[Swift-commit] r5378 - wwwdev/js
vytas at ci.uchicago.edu vytas at ci.uchicago.edu
Thu Dec 8 09:56:16 CST 2011
Author: vytas
Date: 2011-12-08 09:54:46 -0600 (Thu, 08 Dec 2011)
New Revision: 5378
Modified:
   wwwdev/js/jquery.orbit-1.2.3.min.js
Log:
changed rotator speed from 600ms to 900ms
Modified: wwwdev/js/jquery.orbit-1.2.3.min.js
--- wwwdev/js/jquery.orbit-1.2.3.min.js	2011-12-08 15:30:37 UTC (rev 5377)
+++ wwwdev/js/jquery.orbit-1.2.3.min.js	2011-12-08 15:54:46 UTC (rev 5378)
@@ -6,7 +6,7 @@
  * http://www.opensource.org/licenses/mit-license.php
-(function(d){d.fn.orbit=function(a){a=d.extend({animation:"horizontal-push",animationSpeed:600,timer:!0,advanceSpeed:4E3,pauseOnHover:!1,startClockOnMouseOut:!1,startClockOnMouseOutAfter:1E3,directionalNav:!0,captions:!0,captionAnimation:"fade",captionAnimationSpeed:600,bullets:!1,bulletThumbs:!1,bulletThumbLocation:"",afterSlideChange:function(){}},a);return this.each(function(){function q(){if(!a.timer||a.timer=="false")return!1;else r.is(":hidden")?s=setInterval(function(){l("next")},a.advanceSpeed):
+(function(d){d.fn.orbit=function(a){a=d.extend({animation:"horizontal-push",animationSpeed:900,timer:!0,advanceSpeed:4E3,pauseOnHover:!1,startClockOnMouseOut:!1,startClockOnMouseOutAfter:1E3,directionalNav:!0,captions:!0,captionAnimation:"fade",captionAnimationSpeed:600,bullets:!1,bulletThumbs:!1,bulletThumbLocation:"",afterSlideChange:function(){}},a);return this.each(function(){function q(){if(!a.timer||a.timer=="false")return!1;else r.is(":hidden")?s=setInterval(function(){l("next")},a.advanceSpeed):
 (o=!0,x.removeClass("active"),s=setInterval(function(){var a="rotate("+m+"deg)";m+=2;t.css({"-webkit-transform":a,"-moz-transform":a,"-o-transform":a});m>180&&(t.addClass("move"),z.addClass("move"));m>360&&(t.removeClass("move"),z.removeClass("move"),m=0,l("next"))},a.advanceSpeed/180))}function n(){if(!a.timer||a.timer=="false")return!1;else o=!1,clearInterval(s),x.addClass("active")}function A(){if(!a.captions||a.captions=="false")return!1;else{var y=e.eq(b).data("caption");(_captionHTML=d(y).html())?
 (j.attr("id",y).html(_captionHTML),a.captionAnimation=="none"&&j.show(),a.captionAnimation=="fade"&&j.fadeIn(a.captionAnimationSpeed),a.captionAnimation=="slideOpen"&&j.slideDown(a.captionAnimationSpeed)):(a.captionAnimation=="none"&&j.hide(),a.captionAnimation=="fade"&&j.fadeOut(a.captionAnimationSpeed),a.captionAnimation=="slideOpen"&&j.slideUp(a.captionAnimationSpeed))}}function B(){if(a.bullets)D.children("li").removeClass("active").eq(b).addClass("active");else return!1}function l(d){function c(){e.eq(f).css({"z-index":1});
 u=!1;a.afterSlideChange.call(this)}var f=b,g=d;if(f==g)return!1;if(e.length=="1")return!1;u||(u=!0,d=="next"?(b++,b==p&&(b=0)):d=="prev"?(b--,b<0&&(b=p-1)):(b=d,f<b?g="next":f>b&&(g="prev")),B(),e.eq(f).css({"z-index":2}),a.animation=="fade"&&e.eq(b).css({opacity:0,"z-index":3}).animate({opacity:1},a.animationSpeed,c),a.animation=="horizontal-slide"&&(g=="next"&&e.eq(b).css({left:h,"z-index":3}).animate({left:0},a.animationSpeed,c),g=="prev"&&e.eq(b).css({left:-h,"z-index":3}).animate({left:0},a.animationSpeed,
