[Swift-commit] r5464 - branches/release-0.93/docs/siteguide
davidk at ci.uchicago.edu
Fri Dec 23 22:12:50 CST 2011
Author: davidk
Date: 2011-12-23 22:12:50 -0600 (Fri, 23 Dec 2011)
New Revision: 5464
Modified:
branches/release-0.93/docs/siteguide/fusion
Log:
Reorganize fusion siteguide and give a more general description
Modified: branches/release-0.93/docs/siteguide/fusion
--- branches/release-0.93/docs/siteguide/fusion 2011-12-24 03:32:13 UTC (rev 5463)
+++ branches/release-0.93/docs/siteguide/fusion 2011-12-24 04:12:50 UTC (rev 5464)
@@ -1,13 +1,49 @@
Fusion
+Fusion is a 320-node computing cluster for the Argonne
+National Laboratory community. The primary goal of the LCRC is to
+facilitate mid-range computing in all of the scientific programs of
+Argonne and the University of Chicago.
-Fusion Quickstart
This section will walk you through running a simple Swift script
on Fusion.
+Requesting Access
+If you do not already have a Fusion account, you can request one at
+https://accounts.lcrc.anl.gov/request.php. Email support at lcrc.anl.gov
+for additional help.
+Projects
+In order to run a job on a Fusion compute node, you must first be associated
+with a project.
+Each project has one or more Primary Investigators, or PIs. These PIs are
+responsible for adding and removing users to a project. Contact the PI of
+your project to be added.
+More information on this process can be found at
+http://www.lcrc.anl.gov/info/Projects.
+SSH Keys
+Before accessing Fusion, be sure to have your SSH keys configured correctly.
+SSH keys are required to access fusion. You should see information about
+this when you request your account. Email support at lcrc.anl.gov for
+additional help.
+Connecting to a login node
+Once your keys are configured, you should be able to access a Fusion login
+node with the following command:
+ssh yourusername at fusion.lcrc.anl.gov
Creating sites.xml
Swift relies on various configuration files to determine how to
run. This section will provide a working configuration file which
you can copy and paste to get running quickly. The sites.xml file
@@ -29,7 +65,7 @@
Creating tc.data
The tc.data configuration file gives information about the applications
that will be called by Swift. More information about the format
of tc.data can be found in the Swift User's guide.
@@ -41,8 +77,7 @@
Copy a Swift Script
Within the Swift directory is an examples directory which contains
several introductory Swift scripts. The example we will use in this
section is called catsn.swift. Copy this script to the same directory
@@ -55,8 +90,7 @@
TIP: The location of your swift directory may vary depending on how you installed it. Change this to the examples/misc directory of your installation as needed.
Run Swift
Finally, run the script
$ swift -sites.file sites.xml -tc.file tc.data catsn.swift
@@ -65,40 +99,6 @@
You should see 10 new text files get created, named catsn*.out. If
you see these files, then you have succesfully run Swift on Fusion!
-Requesting Access
-If you do not already have a Fusion account, you can request one at
-https://accounts.lcrc.anl.gov/request.php. Email support at lcrc.anl.gov
-for additional help.
-SSH Keys
-Before accessing Fusion, be sure to have your SSH keys configured correctly.
-SSH keys are required to access fusion. You should see information about
-this when you request your account. Email support at lcrc.anl.gov for
-additional help.
-Connecting to a login node
-Once your keys are configured, you should be able to access a Fusion login
-node with the following command:
-ssh yourusername at fusion.lcrc.anl.gov
-Projects
-In order to run a job on a Fusion compute node, you must first be associated
-with a project.
-Each project has one or more Primary Investigators, or PIs. These PIs are
-responsible for adding and removing users to a project. Contact the PI of
-your project to be added.
-More information on this process can be found at
-http://www.lcrc.anl.gov/info/Projects.
Queues
Fusion has two queues: shared and batch. The shared queue has a maximum 1
More information about the Swift-commit
