[Swift-commit] r5432 - branches/release-0.93/docs/siteguide
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Sat Dec 17 20:19:12 CST 2011
Author: ketan
Date: 2011-12-17 20:19:12 -0600 (Sat, 17 Dec 2011)
New Revision: 5432
Modified:
   branches/release-0.93/docs/siteguide/beagle
Log:
minor addition to siteguide beagle
Modified: branches/release-0.93/docs/siteguide/beagle
--- branches/release-0.93/docs/siteguide/beagle	2011-12-18 01:52:26 UTC (rev 5431)
+++ branches/release-0.93/docs/siteguide/beagle	2011-12-18 02:19:12 UTC (rev 5432)
@@ -169,5 +169,14 @@
 Swift version swift-0.93RC5 loaded
-* Failed to transfer wrapperlog for job cat-nmobtbkk and/or Job failed with an exit code of 254. Check the <workdirectory> element on the sites.xml file. It is likely that it is set to a path where the compute nodes can not write, e.g. your /home directory. The remedy for this error is to set your workdirectory to the /lustre path where swift could write from compute nodes.
+* Failed to transfer wrapperlog for job cat-nmobtbkk and/or Job failed with an exit code of 254. Check the <workdirectory> element on the sites.xml file.
+<workdirectory >/home/ketan/swift.workdir</workdirectory>
+It is likely that it is set to a path where the compute nodes can not write, e.g. your /home directory. The remedy for this error is to set your workdirectory to the /lustre path where swift could write from compute nodes.
+<workdirectory >/lustre/beagle/ketan/swift.workdir</workdirectory>
