[Swift-commit] r5470 - in trunk: docs/siteguide tests
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Sat Dec 24 11:01:44 CST 2011
Author: davidk
Date: 2011-12-24 11:01:43 -0600 (Sat, 24 Dec 2011)
New Revision: 5470
Removed:
   trunk/tests/sites/
Modified:
   trunk/docs/siteguide/beagle
   trunk/docs/siteguide/futuregrid
Log:
Modified: trunk/docs/siteguide/beagle
--- trunk/docs/siteguide/beagle	2011-12-24 16:31:50 UTC (rev 5469)
+++ trunk/docs/siteguide/beagle	2011-12-24 17:01:43 UTC (rev 5470)
@@ -1,5 +1,18 @@
 Beagle
+Beagle is a Cray XE6 supercomputer at UChicago. It employs a batch-oriented
+computational model where-in a PBS schedular accepts user's jobs and queues
+them in the queueing system for execution. The computational model requires
+a user to prepare the submit files, track job submissions, chackpointing,
+managing input/output data and handling exceptional conditions manually.
+Running Swift under Beagle can accomplish the above tasks with least manual
+user intervention and maximal oppurtunistic computation time on Beagle
+queues. In the following sections, we discuss more about specifics of
+running Swift on Beagle. A more detailed information about Swift and its
+workings can be found on Swift documentation page here:
+http://www.ci.uchicago.edu/swift/wwwdev/docs/index.php
+More information on Beagle can be found on UChicago Beagle website here:
+http://beagle.ci.uchicago.edu
 Requesting Access
Modified: trunk/docs/siteguide/futuregrid
--- trunk/docs/siteguide/futuregrid	2011-12-24 16:31:50 UTC (rev 5469)
+++ trunk/docs/siteguide/futuregrid	2011-12-24 17:01:43 UTC (rev 5470)
@@ -1,6 +1,11 @@
 Futuregrid Quickstart Guide
+FutureGrid is a distributed, high-performance test-bed that allows
+scientists to collaboratively develop and test innovative approaches
+to parallel, grid, and cloud computing.
+More information on futuregrid can be found at https://portal.futuregrid.org/.
 Requesting Futuregrid Access
 If you do not already have a futuregrid account, you can follow the
@@ -15,13 +20,14 @@
 following command:
-$ svn co https://svn.ci.uchicago.edu/svn/vdl2/usertools/swift-vm-boot
+$ svn co https://svn.ci.uchicago.edu/svn/vdl2/usertools/swift-vm-boot swift-vm-boot
 Download your Credentials
 Run the following commands to retrieve your credentials:
+$ cd swift-vm-boot
 $ scp yourusername at hotel.futuregrid.org:nimbus_creds.tar.gz .
 $ tar xvfz nimbus_creds.tar.gz
@@ -30,45 +36,57 @@
 called vws.repository.s3id and vws.repository.s3key. Copy these
 values for the next step.
-Configuring Swift VM Tools
-Change directories into the swift-vm-boot directory. Edit the file
-called env.sh. There are two settings here that you will need to
-modify: FUTUREGRID_IAAS_ACCESS_KEY and FUTUREGRID_IAAS_SECRET_KEY.
-Paste your access key (s3id) and secret key (s3key) here and save
-the file. By default, env.sh requests 2 nodes on hotel and 2 nodes
-on sierra. Change these values as needed. Run install.sh from the
-swift-vm-boot directory to complete the installation of Swift VM
-Tools. The Swift VM Tools may require a fairly recent version of
-Python. If you run into problems while running the install.sh
-script, please try a more recent version of Python and associated
-libraries.
 Configuring coaster-service.conf
-Within your swift distribution's etc directory is a file called
-coaster-service.conf. There are many options here you can modify
-as needed, but these are the settings that will be required
-to run on futuregrid:
+To run on futuregrid, you will need a file called coaster-service.conf.
+This file contains many options to control how things run. Here is
+an example of a working coaster-service.conf on futuregrid.
-export WORKER_WORK=/tmp
+# Where to copy worker.pl on the remote machine for sites.xml
+export WORKER_LOCATION=/tmp
+# How to launch workers: local, ssh, cobalt, or futuregrid
 export WORKER_MODE=futuregrid
+# Do all the worker nodes you're using have a shared filesystem? (yes/no)
 export SHARED_FILESYSTEM=no
+# Username to use on worker nodes
 export WORKER_USERNAME=root
+# Enable SSH tunneling? (yes/no)
 export SSH_TUNNELING=yes
+# Directory to keep log files, relative to working directory when launching start-coaster-service
+export LOG_DIR=logs
+# Location of the swift-vm-boot scripts
 export SWIFTVMBOOT_DIR=$HOME/swift-vm-boot
+# Futuregrid settings
+export FUTUREGRID_IAAS_ACCESS_KEY=XXXXXXXXXXXXXXXXXXXXX
+export FUTUREGRID_IAAS_SECRET_KEY=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
+export FUTUREGRID_HOTEL_NODES=0
+export FUTUREGRID_SIERRA_NODES=2
+export FUTUREGRID_CPUS_PER_NODE=1
+# Swift information for creating sites.xml
 export WORK=/tmp
+export JOBS_PER_NODE=$FUTUREGRID_CPUS_PER_NODE
+export JOB_THROTTLE=$( echo "scale=5; ($JOBS_PER_NODE * $(($FUTUREGRID_HOTEL_NODES + $FUTUREGRID_SIERRA_NODES)))/100 - 0.00001"|bc )
+# Application locations for tc.data
+#app convert=/usr/bin/convert
-These is a brief description of these settings in the coaster-service.conf file.
-Tunneling should be used when you are restricted by a firewall. If your local
-machine has multiple network interfaces, you should also manually set the IP
-address of your machine with export IPADDR=your.ip.address.here.
+Paste your credentials from the hotel.conf file into the FUTUREGRID_IAAS_ACCESS_KEY and FUTUREGRID_IAAS_SECRET_KEY fields.
+Adjust the number of nodes you would like to allocate here by changing the values of FUTUREGRID_HOTEL_NODES and FUTUREGRID_SIERRA_NODES.
+Add a list of any applications you want to run in the format "#app myapp=/path/to/app".
 Starting the Coaster Service Script
-Now that everything is configured, change to a temporary directory
+Now that everything is configured, change to the location of the coaster-service.conf file
 and run this command to start the coaster service:
