[Swift-commit] r5453 - branches/release-0.93/docs
ketan at ci.uchicago.edu
Tue Dec 20 16:33:01 CST 2011
Author: ketan
Date: 2011-12-20 16:33:01 -0600 (Tue, 20 Dec 2011)
New Revision: 5453
Modified:
branches/release-0.93/docs/build_docs.sh
Log:
implemented a simple caching scheme that skips the processing of files that are not changed
Modified: branches/release-0.93/docs/build_docs.sh
--- branches/release-0.93/docs/build_docs.sh 2011-12-20 22:06:23 UTC (rev 5452)
+++ branches/release-0.93/docs/build_docs.sh 2011-12-20 22:33:01 UTC (rev 5453)
@@ -42,10 +42,16 @@
FILES=`ls -1 *.txt 2>/dev/null`
for file in $FILES
do
- echo Converting $directory"$file" to HTML
- asciidoc -a toc -a max-width=750px -a stylesheet=$(pwd)/../stylesheets/asciidoc.css $file
- echo Converting $directory"$file" to PDF
- a2x --format=pdf --no-xmllint $file
+ diff $file .cache/$file >/dev/null 2>/dev/null
+ if [ $? -ne 0 ]
+ then
+ echo "updating cache"
+ cp $file .cache
+ echo Converting $directory"$file" to HTML
+ asciidoc -a toc -a max-width=750px -a stylesheet=$(pwd)/../stylesheets/asciidoc.css $file
+ echo Converting $directory"$file" to PDF
+ a2x --format=pdf --no-xmllint $file
+ fi
done
if [ ! -d "$INSTALLATION_DIRECTORY/$VERSION" ]; then
More information about the Swift-commit
