give any other recipients of the Work or
-          Derivative Works a copy of this License; and
-      (b) You must cause any modified files to carry prominent notices
-          stating that You changed the files; and
-      (c) You must retain, in the Source form of any Derivative Works
-          that You distribute, all copyright, patent, trademark, and
-          attribution notices from the Source form of the Work,
-          excluding those notices that do not pertain to any part of
-          the Derivative Works; and
-      (d) If the Work includes a "NOTICE" text file as part of its
-          distribution, then any Derivative Works that You distribute must
-          include a readable copy of the attribution notices contained
-          within such NOTICE file, excluding those notices that do not
-          pertain to any part of the Derivative Works, in at least one
-          of the following places: within a NOTICE text file distributed
-          as part of the Derivative Works; within the Source form or
-          documentation, if provided along with the Derivative Works; or,
-          within a display generated by the Derivative Works, if and
-          wherever such third-party notices normally appear. The contents
-          of the NOTICE file are for informational purposes only and
-          do not modify the License. You may add Your own attribution
-          notices within Derivative Works that You distribute, alongside
-          or as an addendum to the NOTICE text from the Work, provided
-          that such additional attribution notices cannot be construed
-          as modifying the License.
-      You may add Your own copyright statement to Your modifications and
-      may provide additional or different license terms and conditions
-      for use, reproduction, or distribution of Your modifications, or
-      for any such Derivative Works as a whole, provided Your use,
-      reproduction, and distribution of the Work otherwise complies with
-      the conditions stated in this License.
-   5. Submission of Contributions. Unless You explicitly state otherwise,
-      any Contribution intentionally submitted for inclusion in the Work
-      by You to the Licensor shall be under the terms and conditions of
-      this License, without any additional terms or conditions.
-      Notwithstanding the above, nothing herein shall supersede or modify
-      the terms of any separate license agreement you may have executed
-      with Licensor regarding such Contributions.
-   6. Trademarks. This License does not grant permission to use the trade
-      names, trademarks, service marks, or product names of the Licensor,
-      except as required for reasonable and customary use in describing the
-      origin of the Work and reproducing the content of the NOTICE file.
-   7. Disclaimer of Warranty. Unless required by applicable law or
-      agreed to in writing, Licensor provides the Work (and each
-      Contributor provides its Contributions) on an "AS IS" BASIS,
-      WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
-      implied, including, without limitation, any warranties or conditions
-      of TITLE, NON-INFRINGEMENT, MERCHANTABILITY, or FITNESS FOR A
-      PARTICULAR PURPOSE. You are solely responsible for determining the
-      appropriateness of using or redistributing the Work and assume any
-      risks associated with Your exercise of permissions under this License.
-   8. Limitation of Liability. In no event and under no legal theory,
-      whether in tort (including negligence), contract, or otherwise,
-      unless required by applicable law (such as deliberate and grossly
-      negligent acts) or agreed to in writing, shall any Contributor be
-      liable to You for damages, including any direct, indirect, special,
-      incidental, or consequential damages of any character arising as a
-      result of this License or out of the use or inability to use the
-      Work (including but not limited to damages for loss of goodwill,
-      work stoppage, computer failure or malfunction, or any and all
-      other commercial damages or losses), even if such Contributor
-      has been advised of the possibility of such damages.
-   9. Accepting Warranty or Additional Liability. While redistributing
-      the Work or Derivative Works thereof, You may choose to offer,
-      and charge a fee for, acceptance of support, warranty, indemnity,
-      or other liability obligations and/or rights consistent with this
-      License. However, in accepting such obligations, You may act only
-      on Your own behalf and on Your sole responsibility, not on behalf
-      of any other Contributor, and only if You agree to indemnify,
-      defend, and hold each Contributor harmless for any liability
-      incurred by, or claims asserted against, such Contributor by reason
-      of your accepting any such warranty or additional liability.
-   END OF TERMS AND CONDITIONS
-   APPENDIX: How to apply the Apache License to your work.
-      To apply the Apache License to your work, attach the following
-      boilerplate notice, with the fields enclosed by brackets "[]"
-      replaced with your own identifying information. (Don't include
-      the brackets!)  The text should be enclosed in the appropriate
-      comment syntax for the file format. We also recommend that a
-      file or class name and description of purpose be included on the
-      same "printed page" as the copyright notice for easier
-      identification within third-party archives.
-   Copyright [yyyy] [name of copyright owner]
-   Licensed under the Apache License, Version 2.0 (the "License");
-   you may not use this file except in compliance with the License.
-   You may obtain a copy of the License at
-       http://www.apache.org/licenses/LICENSE-2.0
-   Unless required by applicable law or agreed to in writing, software
-   distributed under the License is distributed on an "AS IS" BASIS,
-   WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
-   See the License for the specific language governing permissions and
-   limitations under the License.
-  xfire-all-1.2.6.jar
-  xfire-jsr181-api-1.0-M1.jar
-  Copyright (c) 2005 Envoi Solutions LLC
-  Permission is hereby granted, free of charge, to any person obtaining a copy
-  of this software and associated documentation files (the "Software"), to deal
-  in the Software without restriction, including without limitation the rights
-  to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
-  copies of the Software, and to permit persons to whom the Software is
-  furnished to do so, subject to the following conditions:
-  The above copyright notice and this permission notice shall be included in all
-  copies or substantial portions of the Software.
-  THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
-  IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
-  FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
-  AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
-  LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
-  OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
-  SOFTWARE.
-  jdom-1.0.jar
- Copyright (C) 2000-2004 Jason Hunter & Brett McLaughlin.
- All rights reserved.
- Redistribution and use in source and binary forms, with or without
- modification, are permitted provided that the following conditions
- are met:
- 1. Redistributions of source code must retain the above copyright
-    notice, this list of conditions, and the following disclaimer.
- 2. Redistributions in binary form must reproduce the above copyright
-    notice, this list of conditions, and the disclaimer that follows
-    these conditions in the documentation and/or other materials
-    provided with the distribution.
- 3. The name "JDOM" must not be used to endorse or promote products
-    derived from this software without prior written permission.  For
-    written permission, please contact <request_AT_jdom_DOT_org>.
- 4. Products derived from this software may not be called "JDOM", nor
-    may "JDOM" appear in their name, without prior written permission
-    from the JDOM Project Management <request_AT_jdom_DOT_org>.
- In addition, we request (but do not require) that you include in the
- end-user documentation provided with the redistribution and/or in the
- software itself an acknowledgement equivalent to the following:
-     "This product includes software developed by the
-      JDOM Project (http://www.jdom.org/)."
- Alternatively, the acknowledgment may be graphical using the logos
- available at http://www.jdom.org/images/logos.
- THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
- WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
- OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
- DISCLAIMED.  IN NO EVENT SHALL THE JDOM AUTHORS OR THE PROJECT
- CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
- LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
- USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
- ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
- OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- SUCH DAMAGE.
- This software consists of voluntary contributions made by many
- individuals on behalf of the JDOM Project and was originally
- created by Jason Hunter <jhunter_AT_jdom_DOT_org> and
- Brett McLaughlin <brett_AT_jdom_DOT_org>.  For more information
- on the JDOM Project, please see <http://www.jdom.org/>.
-  bcprov.jar
-Copyright (c) 2000 - 2008 The Legion Of The Bouncy Castle
-(http://www.bouncycastle.org)
-Permission is hereby granted, free of charge, to any person obtaining a copy of
-this software and associated documentation files (the "Software"), to deal in
-the Software without restriction, including without limitation the rights to
-use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies
-of the Software, and to permit persons to whom the Software is furnished to do
-so, subject to the following conditions:
-The above copyright notice and this permission notice shall be included in all
-copies or substantial portions of the Software.
-THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
-IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
-FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
-AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
-LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
-OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
-SOFTWARE.
-  activation-1.1.jar
-  jaxb-api-2.0.jar
-  jaxb-impl-2.0.1.jar
-  jaxws-api-2.0.jar
-  mail-1.4.jar
-These are released under dual license consisting of the CDDL v1.0 and GPL v2 with "CLASSPATH" EXCEPTION.
-COMMON DEVELOPMENT AND DISTRIBUTION LICENSE (CDDL) Version 1.0
-1. Definitions.
-1.1. "Contributor" means each individual or entity that
-creates or contributes to the creation of Modifications.
-1.2. "Contributor Version" means the combination of the
-Original Software, prior Modifications used by a
-Contributor (if any), and the Modifications made by that
-particular Contributor.
-1.3. "Covered Software" means (a) the Original Software, or
-(b) Modifications, or (c) the combination of files
-containing Original Software with files containing
-Modifications, in each case including portions thereof.
-1.4. "Executable" means the Covered Software in any form
-other than Source Code.
-1.5. "Initial Developer" means the individual or entity
-that first makes Original Software available under this
-License.
-1.6. "Larger Work" means a work which combines Covered
-Software or portions thereof with code not governed by the
-terms of this License.
-1.7. "License" means this document.
-1.8. "Licensable" means having the right to grant, to the
-maximum extent possible, whether at the time of the initial
-grant or subsequently acquired, any and all of the rights
-conveyed herein.
-1.9. "Modifications" means the Source Code and Executable
-form of any of the following:
-A. Any file that results from an addition to,
-deletion from or modification of the contents of a
-file containing Original Software or previous
-Modifications;
-B. Any new file that contains any part of the
-Original Software or previous Modification; or
-C. Any new file that is contributed or otherwise made
-available under the terms of this License.
-1.10. "Original Software" means the Source Code and
-Executable form of computer software code that is
-originally released under this License.
-1.11. "Patent Claims" means any patent claim(s), now owned
-or hereafter acquired, including without limitation,
-method, process, and apparatus claims, in any patent
-Licensable by grantor.
-1.12. "Source Code" means (a) the common form of computer
-software code in which modifications are made and (b)
-associated documentation included in or with such code.
-1.13. "You" (or "Your") means an individual or a legal
-entity exercising rights under, and complying with all of
-the terms of, this License. For legal entities, "You"
-includes any entity which controls, is controlled by, or is
-under common control with You. For purposes of this
-definition, "control" means (a) the power, direct or
-indirect, to cause the direction or management of such
-entity, whether by contract or otherwise, or (b) ownership
-of more than fifty percent (50%) of the outstanding shares
-or beneficial ownership of such entity.
-2. License Grants.
-2.1. The Initial Developer Grant.
-Conditioned upon Your compliance with Section 3.1 below and
-subject to third party intellectual property claims, the
-Initial Developer hereby grants You a world-wide,
-royalty-free, non-exclusive license:
-(a) under intellectual property rights (other than
-patent or trademark) Licensable by Initial Developer,
-to use, reproduce, modify, display, perform,
-sublicense and distribute the Original Software (or
-portions thereof), with or without Modifications,
-and/or as part of a Larger Work; and
-(b) under Patent Claims infringed by the making,
-using or selling of Original Software, to make, have
-made, use, practice, sell, and offer for sale, and/or
-otherwise dispose of the Original Software (or
-portions thereof).
-(c) The licenses granted in Sections 2.1(a) and (b)
-are effective on the date Initial Developer first
-distributes or otherwise makes the Original Software
-available to a third party under the terms of this
-License.
-(d) Notwithstanding Section 2.1(b) above, no patent
-license is granted: (1) for code that You delete from
-the Original Software, or (2) for infringements
-caused by: (i) the modification of the Original
-Software, or (ii) the combination of the Original
-Software with other software or devices.
-2.2. Contributor Grant.
-subject to third party intellectual property claims, each
-Contributor hereby grants You a world-wide, royalty-free,
-non-exclusive license:
-patent or trademark) Licensable by Contributor to
-use, reproduce, modify, display, perform, sublicense
-and distribute the Modifications created by such
-Contributor (or portions thereof), either on an
-unmodified basis, with other Modifications, as
-Covered Software and/or as part of a Larger Work; and
-using, or selling of Modifications made by that
-Contributor either alone and/or in combination with
-its Contributor Version (or portions of such
-combination), to make, use, sell, offer for sale,
-have made, and/or otherwise dispose of: (1)
-Modifications made by that Contributor (or portions
-thereof); and (2) the combination of Modifications
-made by that Contributor with its Contributor Version
-(or portions of such combination).
-(c) The licenses granted in Sections 2.2(a) and
-2.2(b) are effective on the date Contributor first
-distributes or otherwise makes the Modifications
-available to a third party.
-(d) Notwithstanding Section 2.2(b) above, no patent
-license is granted: (1) for any code that Contributor
-has deleted from the Contributor Version; (2) for
-infringements caused by: (i) third party
-modifications of Contributor Version, or (ii) the
-combination of Modifications made by that Contributor
-with other software (except as part of the
-Contributor Version) or other devices; or (3) under
-Patent Claims infringed by Covered Software in the
-absence of Modifications made by that Contributor.
-3. Distribution Obligations.
-3.1. Availability of Source Code.
-Any Covered Software that You distribute or otherwise make
-available in Executable form must also be made available in
-Source Code form and that Source Code form must be
-distributed only under the terms of this License. You must
-include a copy of this License with every copy of the
-Source Code form of the Covered Software You distribute or
-otherwise make available. You must inform recipients of any
-such Covered Software in Executable form as to how they can
-obtain such Covered Software in Source Code form in a
-reasonable manner on or through a medium customarily used
-for software exchange.
-3.2. Modifications.
-The Modifications that You create or to which You
-contribute are governed by the terms of this License. You
-represent that You believe Your Modifications are Your
-original creation(s) and/or You have sufficient rights to
-grant the rights conveyed by this License.
-3.3. Required Notices.
-You must include a notice in each of Your Modifications
-that identifies You as the Contributor of the Modification.
-You may not remove or alter any copyright, patent or
-trademark notices contained within the Covered Software, or
-any notices of licensing or any descriptive text giving
-attribution to any Contributor or the Initial Developer.
-3.4. Application of Additional Terms.
-You may not offer or impose any terms on any Covered
-Software in Source Code form that alters or restricts the
-applicable version of this License or the recipients'
-rights hereunder. You may choose to offer, and to charge a
-fee for, warranty, support, indemnity or liability
-obligations to one or more recipients of Covered Software.
-However, you may do so only on Your own behalf, and not on
-behalf of the Initial Developer or any Contributor. You
-must make it absolutely clear that any such warranty,
-support, indemnity or liability obligation is offered by
-You alone, and You hereby agree to indemnify the Initial
-Developer and every Contributor for any liability incurred
-by the Initial Developer or such Contributor as a result of
-warranty, support, indemnity or liability terms You offer.
-3.5. Distribution of Executable Versions.
-You may distribute the Executable form of the Covered
-Software under the terms of this License or under the terms
-of a license of Your choice, which may contain terms
-different from this License, provided that You are in
-compliance with the terms of this License and that the
-license for the Executable form does not attempt to limit
-or alter the recipient's rights in the Source Code form
-from the rights set forth in this License. If You
-distribute the Covered Software in Executable form under a
-different license, You must make it absolutely clear that
-any terms which differ from this License are offered by You
-alone, not by the Initial Developer or Contributor. You
-hereby agree to indemnify the Initial Developer and every
-Contributor for any liability incurred by the Initial
-Developer or such Contributor as a result of any such terms
-You offer.
-3.6. Larger Works.
-You may create a Larger Work by combining Covered Software
-with other code not governed by the terms of this License
-and distribute the Larger Work as a single product. In such
-a case, You must make sure the requirements of this License
-are fulfilled for the Covered Software.
-4. Versions of the License.
-4.1. New Versions.
-Sun Microsystems, Inc. is the initial license steward and
-may publish revised and/or new versions of this License
-from time to time. Each version will be given a
-distinguishing version number. Except as provided in
-Section 4.3, no one other than the license steward has the
-right to modify this License.
-4.2. Effect of New Versions.
-You may always continue to use, distribute or otherwise
-make the Covered Software available under the terms of the
-version of the License under which You originally received
-the Covered Software. If the Initial Developer includes a
-notice in the Original Software prohibiting it from being
-distributed or otherwise made available under any
-subsequent version of the License, You must distribute and
-the Covered Software. Otherwise, You may also choose to
-use, distribute or otherwise make the Covered Software
-available under the terms of any subsequent version of the
-License published by the license steward.
-4.3. Modified Versions.
-When You are an Initial Developer and You want to create a
-new license for Your Original Software, You may create and
-use a modified version of this License if You: (a) rename
-the license and remove any references to the name of the
-license steward (except to note that the license differs
-from this License); and (b) otherwise make it clear that
-the license contains terms which differ from this License.
-5. DISCLAIMER OF WARRANTY.
-COVERED SOFTWARE IS PROVIDED UNDER THIS LICENSE ON AN "AS IS"
-BASIS, WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED OR IMPLIED,
-INCLUDING, WITHOUT LIMITATION, WARRANTIES THAT THE COVERED
-SOFTWARE IS FREE OF DEFECTS, MERCHANTABLE, FIT FOR A PARTICULAR
-PURPOSE OR NON-INFRINGING. THE ENTIRE RISK AS TO THE QUALITY AND
-PERFORMANCE OF THE COVERED SOFTWARE IS WITH YOU. SHOULD ANY
-COVERED SOFTWARE PROVE DEFECTIVE IN ANY RESPECT, YOU (NOT THE
-INITIAL DEVELOPER OR ANY OTHER CONTRIBUTOR) ASSUME THE COST OF
-ANY NECESSARY SERVICING, REPAIR OR CORRECTION. THIS DISCLAIMER OF
-WARRANTY CONSTITUTES AN ESSENTIAL PART OF THIS LICENSE. NO USE OF
-ANY COVERED SOFTWARE IS AUTHORIZED HEREUNDER EXCEPT UNDER THIS
-DISCLAIMER.
-6. TERMINATION.
-6.1. This License and the rights granted hereunder will
-terminate automatically if You fail to comply with terms
-herein and fail to cure such breach within 30 days of
-becoming aware of the breach. Provisions which, by their
-nature, must remain in effect beyond the termination of
-this License shall survive.
-6.2. If You assert a patent infringement claim (excluding
-declaratory judgment actions) against Initial Developer or
-a Contributor (the Initial Developer or Contributor against
-whom You assert such claim is referred to as "Participant")
-alleging that the Participant Software (meaning the
-Contributor Version where the Participant is a Contributor
-or the Original Software where the Participant is the
-Initial Developer) directly or indirectly infringes any
-patent, then any and all rights granted directly or
-indirectly to You by such Participant, the Initial
-Developer (if the Initial Developer is not the Participant)
-and all Contributors under Sections 2.1 and/or 2.2 of this
-License shall, upon 60 days notice from Participant
-terminate prospectively and automatically at the expiration
-of such 60 day notice period, unless if within such 60 day
-period You withdraw Your claim with respect to the
-Participant Software against such Participant either
-unilaterally or pursuant to a written agreement with
-Participant.
-6.3. In the event of termination under Sections 6.1 or 6.2
-above, all end user licenses that have been validly granted
-by You or any distributor hereunder prior to termination
-(excluding licenses granted to You by any distributor)
-shall survive termination.
-7. LIMITATION OF LIABILITY.
-UNDER NO CIRCUMSTANCES AND UNDER NO LEGAL THEORY, WHETHER TORT
-(INCLUDING NEGLIGENCE), CONTRACT, OR OTHERWISE, SHALL YOU, THE
-INITIAL DEVELOPER, ANY OTHER CONTRIBUTOR, OR ANY DISTRIBUTOR OF
-COVERED SOFTWARE, OR ANY SUPPLIER OF ANY OF SUCH PARTIES, BE
-LIABLE TO ANY PERSON FOR ANY INDIRECT, SPECIAL, INCIDENTAL, OR
-CONSEQUENTIAL DAMAGES OF ANY CHARACTER INCLUDING, WITHOUT
-LIMITATION, DAMAGES FOR LOST PROFITS, LOSS OF GOODWILL, WORK
-STOPPAGE, COMPUTER FAILURE OR MALFUNCTION, OR ANY AND ALL OTHER
-COMMERCIAL DAMAGES OR LOSSES, EVEN IF SUCH PARTY SHALL HAVE BEEN
-INFORMED OF THE POSSIBILITY OF SUCH DAMAGES. THIS LIMITATION OF
-LIABILITY SHALL NOT APPLY TO LIABILITY FOR DEATH OR PERSONAL
-INJURY RESULTING FROM SUCH PARTY'S NEGLIGENCE TO THE EXTENT
-APPLICABLE LAW PROHIBITS SUCH LIMITATION. SOME JURISDICTIONS DO
-NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR
-CONSEQUENTIAL DAMAGES, SO THIS EXCLUSION AND LIMITATION MAY NOT
-APPLY TO YOU.
-8. U.S. GOVERNMENT END USERS.
-The Covered Software is a "commercial item," as that term is
-defined in 48 C.F.R. 2.101 (Oct. 1995), consisting of "commercial
-computer software" (as that term is defined at 48 C.F.R. ¤
-252.227-7014(a)(1)) and "commercial computer software
-documentation" as such terms are used in 48 C.F.R. 12.212 (Sept.
-1995). Consistent with 48 C.F.R. 12.212 and 48 C.F.R. 227.7202-1
-through 227.7202-4 (June 1995), all U.S. Government End Users
-acquire Covered Software with only those rights set forth herein.
-This U.S. Government Rights clause is in lieu of, and supersedes,
-any other FAR, DFAR, or other clause or provision that addresses
-Government rights in computer software under this License.
-9. MISCELLANEOUS.
-This License represents the complete agreement concerning subject
-matter hereof. If any provision of this License is held to be
-unenforceable, such provision shall be reformed only to the
-extent necessary to make it enforceable. This License shall be
-governed by the law of the jurisdiction specified in a notice
-contained within the Original Software (except to the extent
-applicable law, if any, provides otherwise), excluding such
-jurisdiction's conflict-of-law provisions. Any litigation
-relating to this License shall be subject to the jurisdiction of
-the courts located in the jurisdiction and venue specified in a
-notice contained within the Original Software, with the losing
-party responsible for costs, including, without limitation, court
-costs and reasonable attorneys' fees and expenses. The
-application of the United Nations Convention on Contracts for the
-International Sale of Goods is expressly excluded. Any law or
-regulation which provides that the language of a contract shall
-be construed against the drafter shall not apply to this License.
-You agree that You alone are responsible for compliance with the
-United States export administration regulations (and the export
-control laws and regulation of any other countries) when You use,
-distribute or otherwise make available any Covered Software.
-10. RESPONSIBILITY FOR CLAIMS.
-As between Initial Developer and the Contributors, each party is
-responsible for claims and damages arising, directly or
-indirectly, out of its utilization of rights under this License
-and You agree to work with Initial Developer and Contributors to
-distribute such responsibility on an equitable basis. Nothing
-herein is intended or shall be deemed to constitute any admission
-of liability.
-  wsdl4j-1.6.1.jar
-Common Public License Version 1.0
-THE ACCOMPANYING PROGRAM IS PROVIDED UNDER THE TERMS OF THIS COMMON PUBLIC
-LICENSE ("AGREEMENT"). ANY USE, REPRODUCTION OR DISTRIBUTION OF THE PROGRAM
-CONSTITUTES RECIPIENT'S ACCEPTANCE OF THIS AGREEMENT.
-1. DEFINITIONS
-"Contribution" means:
-    a) in the case of the initial Contributor, the initial code and
-documentation distributed under this Agreement, and
-    b) in the case of each subsequent Contributor:
-    i) changes to the Program, and
-    ii) additions to the Program;
-    where such changes and/or additions to the Program originate from and are
-distributed by that particular Contributor. A Contribution 'originates' from a
-Contributor if it was added to the Program by such Contributor itself or anyone
-acting on such Contributor's behalf. Contributions do not include additions to
-the Program which: (i) are separate modules of software distributed in
-conjunction with the Program under their own license agreement, and (ii) are not
-derivative works of the Program.
-"Contributor" means any person or entity that distributes the Program.
-"Licensed Patents " mean patent claims licensable by a Contributor which are
-necessarily infringed by the use or sale of its Contribution alone or when
-combined with the Program.
-"Program" means the Contributions distributed in accordance with this Agreement.
-"Recipient" means anyone who receives the Program under this Agreement,
-including all Contributors.
-2. GRANT OF RIGHTS
-    a) Subject to the terms of this Agreement, each Contributor hereby grants
-Recipient a non-exclusive, worldwide, royalty-free copyright license to
-reproduce, prepare derivative works of, publicly display, publicly perform,
-distribute and sublicense the Contribution of such Contributor, if any, and such
-derivative works, in source code and object code form.
-    b) Subject to the terms of this Agreement, each Contributor hereby grants
-Recipient a non-exclusive, worldwide, royalty-free patent license under Licensed
-Patents to make, use, sell, offer to sell, import and otherwise transfer the
-Contribution of such Contributor, if any, in source code and object code form.
-This patent license shall apply to the combination of the Contribution and the
-Program if, at the time the Contribution is added by the Contributor, such
-addition of the Contribution causes such combination to be covered by the
-Licensed Patents. The patent license shall not apply to any other combinations
-which include the Contribution. No hardware per se is licensed hereunder.
-    c) Recipient understands that although each Contributor grants the licenses
-to its Contributions set forth herein, no assurances are provided by any
-Contributor that the Program does not infringe the patent or other intellectual
-property rights of any other entity. Each Contributor disclaims any liability to
-Recipient for claims brought by any other entity based on infringement of
-intellectual property rights or otherwise. As a condition to exercising the
-rights and licenses granted hereunder, each Recipient hereby assumes sole
-responsibility to secure any other intellectual property rights needed, if any.
-For example, if a third party patent license is required to allow Recipient to
-distribute the Program, it is Recipient's responsibility to acquire that license
-before distributing the Program.
-    d) Each Contributor represents that to its knowledge it has sufficient
-copyright rights in its Contribution, if any, to grant the copyright license set
-forth in this Agreement.
-3. REQUIREMENTS
-A Contributor may choose to distribute the Program in object code form under its
-own license agreement, provided that:
-    a) it complies with the terms and conditions of this Agreement; and
-    b) its license agreement:
-    i) effectively disclaims on behalf of all Contributors all warranties and
-conditions, express and implied, including warranties or conditions of title and
-non-infringement, and implied warranties or conditions of merchantability and
-fitness for a particular purpose;
-    ii) effectively excludes on behalf of all Contributors all liability for
-damages, including direct, indirect, special, incidental and consequential
-damages, such as lost profits;
-    iii) states that any provisions which differ from this Agreement are offered
-by that Contributor alone and not by any other party; and
-    iv) states that source code for the Program is available from such
-Contributor, and informs licensees how to obtain it in a reasonable manner on or
-through a medium customarily used for software exchange.
-When the Program is made available in source code form:
-    a) it must be made available under this Agreement; and
-    b) a copy of this Agreement must be included with each copy of the Program.
-Contributors may not remove or alter any copyright notices contained within the
-Program.
-Each Contributor must identify itself as the originator of its Contribution, if
-any, in a manner that reasonably allows subsequent Recipients to identify the
-originator of the Contribution.
-4. COMMERCIAL DISTRIBUTION
-Commercial distributors of software may accept certain responsibilities with
-respect to end users, business partners and the like. While this license is
-intended to facilitate the commercial use of the Program, the Contributor who
-includes the Program in a commercial product offering should do so in a manner
-which does not create potential liability for other Contributors. Therefore, if
-a Contributor includes the Program in a commercial product offering, such
-Contributor ("Commercial Contributor") hereby agrees to defend and indemnify
-every other Contributor ("Indemnified Contributor") against any losses, damages
-and costs (collectively "Losses") arising from claims, lawsuits and other legal
-actions brought by a third party against the Indemnified Contributor to the
-extent caused by the acts or omissions of such Commercial Contributor in
-connection with its distribution of the Program in a commercial product
-offering. The obligations in this section do not apply to any claims or Losses
-relating to any actual or alleged intellectual property infringement. In order
-to qualify, an Indemnified Contributor must: a) promptly notify the Commercial
-Contributor in writing of such claim, and b) allow the Commercial Contributor to
-control, and cooperate with the Commercial Contributor in, the defense and any
-related settlement negotiations. The Indemnified Contributor may participate in
-any such claim at its own expense.
-For example, a Contributor might include the Program in a commercial product
-offering, Product X. That Contributor is then a Commercial Contributor. If that
-Commercial Contributor then makes performance claims, or offers warranties
-related to Product X, those performance claims and warranties are such
-Commercial Contributor's responsibility alone. Under this section, the
-Commercial Contributor would have to defend claims against the other
-Contributors related to those performance claims and warranties, and if a court
-requires any other Contributor to pay any damages as a result, the Commercial
-Contributor must pay those damages.
-5. NO WARRANTY
-EXCEPT AS EXPRESSLY SET FORTH IN THIS AGREEMENT, THE PROGRAM IS PROVIDED ON AN
-"AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, EITHER EXPRESS OR
-IMPLIED INCLUDING, WITHOUT LIMITATION, ANY WARRANTIES OR CONDITIONS OF TITLE,
-NON-INFRINGEMENT, MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. Each
-Recipient is solely responsible for determining the appropriateness of using and
-distributing the Program and assumes all risks associated with its exercise of
-rights under this Agreement, including but not limited to the risks and costs of
-program errors, compliance with applicable laws, damage to or loss of data,
-programs or equipment, and unavailability or interruption of operations.
-6. DISCLAIMER OF LIABILITY
-EXCEPT AS EXPRESSLY SET FORTH IN THIS AGREEMENT, NEITHER RECIPIENT NOR ANY
-CONTRIBUTORS SHALL HAVE ANY LIABILITY FOR ANY DIRECT, INDIRECT, INCIDENTAL,
-SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING WITHOUT LIMITATION LOST
-PROFITS), HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
-STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
-OUT OF THE USE OR DISTRIBUTION OF THE PROGRAM OR THE EXERCISE OF ANY RIGHTS
-GRANTED HEREUNDER, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
-7. GENERAL
-If any provision of this Agreement is invalid or unenforceable under applicable
-law, it shall not affect the validity or enforceability of the remainder of the
-terms of this Agreement, and without further action by the parties hereto, such
-provision shall be reformed to the minimum extent necessary to make such
-provision valid and enforceable.
-If Recipient institutes patent litigation against a Contributor with respect to
-a patent applicable to software (including a cross-claim or counterclaim in a
-lawsuit), then any patent licenses granted by that Contributor to such Recipient
-under this Agreement shall terminate as of the date such litigation is filed. In
-addition, if Recipient institutes patent litigation against any entity
-(including a cross-claim or counterclaim in a lawsuit) alleging that the Program
-itself (excluding combinations of the Program with other software or hardware)
-infringes such Recipient's patent(s), then such Recipient's rights granted under
-Section 2(b) shall terminate as of the date such litigation is filed.
-All Recipient's rights under this Agreement shall terminate if it fails to
-comply with any of the material terms or conditions of this Agreement and does
-not cure such failure in a reasonable period of time after becoming aware of
-such noncompliance. If all Recipient's rights under this Agreement terminate,
-Recipient agrees to cease use and distribution of the Program as soon as
-reasonably practicable. However, Recipient's obligations under this Agreement
-and any licenses granted by Recipient relating to the Program shall continue and
-survive.
-Everyone is permitted to copy and distribute copies of this Agreement, but in
-order to avoid inconsistency the Agreement is copyrighted and may only be
-modified in the following manner. The Agreement Steward reserves the right to
-publish new versions (including revisions) of this Agreement from time to time.
-No one other than the Agreement Steward has the right to modify this Agreement.
-IBM is the initial Agreement Steward. IBM may assign the responsibility to serve
-as the Agreement Steward to a suitable separate entity. Each new version of the
-Agreement will be given a distinguishing version number. The Program (including
-Contributions) may always be distributed subject to the version of the Agreement
-under which it was received. In addition, after a new version of the Agreement
-is published, Contributor may elect to distribute the Program (including its
-Contributions) under the new version. Except as expressly stated in Sections
-2(a) and 2(b) above, Recipient receives no rights or licenses to the
-intellectual property of any Contributor under this Agreement, whether
-expressly, by implication, estoppel or otherwise. All rights in the Program not
-expressly granted under this Agreement are reserved.
-This Agreement is governed by the laws of the State of New York and the
-intellectual property laws of the United States of America. No party to this
-Agreement will bring a legal action under this Agreement more than one year
-after the cause of action arose. Each party waives its rights to a jury trial in
-any resulting litigation.
Deleted: usertools/swift-ec2-boot/license.txt
--- usertools/swift-ec2-boot/license.txt	2011-12-16 18:28:15 UTC (rev 5424)
+++ usertools/swift-ec2-boot/license.txt	2011-12-16 18:38:06 UTC (rev 5425)
@@ -1,40 +0,0 @@
-Amazon Software License
-This Amazon Software License (“License”) governs your use, reproduction, and distribution of the accompanying software as specified below.
-1. Definitions
-“Licensor” means any person or entity that distributes its Work.
-“Software” means the original work of authorship made available under this License.
-“Work” means the Software and any additions to or derivative works of the Software that are made available under this License.
-The terms “reproduce,” “reproduction,” “derivative works,” and “distribution” have the meaning as provided under U.S. copyright law; provided, however, that for the purposes of this License, derivative works shall not include works that remain separable from, or merely link (or bind by name) to the interfaces of, the Work.
-Works, including the Software, are “made available” under this License by including in or with the Work either (a) a copyright notice referencing the applicability of this License to the Work, or (b) a copy of this License.
-2. License Grants
-2.1 Copyright Grant. Subject to the terms and conditions of this License, each Licensor grants to you a perpetual, worldwide, non-exclusive, royalty-free, copyright license to reproduce, prepare derivative works of, publicly display, publicly perform, sublicense and distribute its Work and any resulting derivative works in any form.
-2.2 Patent Grant. Subject to the terms and conditions of this License, each Licensor grants to you a perpetual, worldwide, non-exclusive, royalty-free patent license to make, have made, use, sell, offer for sale, import, and otherwise transfer its Work, in whole or in part. The foregoing license applies only to the patent claims licensable by Licensor that would be infringed by Licensor’s Work (or portion thereof) individually and excluding any combinations with any other materials or technology.
-3. Limitations
-3.1 Redistribution. You may reproduce or distribute the Work only if (a) you do so under this License, (b) you include a complete copy of this License with your distribution, and© you retain without modification any copyright, patent, trademark, or attribution notices that are present in the Work.
-3.2 Derivative Works. You may specify that additional or different terms apply to the use, reproduction, and distribution of your derivative works of the Work (“Your Terms”) only if (a) Your Terms provide that the use limitation in Section 3.3 applies to your derivative works, and (b) you identify the specific derivative works that are subject to Your Terms. Notwithstanding Your Terms, this License (including the redistribution requirements in Section 3.1) will continue to apply to the Work itself.
-3.3 Use Limitation. The Work and any derivative works thereof only may be used or intended for use with the web services, computing platforms or applications provided by Amazon.com, Inc. or its affiliates, including Amazon Web Services LLC.
-3.4 Patent Claims. If you bring or threaten to bring a patent claim against any Licensor (including any claim, cross-claim or counterclaim in a lawsuit) to enforce any patents that you allege are infringed by any Work, then your rights under this License from such Licensor (including the grants in Sections 2.1 and 2.2) will terminate immediately.
-3.5 Trademarks. This License does not grant any rights to use any Licensor’s or its affiliates’ names, logos, or trademarks, except as necessary to reproduce the notices described in this License.
-3.6 Termination. If you violate any term of this License, then your rights under this License (including the grants in Sections 2.1 and 2.2) will terminate immediately.
-4. Disclaimer of Warranty.
-THE WORK IS PROVIDED “AS IS” WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, EITHER EXPRESS OR IMPLIED, INCLUDING WARRANTIES OR CONDITIONS OF M ERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, TITLE OR NON-INFRINGEMENT. YOU BEAR THE RISK OF UNDERTAKING ANY ACTIVITIES UNDER THIS LICENSE. SOME STATES’ CONSUMER LAWS DO NOT ALLOW EXCLUSION OF AN IMPLIED WARRANTY, SO THIS DISCLAIMER MAY NOT APPLY TO YOU.
-5. Limitation of Liability.
-EXCEPT AS PROHIBITED BY APPLICABLE LAW, IN NO EVENT AND UNDER NO LEGAL THEORY, WHETHER IN TORT (INCLUDING NEGLIGENCE), CONTRACT, OR OTHERWISE SHALL ANY LICENSOR BE LIABLE TO YOU FOR DAMAGES, INCLUDING ANY DIRECT, INDIRECT, SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES ARISING OUT OF OR RELATED TO THIS LICENSE, THE USE OR INABILITY TO USE THE WORK (INCLUDING BUT NOT LIMITED TO LOSS OF GOODWILL, BUSINESS INTERRUPTION, LOST PROFITS OR DATA, COMPUTER FAILURE OR MALFUNCTION, OR ANY OTHER COMM ERCIAL DAMAGES OR LOSSES), EVEN IF THE LICENSOR HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
-Effective Date – April 18, 2008 © 2008 Amazon.com, Inc. or its affiliates. All rights reserved.
Deleted: usertools/swift-ec2-boot/notice.txt
--- usertools/swift-ec2-boot/notice.txt	2011-12-16 18:28:15 UTC (rev 5424)
+++ usertools/swift-ec2-boot/notice.txt	2011-12-16 18:38:06 UTC (rev 5425)
@@ -1,5 +0,0 @@
-Copyright 2006-2010 Amazon.com, Inc. or its affiliates.  All Rights Reserved.  Licensed under the
-Amazon Software License (the "License").  You may not use this file except in compliance with the License. A copy of the
-License is located at http://aws.amazon.com/asl or in the "license" file accompanying this file.  This file is distributed on an "AS
-IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License for the specific
-language governing permissions and limitations under the License.
Deleted: usertools/swift-gp-boot/ec2.template.conf
--- usertools/swift-gp-boot/ec2.template.conf	2011-12-16 18:28:15 UTC (rev 5424)
+++ usertools/swift-gp-boot/ec2.template.conf	2011-12-16 18:38:06 UTC (rev 5425)
@@ -1,17 +0,0 @@
-[general]
-domains: swift
-deploy: ec2
-[domain-swift]
-users: swift
-nfs-nis: yes
-lrm: none
-cluster-nodes: _CLUSTER-NODES_
-[ec2]
-ami: _AMI_
-instance-type: _INSTANCE-TYPE_
-keypair: _KEYPAIR_
-keyfile: _KEYFILE_
-username: ubuntu
Deleted: usertools/swift-gp-boot/globus-provision-0.3.2.tar.gz
(Binary files differ)
Deleted: usertools/swift-gp-boot/install.sh
--- usertools/swift-gp-boot/install.sh	2011-12-16 18:28:15 UTC (rev 5424)
+++ usertools/swift-gp-boot/install.sh	2011-12-16 18:38:06 UTC (rev 5425)
@@ -1,8 +0,0 @@
-#!/bin/bash
-tar xvfz globus-provision-0.3.2.tar.gz
-cd globus-provision-0.3.2
-python setup.py install --user
-cd ..
-ln -s ~/.local/bin
-ln -s ~/.local/lib
Copied: usertools/swift-vm-boot/ec2/THIRDPARTYLICENSE.TXT (from rev 5424, usertools/swift-ec2-boot/THIRDPARTYLICENSE.TXT)
--- usertools/swift-vm-boot/ec2/THIRDPARTYLICENSE.TXT	                        (rev 0)
+++ usertools/swift-vm-boot/ec2/THIRDPARTYLICENSE.TXT	2011-12-16 18:38:06 UTC (rev 5425)
@@ -0,0 +1,974 @@
+%% The following software may be included in this product:
+  xalan-j2-2.7.0.jar
+Use of any of this software is governed by the terms of the license below:
+   ==  NOTICE file corresponding to section 4(d) of the Apache License,   ==
+   ==  Version 2.0, in this case for the Apache Xalan serializer          ==
+   ==  distribution.                                                      ==
+   This product includes software developed by IBM Corporation (http://www.ibm.com)
+   and The Apache Software Foundation (http://www.apache.org/).
+   Portions of this software was originally based on the following:
+     - software copyright (c) 1999-2002, Lotus Development Corporation.,
+       http://www.lotus.com.
+     - software copyright (c) 2001-2002, Sun Microsystems.,
+       http://www.sun.com.
+     - software copyright (c) 2003, IBM Corporation., http://www.ibm.com.
+  commons-cli-1.1.jar
+  commons-codec-1.3.jar
+  commons-discovery-0.2.jar
+  commons-httpclient-3.0.jar
+  commons-logging-1.0.4.jar
+  jets3t-0.8.0.jar
+  log4j.jar
+  stax-api-1.0.1.jar
+  wss4j-1.5.1.jar
+  wstx-asl-3.2.0.jar
+  xalan-j2-serializer.jar
+  xmlsec-1.3.0.jar
+  java-xmlbuilder-0.4-SNAPSHOT.jar
+                                 Apache License
+                           Version 2.0, January 2004
+                        http://www.apache.org/licenses/
+   TERMS AND CONDITIONS FOR USE, REPRODUCTION, AND DISTRIBUTION
+   1. Definitions.
+      "License" shall mean the terms and conditions for use, reproduction,
+      and distribution as defined by Sections 1 through 9 of this document.
+      "Licensor" shall mean the copyright owner or entity authorized by
+      the copyright owner that is granting the License.
+      "Legal Entity" shall mean the union of the acting entity and all
+      other entities that control, are controlled by, or are under common
+      control with that entity. For the purposes of this definition,
+      "control" means (i) the power, direct or indirect, to cause the
+      direction or management of such entity, whether by contract or
+      otherwise, or (ii) ownership of fifty percent (50%) or more of the
+      outstanding shares, or (iii) beneficial ownership of such entity.
+      "You" (or "Your") shall mean an individual or Legal Entity
+      exercising permissions granted by this License.
+      "Source" form shall mean the preferred form for making modifications,
+      including but not limited to software source code, documentation
+      source, and configuration files.
+      "Object" form shall mean any form resulting from mechanical
+      transformation or translation of a Source form, including but
+      not limited to compiled object code, generated documentation,
+      and conversions to other media types.
+      "Work" shall mean the work of authorship, whether in Source or
+      Object form, made available under the License, as indicated by a
+      copyright notice that is included in or attached to the work
+      (an example is provided in the Appendix below).
+      "Derivative Works" shall mean any work, whether in Source or Object
+      form, that is based on (or derived from) the Work and for which the
+      editorial revisions, annotations, elaborations, or other modifications
+      represent, as a whole, an original work of authorship. For the purposes
+      of this License, Derivative Works shall not include works that remain
+      separable from, or merely link (or bind by name) to the interfaces of,
+      the Work and Derivative Works thereof.
+      "Contribution" shall mean any work of authorship, including
+      the original version of the Work and any modifications or additions
+      to that Work or Derivative Works thereof, that is intentionally
+      submitted to Licensor for inclusion in the Work by the copyright owner
+      or by an individual or Legal Entity authorized to submit on behalf of
+      the copyright owner. For the purposes of this definition, "submitted"
+      means any form of electronic, verbal, or written communication sent
+      to the Licensor or its representatives, including but not limited to
+      communication on electronic mailing lists, source code control systems,
+      and issue tracking systems that are managed by, or on behalf of, the
+      Licensor for the purpose of discussing and improving the Work, but
+      excluding communication that is conspicuously marked or otherwise
+      designated in writing by the copyright owner as "Not a Contribution."
+      "Contributor" shall mean Licensor and any individual or Legal Entity
+      on behalf of whom a Contribution has been received by Licensor and
+      subsequently incorporated within the Work.
+   2. Grant of Copyright License. Subject to the terms and conditions of
+      this License, each Contributor hereby grants to You a perpetual,
+      worldwide, non-exclusive, no-charge, royalty-free, irrevocable
+      copyright license to reproduce, prepare Derivative Works of,
+      publicly display, publicly perform, sublicense, and distribute the
+      Work and such Derivative Works in Source or Object form.
+   3. Grant of Patent License. Subject to the terms and conditions of
+      (except as stated in this section) patent license to make, have made,
+      use, offer to sell, sell, import, and otherwise transfer the Work,
+      where such license applies only to those patent claims licensable
+      by such Contributor that are necessarily infringed by their
+      Contribution(s) alone or by combination of their Contribution(s)
+      with the Work to which such Contribution(s) was submitted. If You
+      institute patent litigation against any entity (including a
+      cross-claim or counterclaim in a lawsuit) alleging that the Work
+      or a Contribution incorporated within the Work constitutes direct
+      or contributory patent infringement, then any patent licenses
+      granted to You under this License for that Work shall terminate
+      as of the date such litigation is filed.
+   4. Redistribution. You may reproduce and distribute copies of the
+      Work or Derivative Works thereof in any medium, with or without
+      modifications, and in Source or Object form, provided that You
+      meet the following conditions:
+      (a) You must give any other recipients of the Work or
+          Derivative Works a copy of this License; and
+      (b) You must cause any modified files to carry prominent notices
+          stating that You changed the files; and
+      (c) You must retain, in the Source form of any Derivative Works
+          that You distribute, all copyright, patent, trademark, and
+          attribution notices from the Source form of the Work,
+          excluding those notices that do not pertain to any part of
+          the Derivative Works; and
+      (d) If the Work includes a "NOTICE" text file as part of its
+          distribution, then any Derivative Works that You distribute must
+          include a readable copy of the attribution notices contained
+          within such NOTICE file, excluding those notices that do not
+          pertain to any part of the Derivative Works, in at least one
+          of the following places: within a NOTICE text file distributed
+          as part of the Derivative Works; within the Source form or
+          documentation, if provided along with the Derivative Works; or,
+          within a display generated by the Derivative Works, if and
+          wherever such third-party notices normally appear. The contents
+          of the NOTICE file are for informational purposes only and
+          do not modify the License. You may add Your own attribution
+          notices within Derivative Works that You distribute, alongside
+          or as an addendum to the NOTICE text from the Work, provided
+          that such additional attribution notices cannot be construed
+          as modifying the License.
+      You may add Your own copyright statement to Your modifications and
+      may provide additional or different license terms and conditions
+      for use, reproduction, or distribution of Your modifications, or
+      for any such Derivative Works as a whole, provided Your use,
+      reproduction, and distribution of the Work otherwise complies with
+      the conditions stated in this License.
+   5. Submission of Contributions. Unless You explicitly state otherwise,
+      any Contribution intentionally submitted for inclusion in the Work
+      by You to the Licensor shall be under the terms and conditions of
+      this License, without any additional terms or conditions.
+      Notwithstanding the above, nothing herein shall supersede or modify
+      the terms of any separate license agreement you may have executed
+      with Licensor regarding such Contributions.
+   6. Trademarks. This License does not grant permission to use the trade
+      names, trademarks, service marks, or product names of the Licensor,
+      except as required for reasonable and customary use in describing the
+      origin of the Work and reproducing the content of the NOTICE file.
+   7. Disclaimer of Warranty. Unless required by applicable law or
+      agreed to in writing, Licensor provides the Work (and each
+      Contributor provides its Contributions) on an "AS IS" BASIS,
+      WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
+      implied, including, without limitation, any warranties or conditions
+      of TITLE, NON-INFRINGEMENT, MERCHANTABILITY, or FITNESS FOR A
+      PARTICULAR PURPOSE. You are solely responsible for determining the
+      appropriateness of using or redistributing the Work and assume any
+      risks associated with Your exercise of permissions under this License.
+   8. Limitation of Liability. In no event and under no legal theory,
+      whether in tort (including negligence), contract, or otherwise,
+      unless required by applicable law (such as deliberate and grossly
+      negligent acts) or agreed to in writing, shall any Contributor be
+      liable to You for damages, including any direct, indirect, special,
+      incidental, or consequential damages of any character arising as a
+      result of this License or out of the use or inability to use the
+      Work (including but not limited to damages for loss of goodwill,
+      work stoppage, computer failure or malfunction, or any and all
+      other commercial damages or losses), even if such Contributor
+      has been advised of the possibility of such damages.
+   9. Accepting Warranty or Additional Liability. While redistributing
+      the Work or Derivative Works thereof, You may choose to offer,
+      and charge a fee for, acceptance of support, warranty, indemnity,
+      or other liability obligations and/or rights consistent with this
+      License. However, in accepting such obligations, You may act only
+      on Your own behalf and on Your sole responsibility, not on behalf
+      of any other Contributor, and only if You agree to indemnify,
+      defend, and hold each Contributor harmless for any liability
+      incurred by, or claims asserted against, such Contributor by reason
+      of your accepting any such warranty or additional liability.
+   END OF TERMS AND CONDITIONS
+   APPENDIX: How to apply the Apache License to your work.
+      To apply the Apache License to your work, attach the following
+      boilerplate notice, with the fields enclosed by brackets "[]"
+      replaced with your own identifying information. (Don't include
+      the brackets!)  The text should be enclosed in the appropriate
+      comment syntax for the file format. We also recommend that a
+      file or class name and description of purpose be included on the
+      same "printed page" as the copyright notice for easier
+      identification within third-party archives.
+   Copyright [yyyy] [name of copyright owner]
+   Licensed under the Apache License, Version 2.0 (the "License");
+   you may not use this file except in compliance with the License.
+   You may obtain a copy of the License at
+       http://www.apache.org/licenses/LICENSE-2.0
+   Unless required by applicable law or agreed to in writing, software
+   distributed under the License is distributed on an "AS IS" BASIS,
+   WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+   See the License for the specific language governing permissions and
+   limitations under the License.
+  xfire-all-1.2.6.jar
+  xfire-jsr181-api-1.0-M1.jar
+  Copyright (c) 2005 Envoi Solutions LLC
+  Permission is hereby granted, free of charge, to any person obtaining a copy
+  of this software and associated documentation files (the "Software"), to deal
+  in the Software without restriction, including without limitation the rights
+  to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
+  copies of the Software, and to permit persons to whom the Software is
+  furnished to do so, subject to the following conditions:
+  The above copyright notice and this permission notice shall be included in all
+  copies or substantial portions of the Software.
+  THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+  IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+  FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
+  AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+  LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
+  OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
+  SOFTWARE.
+  jdom-1.0.jar
+ Copyright (C) 2000-2004 Jason Hunter & Brett McLaughlin.
+ All rights reserved.
+ Redistribution and use in source and binary forms, with or without
+ modification, are permitted provided that the following conditions
+ are met:
+ 1. Redistributions of source code must retain the above copyright
+    notice, this list of conditions, and the following disclaimer.
+ 2. Redistributions in binary form must reproduce the above copyright
+    notice, this list of conditions, and the disclaimer that follows
+    these conditions in the documentation and/or other materials
+    provided with the distribution.
+ 3. The name "JDOM" must not be used to endorse or promote products
+    derived from this software without prior written permission.  For
+    written permission, please contact <request_AT_jdom_DOT_org>.
+ 4. Products derived from this software may not be called "JDOM", nor
+    may "JDOM" appear in their name, without prior written permission
+    from the JDOM Project Management <request_AT_jdom_DOT_org>.
+ In addition, we request (but do not require) that you include in the
+ end-user documentation provided with the redistribution and/or in the
+ software itself an acknowledgement equivalent to the following:
+     "This product includes software developed by the
+      JDOM Project (http://www.jdom.org/)."
+ Alternatively, the acknowledgment may be graphical using the logos
+ available at http://www.jdom.org/images/logos.
+ THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
+ WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ DISCLAIMED.  IN NO EVENT SHALL THE JDOM AUTHORS OR THE PROJECT
+ CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+ LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
+ USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
+ ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ SUCH DAMAGE.
+ This software consists of voluntary contributions made by many
+ individuals on behalf of the JDOM Project and was originally
+ created by Jason Hunter <jhunter_AT_jdom_DOT_org> and
+ Brett McLaughlin <brett_AT_jdom_DOT_org>.  For more information
+ on the JDOM Project, please see <http://www.jdom.org/>.
+  bcprov.jar
+Copyright (c) 2000 - 2008 The Legion Of The Bouncy Castle
+(http://www.bouncycastle.org)
+Permission is hereby granted, free of charge, to any person obtaining a copy of
+this software and associated documentation files (the "Software"), to deal in
+the Software without restriction, including without limitation the rights to
+use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies
+of the Software, and to permit persons to whom the Software is furnished to do
+so, subject to the following conditions:
+The above copyright notice and this permission notice shall be included in all
+copies or substantial portions of the Software.
+THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
+AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
+OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
+SOFTWARE.
+  activation-1.1.jar
+  jaxb-api-2.0.jar
+  jaxb-impl-2.0.1.jar
+  jaxws-api-2.0.jar
+  mail-1.4.jar
+These are released under dual license consisting of the CDDL v1.0 and GPL v2 with "CLASSPATH" EXCEPTION.
+COMMON DEVELOPMENT AND DISTRIBUTION LICENSE (CDDL) Version 1.0
+1. Definitions.
+1.1. "Contributor" means each individual or entity that
+creates or contributes to the creation of Modifications.
+1.2. "Contributor Version" means the combination of the
+Original Software, prior Modifications used by a
+Contributor (if any), and the Modifications made by that
+particular Contributor.
+1.3. "Covered Software" means (a) the Original Software, or
+(b) Modifications, or (c) the combination of files
+containing Original Software with files containing
+Modifications, in each case including portions thereof.
+1.4. "Executable" means the Covered Software in any form
+other than Source Code.
+1.5. "Initial Developer" means the individual or entity
+that first makes Original Software available under this
+License.
+1.6. "Larger Work" means a work which combines Covered
+Software or portions thereof with code not governed by the
+terms of this License.
+1.7. "License" means this document.
+1.8. "Licensable" means having the right to grant, to the
+maximum extent possible, whether at the time of the initial
+grant or subsequently acquired, any and all of the rights
+conveyed herein.
+1.9. "Modifications" means the Source Code and Executable
+form of any of the following:
+A. Any file that results from an addition to,
+deletion from or modification of the contents of a
+file containing Original Software or previous
+Modifications;
+B. Any new file that contains any part of the
+Original Software or previous Modification; or
+C. Any new file that is contributed or otherwise made
+available under the terms of this License.
+1.10. "Original Software" means the Source Code and
+Executable form of computer software code that is
+originally released under this License.
+1.11. "Patent Claims" means any patent claim(s), now owned
+or hereafter acquired, including without limitation,
+method, process, and apparatus claims, in any patent
+Licensable by grantor.
+1.12. "Source Code" means (a) the common form of computer
+software code in which modifications are made and (b)
+associated documentation included in or with such code.
+1.13. "You" (or "Your") means an individual or a legal
+entity exercising rights under, and complying with all of
+the terms of, this License. For legal entities, "You"
+includes any entity which controls, is controlled by, or is
+under common control with You. For purposes of this
+definition, "control" means (a) the power, direct or
+indirect, to cause the direction or management of such
+entity, whether by contract or otherwise, or (b) ownership
+of more than fifty percent (50%) of the outstanding shares
+or beneficial ownership of such entity.
+2. License Grants.
+2.1. The Initial Developer Grant.
+Conditioned upon Your compliance with Section 3.1 below and
+subject to third party intellectual property claims, the
+Initial Developer hereby grants You a world-wide,
+royalty-free, non-exclusive license:
+(a) under intellectual property rights (other than
+patent or trademark) Licensable by Initial Developer,
+to use, reproduce, modify, display, perform,
+sublicense and distribute the Original Software (or
+portions thereof), with or without Modifications,
+and/or as part of a Larger Work; and
+(b) under Patent Claims infringed by the making,
+using or selling of Original Software, to make, have
+made, use, practice, sell, and offer for sale, and/or
+otherwise dispose of the Original Software (or
+portions thereof).
+(c) The licenses granted in Sections 2.1(a) and (b)
+are effective on the date Initial Developer first
+distributes or otherwise makes the Original Software
+available to a third party under the terms of this
+License.
+(d) Notwithstanding Section 2.1(b) above, no patent
+license is granted: (1) for code that You delete from
+the Original Software, or (2) for infringements
+caused by: (i) the modification of the Original
+Software, or (ii) the combination of the Original
+Software with other software or devices.
+2.2. Contributor Grant.
+subject to third party intellectual property claims, each
+Contributor hereby grants You a world-wide, royalty-free,
+non-exclusive license:
+patent or trademark) Licensable by Contributor to
+use, reproduce, modify, display, perform, sublicense
+and distribute the Modifications created by such
+Contributor (or portions thereof), either on an
+unmodified basis, with other Modifications, as
+Covered Software and/or as part of a Larger Work; and
+using, or selling of Modifications made by that
+Contributor either alone and/or in combination with
+its Contributor Version (or portions of such
+combination), to make, use, sell, offer for sale,
+have made, and/or otherwise dispose of: (1)
+Modifications made by that Contributor (or portions
+thereof); and (2) the combination of Modifications
+made by that Contributor with its Contributor Version
+(or portions of such combination).
+(c) The licenses granted in Sections 2.2(a) and
+2.2(b) are effective on the date Contributor first
+distributes or otherwise makes the Modifications
+available to a third party.
+(d) Notwithstanding Section 2.2(b) above, no patent
+license is granted: (1) for any code that Contributor
+has deleted from the Contributor Version; (2) for
+infringements caused by: (i) third party
+modifications of Contributor Version, or (ii) the
+combination of Modifications made by that Contributor
+with other software (except as part of the
+Contributor Version) or other devices; or (3) under
+Patent Claims infringed by Covered Software in the
+absence of Modifications made by that Contributor.
+3. Distribution Obligations.
+3.1. Availability of Source Code.
+Any Covered Software that You distribute or otherwise make
+available in Executable form must also be made available in
+Source Code form and that Source Code form must be
+distributed only under the terms of this License. You must
+include a copy of this License with every copy of the
+Source Code form of the Covered Software You distribute or
+otherwise make available. You must inform recipients of any
+such Covered Software in Executable form as to how they can
+obtain such Covered Software in Source Code form in a
+reasonable manner on or through a medium customarily used
+for software exchange.
+3.2. Modifications.
+The Modifications that You create or to which You
+contribute are governed by the terms of this License. You
+represent that You believe Your Modifications are Your
+original creation(s) and/or You have sufficient rights to
+grant the rights conveyed by this License.
+3.3. Required Notices.
+You must include a notice in each of Your Modifications
+that identifies You as the Contributor of the Modification.
+You may not remove or alter any copyright, patent or
+trademark notices contained within the Covered Software, or
+any notices of licensing or any descriptive text giving
+attribution to any Contributor or the Initial Developer.
+3.4. Application of Additional Terms.
+You may not offer or impose any terms on any Covered
+Software in Source Code form that alters or restricts the
+applicable version of this License or the recipients'
+rights hereunder. You may choose to offer, and to charge a
+fee for, warranty, support, indemnity or liability
+obligations to one or more recipients of Covered Software.
+However, you may do so only on Your own behalf, and not on
+behalf of the Initial Developer or any Contributor. You
+must make it absolutely clear that any such warranty,
+support, indemnity or liability obligation is offered by
+You alone, and You hereby agree to indemnify the Initial
+Developer and every Contributor for any liability incurred
+by the Initial Developer or such Contributor as a result of
+warranty, support, indemnity or liability terms You offer.
+3.5. Distribution of Executable Versions.
+You may distribute the Executable form of the Covered
+Software under the terms of this License or under the terms
+of a license of Your choice, which may contain terms
+different from this License, provided that You are in
+compliance with the terms of this License and that the
+license for the Executable form does not attempt to limit
+or alter the recipient's rights in the Source Code form
+from the rights set forth in this License. If You
+distribute the Covered Software in Executable form under a
+different license, You must make it absolutely clear that
+any terms which differ from this License are offered by You
+alone, not by the Initial Developer or Contributor. You
+hereby agree to indemnify the Initial Developer and every
+Contributor for any liability incurred by the Initial
+Developer or such Contributor as a result of any such terms
+You offer.
+3.6. Larger Works.
+You may create a Larger Work by combining Covered Software
+with other code not governed by the terms of this License
+and distribute the Larger Work as a single product. In such
+a case, You must make sure the requirements of this License
+are fulfilled for the Covered Software.
+4. Versions of the License.
+4.1. New Versions.
+Sun Microsystems, Inc. is the initial license steward and
+may publish revised and/or new versions of this License
+from time to time. Each version will be given a
+distinguishing version number. Except as provided in
+Section 4.3, no one other than the license steward has the
+right to modify this License.
+4.2. Effect of New Versions.
+You may always continue to use, distribute or otherwise
+make the Covered Software available under the terms of the
+version of the License under which You originally received
+the Covered Software. If the Initial Developer includes a
+notice in the Original Software prohibiting it from being
+distributed or otherwise made available under any
+subsequent version of the License, You must distribute and
+the Covered Software. Otherwise, You may also choose to
+use, distribute or otherwise make the Covered Software
+available under the terms of any subsequent version of the
+License published by the license steward.
+4.3. Modified Versions.
+When You are an Initial Developer and You want to create a
+new license for Your Original Software, You may create and
+use a modified version of this License if You: (a) rename
+the license and remove any references to the name of the
+license steward (except to note that the license differs
+from this License); and (b) otherwise make it clear that
+the license contains terms which differ from this License.
+5. DISCLAIMER OF WARRANTY.
+COVERED SOFTWARE IS PROVIDED UNDER THIS LICENSE ON AN "AS IS"
+BASIS, WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED OR IMPLIED,
+INCLUDING, WITHOUT LIMITATION, WARRANTIES THAT THE COVERED
+SOFTWARE IS FREE OF DEFECTS, MERCHANTABLE, FIT FOR A PARTICULAR
+PURPOSE OR NON-INFRINGING. THE ENTIRE RISK AS TO THE QUALITY AND
+PERFORMANCE OF THE COVERED SOFTWARE IS WITH YOU. SHOULD ANY
+COVERED SOFTWARE PROVE DEFECTIVE IN ANY RESPECT, YOU (NOT THE
+INITIAL DEVELOPER OR ANY OTHER CONTRIBUTOR) ASSUME THE COST OF
+ANY NECESSARY SERVICING, REPAIR OR CORRECTION. THIS DISCLAIMER OF
+WARRANTY CONSTITUTES AN ESSENTIAL PART OF THIS LICENSE. NO USE OF
+ANY COVERED SOFTWARE IS AUTHORIZED HEREUNDER EXCEPT UNDER THIS
+DISCLAIMER.
+6. TERMINATION.
+6.1. This License and the rights granted hereunder will
+terminate automatically if You fail to comply with terms
+herein and fail to cure such breach within 30 days of
+becoming aware of the breach. Provisions which, by their
+nature, must remain in effect beyond the termination of
+this License shall survive.
+6.2. If You assert a patent infringement claim (excluding
+declaratory judgment actions) against Initial Developer or
+a Contributor (the Initial Developer or Contributor against
+whom You assert such claim is referred to as "Participant")
+alleging that the Participant Software (meaning the
+Contributor Version where the Participant is a Contributor
+or the Original Software where the Participant is the
+Initial Developer) directly or indirectly infringes any
+patent, then any and all rights granted directly or
+indirectly to You by such Participant, the Initial
+Developer (if the Initial Developer is not the Participant)
+and all Contributors under Sections 2.1 and/or 2.2 of this
+License shall, upon 60 days notice from Participant
+terminate prospectively and automatically at the expiration
+of such 60 day notice period, unless if within such 60 day
+period You withdraw Your claim with respect to the
+Participant Software against such Participant either
+unilaterally or pursuant to a written agreement with
+Participant.
+6.3. In the event of termination under Sections 6.1 or 6.2
+above, all end user licenses that have been validly granted
+by You or any distributor hereunder prior to termination
+(excluding licenses granted to You by any distributor)
+shall survive termination.
+7. LIMITATION OF LIABILITY.
+UNDER NO CIRCUMSTANCES AND UNDER NO LEGAL THEORY, WHETHER TORT
+(INCLUDING NEGLIGENCE), CONTRACT, OR OTHERWISE, SHALL YOU, THE
+INITIAL DEVELOPER, ANY OTHER CONTRIBUTOR, OR ANY DISTRIBUTOR OF
+COVERED SOFTWARE, OR ANY SUPPLIER OF ANY OF SUCH PARTIES, BE
+LIABLE TO ANY PERSON FOR ANY INDIRECT, SPECIAL, INCIDENTAL, OR
+CONSEQUENTIAL DAMAGES OF ANY CHARACTER INCLUDING, WITHOUT
+LIMITATION, DAMAGES FOR LOST PROFITS, LOSS OF GOODWILL, WORK
+STOPPAGE, COMPUTER FAILURE OR MALFUNCTION, OR ANY AND ALL OTHER
+COMMERCIAL DAMAGES OR LOSSES, EVEN IF SUCH PARTY SHALL HAVE BEEN
+INFORMED OF THE POSSIBILITY OF SUCH DAMAGES. THIS LIMITATION OF
+LIABILITY SHALL NOT APPLY TO LIABILITY FOR DEATH OR PERSONAL
+INJURY RESULTING FROM SUCH PARTY'S NEGLIGENCE TO THE EXTENT
+APPLICABLE LAW PROHIBITS SUCH LIMITATION. SOME JURISDICTIONS DO
+NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR
+CONSEQUENTIAL DAMAGES, SO THIS EXCLUSION AND LIMITATION MAY NOT
+APPLY TO YOU.
+8. U.S. GOVERNMENT END USERS.
+The Covered Software is a "commercial item," as that term is
+defined in 48 C.F.R. 2.101 (Oct. 1995), consisting of "commercial
+computer software" (as that term is defined at 48 C.F.R. ¤
+252.227-7014(a)(1)) and "commercial computer software
+documentation" as such terms are used in 48 C.F.R. 12.212 (Sept.
+1995). Consistent with 48 C.F.R. 12.212 and 48 C.F.R. 227.7202-1
+through 227.7202-4 (June 1995), all U.S. Government End Users
+acquire Covered Software with only those rights set forth herein.
+This U.S. Government Rights clause is in lieu of, and supersedes,
+any other FAR, DFAR, or other clause or provision that addresses
+Government rights in computer software under this License.
+9. MISCELLANEOUS.
+This License represents the complete agreement concerning subject
+matter hereof. If any provision of this License is held to be
+unenforceable, such provision shall be reformed only to the
+extent necessary to make it enforceable. This License shall be
+governed by the law of the jurisdiction specified in a notice
+contained within the Original Software (except to the extent
+applicable law, if any, provides otherwise), excluding such
+jurisdiction's conflict-of-law provisions. Any litigation
+relating to this License shall be subject to the jurisdiction of
+the courts located in the jurisdiction and venue specified in a
+notice contained within the Original Software, with the losing
+party responsible for costs, including, without limitation, court
+costs and reasonable attorneys' fees and expenses. The
+application of the United Nations Convention on Contracts for the
+International Sale of Goods is expressly excluded. Any law or
+regulation which provides that the language of a contract shall
+be construed against the drafter shall not apply to this License.
+You agree that You alone are responsible for compliance with the
+United States export administration regulations (and the export
+control laws and regulation of any other countries) when You use,
+distribute or otherwise make available any Covered Software.
+10. RESPONSIBILITY FOR CLAIMS.
+As between Initial Developer and the Contributors, each party is
+responsible for claims and damages arising, directly or
+indirectly, out of its utilization of rights under this License
+and You agree to work with Initial Developer and Contributors to
+distribute such responsibility on an equitable basis. Nothing
+herein is intended or shall be deemed to constitute any admission
+of liability.
+  wsdl4j-1.6.1.jar
+Common Public License Version 1.0
+THE ACCOMPANYING PROGRAM IS PROVIDED UNDER THE TERMS OF THIS COMMON PUBLIC
+LICENSE ("AGREEMENT"). ANY USE, REPRODUCTION OR DISTRIBUTION OF THE PROGRAM
+CONSTITUTES RECIPIENT'S ACCEPTANCE OF THIS AGREEMENT.
+1. DEFINITIONS
+"Contribution" means:
+    a) in the case of the initial Contributor, the initial code and
+documentation distributed under this Agreement, and
+    b) in the case of each subsequent Contributor:
+    i) changes to the Program, and
+    ii) additions to the Program;
+    where such changes and/or additions to the Program originate from and are
+distributed by that particular Contributor. A Contribution 'originates' from a
+Contributor if it was added to the Program by such Contributor itself or anyone
+acting on such Contributor's behalf. Contributions do not include additions to
+the Program which: (i) are separate modules of software distributed in
+conjunction with the Program under their own license agreement, and (ii) are not
+derivative works of the Program.
+"Contributor" means any person or entity that distributes the Program.
+"Licensed Patents " mean patent claims licensable by a Contributor which are
+necessarily infringed by the use or sale of its Contribution alone or when
+combined with the Program.
+"Program" means the Contributions distributed in accordance with this Agreement.
+"Recipient" means anyone who receives the Program under this Agreement,
+including all Contributors.
+2. GRANT OF RIGHTS
+    a) Subject to the terms of this Agreement, each Contributor hereby grants
+Recipient a non-exclusive, worldwide, royalty-free copyright license to
+reproduce, prepare derivative works of, publicly display, publicly perform,
+distribute and sublicense the Contribution of such Contributor, if any, and such
+derivative works, in source code and object code form.
+    b) Subject to the terms of this Agreement, each Contributor hereby grants
+Recipient a non-exclusive, worldwide, royalty-free patent license under Licensed
+Patents to make, use, sell, offer to sell, import and otherwise transfer the
+Contribution of such Contributor, if any, in source code and object code form.
+This patent license shall apply to the combination of the Contribution and the
+Program if, at the time the Contribution is added by the Contributor, such
+addition of the Contribution causes such combination to be covered by the
+Licensed Patents. The patent license shall not apply to any other combinations
+which include the Contribution. No hardware per se is licensed hereunder.
+    c) Recipient understands that although each Contributor grants the licenses
+to its Contributions set forth herein, no assurances are provided by any
+Contributor that the Program does not infringe the patent or other intellectual
+property rights of any other entity. Each Contributor disclaims any liability to
+Recipient for claims brought by any other entity based on infringement of
+intellectual property rights or otherwise. As a condition to exercising the
+rights and licenses granted hereunder, each Recipient hereby assumes sole
+responsibility to secure any other intellectual property rights needed, if any.
+For example, if a third party patent license is required to allow Recipient to
+distribute the Program, it is Recipient's responsibility to acquire that license
+before distributing the Program.
+    d) Each Contributor represents that to its knowledge it has sufficient
+copyright rights in its Contribution, if any, to grant the copyright license set
+forth in this Agreement.
+3. REQUIREMENTS
+A Contributor may choose to distribute the Program in object code form under its
+own license agreement, provided that:
+    a) it complies with the terms and conditions of this Agreement; and
+    b) its license agreement:
+    i) effectively disclaims on behalf of all Contributors all warranties and
+conditions, express and implied, including warranties or conditions of title and
+non-infringement, and implied warranties or conditions of merchantability and
+fitness for a particular purpose;
+    ii) effectively excludes on behalf of all Contributors all liability for
+damages, including direct, indirect, special, incidental and consequential
+damages, such as lost profits;
+    iii) states that any provisions which differ from this Agreement are offered
+by that Contributor alone and not by any other party; and
+    iv) states that source code for the Program is available from such
+Contributor, and informs licensees how to obtain it in a reasonable manner on or
+through a medium customarily used for software exchange.
+When the Program is made available in source code form:
+    a) it must be made available under this Agreement; and
+    b) a copy of this Agreement must be included with each copy of the Program.
+Contributors may not remove or alter any copyright notices contained within the
+Program.
+Each Contributor must identify itself as the originator of its Contribution, if
+any, in a manner that reasonably allows subsequent Recipients to identify the
+originator of the Contribution.
+4. COMMERCIAL DISTRIBUTION
+Commercial distributors of software may accept certain responsibilities with
+respect to end users, business partners and the like. While this license is
+intended to facilitate the commercial use of the Program, the Contributor who
+includes the Program in a commercial product offering should do so in a manner
+which does not create potential liability for other Contributors. Therefore, if
+a Contributor includes the Program in a commercial product offering, such
+Contributor ("Commercial Contributor") hereby agrees to defend and indemnify
+every other Contributor ("Indemnified Contributor") against any losses, damages
+and costs (collectively "Losses") arising from claims, lawsuits and other legal
+actions brought by a third party against the Indemnified Contributor to the
+extent caused by the acts or omissions of such Commercial Contributor in
+connection with its distribution of the Program in a commercial product
+offering. The obligations in this section do not apply to any claims or Losses
+relating to any actual or alleged intellectual property infringement. In order
+to qualify, an Indemnified Contributor must: a) promptly notify the Commercial
+Contributor in writing of such claim, and b) allow the Commercial Contributor to
+control, and cooperate with the Commercial Contributor in, the defense and any
+related settlement negotiations. The Indemnified Contributor may participate in
+any such claim at its own expense.
+For example, a Contributor might include the Program in a commercial product
+offering, Product X. That Contributor is then a Commercial Contributor. If that
+Commercial Contributor then makes performance claims, or offers warranties
+related to Product X, those performance claims and warranties are such
+Commercial Contributor's responsibility alone. Under this section, the
+Commercial Contributor would have to defend claims against the other
+Contributors related to those performance claims and warranties, and if a court
+requires any other Contributor to pay any damages as a result, the Commercial
+Contributor must pay those damages.
+5. NO WARRANTY
+EXCEPT AS EXPRESSLY SET FORTH IN THIS AGREEMENT, THE PROGRAM IS PROVIDED ON AN
+"AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, EITHER EXPRESS OR
+IMPLIED INCLUDING, WITHOUT LIMITATION, ANY WARRANTIES OR CONDITIONS OF TITLE,
+NON-INFRINGEMENT, MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. Each
+Recipient is solely responsible for determining the appropriateness of using and
+distributing the Program and assumes all risks associated with its exercise of
+rights under this Agreement, including but not limited to the risks and costs of
+program errors, compliance with applicable laws, damage to or loss of data,
+programs or equipment, and unavailability or interruption of operations.
+6. DISCLAIMER OF LIABILITY
+EXCEPT AS EXPRESSLY SET FORTH IN THIS AGREEMENT, NEITHER RECIPIENT NOR ANY
+CONTRIBUTORS SHALL HAVE ANY LIABILITY FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING WITHOUT LIMITATION LOST
+PROFITS), HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
+STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+OUT OF THE USE OR DISTRIBUTION OF THE PROGRAM OR THE EXERCISE OF ANY RIGHTS
+GRANTED HEREUNDER, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
+7. GENERAL
+If any provision of this Agreement is invalid or unenforceable under applicable
+law, it shall not affect the validity or enforceability of the remainder of the
+terms of this Agreement, and without further action by the parties hereto, such
+provision shall be reformed to the minimum extent necessary to make such
+provision valid and enforceable.
+If Recipient institutes patent litigation against a Contributor with respect to
+a patent applicable to software (including a cross-claim or counterclaim in a
+lawsuit), then any patent licenses granted by that Contributor to such Recipient
+under this Agreement shall terminate as of the date such litigation is filed. In
+addition, if Recipient institutes patent litigation against any entity
+(including a cross-claim or counterclaim in a lawsuit) alleging that the Program
+itself (excluding combinations of the Program with other software or hardware)
+infringes such Recipient's patent(s), then such Recipient's rights granted under
+Section 2(b) shall terminate as of the date such litigation is filed.
+All Recipient's rights under this Agreement shall terminate if it fails to
+comply with any of the material terms or conditions of this Agreement and does
+not cure such failure in a reasonable period of time after becoming aware of
+such noncompliance. If all Recipient's rights under this Agreement terminate,
+Recipient agrees to cease use and distribution of the Program as soon as
+reasonably practicable. However, Recipient's obligations under this Agreement
+and any licenses granted by Recipient relating to the Program shall continue and
+survive.
+Everyone is permitted to copy and distribute copies of this Agreement, but in
+order to avoid inconsistency the Agreement is copyrighted and may only be
+modified in the following manner. The Agreement Steward reserves the right to
+publish new versions (including revisions) of this Agreement from time to time.
+No one other than the Agreement Steward has the right to modify this Agreement.
+IBM is the initial Agreement Steward. IBM may assign the responsibility to serve
+as the Agreement Steward to a suitable separate entity. Each new version of the
+Agreement will be given a distinguishing version number. The Program (including
+Contributions) may always be distributed subject to the version of the Agreement
+under which it was received. In addition, after a new version of the Agreement
+is published, Contributor may elect to distribute the Program (including its
+Contributions) under the new version. Except as expressly stated in Sections
+2(a) and 2(b) above, Recipient receives no rights or licenses to the
+intellectual property of any Contributor under this Agreement, whether
+expressly, by implication, estoppel or otherwise. All rights in the Program not
+expressly granted under this Agreement are reserved.
+This Agreement is governed by the laws of the State of New York and the
+intellectual property laws of the United States of America. No party to this
+Agreement will bring a legal action under this Agreement more than one year
+after the cause of action arose. Each party waives its rights to a jury trial in
+any resulting litigation.
Copied: usertools/swift-vm-boot/ec2/license.txt (from rev 5424, usertools/swift-ec2-boot/license.txt)
--- usertools/swift-vm-boot/ec2/license.txt	                        (rev 0)
+++ usertools/swift-vm-boot/ec2/license.txt	2011-12-16 18:38:06 UTC (rev 5425)
@@ -0,0 +1,40 @@
+Amazon Software License
+This Amazon Software License (“License”) governs your use, reproduction, and distribution of the accompanying software as specified below.
+1. Definitions
+“Licensor” means any person or entity that distributes its Work.
+“Software” means the original work of authorship made available under this License.
+“Work” means the Software and any additions to or derivative works of the Software that are made available under this License.
+The terms “reproduce,” “reproduction,” “derivative works,” and “distribution” have the meaning as provided under U.S. copyright law; provided, however, that for the purposes of this License, derivative works shall not include works that remain separable from, or merely link (or bind by name) to the interfaces of, the Work.
+Works, including the Software, are “made available” under this License by including in or with the Work either (a) a copyright notice referencing the applicability of this License to the Work, or (b) a copy of this License.
+2. License Grants
+2.1 Copyright Grant. Subject to the terms and conditions of this License, each Licensor grants to you a perpetual, worldwide, non-exclusive, royalty-free, copyright license to reproduce, prepare derivative works of, publicly display, publicly perform, sublicense and distribute its Work and any resulting derivative works in any form.
+2.2 Patent Grant. Subject to the terms and conditions of this License, each Licensor grants to you a perpetual, worldwide, non-exclusive, royalty-free patent license to make, have made, use, sell, offer for sale, import, and otherwise transfer its Work, in whole or in part. The foregoing license applies only to the patent claims licensable by Licensor that would be infringed by Licensor’s Work (or portion thereof) individually and excluding any combinations with any other materials or technology.
+3. Limitations
+3.1 Redistribution. You may reproduce or distribute the Work only if (a) you do so under this License, (b) you include a complete copy of this License with your distribution, and© you retain without modification any copyright, patent, trademark, or attribution notices that are present in the Work.
+3.2 Derivative Works. You may specify that additional or different terms apply to the use, reproduction, and distribution of your derivative works of the Work (“Your Terms”) only if (a) Your Terms provide that the use limitation in Section 3.3 applies to your derivative works, and (b) you identify the specific derivative works that are subject to Your Terms. Notwithstanding Your Terms, this License (including the redistribution requirements in Section 3.1) will continue to apply to the Work itself.
+3.3 Use Limitation. The Work and any derivative works thereof only may be used or intended for use with the web services, computing platforms or applications provided by Amazon.com, Inc. or its affiliates, including Amazon Web Services LLC.
+3.4 Patent Claims. If you bring or threaten to bring a patent claim against any Licensor (including any claim, cross-claim or counterclaim in a lawsuit) to enforce any patents that you allege are infringed by any Work, then your rights under this License from such Licensor (including the grants in Sections 2.1 and 2.2) will terminate immediately.
+3.5 Trademarks. This License does not grant any rights to use any Licensor’s or its affiliates’ names, logos, or trademarks, except as necessary to reproduce the notices described in this License.
+3.6 Termination. If you violate any term of this License, then your rights under this License (including the grants in Sections 2.1 and 2.2) will terminate immediately.
+4. Disclaimer of Warranty.
+THE WORK IS PROVIDED “AS IS” WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, EITHER EXPRESS OR IMPLIED, INCLUDING WARRANTIES OR CONDITIONS OF M ERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, TITLE OR NON-INFRINGEMENT. YOU BEAR THE RISK OF UNDERTAKING ANY ACTIVITIES UNDER THIS LICENSE. SOME STATES’ CONSUMER LAWS DO NOT ALLOW EXCLUSION OF AN IMPLIED WARRANTY, SO THIS DISCLAIMER MAY NOT APPLY TO YOU.
+5. Limitation of Liability.
+EXCEPT AS PROHIBITED BY APPLICABLE LAW, IN NO EVENT AND UNDER NO LEGAL THEORY, WHETHER IN TORT (INCLUDING NEGLIGENCE), CONTRACT, OR OTHERWISE SHALL ANY LICENSOR BE LIABLE TO YOU FOR DAMAGES, INCLUDING ANY DIRECT, INDIRECT, SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES ARISING OUT OF OR RELATED TO THIS LICENSE, THE USE OR INABILITY TO USE THE WORK (INCLUDING BUT NOT LIMITED TO LOSS OF GOODWILL, BUSINESS INTERRUPTION, LOST PROFITS OR DATA, COMPUTER FAILURE OR MALFUNCTION, OR ANY OTHER COMM ERCIAL DAMAGES OR LOSSES), EVEN IF THE LICENSOR HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
+Effective Date – April 18, 2008 © 2008 Amazon.com, Inc. or its affiliates. All rights reserved.
Copied: usertools/swift-vm-boot/ec2/notice.txt (from rev 5424, usertools/swift-ec2-boot/notice.txt)
--- usertools/swift-vm-boot/ec2/notice.txt	                        (rev 0)
+++ usertools/swift-vm-boot/ec2/notice.txt	2011-12-16 18:38:06 UTC (rev 5425)
@@ -0,0 +1,5 @@
+Copyright 2006-2010 Amazon.com, Inc. or its affiliates.  All Rights Reserved.  Licensed under the
+Amazon Software License (the "License").  You may not use this file except in compliance with the License. A copy of the
+License is located at http://aws.amazon.com/asl or in the "license" file accompanying this file.  This file is distributed on an "AS
+IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License for the specific
+language governing permissions and limitations under the License.
Deleted: usertools/swift-vm-boot/env.sh
--- usertools/swift-vm-boot/env.sh	2011-12-16 18:28:15 UTC (rev 5424)
+++ usertools/swift-vm-boot/env.sh	2011-12-16 18:38:06 UTC (rev 5425)
@@ -1,9 +0,0 @@
-export FUTUREGRID_IAAS_ACCESS_KEY=XXXX
-export FUTUREGRID_IAAS_SECRET_KEY=XXXXXXXXX
-export EC2_ACCESS_KEY=$FUTUREGRID_IAAS_ACCESS_KEY
-export EC2_SECRET_KEY=$FUTUREGRID_IAAS_SECRET_KEY
-export EC2_URL=https://s83r.idp.sdsc.futuregrid.org:8444
-export FUTUREGRID_SIERRA_NODES=2
Added: usertools/swift-vm-boot/futuregrid/bin/bootit.sh
--- usertools/swift-vm-boot/futuregrid/bin/bootit.sh	                        (rev 0)
+++ usertools/swift-vm-boot/futuregrid/bin/bootit.sh	2011-12-16 18:38:06 UTC (rev 5425)
@@ -0,0 +1,22 @@
+#!/bin/bash
+dir=`dirname $0`
+cd $dir
+cd ..
+source env.sh
+source ve/bin/activate
+output="output.json"
+cloudinitd -l debug -v -v -v boot plan/top.conf -o $output
+if [ $? -ne 0 ]; then
+    echo "The boot failed.  Check the logs"
+    exit 1
+fi
+echo "getting the hostnames..."
+python bin/handleoutput.py $output
+    echo "The output parse failed"
+    exit 1
+fi
Property changes on: usertools/swift-vm-boot/futuregrid/bin/bootit.sh
___________________________________________________________________
Added: svn:executable
Added: usertools/swift-vm-boot/futuregrid/bin/handleoutput.py
--- usertools/swift-vm-boot/futuregrid/bin/handleoutput.py	                        (rev 0)
+++ usertools/swift-vm-boot/futuregrid/bin/handleoutput.py	2011-12-16 18:38:06 UTC (rev 5425)
@@ -0,0 +1,16 @@
+#!/usr/bin/env python
+import os
+import sys
+import simplejson as json
+x = json.load(open(sys.argv[1], "r"))
+levels = x['levels']
+lvl1 = levels[0]
+services = lvl1['services']
+for svc in services:
+    print svc['hostname']
Property changes on: usertools/swift-vm-boot/futuregrid/bin/handleoutput.py
Added: usertools/swift-vm-boot/futuregrid/bin/nimbus-register-key.py
--- usertools/swift-vm-boot/futuregrid/bin/nimbus-register-key.py	                        (rev 0)
+++ usertools/swift-vm-boot/futuregrid/bin/nimbus-register-key.py	2011-12-16 18:38:06 UTC (rev 5425)
@@ -0,0 +1,39 @@
+import os
+import sys
+import base64
+import boto
+from boto.ec2.regioninfo import RegionInfo
+import urllib2
+def add_key(ec2conn, keyname, keytext):
+    pairs = ec2conn.get_all_key_pairs([keyname,])
+    if not pairs:
+        print "Adding a new key pair named %s" % (keyname)
+        ec2conn.import_key_pair(keyname, keytext)
+    else:
+        print "Keyname %s already exists" % (keyname)
+try:
+    access_id = os.environ['FUTUREGRID_IAAS_ACCESS_KEY']
+    access_secret = os.environ['FUTUREGRID_IAAS_SECRET_KEY']
+    iaas_url = os.environ['FUTUREGRID_IAAS_URL']
+except Exception, ex:
+    print "Make sure the envs CLOUDINITD_* are set %s" % (str(ex))
+    sys.exit(1)
+url_parts = urllib2.urlparse.urlparse(iaas_url)
+region = RegionInfo(name="nimbus", endpoint=url_parts.hostname)
+ec2conn = boto.connect_ec2(access_id, access_secret, region=region, port=url_parts.port)
+keyname = sys.argv[1]
+keylocation = sys.argv[2]
+keytext = open(keylocation).read()
+keytext = base64.b64encode(keytext)
+add_key(ec2conn, keyname, keytext)
+sys.exit(0)
Added: usertools/swift-vm-boot/futuregrid/bin/register_key.py
--- usertools/swift-vm-boot/futuregrid/bin/register_key.py	                        (rev 0)
+++ usertools/swift-vm-boot/futuregrid/bin/register_key.py	2011-12-16 18:38:06 UTC (rev 5425)
@@ -0,0 +1,37 @@
+import os
+import sys
+import base64
+import boto
+try:
+except:
+    print "Make sure the envs FUTUREGRID_IAAS_ACCESS_KEY and FUTUREGRID_IAAS_SECRET_KEY are set"
+    sys.exit(1)
+hostfile = sys.argv[1]
+keyname = "swiftkey"
+if len(sys.argv) > 2:
+    keylocation = sys.argv[2]
+else:
+    keylocation = os.path.expanduser("~/.ssh/id_rsa.pub")
+f = open(hostfile, "r")
+for line in f:
+    host = line.strip()
+    print "creating key %s on %s" % (keyname, host)
+    region = RegionInfo(name="nimbus", endpoint=host)
+    ec2conn = boto.connect_ec2(access_id, access_secret, region=region, port=8444)
+#    keytext = base64.b64encode(keytext)
+sys.exit(0)
Property changes on: usertools/swift-vm-boot/futuregrid/bin/register_key.py
Added: usertools/swift-vm-boot/futuregrid/bin/virtualenv.py
--- usertools/swift-vm-boot/futuregrid/bin/virtualenv.py	                        (rev 0)
+++ usertools/swift-vm-boot/futuregrid/bin/virtualenv.py	2011-12-16 18:38:06 UTC (rev 5425)
@@ -0,0 +1,1651 @@
+"""Create a "virtual" Python installation
+virtualenv_version = "1.5.1"
+import sys
+import os
+import optparse
+import re
+import shutil
+import logging
+import tempfile
+import distutils.sysconfig
+try:
+    import subprocess
+except ImportError, e:
+    if sys.version_info <= (2, 3):
+        print 'ERROR: %s' % e
+        print 'ERROR: this script requires Python 2.4 or greater; or at least the subprocess module.'
+        print 'If you copy subprocess.py from a newer version of Python this script will probably work'
+        sys.exit(101)
+    else:
+        raise
+try:
+    set
+except NameError:
+    from sets import Set as set
+join = os.path.join
+py_version = 'python%s.%s' % (sys.version_info[0], sys.version_info[1])
+is_jython = sys.platform.startswith('java')
+is_pypy = hasattr(sys, 'pypy_version_info')
+if is_pypy:
+    expected_exe = 'pypy-c'
+elif is_jython:
+    expected_exe = 'jython'
+else:
+    expected_exe = 'python'
+REQUIRED_MODULES = ['os', 'posix', 'posixpath', 'nt', 'ntpath', 'genericpath',
+                    'fnmatch', 'locale', 'encodings', 'codecs',
+                    'stat', 'UserDict', 'readline', 'copy_reg', 'types',
+                    're', 'sre', 'sre_parse', 'sre_constants', 'sre_compile',
+                    'zlib']
+REQUIRED_FILES = ['lib-dynload', 'config']
+if sys.version_info[:2] >= (2, 6):
+    REQUIRED_MODULES.extend(['warnings', 'linecache', '_abcoll', 'abc'])
+if sys.version_info[:2] >= (2, 7):
+    REQUIRED_MODULES.extend(['_weakrefset'])
+if sys.version_info[:2] <= (2, 3):
+    REQUIRED_MODULES.extend(['sets', '__future__'])
+if is_pypy:
+    # these are needed to correctly display the exceptions that may happen
+    # during the bootstrap
+    REQUIRED_MODULES.extend(['traceback', 'linecache'])
+class Logger(object):
+    Logging object for use in command-line script.  Allows ranges of
+    levels, to avoid some redundancy of displayed information.
+    DEBUG = logging.DEBUG
+    INFO = logging.INFO
+    NOTIFY = (logging.INFO+logging.WARN)/2
+    WARN = WARNING = logging.WARN
+    ERROR = logging.ERROR
+    FATAL = logging.FATAL
+    LEVELS = [DEBUG, INFO, NOTIFY, WARN, ERROR, FATAL]
+    def __init__(self, consumers):
+        self.consumers = consumers
+        self.indent = 0
+        self.in_progress = None
+        self.in_progress_hanging = False
+    def debug(self, msg, *args, **kw):
+        self.log(self.DEBUG, msg, *args, **kw)
+    def info(self, msg, *args, **kw):
+        self.log(self.INFO, msg, *args, **kw)
+    def notify(self, msg, *args, **kw):
+        self.log(self.NOTIFY, msg, *args, **kw)
+    def warn(self, msg, *args, **kw):
+        self.log(self.WARN, msg, *args, **kw)
+    def error(self, msg, *args, **kw):
+    def fatal(self, msg, *args, **kw):
+        self.log(self.FATAL, msg, *args, **kw)
+    def log(self, level, msg, *args, **kw):
+        if args:
+            if kw:
+                raise TypeError(
+                    "You may give positional or keyword arguments, not both")
+        args = args or kw
+        rendered = None
+        for consumer_level, consumer in self.consumers:
+            if self.level_matches(level, consumer_level):
+                if (self.in_progress_hanging
+                    and consumer in (sys.stdout, sys.stderr)):
+                    sys.stdout.write('\n')
+                    sys.stdout.flush()
+                if rendered is None:
+                    if args:
+                        rendered = msg % args
+                    else:
+                        rendered = msg
+                    rendered = ' '*self.indent + rendered
+                if hasattr(consumer, 'write'):
+                    consumer.write(rendered+'\n')
+                else:
+                    consumer(rendered)
+    def start_progress(self, msg):
+        assert not self.in_progress, (
+            "Tried to start_progress(%r) while in_progress %r"
+            % (msg, self.in_progress))
+        if self.level_matches(self.NOTIFY, self._stdout_level()):
+            sys.stdout.write(msg)
+            self.in_progress_hanging = True
+        else:
+        self.in_progress = msg
+    def end_progress(self, msg='done.'):
+        assert self.in_progress, (
+            "Tried to end_progress without start_progress")
+        if self.stdout_level_matches(self.NOTIFY):
+            if not self.in_progress_hanging:
+                # Some message has been printed out since start_progress
+                sys.stdout.write('...' + self.in_progress + msg + '\n')
+            else:
+                sys.stdout.write(msg + '\n')
+    def show_progress(self):
+        """If we are in a progress scope, and no log messages have been
+        shown, write out another '.'"""
+        if self.in_progress_hanging:
+            sys.stdout.write('.')
+    def stdout_level_matches(self, level):
+        """Returns true if a message at this level will go to stdout"""
+        return self.level_matches(level, self._stdout_level())
+    def _stdout_level(self):
+        """Returns the level that stdout runs at"""
+        for level, consumer in self.consumers:
+            if consumer is sys.stdout:
+                return level
+        return self.FATAL
+    def level_matches(self, level, consumer_level):
+        >>> l = Logger()
+        >>> l.level_matches(3, 4)
+        False
+        >>> l.level_matches(3, 2)
+        True
+        >>> l.level_matches(slice(None, 3), 3)
+        False
+        >>> l.level_matches(slice(None, 3), 2)
+        True
+        >>> l.level_matches(slice(1, 3), 1)
+        True
+        >>> l.level_matches(slice(2, 3), 1)
+        False
+        if isinstance(level, slice):
+            start, stop = level.start, level.stop
+            if start is not None and start > consumer_level:
+                return False
+            if stop is not None or stop <= consumer_level:
+                return False
+            return True
+        else:
+            return level >= consumer_level
+    #@classmethod
+    def level_for_integer(cls, level):
+        levels = cls.LEVELS
+        if level < 0:
+            return levels[0]
+        if level >= len(levels):
+            return levels[-1]
+        return levels[level]
+    level_for_integer = classmethod(level_for_integer)
+def mkdir(path):
+    if not os.path.exists(path):
+        logger.info('Creating %s', path)
+        os.makedirs(path)
+    else:
+        logger.info('Directory %s already exists', path)
+def copyfile(src, dest, symlink=True):
+    if not os.path.exists(src):
+        # Some bad symlink in the src
+        logger.warn('Cannot find file %s (bad symlink)', src)
+        return
+    if os.path.exists(dest):
+        logger.debug('File %s already exists', dest)
+        return
+    if not os.path.exists(os.path.dirname(dest)):
+        logger.info('Creating parent directories for %s' % os.path.dirname(dest))
+        os.makedirs(os.path.dirname(dest))
+    if symlink and hasattr(os, 'symlink'):
+        logger.info('Symlinking %s', dest)
+        os.symlink(os.path.abspath(src), dest)
+    else:
+        logger.info('Copying to %s', dest)
+        if os.path.isdir(src):
+            shutil.copytree(src, dest, True)
+        else:
+            shutil.copy2(src, dest)
+def writefile(dest, content, overwrite=True):
+    if not os.path.exists(dest):
+        logger.info('Writing %s', dest)
+        f = open(dest, 'wb')
+        f.write(content)
+        f.close()
+        return
+    else:
+        f = open(dest, 'rb')
+        c = f.read()
+        f.close()
+        if c != content:
+            if not overwrite:
+                logger.notify('File %s exists with different content; not overwriting', dest)
+                return
+            logger.notify('Overwriting %s with new content', dest)
+            f.write(content)
+            f.close()
+        else:
+            logger.info('Content %s already in place', dest)
+def rmtree(dir):
+    if os.path.exists(dir):
+        logger.notify('Deleting tree %s', dir)
+        shutil.rmtree(dir)
+    else:
+        logger.info('Do not need to delete %s; already gone', dir)
+def make_exe(fn):
+    if hasattr(os, 'chmod'):
+        oldmode = os.stat(fn).st_mode & 07777
+        newmode = (oldmode | 0555) & 07777
+        os.chmod(fn, newmode)
+        logger.info('Changed mode of %s to %s', fn, oct(newmode))
+def _find_file(filename, dirs):
+    for dir in dirs:
+        if os.path.exists(join(dir, filename)):
+            return join(dir, filename)
+    return filename
+def _install_req(py_executable, unzip=False, distribute=False):
+    if not distribute:
+        setup_fn = 'setuptools-0.6c11-py%s.egg' % sys.version[:3]
+        project_name = 'setuptools'
+        bootstrap_script = EZ_SETUP_PY
+        source = None
+    else:
+        setup_fn = None
+        source = 'distribute-0.6.14.tar.gz'
+        project_name = 'distribute'
+        bootstrap_script = DISTRIBUTE_SETUP_PY
+        try:
+            # check if the global Python has distribute installed or plain
+            # setuptools
+            import pkg_resources
+            if not hasattr(pkg_resources, '_distribute'):
+                location = os.path.dirname(pkg_resources.__file__)
+                logger.notify("A globally installed setuptools was found (in %s)" % location)
+                logger.notify("Use the --no-site-packages option to use distribute in "
+                              "the virtualenv.")
+        except ImportError:
+            pass
+    search_dirs = file_search_dirs()
+    if setup_fn is not None:
+        setup_fn = _find_file(setup_fn, search_dirs)
+    if source is not None:
+        source = _find_file(source, search_dirs)
+    if is_jython and os._name == 'nt':
+        # Jython's .bat sys.executable can't handle a command line
+        # argument with newlines
+        fd, ez_setup = tempfile.mkstemp('.py')
+        os.write(fd, bootstrap_script)
+        os.close(fd)
+        cmd = [py_executable, ez_setup]
+    else:
+        cmd = [py_executable, '-c', bootstrap_script]
+    if unzip:
+        cmd.append('--always-unzip')
+    env = {}
+    remove_from_env = []
+    if logger.stdout_level_matches(logger.DEBUG):
+        cmd.append('-v')
+    old_chdir = os.getcwd()
+    if setup_fn is not None and os.path.exists(setup_fn):
+        logger.info('Using existing %s egg: %s' % (project_name, setup_fn))
+        cmd.append(setup_fn)
+        if os.environ.get('PYTHONPATH'):
+            env['PYTHONPATH'] = setup_fn + os.path.pathsep + os.environ['PYTHONPATH']
+        else:
+    else:
+        # the source is found, let's chdir
+        if source is not None and os.path.exists(source):
+            os.chdir(os.path.dirname(source))
+            # in this case, we want to be sure that PYTHONPATH is unset (not
+            # just empty, really unset), else CPython tries to import the
+            # site.py that it's in virtualenv_support
+            remove_from_env.append('PYTHONPATH')
+        else:
+            logger.info('No %s egg found; downloading' % project_name)
+        cmd.extend(['--always-copy', '-U', project_name])
+    logger.start_progress('Installing %s...' % project_name)
+    logger.indent += 2
+    cwd = None
+    if project_name == 'distribute':
+        env['DONT_PATCH_SETUPTOOLS'] = 'true'
+    def _filter_ez_setup(line):
+        return filter_ez_setup(line, project_name)
+    if not os.access(os.getcwd(), os.W_OK):
+        cwd = tempfile.mkdtemp()
+            # the current working dir is hostile, let's copy the
+            # tarball to a temp dir
+            target = os.path.join(cwd, os.path.split(source)[-1])
+            shutil.copy(source, target)
+    try:
+        call_subprocess(cmd, show_stdout=False,
+                        filter_stdout=_filter_ez_setup,
+                        extra_env=env,
+                        remove_from_env=remove_from_env,
+                        cwd=cwd)
+    finally:
+        logger.indent -= 2
+        logger.end_progress()
+        if os.getcwd() != old_chdir:
+            os.chdir(old_chdir)
+            os.remove(ez_setup)
+def file_search_dirs():
+    here = os.path.dirname(os.path.abspath(__file__))
+    dirs = ['.', here,
+            join(here, 'virtualenv_support')]
+    if os.path.splitext(os.path.dirname(__file__))[0] != 'virtualenv':
+        # Probably some boot script; just in case virtualenv is installed...
+        try:
+            import virtualenv
+            pass
+        else:
+            dirs.append(os.path.join(os.path.dirname(virtualenv.__file__), 'virtualenv_support'))
+    return [d for d in dirs if os.path.isdir(d)]
+def install_setuptools(py_executable, unzip=False):
+    _install_req(py_executable, unzip)
+def install_distribute(py_executable, unzip=False):
+    _install_req(py_executable, unzip, distribute=True)
+_pip_re = re.compile(r'^pip-.*(zip|tar.gz|tar.bz2|tgz|tbz)$', re.I)
+def install_pip(py_executable):
+    filenames = []
+    for dir in file_search_dirs():
+        filenames.extend([join(dir, fn) for fn in os.listdir(dir)
+                          if _pip_re.search(fn)])
+    filenames = [(os.path.basename(filename).lower(), i, filename) for i, filename in enumerate(filenames)]
+    filenames.sort()
+    filenames = [filename for basename, i, filename in filenames]
+    if not filenames:
+        filename = 'pip'
+    else:
+        filename = filenames[-1]
+    easy_install_script = 'easy_install'
+    if sys.platform == 'win32':
+        easy_install_script = 'easy_install-script.py'
+    cmd = [py_executable, join(os.path.dirname(py_executable), easy_install_script), filename]
+    if filename == 'pip':
+        logger.info('Installing pip from network...')
+    else:
+        logger.info('Installing %s' % os.path.basename(filename))
+    def _filter_setup(line):
+        return filter_ez_setup(line, 'pip')
+    try:
+                        filter_stdout=_filter_setup)
+    finally:
+def filter_ez_setup(line, project_name='setuptools'):
+    if not line.strip():
+        return Logger.DEBUG
+        for prefix in ('Extracting', 'Now working', 'Installing', 'Before',
+                       'Scanning', 'Setuptools', 'Egg', 'Already',
+                       'running', 'writing', 'reading', 'installing',
+                       'creating', 'copying', 'byte-compiling', 'removing',
+                       'Processing'):
+            if line.startswith(prefix):
+    for prefix in ['Reading ', 'Best match', 'Processing setuptools',
+                   'Copying setuptools', 'Adding setuptools',
+                   'Installing ', 'Installed ']:
+    return Logger.INFO
+def main():
+    parser = optparse.OptionParser(
+        version=virtualenv_version,
+        usage="%prog [OPTIONS] DEST_DIR")
+    parser.add_option(
+        '-v', '--verbose',
+        action='count',
+        dest='verbose',
+        default=0,
+        help="Increase verbosity")
+        '-q', '--quiet',
+        action='count',
+        dest='quiet',
+        default=0,
+        help='Decrease verbosity')
+        '-p', '--python',
+        dest='python',
+        metavar='PYTHON_EXE',
+        help='The Python interpreter to use, e.g., --python=python2.5 will use the python2.5 '
+        'interpreter to create the new environment.  The default is the interpreter that '
+        'virtualenv was installed with (%s)' % sys.executable)
+        '--clear',
+        dest='clear',
+        action='store_true',
+        help="Clear out the non-root install and start from scratch")
+        '--no-site-packages',
+        dest='no_site_packages',
+        help="Don't give access to the global site-packages dir to the "
+             "virtual environment")
+        '--unzip-setuptools',
+        dest='unzip_setuptools',
+        help="Unzip Setuptools or Distribute when installing it")
+        '--relocatable',
+        dest='relocatable',
+        help='Make an EXISTING virtualenv environment relocatable.  '
+        'This fixes up scripts and makes all .pth files relative')
+        '--distribute',
+        dest='use_distribute',
+        help='Use Distribute instead of Setuptools. Set environ variable '
+        'VIRTUALENV_USE_DISTRIBUTE to make it the default ')
+        '--prompt=',
+        dest='prompt',
+        help='Provides an alternative prompt prefix for this environment')
+    if 'extend_parser' in globals():
+        extend_parser(parser)
+    options, args = parser.parse_args()
+    global logger
+    if 'adjust_options' in globals():
+        adjust_options(options, args)
+    verbosity = options.verbose - options.quiet
+    logger = Logger([(Logger.level_for_integer(2-verbosity), sys.stdout)])
+    if options.python and not os.environ.get('VIRTUALENV_INTERPRETER_RUNNING'):
+        env = os.environ.copy()
+        interpreter = resolve_interpreter(options.python)
+        if interpreter == sys.executable:
+            logger.warn('Already using interpreter %s' % interpreter)
+        else:
+            logger.notify('Running virtualenv with interpreter %s' % interpreter)
+            env['VIRTUALENV_INTERPRETER_RUNNING'] = 'true'
+            file = __file__
+            if file.endswith('.pyc'):
+                file = file[:-1]
+            popen = subprocess.Popen([interpreter, file] + sys.argv[1:], env=env)
+            raise SystemExit(popen.wait())
+    if not args:
+        print 'You must provide a DEST_DIR'
+        parser.print_help()
+        sys.exit(2)
+    if len(args) > 1:
+        print 'There must be only one argument: DEST_DIR (you gave %s)' % (
+            ' '.join(args))
+        sys.exit(2)
+    home_dir = args[0]
+    if os.environ.get('WORKING_ENV'):
+        logger.fatal('ERROR: you cannot run virtualenv while in a workingenv')
+        logger.fatal('Please deactivate your workingenv, then re-run this script')
+        sys.exit(3)
+    if 'PYTHONHOME' in os.environ:
+        logger.warn('PYTHONHOME is set.  You *must* activate the virtualenv before using it')
+        del os.environ['PYTHONHOME']
+    if options.relocatable:
+        make_environment_relocatable(home_dir)
+        return
+    create_environment(home_dir, site_packages=not options.no_site_packages, clear=options.clear,
+                       unzip_setuptools=options.unzip_setuptools,
+                       use_distribute=options.use_distribute,
+                       prompt=options.prompt)
+    if 'after_install' in globals():
+        after_install(options, home_dir)
+def call_subprocess(cmd, show_stdout=True,
+                    filter_stdout=None, cwd=None,
+                    raise_on_returncode=True, extra_env=None,
+                    remove_from_env=None):
+    cmd_parts = []
+    for part in cmd:
+        if len(part) > 40:
+            part = part[:30]+"..."+part[-5:]
+        if ' ' in part or '\n' in part or '"' in part or "'" in part:
+            part = '"%s"' % part.replace('"', '\\"')
+        cmd_parts.append(part)
+    cmd_desc = ' '.join(cmd_parts)
+    if show_stdout:
+        stdout = None
+    else:
+        stdout = subprocess.PIPE
+    logger.debug("Running command %s" % cmd_desc)
+    if extra_env or remove_from_env:
+        if extra_env:
+            env.update(extra_env)
+        if remove_from_env:
+            for varname in remove_from_env:
+                env.pop(varname, None)
+    else:
+        env = None
+    try:
+        proc = subprocess.Popen(
+            cmd, stderr=subprocess.STDOUT, stdin=None, stdout=stdout,
+            cwd=cwd, env=env)
+    except Exception, e:
+        logger.fatal(
+            "Error %s while executing command %s" % (e, cmd_desc))
+        raise
+    all_output = []
+    if stdout is not None:
+        stdout = proc.stdout
+        while 1:
+            line = stdout.readline()
+            if not line:
+                break
+            line = line.rstrip()
+            all_output.append(line)
+            if filter_stdout:
+                level = filter_stdout(line)
+                if isinstance(level, tuple):
+                    level, line = level
+                logger.log(level, line)
+                if not logger.stdout_level_matches(level):
+                    logger.show_progress()
+            else:
+                logger.info(line)
+    else:
+        proc.communicate()
+    proc.wait()
+    if proc.returncode:
+        if raise_on_returncode:
+            if all_output:
+                logger.notify('Complete output from command %s:' % cmd_desc)
+                logger.notify('\n'.join(all_output) + '\n----------------------------------------')
+            raise OSError(
+                "Command %s failed with error code %s"
+                % (cmd_desc, proc.returncode))
+        else:
+            logger.warn(
+                "Command %s had error code %s"
+def create_environment(home_dir, site_packages=True, clear=False,
+                       unzip_setuptools=False, use_distribute=False,
+                       prompt=None):
+    Creates a new environment in ``home_dir``.
+    If ``site_packages`` is true (the default) then the global
+    ``site-packages/`` directory will be on the path.
+    If ``clear`` is true (default False) then the environment will
+    first be cleared.
+    home_dir, lib_dir, inc_dir, bin_dir = path_locations(home_dir)
+    py_executable = os.path.abspath(install_python(
+        home_dir, lib_dir, inc_dir, bin_dir,
+        site_packages=site_packages, clear=clear))
+    install_distutils(home_dir)
+    if use_distribute or os.environ.get('VIRTUALENV_USE_DISTRIBUTE'):
+        install_distribute(py_executable, unzip=unzip_setuptools)
+    else:
+        install_setuptools(py_executable, unzip=unzip_setuptools)
+    install_pip(py_executable)
+    install_activate(home_dir, bin_dir, prompt)
+def path_locations(home_dir):
+    """Return the path locations for the environment (where libraries are,
+    where scripts go, etc)"""
+    # XXX: We'd use distutils.sysconfig.get_python_inc/lib but its
+    # prefix arg is broken: http://bugs.python.org/issue3386
+        # Windows has lots of problems with executables with spaces in
+        # the name; this function will remove them (using the ~1
+        # format):
+        mkdir(home_dir)
+        if ' ' in home_dir:
+            try:
+                import win32api
+                print 'Error: the path "%s" has a space in it' % home_dir
+                print 'To handle these kinds of paths, the win32api module must be installed:'
+                print '  http://sourceforge.net/projects/pywin32/'
+                sys.exit(3)
+            home_dir = win32api.GetShortPathName(home_dir)
+        lib_dir = join(home_dir, 'Lib')
+        inc_dir = join(home_dir, 'Include')
+        bin_dir = join(home_dir, 'Scripts')
+    elif is_jython:
+        bin_dir = join(home_dir, 'bin')
+    elif is_pypy:
+        lib_dir = home_dir
+        inc_dir = join(home_dir, 'include')
+    else:
+        lib_dir = join(home_dir, 'lib', py_version)
+        inc_dir = join(home_dir, 'include', py_version)
+    return home_dir, lib_dir, inc_dir, bin_dir
+def change_prefix(filename, dst_prefix):
+    prefixes = [sys.prefix]
+    if hasattr(sys, 'real_prefix'):
+        prefixes.append(sys.real_prefix)
+    prefixes = map(os.path.abspath, prefixes)
+    filename = os.path.abspath(filename)
+    for src_prefix in prefixes:
+        if filename.startswith(src_prefix):
+            _, relpath = filename.split(src_prefix, 1)
+            assert relpath[0] == os.sep
+            relpath = relpath[1:]
+            return join(dst_prefix, relpath)
+    assert False, "Filename %s does not start with any of these prefixes: %s" % \
+        (filename, prefixes)
+def copy_required_modules(dst_prefix):
+    import imp
+    for modname in REQUIRED_MODULES:
+        if modname in sys.builtin_module_names:
+            logger.info("Ignoring built-in bootstrap module: %s" % modname)
+            continue
+        try:
+            f, filename, _ = imp.find_module(modname)
+            logger.info("Cannot import bootstrap module: %s" % modname)
+        else:
+            if f is not None:
+                f.close()
+            dst_filename = change_prefix(filename, dst_prefix)
+            copyfile(filename, dst_filename)
+            if filename.endswith('.pyc'):
+                pyfile = filename[:-1]
+                if os.path.exists(pyfile):
+                    copyfile(pyfile, dst_filename[:-1])
+def install_python(home_dir, lib_dir, inc_dir, bin_dir, site_packages, clear):
+    """Install just the base environment, no distutils patches etc"""
+    if sys.executable.startswith(bin_dir):
+        print 'Please use the *system* python to run this script'
+        return
+    if clear:
+        rmtree(lib_dir)
+        ## FIXME: why not delete it?
+        ## Maybe it should delete everything with #!/path/to/venv/python in it
+        logger.notify('Not deleting %s', bin_dir)
+        logger.notify('Using real prefix %r' % sys.real_prefix)
+        prefix = sys.real_prefix
+    else:
+        prefix = sys.prefix
+    mkdir(lib_dir)
+    fix_lib64(lib_dir)
+    stdlib_dirs = [os.path.dirname(os.__file__)]
+        stdlib_dirs.append(join(os.path.dirname(stdlib_dirs[0]), 'DLLs'))
+    elif sys.platform == 'darwin':
+        stdlib_dirs.append(join(stdlib_dirs[0], 'site-packages'))
+    if hasattr(os, 'symlink'):
+        logger.info('Symlinking Python bootstrap modules')
+    else:
+        logger.info('Copying Python bootstrap modules')
+    try:
+        # copy required files...
+        for stdlib_dir in stdlib_dirs:
+            if not os.path.isdir(stdlib_dir):
+                continue
+            for fn in os.listdir(stdlib_dir):
+                if fn != 'site-packages' and os.path.splitext(fn)[0] in REQUIRED_FILES:
+                    copyfile(join(stdlib_dir, fn), join(lib_dir, fn))
+        # ...and modules
+        copy_required_modules(home_dir)
+    finally:
+    mkdir(join(lib_dir, 'site-packages'))
+    import site
+    site_filename = site.__file__
+    if site_filename.endswith('.pyc'):
+        site_filename = site_filename[:-1]
+    elif site_filename.endswith('$py.class'):
+        site_filename = site_filename.replace('$py.class', '.py')
+    site_filename_dst = change_prefix(site_filename, home_dir)
+    site_dir = os.path.dirname(site_filename_dst)
+    writefile(site_filename_dst, SITE_PY)
+    writefile(join(site_dir, 'orig-prefix.txt'), prefix)
+    site_packages_filename = join(site_dir, 'no-global-site-packages.txt')
+    if not site_packages:
+        writefile(site_packages_filename, '')
+    else:
+        if os.path.exists(site_packages_filename):
+            logger.info('Deleting %s' % site_packages_filename)
+            os.unlink(site_packages_filename)
+    if is_pypy:
+        stdinc_dir = join(prefix, 'include')
+    else:
+        stdinc_dir = join(prefix, 'include', py_version)
+    if os.path.exists(stdinc_dir):
+        copyfile(stdinc_dir, inc_dir)
+    else:
+        logger.debug('No include dir %s' % stdinc_dir)
+    if sys.exec_prefix != prefix:
+            exec_dir = join(sys.exec_prefix, 'lib')
+        elif is_jython:
+            exec_dir = join(sys.exec_prefix, 'Lib')
+        else:
+            exec_dir = join(sys.exec_prefix, 'lib', py_version)
+        for fn in os.listdir(exec_dir):
+            copyfile(join(exec_dir, fn), join(lib_dir, fn))
+    if is_jython:
+        # Jython has either jython-dev.jar and javalib/ dir, or just
+        # jython.jar
+        for name in 'jython-dev.jar', 'javalib', 'jython.jar':
+            src = join(prefix, name)
+            if os.path.exists(src):
+                copyfile(src, join(home_dir, name))
+        # XXX: registry should always exist after Jython 2.5rc1
+        src = join(prefix, 'registry')
+            copyfile(src, join(home_dir, 'registry'), symlink=False)
+        copyfile(join(prefix, 'cachedir'), join(home_dir, 'cachedir'),
+                 symlink=False)
+    mkdir(bin_dir)
+    py_executable = join(bin_dir, os.path.basename(sys.executable))
+    if 'Python.framework' in prefix:
+        if re.search(r'/Python(?:-32|-64)*$', py_executable):
+            # The name of the python executable is not quite what
+            # we want, rename it.
+            py_executable = os.path.join(
+                    os.path.dirname(py_executable), 'python')
+    logger.notify('New %s executable in %s', expected_exe, py_executable)
+    if sys.executable != py_executable:
+        ## FIXME: could I just hard link?
+        executable = sys.executable
+        if sys.platform == 'cygwin' and os.path.exists(executable + '.exe'):
+            # Cygwin misreports sys.executable sometimes
+            executable += '.exe'
+            py_executable += '.exe'
+            logger.info('Executable actually exists in %s' % executable)
+        shutil.copyfile(executable, py_executable)
+        make_exe(py_executable)
+        if sys.platform == 'win32' or sys.platform == 'cygwin':
+            pythonw = os.path.join(os.path.dirname(sys.executable), 'pythonw.exe')
+            if os.path.exists(pythonw):
+                logger.info('Also created pythonw.exe')
+                shutil.copyfile(pythonw, os.path.join(os.path.dirname(py_executable), 'pythonw.exe'))
+        if is_pypy:
+            # make a symlink python --> pypy-c
+            python_executable = os.path.join(os.path.dirname(py_executable), 'python')
+            logger.info('Also created executable %s' % python_executable)
+            copyfile(py_executable, python_executable)
+    if os.path.splitext(os.path.basename(py_executable))[0] != expected_exe:
+        secondary_exe = os.path.join(os.path.dirname(py_executable),
+                                     expected_exe)
+        py_executable_ext = os.path.splitext(py_executable)[1]
+        if py_executable_ext == '.exe':
+            # python2.4 gives an extension of '.4' :P
+            secondary_exe += py_executable_ext
+        if os.path.exists(secondary_exe):
+            logger.warn('Not overwriting existing %s script %s (you must use %s)'
+                        % (expected_exe, secondary_exe, py_executable))
+        else:
+            logger.notify('Also creating executable in %s' % secondary_exe)
+            shutil.copyfile(sys.executable, secondary_exe)
+            make_exe(secondary_exe)
+        logger.debug('MacOSX Python framework detected')
+        # Make sure we use the the embedded interpreter inside
+        # the framework, even if sys.executable points to
+        # the stub executable in ${sys.prefix}/bin
+        # See http://groups.google.com/group/python-virtualenv/
+        #                              browse_thread/thread/17cab2f85da75951
+        original_python = os.path.join(
+            prefix, 'Resources/Python.app/Contents/MacOS/Python')
+        shutil.copy(original_python, py_executable)
+        # Copy the framework's dylib into the virtual
+        # environment
+        virtual_lib = os.path.join(home_dir, '.Python')
+        if os.path.exists(virtual_lib):
+            os.unlink(virtual_lib)
+        copyfile(
+            os.path.join(prefix, 'Python'),
+            virtual_lib)
+        # And then change the install_name of the copied python executable
+        try:
+            call_subprocess(
+                ["install_name_tool", "-change",
+                 '@executable_path/../.Python',
+                 py_executable])
+        except:
+            logger.fatal(
+                "Could not call install_name_tool -- you must have Apple's development tools installed")
+            raise
+        # Some tools depend on pythonX.Y being present
+        py_executable_version = '%s.%s' % (
+            sys.version_info[0], sys.version_info[1])
+        if not py_executable.endswith(py_executable_version):
+            # symlinking pythonX.Y > python
+            pth = py_executable + '%s.%s' % (
+            if os.path.exists(pth):
+                os.unlink(pth)
+            os.symlink('python', pth)
+        else:
+            # reverse symlinking python -> pythonX.Y (with --python)
+            pth = join(bin_dir, 'python')
+                os.unlink(pth)
+            os.symlink(os.path.basename(py_executable), pth)
+    if sys.platform == 'win32' and ' ' in py_executable:
+        # There's a bug with subprocess on Windows when using a first
+        # argument that has a space in it.  Instead we have to quote
+        # the value:
+        py_executable = '"%s"' % py_executable
+    cmd = [py_executable, '-c', 'import sys; print sys.prefix']
+    logger.info('Testing executable with %s %s "%s"' % tuple(cmd))
+    proc = subprocess.Popen(cmd,
+                            stdout=subprocess.PIPE)
+    proc_stdout, proc_stderr = proc.communicate()
+    proc_stdout = os.path.normcase(os.path.abspath(proc_stdout.strip()))
+    if proc_stdout != os.path.normcase(os.path.abspath(home_dir)):
+        logger.fatal(
+            'ERROR: The executable %s is not functioning' % py_executable)
+        logger.fatal(
+            'ERROR: It thinks sys.prefix is %r (should be %r)'
+            % (proc_stdout, os.path.normcase(os.path.abspath(home_dir))))
+        logger.fatal(
+            'ERROR: virtualenv is not compatible with this system or executable')
+            logger.fatal(
+                'Note: some Windows users have reported this error when they installed Python for "Only this user".  The problem may be resolvable if you install Python "For all users".  (See https://bugs.launchpad.net/virtualenv/+bug/352844)')
+        sys.exit(100)
+    else:
+        logger.info('Got sys.prefix result: %r' % proc_stdout)
+    pydistutils = os.path.expanduser('~/.pydistutils.cfg')
+    if os.path.exists(pydistutils):
+        logger.notify('Please make sure you remove any previous custom paths from '
+                      'your %s file.' % pydistutils)
+    ## FIXME: really this should be calculated earlier
+    return py_executable
+def install_activate(home_dir, bin_dir, prompt=None):
+    if sys.platform == 'win32' or is_jython and os._name == 'nt':
+        files = {'activate.bat': ACTIVATE_BAT,
+                 'deactivate.bat': DEACTIVATE_BAT}
+        if os.environ.get('OS') == 'Windows_NT' and os.environ.get('OSTYPE') == 'cygwin':
+            files['activate'] = ACTIVATE_SH
+    else:
+        files = {'activate': ACTIVATE_SH}
+        # suppling activate.fish in addition to, not instead of, the
+        # bash script support.
+        files['activate.fish'] = ACTIVATE_FISH
+        # same for csh/tcsh support...
+        files['activate.csh'] = ACTIVATE_CSH
+    files['activate_this.py'] = ACTIVATE_THIS
+    vname = os.path.basename(os.path.abspath(home_dir))
+    for name, content in files.items():
+        content = content.replace('__VIRTUAL_PROMPT__', prompt or '')
+        content = content.replace('__VIRTUAL_WINPROMPT__', prompt or '(%s)' % vname)
+        content = content.replace('__VIRTUAL_ENV__', os.path.abspath(home_dir))
+        content = content.replace('__VIRTUAL_NAME__', vname)
+        content = content.replace('__BIN_NAME__', os.path.basename(bin_dir))
+        writefile(os.path.join(bin_dir, name), content)
+def install_distutils(home_dir):
+    distutils_path = change_prefix(distutils.__path__[0], home_dir)
+    mkdir(distutils_path)
+    ## FIXME: maybe this prefix setting should only be put in place if
+    ## there's a local distutils.cfg with a prefix setting?
+    home_dir = os.path.abspath(home_dir)
+    ## FIXME: this is breaking things, removing for now:
+    #distutils_cfg = DISTUTILS_CFG + "\n[install]\nprefix=%s\n" % home_dir
+    writefile(os.path.join(distutils_path, '__init__.py'), DISTUTILS_INIT)
+    writefile(os.path.join(distutils_path, 'distutils.cfg'), DISTUTILS_CFG, overwrite=False)
+def fix_lib64(lib_dir):
+    Some platforms (particularly Gentoo on x64) put things in lib64/pythonX.Y
+    instead of lib/pythonX.Y.  If this is such a platform we'll just create a
+    symlink so lib64 points to lib
+    if [p for p in distutils.sysconfig.get_config_vars().values()
+        if isinstance(p, basestring) and 'lib64' in p]:
+        logger.debug('This system uses lib64; symlinking lib64 to lib')
+        assert os.path.basename(lib_dir) == 'python%s' % sys.version[:3], (
+            "Unexpected python lib dir: %r" % lib_dir)
+        lib_parent = os.path.dirname(lib_dir)
+        assert os.path.basename(lib_parent) == 'lib', (
+            "Unexpected parent dir: %r" % lib_parent)
+        copyfile(lib_parent, os.path.join(os.path.dirname(lib_parent), 'lib64'))
+def resolve_interpreter(exe):
+    If the executable given isn't an absolute path, search $PATH for the interpreter
+    if os.path.abspath(exe) != exe:
+        paths = os.environ.get('PATH', '').split(os.pathsep)
+        for path in paths:
+            if os.path.exists(os.path.join(path, exe)):
+                exe = os.path.join(path, exe)
+                break
+    if not os.path.exists(exe):
+        logger.fatal('The executable %s (from --python=%s) does not exist' % (exe, exe))
+        sys.exit(3)
+    return exe
+## Relocating the environment:
+def make_environment_relocatable(home_dir):
+    Makes the already-existing environment use relative paths, and takes out
+    the #!-based environment selection in scripts.
+    activate_this = os.path.join(bin_dir, 'activate_this.py')
+    if not os.path.exists(activate_this):
+        logger.fatal(
+            'The environment doesn\'t have a file %s -- please re-run virtualenv '
+            'on this environment to update it' % activate_this)
+    fixup_scripts(home_dir)
+    fixup_pth_and_egg_link(home_dir)
+    ## FIXME: need to fix up distutils.cfg
+OK_ABS_SCRIPTS = ['python', 'python%s' % sys.version[:3],
+                  'activate', 'activate.bat', 'activate_this.py']
+def fixup_scripts(home_dir):
+    # This is what we expect at the top of scripts:
+    shebang = '#!%s/bin/python' % os.path.normcase(os.path.abspath(home_dir))
+    # This is what we'll put:
+    new_shebang = '#!/usr/bin/env python%s' % sys.version[:3]
+    activate = "import os; activate_this=os.path.join(os.path.dirname(__file__), 'activate_this.py'); execfile(activate_this, dict(__file__=activate_this)); del os, activate_this"
+        bin_suffix = 'Scripts'
+    else:
+        bin_suffix = 'bin'
+    bin_dir = os.path.join(home_dir, bin_suffix)
+    for filename in os.listdir(bin_dir):
+        filename = os.path.join(bin_dir, filename)
+        if not os.path.isfile(filename):
+            # ignore subdirs, e.g. .svn ones.
+            continue
+        f = open(filename, 'rb')
+        lines = f.readlines()
+        f.close()
+        if not lines:
+            logger.warn('Script %s is an empty file' % filename)
+            continue
+        if not lines[0].strip().startswith(shebang):
+            if os.path.basename(filename) in OK_ABS_SCRIPTS:
+                logger.debug('Cannot make script %s relative' % filename)
+            elif lines[0].strip() == new_shebang:
+                logger.info('Script %s has already been made relative' % filename)
+            else:
+                logger.warn('Script %s cannot be made relative (it\'s not a normal script that starts with %s)'
+                            % (filename, shebang))
+            continue
+        logger.notify('Making script %s relative' % filename)
+        lines = [new_shebang+'\n', activate+'\n'] + lines[1:]
+        f = open(filename, 'wb')
+        f.writelines(lines)
+        f.close()
+def fixup_pth_and_egg_link(home_dir, sys_path=None):
+    """Makes .pth and .egg-link files use relative paths"""
+    home_dir = os.path.normcase(os.path.abspath(home_dir))
+    if sys_path is None:
+        sys_path = sys.path
+    for path in sys_path:
+        if not path:
+            path = '.'
+        if not os.path.isdir(path):
+            continue
+        path = os.path.normcase(os.path.abspath(path))
+        if not path.startswith(home_dir):
+            logger.debug('Skipping system (non-environment) directory %s' % path)
+            continue
+        for filename in os.listdir(path):
+            filename = os.path.join(path, filename)
+            if filename.endswith('.pth'):
+                if not os.access(filename, os.W_OK):
+                    logger.warn('Cannot write .pth file %s, skipping' % filename)
+                else:
+                    fixup_pth_file(filename)
+            if filename.endswith('.egg-link'):
+                    logger.warn('Cannot write .egg-link file %s, skipping' % filename)
+                else:
+                    fixup_egg_link(filename)
+def fixup_pth_file(filename):
+    lines = []
+    prev_lines = []
+    f = open(filename)
+    prev_lines = f.readlines()
+    f.close()
+    for line in prev_lines:
+        line = line.strip()
+        if (not line or line.startswith('#') or line.startswith('import ')
+            or os.path.abspath(line) != line):
+            lines.append(line)
+        else:
+            new_value = make_relative_path(filename, line)
+            if line != new_value:
+                logger.debug('Rewriting path %s as %s (in %s)' % (line, new_value, filename))
+            lines.append(new_value)
+    if lines == prev_lines:
+        logger.info('No changes to .pth file %s' % filename)
+        return
+    logger.notify('Making paths in .pth file %s relative' % filename)
+    f = open(filename, 'w')
+    f.write('\n'.join(lines) + '\n')
+    f.close()
+def fixup_egg_link(filename):
+    link = f.read().strip()
+    f.close()
+    if os.path.abspath(link) != link:
+        logger.debug('Link in %s already relative' % filename)
+        return
+    new_link = make_relative_path(filename, link)
+    logger.notify('Rewriting link %s in %s as %s' % (link, filename, new_link))
+    f.write(new_link)
+    f.close()
+def make_relative_path(source, dest, dest_is_directory=True):
+    Make a filename relative, where the filename is dest, and it is
+    being referred to from the filename source.
+        >>> make_relative_path('/usr/share/something/a-file.pth',
+        ...                    '/usr/share/another-place/src/Directory')
+        '../another-place/src/Directory'
+        ...                    '/home/user/src/Directory')
+        '../../../home/user/src/Directory'
+        >>> make_relative_path('/usr/share/a-file.pth', '/usr/share/')
+    source = os.path.dirname(source)
+    if not dest_is_directory:
+        dest_filename = os.path.basename(dest)
+        dest = os.path.dirname(dest)
+    dest = os.path.normpath(os.path.abspath(dest))
+    source = os.path.normpath(os.path.abspath(source))
+    dest_parts = dest.strip(os.path.sep).split(os.path.sep)
+    source_parts = source.strip(os.path.sep).split(os.path.sep)
+    while dest_parts and source_parts and dest_parts[0] == source_parts[0]:
+        dest_parts.pop(0)
+        source_parts.pop(0)
+    full_parts = ['..']*len(source_parts) + dest_parts
+        full_parts.append(dest_filename)
+    if not full_parts:
+        # Special case for the current directory (otherwise it'd be '')
+        return './'
+    return os.path.sep.join(full_parts)
+## Bootstrap script creation:
+def create_bootstrap_script(extra_text, python_version=''):
+    Creates a bootstrap script, which is like this script but with
+    extend_parser, adjust_options, and after_install hooks.
+    This returns a string that (written to disk of course) can be used
+    as a bootstrap script with your own customizations.  The script
+    will be the standard virtualenv.py script, with your extra text
+    added (your extra text should be Python code).
+    If you include these functions, they will be called:
+    ``extend_parser(optparse_parser)``:
+        You can add or remove options from the parser here.
+    ``adjust_options(options, args)``:
+        You can change options here, or change the args (if you accept
+        different kinds of arguments, be sure you modify ``args`` so it is
+        only ``[DEST_DIR]``).
+    ``after_install(options, home_dir)``:
+        After everything is installed, this function is called.  This
+        is probably the function you are most likely to use.  An
+        example would be::
+            def after_install(options, home_dir):
+                subprocess.call([join(home_dir, 'bin', 'easy_install'),
+                                 'MyPackage'])
+                subprocess.call([join(home_dir, 'bin', 'my-package-script'),
+                                 'setup', home_dir])
+        This example immediately installs a package, and runs a setup
+        script from that package.
+    If you provide something like ``python_version='2.4'`` then the
+    script will start with ``#!/usr/bin/env python2.4`` instead of
+    ``#!/usr/bin/env python``.  You can use this when the script must
+    be run with a particular Python version.
+    filename = __file__
+        filename = filename[:-1]
+    content = f.read()
+    f.close()
+    py_exe = 'python%s' % python_version
+    content = (('#!/usr/bin/env %s\n' % py_exe)
+               + '## WARNING: This file is generated\n'
+               + content)
+    return content.replace('##EXT' 'END##', extra_text)
+##EXTEND##
+##file site.py
+SITE_PY = """
+eJzVPP1z2zaWv/OvQOXJUEplOh/dzo5T98ZJnNZ7buJt0mluXY+WkiCJNUWyBGlZe3P3t9/7AECA
+pGS77f5wmkwskcDDw8P7xgMGg8FpUchsLtb5vE6lUDIuZytRxNVKiUVeimqVlPPDIi6rLTyd3cRL
+qUSVC7VVEbaKguDpH/wET8WnVaIMCvAtrqt8HVfJLE7TrUjWRV5Wci7mdZlkS5FkSZXEafIvaJFn
+kXj6xzEIzjMBM08TWYpbWSqAq0S+EJfbapVnYlgXOOfn0V/il6OxULMyKSpoUGqcgSKruAoyKeeA
+JrSsFZAyqeShKuQsWSQz23CT1+lcFGk8k+Kf/+SpUdMwDFS+lpuVLKXIABmAKQFWgXjA16QUs3wu
+IyFey1mMA/DzhlgBQxvjmikkY5aLNM+WMKdMzqRScbkVw2ldESBCWcxzwCkBDKokTYNNXt6oESwp
+rccGHomY2cOfDLMHzBPH73IO4PghC37KkrsxwwbuQXDVitmmlIvkTsQIFn7KOzmb6GfDZCHmyWIB
+NMiqETYJGAEl0mR6VNByfKNX6NsjwspyZQxjSESZG/NL6hEF55WIUwVsWxdII0WYv5XTJM6AGtkt
+DAcQgaRB3zjzRFV2HJqdyAFAietYgZSslRiu4yQDZv0hnhHaPyfZPN+oEVEAVkuJX2tVufMf9hAA
+WjsEGAe4WGY16yxNbmS6HQECnwD7Uqo6rVAg5kkpZ1VeJlIRAEBtK+QdID0WcSk1CZkzjdyOif5E
+kyTDhUUBQ4HHl0iSRbKsS5IwsUiAc4Er3n34Ubw9e31++l7zmAHGMrtcA84AhRbawQkGEEe1Ko/S
+HAQ6Ci7wj4jncxSyJY4PeDUNju5d6WAIcy+idh9nwYHsenH1MDDHCpQJjRVQv/+GLmO1Avr8zz3r
+HQSnu6hCE+dvm1UOMpnFaylWMfMXckbwjYbzbVRUq1fADQrhVEAqhYuDCCYID0ji0myYZ1IUwGJp
+kslRABSaUlt/FYEV3ufZIa11ixMAQhlk8NJ5NqIRMwkT7cJ6hfrCNN7SzHSTwK7zOi9JcQD/ZzPS
+RWmc3RCOihiKv03lMskyRAh5IQgPQhpY3STAifNIXFAr0gumkQhZe3FLFIkaeAmZDnhS3sXrIpVj
+Fl/UrfvVCA0mK2HWOmWOg5YVqVdatWaqvbz3Ivrc4jpCs1qVEoDXU0/oFnk+FlPQ2YRNEa9ZvKpN
+TpwT9MgTdUKeoJbQF78DRU+VqtfSvkReAc1CDBUs8jTNN0Cy4yAQ4gAbGaPsMye8hXfwP8DF/1NZ
+zVZB4IxkAWtQiPwuUAgETILMNFdrJDxu06zcVjJJxpoiL+eypKEeRuwjRvyBjXGuwfu80kaNp4ur
+nK+TClXSVJvMhC1eFlasH1/xvGEaYLkV0cw0bei0xumlxSqeSuOSTOUCJUEv0iu77DBm0DMm2eJK
+rNnKwDsgi0zYgvQrFlQ6i0qSEwAwWPjiLCnqlBopZDARw0DrguCvYzTpuXaWgL3ZLAeokNh8z8D+
+AG7/AjHarBKgzwwggIZBLQXLN02qEh2ERh8FvtE3/Xl84NTzhbZNPOQiTlJt5eMsOKeHZ2VJ4juT
+BfYaa2IomGFWoWu3zICOKOaDwSAIjDu0VeZrbr9NJtM6QXs3mQRVuT0G7hAo5AFDF+9hojQcv1mU
++RpfW/Q+gj4AvYw9ggNxSYpCso/rMdMrpICrlQvTFM2vw5ECVUlw+ePZu/PPZx/FibhqtNK4rZKu
+YcyzLAbOJKUOfNEatlFH0BJ1V4LqS7wDC03rCiaJepMEyriqgf0A9U9lTa9hGjPvZXD2/vT1xdnk
+p49nP04+nn86AwTBVMjggKaMFq4Gn09FwN/AWHMVaRMZdHrQg9enH+2DYJKoSbEttvAAbB1wYTmE
++Y5FiA8n2oxOkmyRhyNq/Cv70SesGbTTdHX81bU4ORHhr/FtHAbguDRNeRF/IB7+tC0kdK3gzzBX
+oyCYywXw+41EqRg+JWd0xB2AiNAy18bx1zzJzHt67Q1BQjukHoDDZDJLY6Ww8WQSAmmpQ88HOkTs
+0SKrD6FjsXW7jjQq+CklLEWGXcb4Xw+K8ZT6IRqMotvFNAIZWc9iJbkVTR/6TSaoKCaToR4QJIh4
+HLwclv1QmCaoKMoEnEniFVQcU5Wn+BPho+iRyGA8g6oJF0nHK9FtnNZSDZ1JARGHwxYZUbslijgI
+/IIhmL9m6UajNjUNz0AzIF+ag+oqW5TDzwE4GaAjTOSE0RUHPEwzxPRv7N4TDuDnhahjlWpBYZUk
+Ls8uxctnLw7Rh4BAb26p4zVHs5hktbQPF7BaS1k5CHOvcEzCMHLpskDlhk+P98NcR3Zluqyw0Etc
+ynV+K+eALTKws8riR3oD4TDMYxbDKoIyJSPMSs84azEGfzx7kBY02EC9NUEx62+W/oAjcJkpUB0c
+zRKpdajN9qco89sELfx0q1+CgQL1hmbKeBOBs3Aek6EdAg0BrmeGlNrIEBRYWbOXSHgjSFTx80YV
+RgTuAnXrNX29yfJNNuHw8wTV5HBkWRcFSzMvNmiW4EC8A8MBSOYQTTVEYyjgZwuUrUNAHqYP0wXK
+kkMPgMC6KoqRHFgmvqIpcqiGwyKM0StBwltKNNK3ZgiKbwwxHEj0NrIPjJZASDA5q+CsatBMhrJm
+msHADkl8rruIOO7zAbSoGIGhG2po3MjQ7+oYlLO4cJWS0w9t6OfPn5lt1IqSGojYFCeNdntB5i0q
+tmAKE9AJxg3iFAmxwQY8SgBTK82a4vCjyAt2gWA9L7Vsg+WGkKqqiuOjo81mE+mQPi+XR2px9Je/
+fv31X5+xTpzPiX9gOo606PxWdETv0I2MvjEW6Fuzci1+TDKfGwnWUJIrRP4f4vddncxzcXw4svoT
+ubgxrPi/cT5AgUzMoExloO2gweiJOnwSvVQD8UQM3bbDEXsS2qRaK+ZbXehR5WC7wdOY5XVWhY4i
+VeJLsG4QFs/ltF6GdnDPRpofMFWU06HlgcPn14iBzxmGr4wpnqCWILZAi++Q/kdmm5j8Ga0hkLxo
+ojoh67Zfixnizh8u79Y7dITGzDBRyB0oEX6TBwugbdyVHPxoZxTtnuOMmo9nCIylDwzzaldwiIJD
+uOBajF2pc7gafVSQpg2rZlAwrmoEBQ1u3ZSprcGRjQwRJHo3JsLmhdUtgE6tdJ0Jys0qQAt3nI61
+a7OC4wkhD5yI5/REglN73Hn3jJe2TlPKorR41KMKA/YWGu10Dnw5NADGYlD+NOCWelnOP7QWhdeg
+B1jOiRdksEWHmfCN6wMODgY97NSx+rt6M437QOAiUfuHASeMT3iAUoEwFUOfcXdxuKUtJ5taCO82
+OMRTZpVIotUO2Wrrjl6Z2muXFkmGqtdZo2iW5uAUW6VIfNS8930FClzwcZ8t0wKoydCQw2l0Qs6e
+J3+hbocpq2WNwb2b+0CM1oki44ZkWsF/4FVQToESQEBLgmbBPFTI/In9CSJn56u/7GAPS2hkCLfp
+Li+kYzA0HPP+QCAZdQYEhCADEnZlkTxH1gYpcJizQJ5sw2u5U7gJRqRAzBwDQloGcKeXXnyDTyLc
+dSABRch3lZKF+FIMYPnakvow1f2ncqnJGgydBuQp6HTDiZuKcNIQJ620hM/QfkKC9ieKHDh4Ch6P
+m1x32dwwrc2SgK/u622LFChkSpwMRi6q14YwbgL3ixOnRUMsM4hhKG8gbxvFjDQK7HJr0LDgBoy3
+5u2x9GM3YYF9h2GuXsj1HYR/YZmoWa5CjG87qQv3o7miSxuL7UUyHcAfbwEGo2sPkkx1+gKTLL9j
+kNCDHvZB9yaLWZF5XG6SLCQFpul34i9NBw9LSs/GHX2kaOoIJopZxqN3JQgIbTcegTihJoCgXIZK
+e/1dsHunOLBwufvA85qvjl9ed4k73pXgsZ/+pTq7q8pY4WqlvGgsFLhaXfuNShcmF2dbvWGoN5Qx
+SihzBUGk+PDxs0BCcC51E28fN/WG4RGbe+fkfQzqoNfuJVdrdsQugAhqRWSUo/DxHPlwZB87uT0T
+ewSQRzHMnkUxkDSf/B44+xYKxjicbzNMo7VVBn7g9ddfTXoSoy6SX381uGeUFjH6xH7Y8gTtyLSR
+L3qnbbqUMk7J13A6UVIxa3jHtilGrNAp/NNMdt3jdOLHvDcmo4Hfad6JG83ngOgBUXY+/RViVaXT
+W7dxklJOHtA4PEQ9Z8Jszhz04+NB2o8ypqTAY3k27o2E1NUzWJiQ4/pRdzraLzo1qd+eeNR8ilh1
+UTnQW+jNDpC3Le7u/u2W/V5L/W/SWY8E5M1m0EPAB87B7E7+/58JKyuGppXVqKX1ldyv5w2wB6jD
+HW7OHjekOzRvZi2MM8Fyp8RTFNCnYkNb0pTKw40JgDJnP6MHDi6j3th8U5clb0+SnBeyPMT9urHA
+ahzjaVCRTxfM0XtZISa22YxSo07tRt6nOkOd7LQzCRs/tV9kV7lJkcjsNimhL2iVYfj9hx/Owi4D
+6GGwUz84dx0NlzzcTiHcRzBtqIkTPqYPU+gxXX6/VLVdZZ+gZsvYJCA12bqE7eQdTdzavwb3ZCC8
+/UHeh8WIcLaSs5uJpL1lZFPs6uRg3+BrxMRuOfs1PipeUKESzGSW1kgrdvSwwmxRZzNKx1cS7Lku
+B8XyENox5nTTIo2XYkid55jq0NxI2ZDbuNTeTlHmWIAo6mR+tEzmQv5WxymGkXKxAFxwr0S/inh4
+yniIt7zpzYVpSs7qMqm2QIJY5XqrifbHnYbTLU906CHJuwpMQNwxPxYfcdr4ngk3N+QywaifYMdJ
+YpyHHcxeIHIXPYf3WT7BUSdUxzlmpLrbwPQ4aI+QA4ABAIX5D0Y6U+S/kfTK3c+iNXeJilrSI6Ub
+2ebkcSCU4Qgja/5NP31GdHlrB5bL3Vgu92O5bGO57MVy6WO53I+lKxK4sDZJYiShL1HSzqL3FmS4
+OQ4e5iyerbgd1vdhHR9AFIUJ6IxMcZmrl0nh7SQCQmrb2d+kh02BRcKFg2XOKVcNErkf90x08GgK
+lJ3OVK6hO/NUjM+2q8jE73sURVQONKXuLG/zuIojTy6WaT4FsbXojhsAY9GuN+HcXHY7mXI2sWWp
+Bpf/9en7D++xOYIamN106oaLiIYFpzJ8GpdL1ZWmJtgogB2ppV/3Qd00wIMHZnJ4lAP+7y0VFCDj
+iA1tiOeiAA+Ayn5sM7c4Jgxbz3UVjX7OTM57GydikFWDZlI7iHR6efn29NPpgFJMg/8duAJjaOtL
+h4uPaWEbdP03t7mlOPYBoda5lMb4uXPyaN1wxP021oBtub3PrlsPXjzEYPeGpf4s/62UgiUBQkU6
+2fgYQj04+PlDYUKHPoYRO9Vh7k4OOyv2nSN7joviiH5fmrs9gL+3hjHGBAigXaihiQyaYKql9K15
+3UNRB+gDfb0/HIK1Q692JONT1E6ixwF0KGub7Xb/vH0BNnpKVq/Pvjt/f3H++vL00/eOC4iu3IeP
+Ry/E2Q+fBZUjoAFjnyjGnfgKC1/AsLiHWcQ8h381pjfmdcVJSej19uJC7wys8TgD1reizYngOVfN
+WGico+Gsp32oy10Qo1QHSM65EaoOoXMlGC+t+cyCynUNLB1HmaKzWuvQS58HMueGaBs1AumDxi4p
+GARXNMErqlSuTFRY8o6TPkvTg5S20bYOIaUcVGd32tlvMdl8LzFHneFJ01kr+qvQxTW8jlSRJhDJ
+vQqtLOluWI3RMI5+aDdUGa8+Deh0h5F1Q571TizQar0KeW66/6hhtN9qwLBhsLcw70xSNQLV6GIt
+lQixEe8chPIOvtql12ugYMFwY6nCRTRMl8DsYwiuxSqBAAJ4cgXWF+MEgNBaCT8BfexkB2SOxQDh
+m/X88O+hJojf+pdfeppXZXr4D1FAFCS4ciXsIabb+C0EPpGMxNmHd6OQkaNKUPH3GkvAwSGhLJ8j
+7VQuwzu2k6GS6UKXM/j6AF9oP4Fet7qXsih1937XOEQJeKKG5DU8UYZ+IVYXWdhjnMqoBRqr2y1m
+eErM3fY2nwPxcSXTVBdEn7+9OAPfEQvuUYJ4n+cMhuN8CW7Z6lovPsXWAoUbuvC6RDYu0YWlTf15
+5DXrzcyiyFFvrw7ArhNlP7u9OqnOMk6Ui/YQp82wnJLzCLkZlsOsLHN3txnS2W1GdEfJYcaYXJZU
+NelzBnA0PY05MIKICYv6TbKZ9y6TrDJlcmkyA20KihfU6hhEBUmMJ9eI//KM0715qcyBF3hYbMtk
+uaowpQ6dIyq2x+Y/nH6+OH9P1esvXja+dw+LjikeGHPpwgnWpWHOA764tWbIW5NJH+fqVwgDdRD8
+ab/imogTHqDTj9OL+Kf9ik8cnTjxIM8A1FRdtIUEwwCnW5/0NBLBuNpoGD9u3VmDmQ+GMpJ4wEGX
+F7jz6/KjbdkyKJT9MS8fsVexKDQNh6azWwfV/ug5LgrcXJkP+xvB2z4JM58pdL3pvNlVceV+OrKI
+hx8Bo25rfwxTk9RpqqfjMNsubqHgVlvaXzInY+q0m2UoykDEodt55DJZvyrWzZkDvdrdDjDxjUbX
+SGKvQh/8kg20n+FhYondiVZMRzo7QaYA8xlSHxGpwZNCuwAKhEpOh47kjkdPX3hzdGzC/XPUugss
+5PegCHUBKB0syEvgRPjyG7uP/IrQQlV6LELHX8lkltvqJPxsVuhbPvfn2CsDlMpEsSvjbCmHDGts
+YH7pE3tHIpa0rccxV0mrWkJzN3iodzsYvCsW/bsnBrMWH3Ta3chtWxv51MEGvccPfAhlvAHtXtTV
+kNdq52YBNtdbsMMQkyS/hTvodQ96Ghb6Xb/17OHgh4ll3Etrr1pHW0L7QvuVsxICpkrRZoljhY2H
+6BrmxgaeNFZ4YJ/qihH7u+e8kFPl6sJlFFyo3gwHukEr1B/wyRU+uZdQZXRzsEK/m8tbmebgFkHE
+hYXvv9rC91FkUx29NUF/BoKX28ttP3r0pkHu2BTno+OkCljIKJPVEWLUm5C5B7kGH1z2X3TQEGc3
+5Me++fl8LN68/xH+fy0/QOSD59fG4h+AiXiTlxAB8hlKOtyOpf0Vh3Z5rfCQG0GjzQS+BwBdqkuP
+2rhxoc8c+IcNrBYTWGdZrvnyCUCR50jnihsbbirp4bc56tN1Fo0j17c0A/0SybD7AAQeGjjSLaNV
+tU5RnTupjGZNrwYX52/O3n88i6o75Hbzc+CkOvwqHZyR3sgtcdNqLOyTWY1Prh2/9nuZFj1urY4M
+zWEKjAxFCMFDYaNBvtsgthFAXGJ4L4rtPJ9F2BJ4n89vVRvwc0dOEHivHfaMIMIajvRWV+Ns42Og
+hvilrZcG0JD66DlRT0IonuJBIn4cDfot5VhQ/hn+PL3ZzN30tT4RQhNsY9rMeuh3t6pxxXTW8Fxm
+ItRO7EqYc4JpEqv1dOaeH/uQCX07BSg92o+Qi7hOKyEzEGEKxumaAND97pEvlhPmFrY4dA6K0inp
+Jt4qpyImVmKAow7opDNunFBmD2LlH+IbthB4Fk3UfKgVoBOiFOHkTldVz1Ysxxy0EAF7CgQ2Sfby
+RdghMg/KkeyscTVhnujYMUZLWen584Ph6Op5Y+wpezzzDnzOCrCDLqccgA4tnj59OhD/cb9/wqhE
+aZ7fgOMEsPvCVnFBr3d4FnpydrW6vrd5EwFLzlbyCh5cU5bbPq8zSiHu6UoLIu1fAyPEtQktP5r2
+LUvNybWSN4S5BW8saRPyU5bQHTSYApKocvVVPpgeMgJFLAm6IYzVLElCTifAemzzGs9qYTpQ84u8
+A45PEMwY3+JOFgfDK/QBqbDSco9F50QMCPCACp14NDrsSqeVAM/J5VajOTnPkqo5Z/DM3eTUh7or
+e7WM5isRb1AyzDxaxHCO/Xms2vjA+V4W9WKKfHblJgZbs+TX9+EOrA2Sli8WBlN4aBZplstyZowq
+rlgySyoHjGmHcLgz3ahDBigKelAagIYnwzC3Em3ffmHXxcX0A+33HpqRdJlPZW8p4iROnLWq3aKo
+GZ/SRZaQlm/NlxGM8p7Sz9of8MYSX+jkJxaZe5cpuMfd6kxfksB1Fs3NCQCHLuaxCtKyo6cjnNug
+LHxmWh1uNHcqODXxGEQTbrdJWdVxOtEH+SfouU3sBrjG0x6T2nsA0Pos4Pbn4BAf6pJu8B1MNQzS
+EysyTcn+iVjoJELkHj3yT+kUOfp6Lzw9jqnpZ3wRgKPBseWX5vDKQ1S+OULROX3gYjmm2qNw1K6o
+7LTCfQ5TIm+d7HYc8KghW7B8h31WbPFOHpjWk3lE/0LfkaPLFHBj6tGDp8mUBgv7Co/v76srATH+
+W4OgLBI5P3yiEDvG+Y9C1VAMddxA4REzDOnuCQL5ZWsnzykv5NrfXds3HaBff7UPrKuCewufac/E
+V8v6aJtbidxs2uDnwHrEK3C6UW/MzWFkrZb43CbqEDaI9qy5qVdpH5mB1w+f8p4JP2BHNMTBNHe4
+8rqPVha/faRqGgW/i0q6Vz+t0AnGUtFVzG9QmdXFsQ0V+TBfRmn2oVtAhJ/qpre0Psa7j4jRq5tw
+3/S5/7656xaBnbnZP+vM3T9C49JA993NL300YAddE+JBVbkWo8mfI7pjvbXbn6LSn4W9hZEzVcSD
+GrWxZsl1PHO/Y4HBIV/i6B6HClyQZtVbc+qcD2uzc5eTu9zMm6n43J6QpB3yuWYvNud0pc+Ea64m
+crlUkxhvhJqQD0j1AR3jbryKd3QbkIzV1jgDeOcCgDCsoiu53GJNWHXwM/lmSt5edw7XCxqaitCc
+qjaVzDm2154HgIs4pqf+JnPEZWmDVGI2RtVlUYKzNtD3F/K+b1+pXAPUxJfrWN0Y1E2Psb7ODofg
+YgNzhIozCewAetQBQvDJCudmF67znEzsO+CXZ81R0WRsGUJm9VqWcdXckuDvLyXiW2cEOjiHC+xE
+kI3YtTjFRSyx/OEghTGc/f6ldo4832/P+dCRVWkPZyvqoZMTjzl66ki54ebkzt6S5N7OMadrMSle
+5Ns1hG3WcJ+9GQKWwlz5Q4pQh3T8Vl9DwvfTcc4Jq+ocPgK5d4+t+NWNVmexw2DRcJ65iqF77wSe
+fCRD23edVIcLuhdH+czQjO/rDcssnd2EHY0tFU+4Ra/iaUYbNYEOFiLdE+j4xaaPDHQ8+A8MdPTl
+X2BNND5aH/SWn94TEbGacG/SahgB+kyASLhh0rqHydjDoVvMCeFKcjewl1GyznROiBgzgRzZvWKF
+QPCNWcqtfPNutDHj9kUivnTR4+8uPrw+vSBaTC5P3/zn6Xe0zY9ZvZbNenAkmOWHTO1Dr6zQjQr1
+1mzf4A22PVfTcW28htB539nW6oHQfw6ib0Hbisx9vatDp5682wkQ3z/tFtRdKrsXcsf50rXL7oZs
+q/4v0E+5WMv8cvbWzCOTU2ZxaBLG5n2T49My2kmB7Fo4p2yqq060U6ovM9uRnhnZ4j1aAUztIX/Z
+zJ6pxLb5I3ZU2leEU8UhnmIxNwGAFM6kcyEV3UXFoCr/LvISlF2MOxTsMI7tvZ7UjrOYyl5Yi7sU
+MxkZgnjHSAbd+bnCPpfpDioEASs8fd0SI2L0n877272yJ0pcHdKBtUNUNtf2F66ZdnJ/TnBHrLL3
+liiz5Y27AdB4UafuLpft0+lAzh8lTfOFUyENmu8I6NyIpwL2Rp+JFeJ0K0KIEvVWDhZdER31nUMO
+8mg3HewNrZ6Jw13HmdzjPEI8391w3joxpHu84B7qnh6qNodGHAuMdT+7zimJbwkyZ90FXVTiOR+4
+26Ovx4Svt1fPj23KFvkdX7vXYCDtB45hv2pOBuy9GsvpTbxSjqn+A4uNRm3w1wOHNRdid4DTqXPe
+EQSZ7TiGNPDe99dGmB7enb2DNqKW745hQmL4RI1oUk5luMbdPhl1JtuorC4MLnK/H0ZH+wEohNLv
+m+CHb2MB9fxMx4PTmu4TtA4nHg115IEKHXxe4B7G62uwa3eno2kP6k4l//agADdo855ebxBr9hq4
+lZfo2G0L2jNveGCH7edDfv39nz+gf7ckxnZ/sc+htq1e9h4sYScWi6hw87pFIfM4AusCCnNIahrr
+b42E4+H9howONzVTQ65Ah4/qsvCuUAosyImdaMtvjUHwf71Zz9M=
+""".decode("base64").decode("zlib")
+##file ez_setup.py
+EZ_SETUP_PY = """
+eJzNWmuP28YV/a5fwShYSIJlLt8PGXKRJi5gIEiDPAoU9lY7zxVrilRJyhu1yH/vmeFDJLVU2iIf
+ysDZXXJ45z7PuXekL784nqt9ns3m8/kf87wqq4IcjVJUp2OV52lpJFlZkTQlVYJFs/fSOOcn45lk
+lVHlxqkUw7XqaWEcCftEnsSirB+ax/Pa+PuprLCApScujGqflDOZpEK9Uu0hhByEwZNCsCovzsZz
+Uu2NpFobJOMG4Vy/oDZUa6v8aOSy3qmVv9nMZgYuWeQHQ/xzp+8byeGYF5XScnfRUq8b3lquriwr
+xD9OUMcgRnkULJEJMz6LooQT1N6XV9fqd6zi+XOW5oTPDklR5MXayAvtHZIZJK1EkZFKdIsulq71
+pgyreG6UuUHPRnk6HtNzkj3NlLHkeCzyY5Go1/OjCoL2w+Pj2ILHR3M2+0m5SfuV6Y2VRGEUJ/xe
+KlNYkRy1eU1UtZbHp4LwfhxNlQyzxnnluZx98+5PX/387U+7v7z74cf3f/7O2BpzywyYbc+7Rz//
+8K3yq3q0r6rj5v7+eD4mZp1cZl483TdJUd7flff4r9vtfm7cqV3Mxr8fNu7DbHbg/o6TikDgv3TE
+Fpc3XmNzar8+nh3TNcXT02JjLKLIcRiRsWU7vsUjL6JxHNBQOj4LRMDIYn1DitdKoWFMIuJZrvB8
+y5GURr4QrrRjzw5dn9EJKc5QFz/ww9CPeUQCHknmeVZokZhboRM6PI5vS+l08WAAibgdxNyhIghs
+SVyHBMJ3hCcjZ8oid6gLpa7NLMlCN45J4PphHIc+IzyWPrECO7oppdPFjUjEcJcHgnHHcbxQ2mEs
+Q06CIJaETUjxhroEjuX5xPEE94QtKAtDKSw3JsQTgQyFf1PKxS+MOsSOfOgRccKkpA63oY/lUpfa
+zHtZChvlC3WlQ33fjXmAuIYy9AgPY9uBIBJb0YRFbJwvsIcLDk8GIXe4I6WwPcuK3cCTDvEmIs1s
+a6gMgzscQn3uEsvxA88PEB9mu5FlkdCKrdtiOm38kONFxCimkRWGDvNj4rsk8lyX+JxPeqYW47di
+uPACwiL4Mg5ZFPt+6AhfRD7SUdCIhbfFBJ02kUAlESGtAA5ymAg824M0B0bC4RPRBqgMfeNQIghq
+2HY53kcZOZEIKfGpT6ARF7fFXCLFAzeWMbUgzGOe48Wh5XpcMEcwizmTkbKHvgk8FnvSpTIkIbLQ
+FSxyhUUdhDv0YurcFtP5hkoSO7ZlUY4wcdQEJAnOXQQ+8KwomBAzwhlpWYFHZUCIQ0NuQS141kNi
+W5EdMmcqUCOcCezAjh0hmOtLLxSImh0wHhDbgVQnnJIywhlpRwAogC+XSBXi+DGLIUXaPKRhJCfQ
+io1wRliCh14QOSyOIyppCE9HFrLXQsxDeyrY7jBIhAppB5JzGOb7vu1Fns1C4BePozjwp6SM0Ipa
+NLZdmzBCXceCM4BzofQ85gMoQlvelNJZhCSR2DPgnqTSRUVRGXsBs+AqoJ6YShhvaFGk0BrA7zqM
+05iFDmXSA3w5gXQiIqfQyh9aJEQseWRBHRQkMla6ApjuhwAMHtnBVKT9oUVEAqu4BKvYoWULAeeG
+ICefMhAeCaZQxh/FKOKuDAAIHmOERKHtIXG4G1LGuMt9PiElGFqEgonA8pFtB2CiKPJCByLAmL4X
+o7SngDMYsRvzAyL9kMK/6B5QDYEFQzzPRYH5ZAobgqFF1JERCX0HZA/YpS5I2kKoufAlWgnfnZAS
+juDOQoxkTDhzSWD7wrdtH2WIliICBE7mSzhiAhLJ2PfAAhxYbkkahEza0kEY8MiZqoBwaJEHjiXA
+W4mWAQXouZ5t25KLyLXxL5zSJRp1Q5bqhZwYHok5+EOlIAA8ci3VWFm3pXQWMUrcCNiAnsOLXGap
+nEW2wdkMzDJJA9HQIjt07BAgh0DHnNm+5ccW8SPqCtR57E9FOh5aBN2ZZ6GZsZWHqRcHwmOSCiuC
+rcyainQ8QgYkGRo7cKsbRTwAOhEhrADgxQLXm+rvGimdRVIgtK7wiR1S22EIE/M9m4bgXjC/mGKS
+eMhHjKBsbKlQkziCA5js2AWzhdSPHfQ4kPLrrDcRYLwpZ1Vx3tQD156U+zSh7byF3n0mfmECo8Z7
+feedGomatXjYXzfjQhq7zyRN0O2LHW4todMuwzy4NtQAsNpoAxJptPfVzNiOB/VDdfEEs0WFcUGJ
+0C+ae/FLfRfzXbsMcpqVX2w7KR9a0Q8XeerC3IVp8O1bNZ2UFRcF5rrlYIW65sqkxoJmPrzDFEYw
+hvEvDGP5fV6WCU174x9GOvx9+MNqfiXsrjNz8Gg1+EvpI35JqqVT3y8Q3CLT7qodOhoO9aJmvNqO
+hrl1p9aOklJsewPdGpPiDqPqNi9NdirwW51M3QtcpOS8tf1ZEySMjV+dqvwAPzBMl2eMohm/78zu
+nRSouf5APiGWGJ4/w1VEOQjOU6YdSbWvx/nHRulHo9znp5SraZbUvu5Layfz7HSgojCqPakMDMKd
+YC1LTcCZ8q4hMfV2Sp0yrl8RxuPAEY+GGmmXz/uE7dvdBbRWRxO1PGNxv1iZULL20qPaUsnpHWPs
+RTE4IHlOMHPTSyYIvkZG1gmuVc5y+CMtBOHni/rY473sqafdrrdrzia0mKrRUkujQqvSOESfWLA8
+42Xtm1aNI0GiKKfCI6qskipB6LKn3nlGHfHG/jwT+jyhPhvhtV5wap4qH754PqK0bA4bRCNMn+UU
++Qk7iVqVus6IcRBlSZ5EfcBxKbrHR50vBUlKYfx4LitxePeL8ldWByIzSIV79ckGoQpalPEqBZUx
+9amH2Wao/vlMyl2NQrB/ayyOn552hSjzU8FEuVAIo7Y/5PyUilKdkvQAdPy4rglUHUceNG5bri5I
+olJueymaXl02HhuVYFt261GhXTCgLRITnhVFtbTWapMeyDVA3e30pn+6Q9tjvl0TmJ0G5q2SUQcI
+wD6WNXCQfvgCwncvtYDUd0jz6HqHgWizSa7l/KLx2+38VeOq1ZtGdl+FoYC/1Cu/zjOZJqyCazZ9
+9O9H/r9F+/lP+0v2T+T78u32rlx1tdzWsD7K/JgNAX/OSLaoVEl1JQLMUMd3ukaa4zpVLacsQyqb
+xvepQIa0y6/kqRpSpQwAErCl1VAmRQlHnEpVDgtIOLehN17/3FN+YY7kfcw+ZsuvT0UBaYDzWsBd
+MeKtFVjrksvCJMVT+cF6uM1ZOn5pKYYxQKIPw7nuV9qHUZ0+qFe+hLUayfNPA1Ev5eB01nyToCQS
+elIM/l1e/SkHL9zO55ppXyrr35tuVfGjPAc8+80LpKrLmFxIwUhzVrckGj5rG5KqPiHWLcb/KcnW
+EK0+A2hJ9rc4Vt1Tu14TbI37jxfOnODFvGbDlgwVqbDqRNKLEQ3JDImk/YihANdQB9m6RwqldZ61
+/erW6IHZ67sSvfddqVrveb9wRkfgda5Cbp87lM+MV8MWsSSfBbTfoiWvSeHveZItWwppl9biyoIp
+cbpP/g5s3rbWCqra11GkZVUua7GrjSqwrz7niUqgoyCKL1t1yq4+BniuLp2KHIKUN8rWS2n+NFil
+mnEVl+G76sJK85kU2VL5+fXvd9WfkDTA2iB5+VKW3+mUUJ+cLMVnkak/YM4Rys72Ij2qvu99nW29
+3qNLFTQnKv/VZztL5YoZKGFtAF1m6tYB5ZwJOBKvoA5V5wuEFs8KjwnG2bLUb/c5QCO4OWu2BHQ3
+Pc5lR6jM22w2Z7MlQExslIe1mANhe9Vu8VzUxLRHeKFE9ZwXn5pN18axZpecVqT5XE4hhUaJu3I2
+UygCDzDdtesFkHypxKZyCtGwVd8Ac/V7RhFJsb5KmR7oXjVUOsvWqpquXkNHoZO1StRk2TROqRDH
+N/WP5aj3GmZnC8OaF8u53mLEe7rkGnww8TM/imx5texL4wc0/ffPRVIBfBBj+Fe328DwT2v10eCz
+ip5qF1ihyhDQyPKiOOnkSMVImI57Pz1UF14Jvb7FxPZqPmabGsJhgKkGkuVqqHGNItqaGivW82c6
+hzvxwNR21GN49xKGQTUUbsYQgA02eheW5qVYrq4goqw2Wmj/ecNmLWhBwVT90sLW7D+5FH8fkOlL
+NCyf11OMfeHc97c+NNUc+w6tVbOqJYiXmunRh9G3Oul6eOiw+kriZc3tAUNP6tZ1SzYcIwZThI6Z
+Ko3e7MDywwGGmoMesj3OIc1A1l5NjLSLU3CB9vPqlTpteVjpNH0Wi0KntTAUjf9mqihLlZ9HXKXU
+vuYQLDplmAA/LTuzhg1n0m/czd2u8dZuZ2wxElqmZdqL/3pE+CsAXoOrmotpmacCtToxGrdNP8ik
+buyvGvpCHPLPGm91JOrvPOgJGMxRAXrT38DdUac+2ZI3RfWPYbPSm7z63c71MPgfDHT4eaP/Hk1t
+m+ls/59T8laZdYJ/U8pVNr9Ud225PQxndu1sa4XEh1WK/RE4pjNFPXk5Q9Uuv5MDOvW15jemsDrN
+5z9etUXzdYsoc4DgkyaiQh3/IgnRJF0Sev6CvMXyB7RT8/bbOebxPJw+5/X3bq6/mmKuFs2x5rHj
+p3aEKS/w/LN+aqgSoackrV7X58QQ+aSGu7NC5H4WF838o3qt9ly5E3txiO65L921+lOtWF66ai2k
+5UJNmouCLi7PumNm9e5Dc0QtW1J98ZhadmRXj4A1RX+Yqz/uig3+rYEVGB+aTrNuyNqNTJDvoVyu
+HrqXzRIWd9R5VEPFfF5PCjVJ9x2DCGCErNqJQX+faNveNZ9EVRetur/sT+c73THsdk3Wdy5pZKwN
+7ZY3TUvUOuDN2NgDqTANbqGnWQpSsP1y/jHrfx/oY7b88LdfH16tfp3r9mTVH2P02z0segGxQeT6
+G1mpIRQKfDG/LtIWEWtV8f8PGy3Y1K330l49YAzTjnyln9YPMbri0ebhZfMXz01OyKY96lTvOWAG
+M1o/breL3U4V7G636D4FSZVEqKlr+K2j6bD9+4P9gHdev4az6lLp0VevdrrlzubhJV7UGHGRqRbV
+178BYnMUkw==
+##file distribute_setup.py
+DISTRIBUTE_SETUP_PY = """
+eJztG2tz2zbyu34FTh4PqYSi7TT3GM+pM2nj9DzNJZnYaT8kHhoiIYk1X+XDsvrrb3cBkCAJyc61
+dzM3c7qrIxGLxWLfuwCP/lTs6k2eTabT6Xd5Xld1yQsWxfBvvGxqweKsqnmS8DoGoMnliu3yhm15
+VrM6Z00lWCXqpqjzPKkAFkdLVvDwjq+FU8lBv9h57JemqgEgTJpIsHoTV5NVnCB6+AFIeCpg1VKE
+dV7u2DauNyyuPcaziPEoogm4IMLWecHylVxJ4z8/n0wYfFZlnhrUBzTO4rTIyxqpDTpqCb7/yJ2N
+dliKXxsgi3FWFSKMV3HI7kVZATOQhm6qh98BKsq3WZLzaJLGZZmXHstL4hLPGE9qUWYceKqBuh17
+tGgIUFHOqpwtd6xqiiLZxdl6gpvmRVHmRRnj9LxAYRA/bm+HO7i99SeTa2QX8TekhRGjYGUD3yvc
+SljGBW1PSZeoLNYlj0x5+qgUE8W8vNLfql37tY5Tob+vspTX4aYdEmmBFLS/eUk/Wwk1dYwqI0eT
+fD2Z1OXuvJNiFaP2yeFPVxcfg6vL64uJeAgFkH5Jzy+QxXJKC8EW7F2eCQObJrtZAgtDUVVSVSKx
+YoFU/iBMI/cZL9fVTE7BD/4EZC5s1xcPImxqvkyEN2PPaaiFK4FfZWag90PgqEvY2GLBTid7iT4C
+RQfmg2hAihFbgRQkQeyF/80fSuQR+7XJa1AmfNykIquB9StYPgNd7MDgEWIqwNyBmBTJdwDmmxdO
+t6QmCxEK3OasP6bwOPA/MG4YHw8bbHOmx9XUYccIOIJTMMMhtenPHQXEOviiVqxuhtLJK78qOFid
+C98+BD+/urz22IBp7Jkps9cXb159ensd/HTx8ery/TtYb3rq/8U/ezlthz59fIuPN3VdnJ+cFLsi
+9qWo/LxcnygnWJ1U4KhCcRKddH7pZDq5urj+9OH6/fu3V8GbVz9evB4sFJ6dTScm0Icffwgu3715
+j+PT6ZfJP0XNI17z+U/SHZ2zM/908g786LlhwpN29LiaXDVpysEq2AN8Jv/IUzEvgEL6PXnVAOWl
++X0uUh4n8snbOBRZpUBfC+lACC8+AIJAgvt2NJlMSI2Vr3HBEyzh35m2AfEAMSck5ST3LodpsE4L
+cJGwZe1N/PQuwu/gqXEc3Ia/5WXmOhcdEtCB48rx1GQJmCdRsI0AEYh/LepwGykMrZcgKLDdDcxx
+zakExYkI6cL8vBBZu4sWJlD7UFvsTfbDJK8EhpfOINe5IhY33QaCFgD8idw6EFXweuP/AvCKMA8f
+JqBNBq2fT29m441ILN1Ax7B3+ZZt8/LO5JiGNqhUQsMwNMZx2Q6y161uOzPTnWR53XNgjo7YsJyj
+kDsDD9ItcAU6CqEf8G/BZbFtmcPXqCm1rpjJiW8sPMAiBEEL9LwsBRcNWs/4Mr8XetIqzgCPTRWk
+5sy0Ei+bGB6I9dqF/zytrPAlD5B1/9fp/wGdJhlSLMwYSNGC6LsWwlBshO0EIeXdcWqfjs9/xb9L
+9P2oNvRojr/gT2kgeqIayh3IqKa1qxRVk9R95YGlJLCyQc1x8QBLVzTcrVLyGFLUy/eUmrjO93mT
+RDSLOCVtZ71GW1FWEAHRKod1VTrstVltsOSV0BszHkci4Tu1KrJyqAYK3unC5Py4mhe748iH/yPv
+rIkEfI5ZRwUGdfUDIs4qBx2yPDy7mT2dPcosgOB2L0bGvWf/+2gdfPZwqdOrRxwOAVLOhuSDPxRl
+7Z56rJO/yn77dY+R5C911acDdEDp94JMQ8p7UGOoHS8GKdKAAwsjTbJyQ+5ggSrelBYmLM7+7IFw
+ghW/E4vrshGtd005mXjVQGG2peSZdJQvqzxBQ0VeTLolDE0DEPzXNbm35VUguSTQmzrF3ToAk6Ks
+raIkFvmb5lGTiAorpS/tbpyOK0PAsSfu/TBE01uvDyCVc8MrXtel2wMEQwkiI+hak3CcrThoz8Jp
+qF8BD0GUc+hqlxZiX1nTzpS59+/xFvuZ12OGr8p0d9qx5NvF9LlabWYha7iLPj6VNn+fZ6skDuv+
+0gK0RNYOIXkTdwb+ZCg4U6vGvMfpEOogI/G3JRS67ghiek2enbYVmT0Hozfjfrs4hoIFan0UNL+H
+dJ0qmS/ZdIwPWykhz5wa601l6oB5u8E2AfVXVFsAvpVNhtHFZx8SAeKx4tOtA87SvERSQ0zRNKGr
+uKxqD0wT0FinO4B4p10Om38y9uX4Fvgv2ZfM/b4pS1gl2UnE7LicAfKe/xc+VnGYOYxVWQotrt0X
+/TGRVBb7AA1kA5Mz7PvzwE/c4BSMzNTYye/2FbNfYw1PiiH7LMaq1202A6u+y+s3eZNFv9toHyXT
+RuIo1TnkroKwFLwWQ28V4ObIAtssCsPVgSj9e2MWfSyBS8Ur5YWhHn7dtfhac6W42jYSwfaSPKTS
+hdqcivFxLTt3GVTyMim8VbTfsmpDmdkS25H3PIl72LXlZU26FCVYNCdTbr0C4cL2HyW91DFp+5Cg
+BTRFsNseP24Z9jhc8BHhRq8uskiGTezRcuacODOf3Uqe3OKKvdwf/IsohU4h236XXkVEvtwjcbCd
+rvZAHdYwzyLqdRYcA/1SrNDdYFszrBuedB1X2l+NlVTtazH8RxKGXiwioTYlVMFLikIC29yq31wm
+WFZNDGu0xkoDxQvb3Hr9W4DqgK2fXnLsYxm2/g0doJK+bGqXvVwVBcmet1hk/sfvBbB0TwquQVV2
+WYaIDvalWquGtQ7yZol2do48f3Wfx6jVBVpu1JLTZTijkN4WL631kI+vph5uqe+yJVGKS+5o+Ih9
+FDw6odjKMMBAcgaksyWY3J2HHfYtKiFGQ+laQJPDvCzBXZD1DZDBbkmrtb3EeNZRC4LXKqw/2JTD
+BKEMQR94NMioJBuJaMksj023y+kISKUFiKwbG/lMJQlYy5JiAAG6RB/AA35LuINFTfiuc0oShr0k
+ZAlKxqoSBHddgfda5g/uqslC9GbKCdKwOU7tVY89e3a3nR3IimXzv6tP1HRtGK+1Z7mSzw8lzENY
+zJmhkLYly0jtfZzLVtKozW5+Cl5Vo4HhSj6uA4IeP28XeQKOFhYw7Z9X4LELlS5YJD0hsekmvOEA
+8OR8fjhvvwyV7miN6In+UW1Wy4zpPswgqwisSZ0d0lR6U2+VohNVAfoGF83AA3cBHiCru5D/M8U2
+Ht41BXmLlUysRSZ3BJFdByTyluDbAoVDewREPDO9BnBjDLvQS3ccOgIfh9N2mnmWntarPoTZLlW7
+7rShm/UBobEU8PUEyCYxNgTkDIhimc+ZmwBD2zq2YKncmuadPRNc2fwQ6fbEEAOsZ3oXY0T7JjxU
+1myzCk27uCHvDR4rVKM9SwSZ2OrIjE8hyjr++7ev/eMKj7TwdNTHP6PO7kdEJ4MbBpJc9hQliRqn
+avJibYs/Xduo2oB+2BKb5veQLINpBGaH3C0SHooNKLvQnepBGI8r7DWOwfrUf8ruIBD2mu+QeKk9
+GHP369cK646e/8F0VF8IMBrBdlKAanXa7Kt/XZzrmf2YZ9gxnGNxMHT3evGRt1yC9O9Mtqz65VHH
+ga5DSim8eWhurjtgwGSkBSAn1AKRCHkkmzc1Jr3oPbZ819mcrnOGCZvBHo9J1VfkDySq5huc6Jy5
+shwgO+jBSlfViyCjSdIfqhkes5xXqs624ujIt3fcAFPgQxflsT41VmU6AsxblojaqRgqfut8h/xs
+FU3xG3XNNVt43qD5p1r4eBMBvxrc0xgOyUPB9I7Dhn1mBTKodk1vM8Iyjuk2vQSnKhv3wFZNrOLE
+nja6c9Vd5ImMNoEz2EnfH+/zNUPvvA9O+2q+gnS6PSLG9RVTjACGIO2NlbZt3dpIx3ssVwADnoqB
+/09TICLIl7+43YGjr3vdBZSEUHfJyPZYl6Hn3CTdXzOl53JNckElLcXUY27YImzNHN1YGLsg4tTu
+nngEJqcilfvkUxNZEXYbVZHYsCJ1aFN1fhAW+NLTOXffVQFP0vYVTm9Aysj/aV6OHaDV80jwA35n
+6MO/R/nLSD6a1aVErYM8nBZZ3ScB7E+RJKvqNifazypDRj5McIZJyWAr9cbgaLcV9fixrfTIMDpl
+Q3k9vr/HTGzoaR4Bn/Xy+TbodTndkQolEIHCO1SlGH/Z8uu9Cioz4IsffpijCDGEgDjl969Q0HiU
+wh6Ms/tiwlPjquHbu9i6J9kH4tO7lm/9RwdZMXvEtB/l3H/FpgxW9MoOpS32ykMNav2Sfco2oo2i
+2Xeyj7k3nFlO5hRmatYGRSlW8YOrPX0XXNogR6FBHUpC/X1vnPcbe8Pf6kKdBvysv0CUjMSDETaf
+n53ftFkUDXr62p3ImlSUXF7IM3snCCpvrMp8az4vYa/yHoTcxDBBh00ADh/WLOsK28yoxAsMIxKP
+pTFT54WSDM0skrh2HVxn4cw+zwencwYLNPvMxRSu4RGRpApLQ0mF9cA1Ac2Utwi/lfyx95B65Faf
+CfK5hcqvpbSjEZjbVKJ06GihuxyrjgqxjWvt2NhWaWdbDENq5EhVh8p+FXI6UDTOHfX1SJvt7j0Y
+P9ShOmJb4YBFhUCCJcgb2S0opHGrJ8qFZEolRIrnDObx6LhLQj+3aC79UkHdO0I2jDdkxCFMTGHy
+tvIxa+uf6fsf5XkvJtvgFUtwRr3yxJ64D7SFYj5iWJAbVx5Xce56V4gR37BVaRwkvfpw+QcTPuuK
+wCFCUMi+Mpq3ucx3C8ySRBbmdtEcsUjUQt2aw+CNJ/FtBERNjYY5bHsMtxiS5+uhoT6b7zwYRY9c
+GrRbt0Msqyhe0KGC9IWokOQL4wcitijz+zgSkXz9IV4pePNFi8poPkTqwl3qdYcauuNoVhz9wGGj
+zC4FhQ0Y6g0JBkTyLMR2D3SsrfJGONCygfpjf43SS8PAKqUcK/O6ntqSZRO+yCIVNOjO2J5NZXN5
+m68TXo8OtO/9fTSrVPVkRRrgsHlYS1PFuPC5n6R9GZOFlMMJlCLR3Zd/os71uxFfkYPuTUIPNJ8H
+vOnPG7efTd1oj+7QrOl8Wbo/Ous1/H0mhqLtZ/+/V54Deum0MxNGwzzhTRZuuhSuezKMlB/VSG/P
+GNrYhmNrC99IkhBU8Os3WiRUERcs5eUdnuXnjNMBLO8mLJvWeNpU7/ybG0wXPjvz0LyRTdkZXrFJ
+xFy1AObigd5fgpx5nvIMYnfk3BghTmM8vWn7Adg0MxPMz/03Lm7Y83baROOg+znWl2la7hmXkiuR
+rGTjfDH1px5LBV4cqBYYU7qTGXWRmg6CFYQ8ZqRLACVwW7IWf4byipG+R6z3111oQJ+M73rl2wyr
+6jSP8K0w6f+x2U8AhSjTuKroNa3uyE4jiUEJqeEFMo8qn93iBpz2Ygi+ogVIV4IIGV2jBkIVB+Ar
+TFY7ctATy9SUJ0REiq/c0WUR4CeRTA1AjQd77EqLQWOXO7YWtcLlzvo3KFRCFubFzvwNhRhk/OpG
+oGSovE6uARTju2uDJgdAH27avECLZZQP6AGMzclq0lYfsBL5Q4goCqRXOath1f8e+KUjTViPHnWh
+peIrgVIVg2P9DtLnBVSgkavW6LsyTdeCuOXjn4OAeJ8M+zYvX/6NcpcwTkF8VDQBfad/PT01krFk
+5SvRa5xS+duc4qNAaxWsQu6bJJuGb/b02N+Z+8JjLw0OoY3hfFG6gOHMQzwvZtZyIUwLgvGxSSAB
+/e50asg2ROpKzHaAUlLv2o4eRojuxG6hFdDH435QX6TZQQKcmccUNnl1WDMIMje66AG4WgturRZV
+l8SBqdyQeQOlM8Z7RNI5oLWtoQXeZ9Do7JykHG6AuE7GCu9sDNjQ+eITAMMN7OwAoCoQTIv9N269
+ShXFyQlwP4Eq+GxcAdON4kF1bbunQMiCaLl2QQmnyrXgm2x44UnocJDymGrue4/tueTXBYLLQ6+7
+kgpc8GqnoLTzO3z9X8X44cttQFxM918weQqoIg8CJDUI1LuURHcbNc/Ob2aTfwH3muVf
+##file activate.sh
+ACTIVATE_SH = """
+eJytVU1v4jAQPW9+xTT0ANVS1GsrDlRFAqmFqmG72m0rY5IJsRRslDiktNr/vuMQ8tFQpNU2B4I9
+H36eeW/SglkgYvBFiLBKYg0LhCRGD1KhA7BjlUQuwkLIHne12HCNNpz5kVrBgsfBmdWCrUrA5VIq
+DVEiQWjwRISuDreW5eE+CtodeLeAnhZEGKMGFXqAciMiJVcoNWx4JPgixDjzEj48QVeCfcqmtzfs
+cfww+zG4ZfeD2ciGF7gCHaDMPM1jtvuHXAsPfF2rSGeOxV4iDY5GUGb3xVEYv2aj6WQ0vRseAlMY
+G5DKsAawwnQUXt2LQOYlzZoYByqhonqoqfxZf4BLD97i4DukgXADCPgGgdOLTK5arYxZB1xnrc9T
+EQFcHoZEAa1gSQioo/TPV5FZrDlxJA+NzwF+Ek1UonOzFnKZp6k5mgLBqSkuuAGXS4whJb5xz/xs
+wXCHjiVerAk5eh9Kfz1wqOldtVv9dkbscfjgjKeTA8XPrtaNauX5rInOxaHuOReNtpFjo1/OxdFG
+5eY9hJ3L3jqcPJbATggXAemDLZX0MNZRYjSDH7C1wMHQh73DyYfTu8a0F9v+6D8W6XNnF1GEIXW/
+JrSKPOtnW1YFat9mrLJkzLbyIlTvYzV0RGXcaTBfVLx7jF2PJ2wyuBsydpm7VSVa4C4Zb6pFO2TR
+huypCEPwuQjNftUrNl6GsYZzuFrrLdC9iJjQ3omAPBbcI2lsU77tUD43kw1NPZhTrnZWzuQKLomx
+Rd4OXM1ByExVVkmoTwfBJ7Lt10Iq1Kgo23Bmd8Ib1KrGbsbO4Pp2yO4fpnf3s6MnZiwuiJuls1/L
+Pu4yUCvhpA+vZaJvWWDTr0yFYYyVnHMqCEq+QniuYX225xmnzRENjbXACF3wkCYNVZ1mBwxoR9Iw
+WAo3/36oSOTfgjwEEQKt15e9Xpqm52+oaXxszmnE9GLl65RH2OMmS6+u5acKxDmlPgj2eT5/gQOX
+LLK0j1y0Uwbmn438VZkVpqlfNKa/YET/53j+99G8H8tUhr9ZSXs2
+##file activate.fish
+ACTIVATE_FISH = """
+eJydVm1v4jgQ/s6vmA1wBxUE7X2stJVYlVWR2lK13d6d9laRk0yIr8HmbIe0++tvnIQQB9pbXT5A
+Ys/LM55nZtyHx5RrSHiGsMm1gRAh1xhDwU0Kng8hFzMWGb5jBv2E69SDs0TJDdj3MxilxmzPZzP7
+pVPMMl+q9bjXh1eZQ8SEkAZULoAbiLnCyGSvvV6SC7IoBcS4Nw0wjcFbvJDcjiuTswzFDpiIQaHJ
+lQAjQUi1YRmUboC2uZJig8J4PaCnT5IaDcgsbm/CjinOwgx1KcUTMEhhTgV4g2B1fRk8Le8fv86v
+g7v545UHpZB9rKnp+gXsMhxLunIIpwVQxP/l9c/Hq9Xt1epm4R27bva6AJqN92G4YhbMG2i+LB+u
+grv71c3dY7B6WtzfLy9bePbp0taDTXSwJQJszUnnp0y57mvpPcrF7ZODyhswtd59+/jdgw+fwBNS
+xLSscksUPIDqwwNmCez3PpxGeyBYg6HE0YdcWBxcKczYzuVJi5Wu915vn5oWePCCoPUZBN5B7IgV
+MCi54ZDLG7TUZ0HweXkb3M5vFmSpFm/gthhBx0UrveoPpv9AJ9unIbQYdUoe21bKg2q48sPFGVwu
+H+afrxd1qvclaNlRFyh1EQ2sSccEuNAGWQwysfVpz1tPajUqbqJUnEcIJkWo6OXDaodK8ZiLdbmM
+L1wb+9H0D+pcyPSrX5u5kgWSygRYXCnJUi/KKcuU4cqsAyTKZBiissLc7NFwizvjxtieKBVCIdWz
+fzilzPaYyljZN0cGN1v7NnaIPNCGmVy3GKuJaQ6iVjE1Qfm+36hglErwmnAD8hu0dDy4uICBA8ZV
+pQr/q/+O0KFW2kjelu9Dgb9SDBsWV4F4x5CswgS0zBVlk5tDMP5bVtUGpslbm81Lu2sdKq7uNMGh
+MVQ4fy9xhogC1lS5guhISa0DlBWv0O8odT6/LP+4WZzDV6FzIkEqC0uolGZSZoMnlpxplmD2euaT
+O4hkTpPnbztDccey0bhjDaBIqaWQa0uwEtQEwtyU56i4fq54F9IE3ORR6mKriODM4XOYZwaVYLYz
+7SPbKkz4i7VkB6/Ot1upDE3znNqYKpM8raa0Bx8vfvntJ32UENsM4aI6gJL+jJwhxhh3jVIDOcpi
+m0r2hmEtS8XXXNBk71QCDXTBNhhPiHX2LtHkrVIlhoEshH/EZgdq53Eirqs5iFKMnkOmqZTtr3Xq
+djvPTWZT4S3NT5aVLgurMPUWI07BRVYqkQrmtCKohNY8qu9EdACoT6ki0a66XxVF4f9AQ3W38yO5
+mWmZmIIpnDFrbXakvKWeZhLwhvrbUH8fahhqD0YUcBDJjEBMQwiznE4y5QbHrbhHBOnUAYzb2tVN
+jJa65e+eE2Ya30E2GurxUP8ssA6e/wOnvo3V78d3vTcvMB3n7l3iX1JXWqk=
+##file activate.csh
+ACTIVATE_CSH = """
+eJx9U11vmzAUffevOCVRu+UB9pws29Kl0iq1aVWllaZlcgxciiViItsQdb9+xiQp+dh4QOB7Pu49
+XHqY59IgkwVhVRmLmFAZSrGRNkdgykonhFiqSCRW1sJSmJg8wCDT5QrucRCyHn6WFRKhVGmhKwVp
+kUpNiS3emup3TY6XIn7DVNQyJUwlrgthJD6n/iCNv72uhCzCpFx9CRkThRQGKe08cWXJ9db/yh/u
+pvzl9mn+PLnjj5P5D1yM8QmXlzBkSdXwZ0H/BBc0mEo5FE5qI2jKhclHOOvy9HD/OO/6YO1mX9vx
+sY0H/tPIV0dtqel0V7iZvWyNg8XFcBA0ToEqVeqOdNUEQFvN41SumAv32VtJrakQNSmLWmgp4oJM
+yDoBHgoydtoEAs47r5wHHnUal5vbJ8oOI+9wI86vb2d8Nrm/4Xy4RZ8R85E4uTZPB5EZPnTaaAGu
+E59J8BE2J8XgrkbLeXMlVoQxznEYFYY8uFFdxsKQRx90Giwx9vSueHP1YNaUSFG4vTaErNSYuBOF
+lXiVyXa9Sy3JdClEyK1dD6Nos9mEf8iKlOpmqSNTZnYjNEWiUYn2pKNB3ttcLJ3HmYYXy6Un76f7
+r8rRsC1TpTJj7f19m5sUf/V3Ir+x/yjtLu8KjLX/CmN/AcVGUUo=
+##file activate.bat
+ACTIVATE_BAT = """
+eJyFUkEKgzAQvAfyhz0YaL9QEWpRqlSjWGspFPZQTevFHOr/adQaU1GaUzI7Mzu7ZF89XhKkEJS8
+qxaKMMsvboQ+LxxE44VICSW1gEa2UFaibqoS0iyJ0xw2lIA6nX5AHCu1jpRsv5KRjknkac9VLVug
+sX9mtzxIeJDE/mg4OGp47qoLo3NHX2jsMB3AiDht5hryAUOEifoTdCXbSh7V0My2NMq/Xbh5MEjU
+ZT63gpgNT9lKOJ/CtHsvT99re3pX303kydn4HeyOeAg5cjf2EW1D6HOPkg9NGKhu
+##file deactivate.bat
+DEACTIVATE_BAT = """
+eJxzSE3OyFfIT0vj4spMU0hJTcvMS01RiPf3cYkP8wwKCXX0iQ8I8vcNCFHQ4FIAguLUEgWIgK0q
+FlWqXJpcICVYpGzx2BAZ4uHv5+Hv6wq1BWINXBTdKriEKkI1DhW2QAfhttcxxANiFZCBbglQSJUL
+i2dASrm4rFz9XLgAwJNbyQ==
+##file distutils-init.py
+DISTUTILS_INIT = """
+eJytV92L4zYQf9dfMU0ottuse/TeFkKh3MvC0Ydy0IdlMVpbTtR1JCMpm+T++s5Y/pBs53oPZ1hQ
+pPnSb34zo5WnVhsH2jLpV/Y2Li/cKKkOFoYN3Za6ErAdFtKC0g44vEvjzrwR6h1Oujo3YgdWw0VA
+yRWcLUo6cBpqqSpwRwHWVY18ZRB9W3jq3HDlfoIvqK7NG2gF7a297VANvZ3O1sGrQI/eDe5yB0ZY
+WQkLUpHxhVX09NDe3FGr31BL1lJUD9f8ln+FShpROm1ujOFS8ZOAPUKRt9wd836Hjqw7O9nYgvYD
+iX+1VOlMPPXQ5EVRy0YURbaDZDSQZEzWo7rS5kSLNHaQwX4RRLrQGe1nj92Fh1zltEhHDDZfEO0g
+O6MraHn5xg8IpYOfLfC2FdxYShLC64EES4A0uuROYhq49Zs368RpMvTHJmOiscKHUXRXKIpcKiuM
+Sz/sYHa7TkxcRYkkEhN8HZaxKCJXFFJJh+baW5JluRG8SjM20JHEA9qWWtXywBjbbvF2rjzC61k2
+VSGuDibTUGlhVeLgTekLHPEP73wQrrscUsUGrPCGjkTCC1JXXyw8EJWP3FSUZY8IiSCCRp97dnfO
+RUUx5a0RtbxSzLX/3XBXYxIpyQka/fh74pGrjQ5QzUt9OnFV5dMV+otOG5gQjctxozNTNtzaSSiN
+JHqu0FeJmsqRN/KrKHRLGbaQWtHUgRB9FDfu5giN4eZWIDqWCv8vrcTjrNZgRXQPzy+RmGjQpLRI
+EKz0UqQLlR28ciusM8jn7PtcLPZy2zbSDeyyos0iO+ybBgPyRvSk/CEFm8IndQebz8iXTRbbjhDP
+5xh7iJfBrKd/Nenjj6Jvgp2B+W7AnP102BXH5IZWPV3tI2MUOvXowpdS12IIXhLLP0lKyeuZrpEv
+pFhPqHg3JFTd1cceVp0EsPgGU0wFO2u4iyYRoFYfEm9kG/RZcUUBm87t9mFtx9iCtC9kx4Rt4R8a
+OdgzSt40vtyFecAZZ8BfCOhCrC8djMGPFaz2Vlt5TSZCk053+37wbLDLRXfZ+F45NtdVpVWdudSC
+xgODI8EsiLoTl5aO0lhoigX7GHZDHAY4LxoMIu1gXPYPksmFquxF4uRKZhEnKzXu82HESb+LlNQz
+Fh/RvFJVuhK+Ee5slBdj30FcRGdJ5rhKxtkyKxWcGoV/WOCYKqkNDYJ5fNQVx3g400tpJBS2FSU+
+Tco9ss8nZ08dtscGQfSby87b73fOw+4UgrEMNnY6uMzYvSDxPVPpsij6+l0/ZPfuH0Iz010giY34
+HpL0ZLyLJB4ukaQRU+GwptO7yIZCQE33B0K9iCqO6X+AR4n7wAeH68DPkJzpTsD3x+/cj9LIVHC2
+An1wmv7CzWHoqR02vb0VL73siP+3nkX0YbQ0l9f6WDyOm24cj3rxO2MMip6kpcu6VCefn/789PR3
+0v0fg21sFIp70rj9PCi8YDRDXFucym/43qN+iENh1Jy/dIIIqF3OIkDvBMsdx+huWv8Kz73vl8g5
+WQ3JOGqwu3lb4dfKKbvLigXDQsb8B/xt39Q=
+##file distutils.cfg
+DISTUTILS_CFG = """
+eJxNj00KwkAMhfc9xYNuxe4Ft57AjYiUtDO1wXSmNJnK3N5pdSEEAu8nH6lxHVlRhtDHMPATA4uH
+xJ4EFmGbvfJiicSHFRzUSISMY6hq3GLCRLnIvSTnEefN0FIjw5tF0Hkk9Q5dRunBsVoyFi24aaLg
+9FDOlL0FPGluf4QjcInLlxd6f6rqkgPu/5nHLg0cXCscXoozRrP51DRT3j9QNl99AP53T2Q=
+##file activate_this.py
+ACTIVATE_THIS = """
+eJyNUlGL2zAMfvevEBlHEujSsXsL9GGDvW1jD3sZpQQ3Ua7aJXawnbT595Ocpe0dO5ghseVP+vRJ
+VpIkn2cYPZknwAvWLXWYhRP5Sk4baKgOWRWNqtpdgTyH2Y5wpq5Tug406YAgKEzkwqg7NBPwR86a
+Hk0olPopaK0NHJHzYQPnE5rI0o8+yBUwiBfyQcT8mMPJGiAT0A0O+b8BY4MKJ7zPcSSzHaKrSpJE
+qeDmUgGvVbPCS41DgO+6xy/OWbfAThMn/OQ9ukDWRCSLiKzk1yrLjWapq6NnvHUoHXQ4bYPdrsVX
+4lQMc/q6ZW975nmSK+oH6wL42a9H65U6aha342Mh0UVDzrD87C1bH73s16R5zsStkBZDp0NrXQ+7
+HaRnMo8f06UBnljKoOtn/YT+LtdvSyaT/BtIv9KR60nF9f3qmuYKO4//T9ItJMsjPfgUHqKwCZ3n
+xu/Lx8M/UvCLTxW7VULHxB1PRRbrYfvWNY5S8it008jOjcleaMqVBDnUXcWULV2YK9JEQ92OfC96
+1Tv4ZicZZZ7GpuEpZbbeQ7DxquVx5hdqoyFSSmXwfC90f1Dc7hjFs/tK99I0fpkI8zSLy4tSy+sI
+3vMWehjQNJmE5VePlZbL61nzX3S93ZcfDqznnkb9AZ3GWJU=
+if __name__ == '__main__':
+    main()
+## TODO:
+## Copy python.exe.manifest
+## Monkeypatch distutils.sysconfig
Property changes on: usertools/swift-vm-boot/futuregrid/bin/virtualenv.py
___________________________________________________________________
Added: svn:executable
Added: usertools/swift-vm-boot/futuregrid/env.sh
--- usertools/swift-vm-boot/futuregrid/env.sh	                        (rev 0)
+++ usertools/swift-vm-boot/futuregrid/env.sh	2011-12-16 18:38:06 UTC (rev 5425)
@@ -0,0 +1,9 @@
+export FUTUREGRID_IAAS_ACCESS_KEY=XXXX
+export FUTUREGRID_IAAS_SECRET_KEY=XXXXXXXXX
+export EC2_ACCESS_KEY=$FUTUREGRID_IAAS_ACCESS_KEY
+export EC2_SECRET_KEY=$FUTUREGRID_IAAS_SECRET_KEY
+export EC2_URL=https://s83r.idp.sdsc.futuregrid.org:8444
+export FUTUREGRID_SIERRA_NODES=2
Added: usertools/swift-vm-boot/futuregrid/hosts.txt
--- usertools/swift-vm-boot/futuregrid/hosts.txt	                        (rev 0)
+++ usertools/swift-vm-boot/futuregrid/hosts.txt	2011-12-16 18:38:06 UTC (rev 5425)
@@ -0,0 +1 @@
+s83r.idp.sdsc.futuregrid.org
Added: usertools/swift-vm-boot/futuregrid/install.sh
--- usertools/swift-vm-boot/futuregrid/install.sh	                        (rev 0)
+++ usertools/swift-vm-boot/futuregrid/install.sh	2011-12-16 18:38:06 UTC (rev 5425)
@@ -0,0 +1,28 @@
+#!/bin/bash
+cd `dirname $0`
+source env.sh
+python bin/virtualenv.py ve
+if [ $? -ne 0 ]; then
+    echo "Failed to created the needed python virtual environment"
+    exit 1
+fi
+source ve/bin/activate
+easy_install cloudinitd
+    echo "Failed to install cloudinitd"
+    exit 1
+fi
+echo "Registering the key names in all the clouds"
+python bin/register_key.py hosts.txt
+    echo "Failed to register the key names"
+    exit 1
+fi
+echo "Success!"
+echo ""
+echo 0
Property changes on: usertools/swift-vm-boot/futuregrid/install.sh
Added: usertools/swift-vm-boot/futuregrid/plan/test-level1.conf
--- usertools/swift-vm-boot/futuregrid/plan/test-level1.conf	                        (rev 0)
+++ usertools/swift-vm-boot/futuregrid/plan/test-level1.conf	2011-12-16 18:38:06 UTC (rev 5425)
@@ -0,0 +1,12 @@
+[svc-sierra]
+replica_count: env.FUTUREGRID_SIERRA_NODES
+iaas_key: env.FUTUREGRID_IAAS_ACCESS_KEY
+iaas_secret: env.FUTUREGRID_IAAS_SECRET_KEY
+sshkeyname: swiftkey
+localsshkeypath: ~/.ssh/id_rsa.pub
+iaas_url: https://s83r.idp.sdsc.futuregrid.org:8444
+image: debian-lenny.gz
+iaas: nimbus
+ssh_username: root
Added: usertools/swift-vm-boot/futuregrid/plan/top.conf
--- usertools/swift-vm-boot/futuregrid/plan/top.conf	                        (rev 0)
+++ usertools/swift-vm-boot/futuregrid/plan/top.conf	2011-12-16 18:38:06 UTC (rev 5425)
@@ -0,0 +1,10 @@
+# This is a sample top level configuration file.  Each entry under runlevels
+# is a file with a single runlevel description.  All of the services in that
+# file are run at the same time but the next level is not begun until
+# all of these services in the previous successfully complete.
+[defaults]
+[runlevels]
+level1: test-level1.conf
Copied: usertools/swift-vm-boot/gp/ec2.template.conf (from rev 5424, usertools/swift-gp-boot/ec2.template.conf)
--- usertools/swift-vm-boot/gp/ec2.template.conf	                        (rev 0)
+++ usertools/swift-vm-boot/gp/ec2.template.conf	2011-12-16 18:38:06 UTC (rev 5425)
@@ -0,0 +1,17 @@
+[general]
+domains: swift
+deploy: ec2
+[domain-swift]
+users: swift
+nfs-nis: yes
+lrm: none
+cluster-nodes: _CLUSTER-NODES_
+[ec2]
+ami: _AMI_
+instance-type: _INSTANCE-TYPE_
+keypair: _KEYPAIR_
+keyfile: _KEYFILE_
+username: ubuntu
Copied: usertools/swift-vm-boot/gp/globus-provision-0.3.2.tar.gz (from rev 5424, usertools/swift-gp-boot/globus-provision-0.3.2.tar.gz)
(Binary files differ)
Copied: usertools/swift-vm-boot/gp/install.sh (from rev 5424, usertools/swift-gp-boot/install.sh)
--- usertools/swift-vm-boot/gp/install.sh	                        (rev 0)
+++ usertools/swift-vm-boot/gp/install.sh	2011-12-16 18:38:06 UTC (rev 5425)
@@ -0,0 +1,8 @@
+#!/bin/bash
+tar xvfz globus-provision-0.3.2.tar.gz
+cd globus-provision-0.3.2
+python setup.py install --user
+cd ..
+ln -s ~/.local/bin
+ln -s ~/.local/lib
Deleted: usertools/swift-vm-boot/hosts.txt
--- usertools/swift-vm-boot/hosts.txt	2011-12-16 18:28:15 UTC (rev 5424)
+++ usertools/swift-vm-boot/hosts.txt	2011-12-16 18:38:06 UTC (rev 5425)
@@ -1 +0,0 @@
-s83r.idp.sdsc.futuregrid.org
Deleted: usertools/swift-vm-boot/install.sh
--- usertools/swift-vm-boot/install.sh	2011-12-16 18:28:15 UTC (rev 5424)
+++ usertools/swift-vm-boot/install.sh	2011-12-16 18:38:06 UTC (rev 5425)
@@ -1,28 +0,0 @@
-#!/bin/bash
-cd `dirname $0`
-source env.sh
-python bin/virtualenv.py ve
-if [ $? -ne 0 ]; then
-    echo "Failed to created the needed python virtual environment"
-    exit 1
-fi
-source ve/bin/activate
-easy_install cloudinitd
-    echo "Failed to install cloudinitd"
-    exit 1
-fi
-echo "Registering the key names in all the clouds"
-python bin/register_key.py hosts.txt
-    echo "Failed to register the key names"
-    exit 1
-fi
-echo "Success!"
-echo ""
-echo 0
