[Swift-commit] r5445 - branches/release-0.93/docs/siteguide
davidk at ci.uchicago.edu
Mon Dec 19 11:26:40 CST 2011
Author: davidk
Date: 2011-12-19 11:26:40 -0600 (Mon, 19 Dec 2011)
New Revision: 5445
Added:
branches/release-0.93/docs/siteguide/mcs
Log:
Updated mcs siteguide entry
Added: branches/release-0.93/docs/siteguide/mcs
--- branches/release-0.93/docs/siteguide/mcs (rev 0)
+++ branches/release-0.93/docs/siteguide/mcs 2011-12-19 17:26:40 UTC (rev 5445)
@@ -0,0 +1,53 @@
+MCS Workstations
+Create a coaster-service.conf
+To begin, copy the text below and paste it into your Swift distribution's etc
+directory. Name the file coaster-service.conf.
+include::../../tests/providers/mcs/coaster-service.conf[]
+Starting the Coaster Service
+Change directories to the location you would like to run a
+Swift script and start the coaster service with this
+command:
+start-coaster-service
+This will create a configuration file that Swift needs
+called sites.xml.
+WARNING: Any existing sites.xml files in this directory
+will be overwritten. Be sure to make a copy of any
+custom configuration files you may have.
+Run Swift
+Next, run Swift. If you do not have a particular script
+in mind, you can test Swift by using a Swift script in
+the examples/ directory.
+Run the following command to run the script:
+swift -sites.file sites.xml -tc.file tc.data yourscript.swift
+Stopping the Coaster Service
+The coaster service will run indefinitely. The stop-coaster-service
+script will terminate the coaster service.
+$ stop-coaster-service
+This will kill the coaster service and kill the worker scripts on remote systems.
More information about the Swift-commit
