[Swift-commit] r5436 - trunk/docs/siteguide
ketan at ci.uchicago.edu
Sat Dec 17 22:00:34 CST 2011
Author: ketan
Date: 2011-12-17 22:00:34 -0600 (Sat, 17 Dec 2011)
New Revision: 5436
Modified:
trunk/docs/siteguide/beagle
Log:
beagle siteguide update
Modified: trunk/docs/siteguide/beagle
--- trunk/docs/siteguide/beagle 2011-12-18 03:06:30 UTC (rev 5435)
+++ trunk/docs/siteguide/beagle 2011-12-18 04:00:34 UTC (rev 5436)
@@ -26,24 +26,170 @@
stay. (say, +mkdir swift-lab+, followed by, +cd swift-lab+)
*step 3.* To get started with a simple example running +/bin/cat+ to read an
-input file +data.txt+ and write to an output file +f.nnn.out+, copy the folder
-at +/home/ketan/catsn+ to the above directory. (+cp -r /home/ketan/catsn
-.+ followed by +cd catsn+).
+input file +data.txt+ and write to an output file +f.nnn.out+, start with writing a simple swift source script as follows:
-*step 4.* In the sites file: +beagle-coaster.xml+, make the following two
-changes: *1)* change the path of +workdirectory+ to your preferred location
-(say to +/lustre/beagle/$USER/swift-lab/swift.workdir+) and *2)* Change the
-project name to your project (+CI-CCR000013+) . The workdirectory will contain
-execution data related to each run, e.g. wrapper scripts, system information,
-inputs and outputs.
+type file;
-*step 5.* Run the example using following commandline (also found in run.sh):
-+swift -config cf -tc.file tc -sites.file beagle-coaster.xml catsn.swift -n=1+
-. You can further change the value of +-n+ to any arbitrary number to run that
+/* App definitio */
+app (file o) cat (file i)
+ cat @i stdout=@o;
+file out[]<simple_mapper; location="outdir", prefix="f.",suffix=".out">;
+file data<"data.txt">;
+/* App invocation: n times */
+foreach j in [1:@toint(@arg("n","1"))] {
+ out[j] = cat(data);
+*step 4.* The next step is to create a sites file. An example sites file (sites.xml) is shown as follows:
+<config>
+ <pool handle="pbs">
+ <execution provider="coaster" jobmanager="local:pbs"/>
+ <!-- replace with your project -->
+ <profile namespace="globus" key="project">CI-CCR000013</profile>
+ <profile namespace="globus" key="providerAttributes">
+ pbs.aprun;pbs.mpp;depth=24</profile>
+ <profile namespace="globus" key="jobsPerNode">24</profile>
+ <profile namespace="globus" key="maxTime">1000</profile>
+ <profile namespace="globus" key="slots">1</profile>
+ <profile namespace="globus" key="nodeGranularity">1</profile>
+ <profile namespace="globus" key="maxNodes">1</profile>
+ <profile namespace="karajan" key="jobThrottle">.63</profile>
+ <profile namespace="karajan" key="initialScore">10000</profile>
+ <filesystem provider="local"/>
+ <!-- replace this with your home on lustre -->
+ <workdirectory >/lustre/beagle/ketan/swift.workdir</workdirectory>
+ </pool>
+</config>
+*step 5.* In this step, we will see the config and tc files. The config file (cf) is as follows:
+wrapperlog.always.transfer=true
+sitedir.keep=true
+execution.retries=1
+lazy.errors=true
+use.provider.staging=true
+provider.staging.pin.swiftfiles=false
+foreach.max.threads=100
+provenance.log=false
+The tc file (tc) is as follows:
+pbs cat /bin/cat null null null
+More about config and tc file options can be found in the swift userguide here: http://www.ci.uchicago.edu/swift/wwwdev/guides/release-0.93/userguide/userguide.html#_swift_configuration_properties.
+*step 6.* Run the example using following commandline:
+swift -config cf -tc.file tc -sites.file sites.xml catsn.swift -n=1
+You can further change the value of +-n+ to any arbitrary number to run that
many number of concurrent +cat+
-*step 6.* Check the output in the generated +outdir+ directory (+ls outdir+)
+*step 7.* Swift will show a status message as "done" after the job has completed its run in the queue. Check the output in the generated +outdir+ directory (+ls outdir+)
-Note: Running from sandbox node or requesting 1 hour walltime for upto 3 nodes
-will get fast prioritized execution. Good for small tests.
+Swift 0.93RC5 swift-r5285 cog-r3322
+RunID: 20111218-0246-6ai8g7f0
+Progress: time: Sun, 18 Dec 2011 02:46:33 +0000
+Progress: time: Sun, 18 Dec 2011 02:46:42 +0000 Active:1
+Final status: time: Sun, 18 Dec 2011 02:46:43 +0000 Finished successfully:1
+Note: Running from sandbox node or requesting 30 minutes walltime for upto 3 nodes
+will get fast prioritized execution. Suitable for small tests.
+Larger Runs on Beagle
+A key factor in scaling up Swift runs on Beagle is to setup the sites.xml parameters.
+The following sites.xml parameters must be set to scale that is intended for a large run:
+ * *maxTime* : The expected walltime for completion of your run. This parameter is accepted in seconds.
+ * *slots* : This parameter specifies the maximum number of pbs jobs/blocks that the coaster scheduler will have running at any given time. On Beagle, this number will determine how many qsubs swift will submit for your run. Typical values range between 40 and 60 for large runs.
+ * *nodeGranularity* : Determines the number of nodes per job. It restricts the number of nodes in a job to a multiple of this value. The total number of workers will then be a multiple of jobsPerNode * nodeGranularity. For Beagle, jobsPerNode value is 24 corresponding to its 24 cores per node.
+ * *maxNodes* : Determines the maximum number of nodes a job must pack into its qsub. This parameter determines the largest single job that your run will submit.
+ * *jobThrottle* : A factor that determines the number of tasks dispatched simultaneously. The intended number of simultaneous tasks must match the number of cores targeted. The number of tasks is calculated from the jobThrottle factor is as follows:
+Number of Tasks = (JobThrottle x 100) + 1
+Following is an example sites.xml for a 50 slots run with each slot occupying 4 nodes (thus, a 200 node run):
+<config>
+ <profile namespace="globus" key="ppn">24:cray:pack</profile>
+ <!-- For swift 0.93
+ <profile namespace="globus" key="ppn">pbs.aprun;pbs.mpp;depth=24</profile>
+ <profile namespace="globus" key="maxTime">50000</profile>
+ <profile namespace="globus" key="slots">50</profile>
+ <profile namespace="globus" key="nodeGranularity">4</profile>
+ <profile namespace="globus" key="maxNodes">4</profile>
+ <profile namespace="karajan" key="jobThrottle">48.00</profile>
+ </pool>
+</config>
+Troubleshooting
+In this section we will discuss some of the common issues and remedies while using Swift on Beagle. The origin of these issues can be Swift or the Beagle's configuration, state and user configuration among other factors. We try to identify maximum known issues and address them here:
+* Command not found: Swift is installed on Beagle as a module. If you see the following error message:
+If 'swift' is not a typo you can run the following command to lookup the package that contains the binary:
+ command-not-found swift
+-bash: swift: command not found
+The most likely cause is the module is not loaded. Do the following to load the Swift module:
+$ module load swift
+Swift version swift-0.93RC5 loaded
+* Failed to transfer wrapperlog for job cat-nmobtbkk and/or Job failed with an exit code of 254. Check the <workdirectory> element on the sites.xml file.
+<workdirectory >/home/ketan/swift.workdir</workdirectory>
+It is likely that it is set to a path where the compute nodes can not write, e.g. your /home directory. The remedy for this error is to set your workdirectory to the /lustre path where swift could write from compute nodes.
+<workdirectory >/lustre/beagle/ketan/swift.workdir</workdirectory>
More information about the Swift-commit
