[Swift-commit] r5424 - branches/release-0.93/tests/functions
davidk at ci.uchicago.edu
Fri Dec 16 12:28:15 CST 2011
Author: davidk
Date: 2011-12-16 12:28:15 -0600 (Fri, 16 Dec 2011)
New Revision: 5424
Added:
branches/release-0.93/tests/functions/501-filenames.check.sh
branches/release-0.93/tests/functions/501-filenames.out.expected
branches/release-0.93/tests/functions/501-filenames.setup.sh
branches/release-0.93/tests/functions/501-filenames.swift
Log:
Test for @filenames
Added: branches/release-0.93/tests/functions/501-filenames.check.sh
--- branches/release-0.93/tests/functions/501-filenames.check.sh (rev 0)
+++ branches/release-0.93/tests/functions/501-filenames.check.sh 2011-12-16 18:28:15 UTC (rev 5424)
@@ -0,0 +1,11 @@
+#!/bin/bash
+sum1=`sum 501-filenames.out`
+sum2=`sum 501-filenames.out.expected`
+if [ "$sum1" != "$sum2" ]; then
+ echo Error: Created file does not match expected output
+ exit 1
+fi
+exit 0
Property changes on: branches/release-0.93/tests/functions/501-filenames.check.sh
___________________________________________________________________
Added: svn:executable
Added: branches/release-0.93/tests/functions/501-filenames.out.expected
--- branches/release-0.93/tests/functions/501-filenames.out.expected (rev 0)
+++ branches/release-0.93/tests/functions/501-filenames.out.expected 2011-12-16 18:28:15 UTC (rev 5424)
@@ -0,0 +1 @@
+a.txt b.txt c.txt
Added: branches/release-0.93/tests/functions/501-filenames.setup.sh
--- branches/release-0.93/tests/functions/501-filenames.setup.sh (rev 0)
+++ branches/release-0.93/tests/functions/501-filenames.setup.sh 2011-12-16 18:28:15 UTC (rev 5424)
@@ -0,0 +1,6 @@
+#!/bin/bash
+cp $GROUP/501-filenames.out.expected .
+echo blah > a.txt
+echo blah > b.txt
+echo blah > c.txt
Property changes on: branches/release-0.93/tests/functions/501-filenames.setup.sh
Added: branches/release-0.93/tests/functions/501-filenames.swift
--- branches/release-0.93/tests/functions/501-filenames.swift (rev 0)
+++ branches/release-0.93/tests/functions/501-filenames.swift 2011-12-16 18:28:15 UTC (rev 5424)
@@ -0,0 +1,11 @@
+type file;
+app (file o) echo ( file files[] )
+ echo @filenames(files) stdout=@o;
+string s[] = [ "a.txt", "b.txt", "c.txt" ];
+file f[] <array_mapper;files=s>;
+file output<"501-filenames.out">;
+output = echo(f);
More information about the Swift-commit
